| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
Waiting on my fast ford..
#2 |
Looking good mate
![]() ![]() ![]() How hard was the Mk5 rear axle to fit? Brian
__________________
#3 |
Cheers, it was literally a staright swap using the same mounts and mk3 shocks. I removed the drum brakes and fitted the focus hubs staright on after removing the abs sensor. Its a lot stronger and stiffer.
#4 |
car looks nice mate
#5 |
very nice.
i'm gonna keep my eye out on this one mate. ![]() be prepared for a few questions fired your way Adam31 cos i've just started a stripdown and rebuild on my own fiesta.
__________________
http://passionford.com/forum/restora...d-rebuild.html |
#6 |
ZETEC TURBO
looks good, dose the zetec s rear axle use a antiroll bar?, also dose any of the zetec s axles fit?
#7 |
Cheers guys, its a long way from being finished but I will get there one day. I'll do my best to answer any questions but I am no expert so be warned! Regards the rear axle, it doesn't have an anti-roll bar as its stiffer than the RS mk3 one without one. However you can fit one from the RS, I haven't tried it so I don't know how it affects it. The best one has to be from the 1.6 Zetec-s or later model Puma 2000 onwards, mine is from a 1.6 fiesta zetec-s.
#8 |
I'm heading up to Sitech on Sunday for a rolling road day, so hopefully I'll sort out a date with Simon that I can take the fiesta up to start the work. I haven't forgotten about this yet....
#9 |
cool project mate
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#10 |
mate im looking to do the rear beam that you've done... can you talk me through how you did it and what parts i'll need???
#11 |
You need to find a mk5 fiesta(00-02) zetec-s, 1.6 engine. You need the axle from this car, it has a few extra bits on it that make it stronger than the mk3 one, even the turbo with the anti-rollbars. Its a straight swap if you want to keep the drum brakes. If not, and you want disks like mine you need the hubs, calipers etc from a mk1 focus. They only came on the 2.0 models and a few later 1.8's. You can fit the ST170 or focus RS ones but they are a bit pricey and won't make much difference on such a small car anyway.
Including the rear brakes I paid £140 for the whole axle, a bargain really. |
#12 |
Looks very nice already
__________________
My carbon clad s2 |
#13 |
Cheers for the replies everyone, one day it will be finished and worth looking at and you never know it might be quite a good drive aswell!
#14 |
ZT massive! Aight!
Looks like a good shell to start your project with mate. Best of luck with it
__________________
![]() Devil-developments 2.1 Zetec Turbo/GT3076r/KMS Management - Fast Ford @ Brunters September 2008 - 0-60 6.03s - More to come... Fast Ford feature June 2009 |
#15 |
looks like a nice shell ,get the under side done while your waiting before that rust gets any worse
__________________
loysport http://www.bafabrications.co.uk/ PM MONSTER FOR CUSTOM VIN TAGS carpartsexpress mail order ford parts 01914272186 |
#16 | |
Quote:
I took my dash out again as I have changed my mind(again!)might want a mk5 fiesta dash instead now. |
#17 |
When you say axle do you mean the beam???
#18 |
#19 |
Trader Score: (1)
Rep Power: 33 ![]() |
I like this little fezzer.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#20 | |
FIESTAHH
Nice project, something I would be looking to do to mine in a few years. What budget do you have for the engine conversion?
__________________
![]() Quote:
#21 |
nice project mate
#22 |
#23 |
#24 |
I am not sure of the turbo spec yet. I am taking the car up to Sitech on the 14th to start the work, I'll have a chat with Simon then and decide, but I'm sure as with most projects the spec will cange during the build.
#25 |
Dropped the car off with Simon yesterday and had a chat about the spec etc. We are going with a blacktop 2.0 zetec with the 6 speed getrac box, GT28 turbo, ERST exhaust manifold and custom inlet.....and a few other bits and bobs, once I go up again I'll get a full spec list made up.
