my 3dr.... Some new parts added
i have decided to clean up my 3dr over the winter. i want 2 new wings fitting because they are'nt ford wings.
i've just bought a adrenaline adjustable rear bear and gripper diff but i dont know if i should paint underneath of the car while its stripper down??
if anyone can point me in the right direction on how to clean, prep paint underneath let me know
this is how it looks
after getting bits swapped over i found the engine had a rattle. i could never find out what it was but it was'nt there before the crash.
so i decided to build another engine and this is the spec i got the car to untill i wanted it looking cleaner
i have pictures on my other laptop of the engine build but its broke. i'll have to try and get it fixed to add pictures of it
200 block (not the turkish type)
7.9-1 cr
0.5 mahle pistons with valve cutouts
lightened and balance bottom end
arp bigend bolts
ap 6 paddle clutch
wrc headgasket
500bhp spec head done by neil roper
double valve springs
bd14inlet standard exhaust cam
4x4 inlet plenum with 10mm spacer
siemans 83lbs inectors
l8 ecu
t4 turbo
anti lag and launch control
wasted spark
ryan braided engine loom
all just been mapped by stu and msd.
group a fuel pump
uprated breather system with seperator, catch tank and braided hoses
alloy header tank with inspection glass
pro alloy rs500 style intercooler
17" comp mo's
gaz coilovers
ap 330 front brakes
4x4 nearly new rear brakes
adjustable tca's (tracking and camber set up)
polly diff mount
fully polly bushed
braided brake lines
thats what i have to decide weather to paint it or just black under seal?
it would look better white with black beam and other little bits, than black floor and black parts
my new beam will be powder coated along with other bits and bobs but i don't have time to strip everything right down like drive shafts, brakes etc to look like new.
