PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 10-03-2010, 05:52 PM   #121
cossytonyt
Trader Score: (4)
cossytonyt is an unknown quantity at this point
cheers mate
final few bits this weekend then off to a paintshop (if i can find one that dont keep dropping me in )
cossytonyt is offline   Reply With Quote
Old 11-03-2010, 05:57 PM   #122
greeny 1
Trader Score: (2)
greeny 1 is on a distinguished road
Hi there can you help i have just fitted yb to my mk1 and having a few problems do you have to get exhaust down pipe made or can you uses some thing else as steering colum right in the middel thanks chris
greeny 1 is offline   Reply With Quote
Old 11-03-2010, 06:21 PM   #123
cossytonyt
Trader Score: (4)
its a tight fit mate you need to get one fabricated really you could always start with a 2wd single downpipe make a few mods to get your shape then get it welded up,theres a few places round here that will make you a stainless system but your looking anywhere between £400-600 depending on spec
try tyre spot in newcastle mate if you can get the car to them they will sort a full system for you
Old 11-03-2010, 06:50 PM   #124
graham c
Trader Score: (3)
graham c is an unknown quantity at this point
i used a 4x4 maifold when i built my first one it woz close but ok
__________________
just dont tell the wife how much it really cost
graham c is offline   Reply With Quote
Old 11-03-2010, 06:50 PM   #125
greeny 1
Trader Score: (2)
thanks for that i have used rs 2000 engish axel with tran x lsd with uprated shafts as you no there a money pit cudent aford atlas yet can you buy singel piece prop to t5box to english axel or do you have to get won made thanks chris
Old 11-03-2010, 06:51 PM   #126
graham c
Trader Score: (3)
rs200 prop cut down i used as well
__________________
Old 11-03-2010, 07:02 PM   #127
greeny 1
Trader Score: (2)
its got 4x4 manafold on i have used full 1993 4x4 engine dont no weather i do right or wrong cut the power steering bracket off used shorter 6rib belt 4x4 themostat housing wat do you lads think
Old 11-03-2010, 09:09 PM   #128
RSLUBBY
RSLUBBY's Avatar
Trader Score: (19)
RSLUBBY is an unknown quantity at this point
Send a message via MSN to RSLUBBY
I love this coming on great keep up the good work
__________________
Ian 07732292868
RSLUBBY is online now   Reply With Quote
Old 11-03-2010, 10:32 PM   #129
cossytonyt
Trader Score: (4)
Quote:
like graham says you can use the original with modifications or buy one over the counter
motorscope stock them,also commercial propshafts at peterlee ive used them on yb builds as well
what sump you using rs2000 or 2wd cos ? i used a late spec 4x4 on one of my mk2 builds had to change loads ie/rs2000 sump with modified pick up pipe/2wd oil cooler/2wd dipstick and tube/2wd flywheel etc 4x4 exh manifold gives you more room but are restrictive depends on spec you are going for
Old 13-03-2010, 10:48 AM   #130
melspec1
Trader Score: (0)
melspec1 is on a distinguished road
your best way mate is like wot tony says, just get one made!
by time you buy a rs2000 one then got to get it cut down, then it cost money again! dont be shy on the rear axle you got, theres nothing wrong with useing a english axle, as long as you got the rite ratio, and lsd, and if you got the uprated half shafts better still! its all good for 200hp plus, and ive seen some use over 350hp, just as long you not drifting the thing.
melspec1 is offline   Reply With Quote
Old 13-03-2010, 12:44 PM   #131
graham c
Trader Score: (3)
i had a new one made it cost 135
__________________
Old 14-03-2010, 07:08 PM   #132
greeny 1
Trader Score: (2)
thanks for help lads the engine is in wate sort of ratio do you think i have two crown wheels and pin won 3.89 not sure wate the other is i was going to run stage 3 coversion 300 330 ish this is for 1/4miles runs at york and pod and road uses to go to my static caravan with kids and have bit fun on the way up
Old 14-03-2010, 07:51 PM   #133
cossytonyt
Trader Score: (4)
bit of an update mel finished off little bits plugged all the trim holes and gussetted front panel to inner wings
checkout the tank stands wood blocks wrapped with alloy quality NOT these will be binned lol
cold air flow for the air filter
first time its been out of the garage for months just need to sort a painter now
check out the superwide wheels lol looks like a go kart
next jobs mount lifeline kit/bulkhead fittings/oil cooler then off for paint
Old 14-03-2010, 08:13 PM   #134
Steve the Plumber
The original Rouge Trader
Trader Score: (10)
Steve the Plumber is on a distinguished road
Some superb fab work there!
__________________
Steve the Plumber.
Steve the Plumber is offline   Reply With Quote
Old 14-03-2010, 08:28 PM   #135
Captain500rs
Trader Score: (0)
Captain500rs is an unknown quantity at this point
Thought you were grinding the plugs down last night when i left, you lazy fooker
Captain500rs is offline   Reply With Quote
Old 14-03-2010, 08:33 PM   #136
cossytonyt
Trader Score: (4)
perfection takes time mate lol
Old 15-03-2010, 07:57 PM   #137
melspec1
Trader Score: (0)
yes thats rite mate... you tell them''
Old 15-03-2010, 07:59 PM   #138
melspec1
Trader Score: (0)
wot size wheels are you useing?