#26 |
Ok Simon e-mailed me the full engine spec this morning....
Zetec 2.0l block Wossner pistons Eagle rods Fresh crank and bearings MLS head gasket Uprated head bolts New oil and water pump Black top head Slightly ported (cleaned up) Uprated valve springs Mountune turbo cams GT28/63 on RST manifold Gotech pro-x and loom FRS injectors Sitech Racing inlet Cossie throttle bodyThis will take up most of the budget with a pro-alloy radiator and airtec intercooler sitting up front. With this spec I am sure I'll see over 300bhp. |
#27 |
YES I KNOW I CANT SPELL
sounds good be sure to get pics up tho
__________________
" im special,, excuse my spellings" |
#28 |
should be good!
Hi Adam, Nik said you called, and passed on the info.
Looking forward to getting the engine put together on this. Also the 6 speed conversion which is well worth it. Simon.
__________________
My new project - http://passionford.com/forum/restora...bs-so-far.html |
#29 |
look's like this could be a good project.
gone for the same colour's as me with regard's to the subframe/roll bar and rear beam. look's much better than black i think, just gotta keep it clean
__________________
my 300+bhp mk5 escort zetec turbo project http://passionford.com/forum/restora...engine-in.html
#30 |
Aye it'l be hard to keep clean,but its worth it. Having some trouble sourcing a gearbox which still has the driveshafts and selector rods etc, I'll keep looking though.
#31 |
Very small update, I managed to source an FRP handbrake cable as its a straight fit for the rear disk brake conversion. Simon was quite busy when I dropped the car off but should have some updates soon.
#32 |
should be good!
Hi Adam, I have managed to get a 6 speed box, drive shafts and gear selector, will be sorting out delivary today.
S.
__________________
#33 |
Bit of an update but no pics. Spoke to Simon yesterday and we got most of the parts ordered for the chassis prep, cage, pedal bx, brake lines, fuel lines, fuel pump, new fuel tank, seat mounts and the dash is off to get flocked.
After a chat I decided to go with an OMP bolt in cage, however we will add in quite a few extra bars. I can use the money saved for other things. I'll get some pics after christmas and new year is out the way. |
#34 |
sounds as if its all coming together are u going to be fitting a diff to the 6speed box
#35 |
Fleet Manager
gonna be a cool fiesta
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 |
#36 |
Alan, I will decide after I get the shafts, flywheel and clutch out the way as that is going to cost a fair bit. How is yours coming on?
#37 |
getting there car is in primer also got my subframes anti rollbars and axle back from the powdercoaters today need to collect the st170 box tomorrow
#38 |
What colour did you decide? I bet it wasn't my idea of renault liquid yellow......
#39 |
toss up between white and kawasaki green for the car the axle and subframes are kawasaki green the anti roll bars are white what a job the guy done
#40 |
Mine is going anthraite inside, cage and engine bay. Will get cage fitted, extra bars welded in then its in with the fuel tank, fuel lines and brake lines.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fiesta mk5 ZS Zetec turbo build (update 13-1-08) | Ken_ZS | Restorations, Rebuilds & Projects. | 18 | 19-10-2009 10:03 PM |
| MK3 Fiesta Turbo, 2.0 Zetec Turbo, 4x4 and power Steering | Pardeep | Ford Fiesta Rs1800 & Rs Turbo | 7 | 10-12-2008 09:14 PM |
| zetec turbo mk3 fiesta , new project :D | luke89 | Restorations, Rebuilds & Projects. | 24 | 02-04-2007 12:27 AM |
| 1.8 zetec turbo into mk3 fiesta | zetecturbo258 | Technical help Q & A | 1 | 27-12-2006 03:52 PM |
| MK3 FIESTA CONVERSION ZETEC OR TURBO?? | leeMGZR | Technical help Q & A | 1 | 26-09-2006 12:12 AM |
