| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
Cornish Fasty
#2 |
Very exciting, will be watching this thread closely.
#3 |
__________________
![]() 395 bhp & 410 lb/ft |
#4 |
can u explain what this 'transmission vibration over 110mph' is. Myn begins to vibrate at around 115mph. and i was thinking about stripping it down and inspecting. but if this is a common problem, it would save me alot of time if anyone knows what causes it.
also shame about the scuff m8. looks like a really nice saff. and good man for using it also nice bike Last edited by m4tt274; 11-10-2009 at 09:20 PM. |
#5 |
fair shout i will be watching this 1
__________________
#6 |
What a shame about the damage... but well done for taking the opportunity to go to town on it. Will be keeping an eye on this!
#7 |
Pity about the damage,wasted spark will sort out any missfires.
#8 |
good luck with it mate
#9 |
Trader Score: (0)
Rep Power: 13 ![]() |
Good luck Dave
__________________
![]() RAISING THE PROFILE OF THE CORNWALL GROUP, BY LOWERING THE TONE |
#10 |
Cornish Fasty
Thanks peeps
M4tt247 - basically, i shakes its tits off once your in 3 figure speeds, i've got a new prop donut ready to fit, was going to refurb and balance both props and get my shafts checked. i would of thought it was wheel balance, but it does it regardless of wheel choice Had all my seats and carpet out this evening, only to find one of my seat mounts has succumbed to the down stuff, pretty much. oh well, suppose i better get used to find that lol |
#11 |
Good luck with the resto.
Think i may have seen it down Bude maybe parked near to the newsagents not far from the falcon hotel pic ? If you see a white Sapph parked next to the Brendan arms soon,that will probably be mine ! Cheers Andy.. |
#12 |
Cornish Fasty
Will keep an eye out, bud
#13 |
thats pal. thats similar to what myn has started doing, it dosent shake its ass off that much its just a fine vibration. think its probably the prop.
#14 |
Cornish Fasty
little update. spent a few hours on her over the weekend, and i'm now at the stage of having the engine and box out the way with the removal of 8 bolts and the use of a couple jacks
interior has been all stripped out...... ![]() ![]() however, that has led to the first bits of rust showing thier ugly heads lol drivers seat mount ![]() drivers side rear footwell ![]() also found over Ł3 in change old 10p ![]() not a lot to a sierra with no bumper! ![]() ![]() ![]() the powerhouse ![]() another breakdown in the waiting :S sure there was a clip on there!! ![]() hopefully have the running gear and rear beam off this week, then the fun begin Anyone give me advice on the correct way of tackling the underside. i'm not after a concours look, but it would be nice to have it looking nice Last edited by Bloomers; 18-10-2009 at 11:35 PM. |
#15 |
stirp all under seal off mate, put 3m sealer on then mate
#16 | |
Trader Score: (0)
Quote:
I'm about to drop all the running gear off of mine and clean up underneath, I've been told satin shark grey paint, as its not porous (spell) like primer, then overspray magenta around the edges, And break pipes use landrover forest green, to make them look like new
__________________
#17 |
Cornish Fasty
something like this, bud?
http://www.autobodytoolmart.com/3m-u...4-p-15900.aspx mike, you not making up new brake pipes? |
#18 |
http://passionford.com/forum/3370620-post3.html This is the stuff mate.
#19 | |
Trader Score: (0)
Quote:
__________________
#20 |
Good luck with it mate
![]() Brian
__________________
#21 | |
Cornish Fasty
Quote:
#22 |
Lord of Longridge
good work pal
__________________
Cheers, Andy ![]() 11.93 1/4 mile @ 116.9mph - Santa pod Lancashire RSOC Group Chairman |
#23 |
best of luck fella ive just finished a resto on my moonstone saph, keep the updates coming, your floor looks in good condition with small amoutns of rust
i found loads of random stuff when taking the carpet up
__________________
#24 |
Ive found this stuff on the net, i reckon it could be good for doing car undersides with as its made to be very tough for truck bed use, so should be a good product ??
http://www.u-pol.com/countries/en/navigate.htm its under products on the left handside then specialists coatings, raptor liner black.
