Should I sandblast
Should I sandblast
Well,
Just got the rocker cover from the cvh and she is fairly rusted. I layered it in WD 40 to get the rust off and i got a good lot off. Then i discovered that the rust went deeper than i taught and it is pitted from the rust.
Is there a need to sand blast or how could i go about removing the pitted marks.
Thanks.
Kieran
Thanks.
Kieran
Lukesville
CVH has a welded tray like section underneath... ( forgive the lack of tech name)
However i would not get sandblasted for this very reason -The sandblast will get into these areas and lay dormant until one day it will decide to go for a trip round the engine and destroys your bearings.. Either blast this yourself if you can so as to make sure all areas are sealed and free from shot/dust.
OR
Just sand this by hand, if its heavily pitted though you might aswell save the hassle and pick one up from ebay/sale rooms for Ł15-Ł20.
Failing that then its time for the filler then a good paint!..
Ford Stratos silver is a good match for them
OR
boy-racer-1
30-03-2014 01:16 PM
FiestaFREAK92
15-01-2013 12:07 PM
