Fiesta track car....NOW MAPPED WITH DYNO GRAPH
Old 26-06-2010, 09:22 PM
  #81
dug112y
passionford pro
dug112y's Avatar
friday night....dummy build
Old 26-06-2010, 09:24 PM
  #82
dug112y
passionford pro
dug112y's Avatar
repost
Old 26-06-2010, 10:00 PM
  #83
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Car's looking good
That crinkle effect on your rocker cover, is it a paint? If so, whats it called/where did you get it from? I want my rocker cover the same
Old 26-06-2010, 10:25 PM
  #84
dug112y
passionford pro
dug112y's Avatar
got it off ebay mate, works a treat
http://cgi.ebay.co.uk/VHT-BLACK-WRIN...#ht_1174wt_754
Old 27-06-2010, 05:10 PM
  #85
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Legend mate, thanks
Old 18-07-2010, 08:31 PM
  #86
EscoVan
EscoVan's Avatar
new bits arrived lately along with some bits i have been gathering up.its getting there now....
engine loom and ecu
steel rods
billet flywheel
exhaust manifold
clutch
flocked dash
looks sweet where do you get the dash flocked mate?
Old 18-07-2010, 08:39 PM
  #87
escort1989uk
escort1989uk's Avatar
everyone seems to be using auto flock from here. hes in the traders section
Old 18-07-2010, 08:52 PM
  #88
Cle
Booooost
Cle's Avatar
I love the carbon fibre trumpets
Old 18-07-2010, 08:57 PM
  #89
dug112y
passionford pro
dug112y's Avatar
i'd get raj to do it mate....i got it done in yorkshire and its now lifting off ....i will be sending it to raj at autoflock next time
Old 18-10-2010, 05:13 PM
  #90
dug112y
passionford pro
dug112y's Avatar
hi folks not updated this in a while, prob cos i've not done alot to it this year. but getting back into it.
fitted the front brakes the other day, 300mm hi spec set up with ebc blue pads
Old 18-10-2010, 05:18 PM
  #91
dug112y
passionford pro
dug112y's Avatar
1st engine is now built
and now dropped into the engine bay
Old 18-10-2010, 05:20 PM
  #92
dug112y
passionford pro
dug112y's Avatar
new inlet manifold, check out the difference in inlet angle.
Old 18-10-2010, 05:24 PM
  #93
dug112y
passionford pro
dug112y's Avatar
new specially made billet oil pump gears, should stop the zetec oil pump issues.
Old 18-10-2010, 05:57 PM
  #94
Minirotty
Lucifer II - 666
Minirotty's Avatar
Who modified your inlet bud?
Old 18-10-2010, 05:58 PM
  #95
xr2imetalhead
xr2imetalhead's Avatar
looks like it going to be pretty lairy m8 nice job
Old 18-10-2010, 06:09 PM
  #96
dug112y
passionford pro
dug112y's Avatar
its not modified mate...jenvey brought out a new manifold, its bigger inside and bigger at the head side and angled to give a better inlet angle to back of valves...its a direct line and a nice fit too.plus gives more clearance on FWD cars.
Old 18-10-2010, 06:12 PM
  #97
dug112y
passionford pro
dug112y's Avatar
bought this too so its been swallowing some time and cash from the fiesta. going st170 on jenveys in this to start with then do head,cams etc
Old 18-10-2010, 06:45 PM
  #98
dug112y
passionford pro
dug112y's Avatar
change of plan on a few things too . went for a helix in place of the techniclutch one i posted earlier. change of management to a dta exp48 as i am going to use the mbe on the autograsser.
.also have a new big bore exhaust manifold which is heat wrapped...we will see how it performs on the dyno as to if it stays on or not.
Old 18-10-2010, 06:51 PM
  #99
0010
0010's Avatar
Nice, where did you get these from and how much?
Old 18-10-2010, 06:52 PM
  #100
dug112y
passionford pro
dug112y's Avatar
got an alloy radiator made for it too
Old 18-10-2010, 06:55 PM
  #101
dug112y
passionford pro
dug112y's Avatar
i got them done myself, they are probably going to be Ł200. they are undergoing testing at the moment.
Old 18-10-2010, 07:47 PM
  #102
dug112y
passionford pro
dug112y's Avatar
new breather
headlight set up
pipercross enclosed airbox
Old 18-10-2010, 08:03 PM
  #103
dug112y
passionford pro
dug112y's Avatar
new jenvey throttle bodies. i had the short ones before and there was a couple clearance issues
Old 18-10-2010, 10:33 PM
  #104
Ollie.