__________________
![]() Last edited by coswurv; 19-10-2009 at 08:07 PM. |
#25 |
Cornish Fasty
Thanks peeps, for the posistive comments
Coswurv - That stuff looks perfect! The tintable version could be made moonstone too! |
#26 |
Cornish Fasty
Little update
went to Essex with my mate to pick up his new 200sx yesterday so didn't get anything done. decided to work like a demon today Engine box and subframe are now dropped on the deck, ready to be pulled out the way and stored at work, once i can get the shell 4 inches higher. Prop and exhaust are off, fuel tank, rear bumper and pump are off. and i have found more rust i knew it was getting a little brown on the sil, but its one of those things you put to the back of your mind lol no matter, though. new sill on the way, once the rear beam is off, it's time to get jiggy with the wire brushes and scrapers.. engine in ![]() engine out... ![]() nsr sill ![]() osr sill ![]() nsr floor, near bumper bracket ![]() mainly solid rear panel ![]() tank ![]() rot free chassis leg ![]() the next hurdle... ![]() cheers for reading Last edited by Bloomers; 22-10-2009 at 07:55 PM. |
#27 |
excellent stuff Bloomers, a right pain in the hole but well worth it in the end, keep it up man
__________________
My 2WD Sapph Rear End Resto Link http://bbs.rsownersclub.co.uk/showthread.php?t=207711 |
#28 |
Looks good mate, keep the updates coming
#29 |
good luck there mate ,sure it will look mint when finished
#30 |
www.fordclubnorway.no
Good project. Looking forward for updates on this one. Keep it up mate
#31 |
Trader Score: (1)
Rep Power: 33 ![]() |
Good work there mate.Its nice to see another saff getting looked after.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#32 |
looks sweet mate i wish mine was as good as that ive spent 3 weekends welding so far and atlease another two to go. id expect to see a bit more inside the sills so id get some nice thick sheet metal aswell
#33 |
Keeping an eye on this... keep 'em coming!!!
#34 |
Cornish Fasty
A little update....
Progress has slowed down, due to 2 things: The massively tedious job of removing all the underseal from a large car, and my the earache my missus has been giving me about focusing on my preperation for RAF selection in January (which is fair enough lol) but i have been able to get in a hour here and there, a few times a week... ![]() Finally got my rear beam off, so have been able to start doing the underseal it was blocking ![]() 20 year old ford underseal, 3-4 mil thick in places. its a wonder these things can rust at all ![]() rear end, mainly cleaned up ![]() ![]() ![]() ![]() stripped floor ![]() ![]() oily mess, this is some after market sealent thats been put on. done the hjob, but a proper pain to get off. hardsuch chips off fine, but the softer bits are going to require petrol and elbow grease ![]() Me, enjoying my sunday afternoon Once its all done, the holes will be welded up, brown bits removed and/or treated and the whole floor zinc or etch primed. then this stuff is going on... ![]() Upol Raptor loadliner. should take the knocks and bumps suffieciently. and is also tintable, so will come out Moonstone Blue with the addition of a bit of base coat cheers for reading, sorry its not the most interesting post |
#35 |
Great progress. I've been through the same hard work getting the undersealing off so I know exactly how you feel. But trust me, it's definitely worth it in the end even though I was so close giving the whole shit up. Just use our time and don't rush it, sure it will be a minter when done
#36 |
Great work, good luck with the project, hope all goes well
#37 |
gr8 work m8
all will b worth it in the end
__________________
#38 |
Trader Score: (0)
Coming on great mate
__________________
#39 |
Cake lover!
Good work. RAF selection is a piece of piss compared to stripping underseal off, trust me i know.
__________________
![]() 88 Saph - 455bhp & 438lb/ft 02 CTR - 248bhp & 184lb/ft |
#40 |
Cornish Fasty
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| restoring my cossie | coachworz | Restorations, Rebuilds & Projects. | 0 | 02-07-2007 04:14 AM |
| restoring recaro's | Number1 | General Car Related Discussion. | 0 | 04-03-2006 10:42 PM |
| Restoring my Series 2! | Poom | Restorations, Rebuilds & Projects. | 34 | 08-11-2005 09:24 PM |
| S2 or S1 restoring? | CasperR | Ford Escort RS Turbo | 13 | 21-08-2005 09:32 PM |
| Restoring My S2 | 'Eck RFC | Ford Escort RS Turbo | 10 | 30-03-2005 10:43 PM |
