Fiesta ST race car project
Old 02-01-2010, 09:29 PM
  #41
jacko
jacko's Avatar
it does but still cheep motorsport wise
Old 02-01-2010, 09:40 PM
  #42
BlairM
BlairM's Avatar
lol yep that is true.
Shouldn't really account tyres as build cost as they are consumables, although they last pretty long I've heard.
Old 02-01-2010, 09:41 PM
  #43
jacko
jacko's Avatar
they will cos the car is light
Old 02-01-2010, 10:38 PM
  #44
dug112y
passionford pro
dug112y's Avatar
i have heard a few of them are running e85 bio..thats why some are bit faster than others
Old 02-01-2010, 11:09 PM
  #45
BlairM
BlairM's Avatar
Tell me which ones and I'll need to ask the drivers!
I'll have some of that..
Old 02-01-2010, 11:22 PM
  #46
dug112y
passionford pro
dug112y's Avatar
ask IC
Old 02-01-2010, 11:40 PM
  #47
BlairM
BlairM's Avatar
I've heard a lot of stories about cars being quicker so it must mean they are up to something, usually find the better drivers are at the front anyway lol
Old 03-01-2010, 01:40 PM
  #48
Allyc85
Allyc85's Avatar
Followed the build of your XR and will watch this one as well mate, looks good
Old 04-01-2010, 06:56 PM
  #49
BlairM
BlairM's Avatar
Cheers Ally.
Moved on to some other jobs now that the sealer is all out. Actually feels like I'm making some progress with the car doing different jobs.
Both rear quarters can be removed, this will be covered up by an M Sport fibreglass panel eventually.
N/S Rear (same on both sides though)
All the redundant mounts in the car shell that were for speakers, seats etc to fix to can be removed. I counted the spot welds I'll have to drill out in my head, around 50 approximately.
Firstly though I needed to remove the side impact bars in the door (my rollcage will take up this job, although hoping not to use it for that purpose!). This is made out of pressed steel plate, guessing around 2mm thick.
To get this out you need to remove the electric window motor firstly, this allows you then to ease the window down to let you at some plastic brackets.
Basically there are two of these, one at front of rear and window and it locates through holes in the glass. Once these are out the glass pretty freely moves around although you have to be careful not to drop it.
Glass safely aside, the door card is held on by roughly 10 bolts, several wiring connections to door locks, window motor etc are part of this door card.
Door less door card, you can see the side impact bar..
There are 6 spot welds holding this on, 3 at front of door between hinges:
3 at rear below door lock:
You can drill out spot welds with a normal type drill, however being advised that these particular ones are hard to drill out, what I did was first drill a small hole with a 1.5mm drill, doesn't need to be very deep, in the centre of the weld. This allows me then to use my special spot weld drill. Basically this is a small hole drill, if you know what I mean, it has a spring loaded pin in the middle which sits into the 1.5mm hole I drilled
It takes a lot of patience, slow drill speed as you can break the teeth on the drill quite easily. When I thought I had drilled through the skin of the door, got a hammer and punch and that helped push the bar away from the fixings.
This bar is a really tight fit, as you'd expect, so this means it needs to be cut in the middle to let you ease it out. I was careful here with the grinder, don't want to cut through the door haha.
One door bar, and best of it is, I weighed it and this thing is 2.4kg. So times by 2 doors, 4.8kg. Add that to my sealer - 8kg, weight is being shed nicely..
Old 04-01-2010, 09:01 PM
  #50
STEVEST24
ST by Name and by Nature
STEVEST24's Avatar
Nice work so far, good to see STs getting serious track action.
Old 06-01-2010, 09:07 PM
  #51
andrewg
andrewg's Avatar
Originally Posted by BlairM
Cheers Brian.
Yeh the spec is very basic so the emphasis is on driver skill, ST is basically Group N spec, so it's as close to showroom as possible.