Ollie.'s Avatar
Looks mega Dougie get the finger out and get it finished!!!!
Old 18-10-2010, 11:35 PM
  #105
dug112y
passionford pro
dug112y's Avatar
am on it mate...i spent a weekend doing melroses that i was gonna spend on mine.
gonna try n get it ready for knockhill on the 7th if all goes well. got 3 fookin projects on the go the now...not enough days in the week at the moment. the grasser will be fun st170 on jenveys,200+ (then cams n head with dta s60 for vvt control) 2 speed box ,locked diff, 400kgs should be nippy lol.
Old 08-12-2010, 04:36 PM
  #106
dug112y
passionford pro
dug112y's Avatar
small change of plan again...this is now going on jenvey 42mm ITB's(using the 45 TB's on grasser) new inlet manifold too which in now port matched to head. bought another load of st170 engine bits so i can see a built st motor going in this next year at some point.
snows been a fookin nightmare so has seriously hampered progress,too fookin cold to be in the garage.
Old 09-12-2010, 09:40 PM
  #107
Paul.V
Paul.V's Avatar
Thumbs up
Hi sorry to butt in on your thread but where did you get the cage from and how much was it?? Cheers and love what you've done so far.
Old 10-12-2010, 12:10 AM
  #108
dug112y
passionford pro
dug112y's Avatar
cage was already in the shell mate...it was done at/through daniels motorsport.
Old 11-12-2010, 07:21 AM
  #109
Very nice project mate.It must be costing you a fortune.
Old 26-03-2011, 12:25 PM
  #110
MEL305E
MEL305E's Avatar
Hey cunto I just spotted this, dont blame me for your lazy-itis
Old 26-03-2011, 01:11 PM
  #111
andy escos
andy escos's Avatar
going to be fun when done if you stop changing your mind on the spec
Old 26-03-2011, 02:28 PM
  #112
dug112y
passionford pro
dug112y's Avatar
i have stopped changing it...for the moment.SHE RUNS.....been working on it last week and got a lot done inc exhaust ,rad, battery box etc.i'll update shortly with some pics. was meant to get it mapped on thurs but there was a tap from top end ill be fixing today...dodgy tappet i hope.
Old 26-03-2011, 09:07 PM
  #113
dug112y
passionford pro
dug112y's Avatar
all fixed and sounding sweet as a nut. bit pissed off i'm not making knockhill this weekend but it was a bit of a rush this week and had a few issues. engine had been sitting a while and it wouldnt lift oil so ended up pissing about with that which meant i missed the dyno slot.
C&C exhausts in hillington ,glasgow done some mods to the exhaust for me and made a proper job,i'd recommend them to anyone.
Old 03-06-2011, 06:36 PM
  #114
dug112y
passionford pro
dug112y's Avatar
well got it mapped today and it done ......203 bhp,which i am well happy with considering theres been no development done.....YET and its still a 1800.got some wiring to tidy up as i aint had time to do the loom yet and get it out on sunday at kames rs day.
anyway heres the dyno graph
still got a lot of little bits to do like fuel filler(bits never came),lap timer,oil cooler ,cold air intake but they can wait till after sunday. i fancy doing CROFT aswell now if everything goes ok.
Old 03-06-2011, 08:25 PM
  #115
Brian
Brian's Avatar
Looking good
Brian
Old 03-06-2011, 08:38 PM
  #116
Scotster
Scotster's Avatar
That must be a right weapon. Looks cracking, definitely what I would call a proper job
Old 03-06-2011, 08:49 PM
  #117
a-mac
a-mac's Avatar
will be good to see this going round kames see you there
Old 03-06-2011, 08:53 PM
  #118
dug112y
passionford pro
dug112y's Avatar
double post
Old 03-06-2011, 08:54 PM
  #119
dug112y
passionford pro
dug112y's Avatar
lol....not even drove it properly yet.......testing tomorrow ...nothing like last minute eh.
is your escort finished yet andy?
Old 03-06-2011, 09:56 PM
  #120
a-mac
a-mac's Avatar
yes car is up and running had it down at anglesey couple weeks ago with dalsy
broke gearbox already, but its all fixed for kames
Quick Reply: Fiesta track car....NOW MAPPED WITH DYNO GRAPH