Old 15-03-2010, 08:55 PM   #139
greeny 1
Trader Score: (2)
Quote:
16" escort cossy wheels
Old 15-03-2010, 09:18 PM   #140
m4tt274
m4tt274's Avatar
Trader Score: (2)
m4tt274 is on a distinguished road
Send a message via MSN to m4tt274 Send a message via Yahoo to m4tt274
il keep watching this. it looks like ur moving fast with it and doing a very thorough and proffesional job. will go like a rocket when done
__________________
mk1 fiesta restoration! - http://passionford.com/forum/restora...-now-on-d.html
m4tt274 is offline   Reply With Quote
Old 15-03-2010, 10:09 PM   #141
cossytonyt
Trader Score: (4)
cheers mate just waiting of a few more parts, some custom tanks etc so i can get them trial fitted before it goes to paint,
got another painter coming tommorra night says he can do it asap ! we,ll see lol not holding my breath
Old 16-03-2010, 02:02 PM   #142
melspec1
Trader Score: (0)
i hope so tony mate,,,,
Old 16-03-2010, 02:12 PM   #143
melspec1
Trader Score: (0)
you mite find wot you got may be ok, with your wheel ratio, but you mite be best off with 3.54 for top power, but just dont go mad
Old 16-03-2010, 06:31 PM   #144
greeny 1
Trader Score: (2)
thanks mate i will put the won in i got and se wate its like can change later thanks for ye help
Old 17-03-2010, 04:48 PM   #145
cossytonyt
Trader Score: (4)
well dropped in again didnt turn up what is it with painters they all say" yes i,ll do it be a couple of weeks mind " then you go back and they have 4 or 5 new cars in lol
could always leave it as it is and go for the rat look
Old 18-03-2010, 08:31 PM   #146
Captain500rs
Trader Score: (0)
Anyone turned up to paint this yet?
Old 18-03-2010, 11:16 PM   #147
cossytonyt
Trader Score: (4)
a lad come round lastnight bud said he would do it,heard it all before so wait and see what he can arrange
Old 18-03-2010, 11:22 PM   #148
turnover
turnover's Avatar
Trader Score: (0)
turnover is an unknown quantity at this point
get yourself a compresor and do the inside and enginebay yourself then get a really nice job done on the out side
turnover is offline   Reply With Quote
Old 19-03-2010, 07:32 PM   #149
Captain500rs
Trader Score: (0)
He's got one in his garage,ave been trying to get him to use it.
Old 19-03-2010, 07:44 PM   #150
steviecossie
steviecossie's Avatar
Trader Score: (0)
steviecossie is an unknown quantity at this point
Send a message via MSN to steviecossie
STUNNING
__________________
R.I.P Colin McRae (a motorsport legend)
WR1 sold, time for a MK2 FRS
steviecossie is offline   Reply With Quote
Old 21-03-2010, 09:48 PM   #151
cossytonyt
Trader Score: (4)
cheers bud
quick update oil cooler now fitted what a bastard of a job cheers mel hour job turned into 6 lol,not sure where the filters going yet think i,ll wait till the engines in
Old 12-04-2010, 08:42 AM   #152
§ace§
Trader Score: (0)
§ace§ is on a distinguished road
tunnel is being raised and modifying the cage to get the drivers seat 3/4 inches further back so this is my gear shift set up,mounts to a billet rose jointed base
hi mate, I'm iotalian and I've got a 3dr sierra cosworth.
who made this lever? it's cool!!
§ace§ is offline   Reply With Quote
Old 12-04-2010, 11:42 AM   #153
cossytonyt
Trader Score: (4)
cant think mate will find out for you
Old 17-04-2010, 09:28 PM   #154
fordrs2005
Trader Score: (4)
fordrs2005 is an unknown quantity at this point
Send a message via ICQ to fordrs2005 Send a message via AIM to fordrs2005
any updates tony ? threads gone abit quiet
looking forward to seeing this finished
fordrs2005 is offline   Reply With Quote
Old 17-04-2010, 11:34 PM   #155
whizzisat114
whizzisat114's Avatar
Trader Score: (1)
whizzisat114 is on a distinguished road
if it was mine id put some drain holes in the lowest part of the strut brace mount's They look like a water trap to me
Nice project will look great when finished.
whizzisat114 is offline   Reply With Quote
Old 18-04-2010, 03:19 AM   #156
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
looking good matey
fezzajsy is offline   Reply With Quote
Old 18-04-2010, 09:57 PM   #157
cossytonyt
Trader Score: (4)
bodywork started today at last lol,mates prepping it here and then taking it to his works to bake it so hopefully shouldnt be long until its in colour
Old 19-04-2010, 10:29 AM   #158
melspec1
Trader Score: (0)
its about time mate....
Old 19-04-2010, 03:54 PM   #159
Captain500rs
Trader Score: (0)
Useless without pics buster
Old 19-05-2010, 08:05 PM   #160
cossytonyt
Trader Score: (4)
been a while put the house on the market so i had to put the escos on hold but now all done and want to get this thing finished got nearly everything i need now to finish ££££££s whole of aeroquip front brakes went for 305mm ap discs with big willwood 4 pots, 15" billet 9, image splitrims ordering wider inner rims for the rear so should squeeze on 235s on the rear un arched and un tubbed booked in for paint in 2 weeks so hopefully wont be long till i can start putting it all together
fronts
rears
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
4x4 mk4 escort cosworth PROJECT red_s1 Restorations, Rebuilds & Projects. 91 13-06-2010 04:54 PM
Project Escort mk2 24V Cosworth needspeed Restorations, Rebuilds & Projects. 40 02-08-2009 08:47 PM
Escort cosworth Project malcs-escort-cos Restorations, Rebuilds & Projects. 12 22-02-2009 10:38 AM
Escort mk2 Cosworth project PieterDW Restorations, Rebuilds & Projects. 20 20-11-2007 07:02 PM
escort cosworth project..... dave cos4x4 General Car Related Discussion. 12 29-09-2004 10:01 AM