The AST suspension kit is around Ł1600 + VAT and the wheels Ł100 each, tyres Ł150 each, consider you need slicks and wets so minimum 8 wheels - soon mounts up.
think we were about 8k in parts! that inc Ł600 to paint inside
Old 06-01-2010, 10:56 PM
  #52
BlairM
BlairM's Avatar
I'm hoping it won't be much more than 10k all in, keeping track of what I've spent already it's 4.5k, for car, repairs, painting, cage.
Might need to hold fire on racing the car. Heard you're selling yours Andy?
Old 07-01-2010, 09:15 AM
  #53
M K
M K's Avatar
glad you showed how to get the side impact bars out nicely as i need to do this with mine when its back from Andrews and hadn't yet looked to see where they were welded too etc
good project.
Old 07-01-2010, 09:36 AM
  #54
alan12112
Focus St mk2 310 bhp :D
alan12112's Avatar
Looking good blair, keep up the good work fela
Old 07-01-2010, 10:40 AM
  #55
andrewg
andrewg's Avatar
yeah going to have a clear out! going try sell the connect too!
Old 07-01-2010, 10:43 AM
  #56
cossiejsy
cossiejsy's Avatar
looking good mate
Old 07-01-2010, 08:49 PM
  #57
Hezz
Hezz's Avatar
good progress pal
Old 11-01-2010, 03:54 PM
  #58
BlairM
BlairM's Avatar
Have continued on removing some of the redundant metal mounts.
Mount that the rear bench hinges on:
Both removed:
Mounts at the rear of the bench. Think these are maybe for seat belts?
All off:
Still got these to grind down, but I'm wanting to wait till there are loads to grind, save me changing discs on the grinder.
Got the side door mouldings, put these on whilst the cordless drill was on charge. Got some double sided foam tape off ebay, it was ideal for this job, cleaned surfaces with panel wipe then using the heat gun made sure the car body was up to a nice temperature before sticking them on.
Left them overnight with tape to hold them in place.
The result
Old 12-01-2010, 04:18 AM
  #59
Ginge
www.virtualseason.net
Ginge's Avatar
Excellent work, saw you on motors tv a few times in the old fiesta, looking forward to seeing you on it again in this hopefully!
Keep up the good work
Ginge
Old 12-01-2010, 11:52 AM
  #60
BlairM
BlairM's Avatar
Yeh was that me crashing in my first race?
Also ended up off the track last year at the Knockhill chicane, whacked another car up the back and it made my car shoot off through the gravel.
Old 18-01-2010, 06:29 PM
  #61
BlairM
BlairM's Avatar
So after my rollcage meant to be turning up last Wednesday, they phoned me to say they didn't have the pictures and instructions ready and it wasn't sent out, was told it'd be sent off on Thursday for Friday delivery.
Got my mum to wait in on Friday (she wanted to go shopping..) and I checked it had been sent - delivery folk phoned later on Friday to say they'd got the package but it only had 2 lines on the address, driver couldn't find us etc. Package turns up today with all the details on it on the rollcage manufacturers headed paper...
Poor effort - hate being spun lies, on both sides, rollcage folk and delivery mob..
Anyway it is here now and all 63 parts have been checked off. Felt like Christmas day unwrapping it!
Foot plates, door gussets, a pillar gussets etc..
Old 18-01-2010, 06:54 PM
  #62
erjones
erjones's Avatar
Nice one, like Meccano for adults!
You going to weld it yourself if get do you need a specialist to meet the regs for the races?
Old 18-01-2010, 08:54 PM
  #63
BlairM
BlairM's Avatar
I'm getting someone else to fit it, guy has done a load of the other ST race cars up here, knows this cage well so should be a doddle to him.
In theory you don't need to be a specialist, just need to know how to weld (I don't ). If you want you can do a weld test and send it back to cage manufacturer to show them you're a competent welder, I'm not sure exactly what this gets, must be certification from them that the cage is installed to their satisfaction. The race regs just really specify the cage must be secured at certain points onto certain plates, thats what the extra plates are for here.
Old 19-01-2010, 06:31 AM
  #64
Roosie
500bhp Cosworth in making
Roosie's Avatar
I know in our championship you dont need any proof on how the cage is fitted, the scruitineering is apauling you could spot weld the cage together and they wouldnt notice.
Old 20-01-2010, 06:34 PM
  #65
BlairM
BlairM's Avatar
Scrutineering can be a bit hit or miss in my experience - what one guy would let you off with, another would notice. For example I have a camera in the car, some guys never check it to see if it's secured around cage as well, incase the mount breaks so it don't smack you in head.
Old 20-01-2010, 07:10 PM
  #66
TimC
TimC's Avatar
Do you still have these? Iv rounded one of mine off and plan on going back to a full interior once car is re-alligned
Old 20-01-2010, 08:08 PM
  #67
BlairM
BlairM's Avatar
Yeh think I've just left them in the car. Give me a shout if you need them.
Old 20-01-2010, 08:14 PM
  #68
TimC
TimC's Avatar
I wouldnt mind them. How much you like for them?
Old 20-01-2010, 08:35 PM
  #69
BlairM
BlairM's Avatar
Mate, they'd be going in the bin anyway. PM me your address and I'll stick them in a jiffy bag for you this week - you wanting both of them ?
Old 20-01-2010, 08:49 PM
  #70
Rsmat
300+
Rsmat's Avatar
looking good mate.
Old 24-01-2010, 07:06 PM
  #71
BlairM
BlairM's Avatar
Car's now ready to go off for the rollcage being fitted, all the mounts are off and high spots grinded down.
There were two of these mounts, I think these are where the rear seat back would clip in to. Both were absolute horrors to remove (with N/S being a lot worse) due to the number of spot welds, thickness of metal etc. Had to cut a lot out with a cutting disc on the grinder first to enable me to get to the spot welds, then I had to contend with two layers of metal to cut through, especially the N/S.
Mount off, all spots ground down
Spot my mistake here... doh!
Some more of the grinding work.
Dash bar and wheel mounted back in place so car can be moved.
Old 24-01-2010, 07:28 PM
  #72
Old 25-01-2010, 12:02 AM
  #73
TimC
TimC's Avatar
Done well with the cleaning up Blair.
Brackets arrived on Saturday. Many thanks once again.
Old 25-01-2010, 09:06 AM
  #74
BlairM
BlairM's Avatar
No problem Tim, hope they are suitable for what you need to do with them.
Old 25-01-2010, 12:23 PM
  #75
erjones
erjones's Avatar
Looking good, when does it go in for the cage to be fitted?
Old 25-01-2010, 01:02 PM
  #76
BlairM
BlairM's Avatar
Hopefully in the next 1 - 2 weeks. Would like to get some pics of the process, but depends if it's being done during the week or not.
Old 25-01-2010, 04:05 PM
  #77
rsjonny
rsjonny's Avatar
very cool mate good progress on this im weighing up wether or not to buy a fully built car or not. I wanted to go racing the xr's last season but was made redundant, I have no previous racing experience so wasnt sure if karting is the better route to take. Now karting is gunna cost me at least 4k to get going i reckon. What would you recommend from your experience? Is karting actually worth the time and effort or would i be best off buying a race car and doing some track days?
This question is open to anyone else on here with previous racing experience im a newbie to racing cars but ive wanted to do it since I dabbled with karting when I was a kid just never really had an opportunity untill now. Sorry to spam your thread looks very cool
Old 25-01-2010, 04:18 PM
  #78
cossiejsy
cossiejsy's Avatar
looking good
Old 25-01-2010, 05:45 PM
  #79
dixon.focus4x4
FOCUS
dixon.focus4x4's Avatar
Default air bags
looking good
Old 25-01-2010, 05:50 PM
  #80
BlairM
BlairM's Avatar
I never had any racing experience at all, even karting but just decided I wanted to have a shot of racing cars so went and done my ARDS test and bought an XR2. I never really was interested in karting, infact I didn't even sit in an indoor go kart till after I'd done my first season racing the XR2.
Quick Reply: Fiesta ST race car project
