| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#81 | ||||
Can't Find 'em? Grind 'em
__________________
Mk3 Fiesta 2L Zetec |
#82 |
good work fella
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#83 |
cheers fellas
yep im using the escort waterpump and it should be ok on the throttle linkage i hope
__________________
#84 |
well the date is set for next friday to start getting the engine swap and i am hoping to get it done by lunch time sunday
but knowing me it will be done saturday can see me being up all night friday i have to change fuel tank fuel lines fit fuel pump engine wiring make exhaust rad hoses need to be modified at the moment i need a few gaskets and oil and oil filter really cant wait
__________________
#85 |
Trader Score: (1)
Rep Power: 33 ![]() |
Im looking forward to seeing it finished.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#86 |
not if they are set up right I have 2 cars on bike carbs a 1800 zetec in a mk2 fiesta on bike carbs pushin out 160bhp completly standard and when it got to 6800 was still on the way up (need some arp bottom end bolts ) and a mk4 escort cab with a 2.0l zetec with 175bhp the power curve on both is a straight line all the way up nice and smooth all the way from low rpm to flat chat . all it takes is a good rolling road garage who knows what they are doing
#87 |
went and took some pics of the car today with a mate in his polo
loads of pics anyone know how to remove the dates???? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#88 |
Looks stunning mate.
How do you find the steering on the steel wheels with the different offset? Is it a lot heavier? |
#89 |
Trader Score: (1)
Im lovin that.It looks like a proper street sleeper.
__________________
#90 |
__________________
#91 |
Fucking superstar........
Trader Score: (0)
Rep Power: 20 ![]() |
That looks outstanding. Really does!
__________________
#92 |
__________________
#93 |
update
i made a start on it today by getting the wiring loom in and pritty much done that just a few earths and lives to connect once the new engine is in i plan on starting the engine swap tomoz after work as i have friday and sat off work to get it done i hope to get the old engine fuel tank pipes out tomorrow and start friday morning on getting the new engine in hopefully i get it done friday night
__________________
#94 |
looking good!
#95 |
Looks great on those pics
And good work on de loom, and wanne see pics when you start swapping the engine
__________________
#96 |
finished work early today at 3 then got home and got started on removing the old engine
within in an hour the old engine was out fitted the new engine and starting putting bits on so tomorrow i still need to weld exhaust to downpipe fit fuel tank pump and lines finish wiring finish the plumbing find and fit aux belt fit throttle pedal ![]() ![]() ![]() ![]()
__________________
#97 |
the engine is now running
just i slight missfire which i think is down to spark plugs as i didnt change them just need to fit exhaust wire up fuel gauge bolt airbox down tidyup any last little bits will get cracking first thing tommorow to get it done cant wait to drive it
__________________
#98 |
Top Work !
__________________
#99 |
startedb today by fitting a standard airbox
sorted the missfire with some new plugs and runs spot on and it goes well monday to make sure everything is ok exhaust got welded and is quiter with the zetec only had a problem with an oil leak which was coming from the sump all sorted now will be tidying up the engine bay tomoz ![]() ![]()
__________________
#100 |
looks sweet pal.
how come you haven't put the carbs on
__________________
Kris ![]()
#101 |
got different plans in mind
__________________
#102 |
Advanced 5 Door User
Top job there mate
#103 |
cheers mate was a 1600
__________________
#104 |
It looks great mate
__________________
#105 |
Orion ZT coming soon
Nicely done
#106 |
good work mate
__________________
![]() Birkbeck Auto Repairs Ltd Sidcup KENT |
#107 |
Great project doing the same thing myself with a bonus
__________________
My carbon clad s2 |
#108 |
are the wheels from the c5 are they the really light ones think they poss alloy ones? looking sweet. am my sleep doing a mk4 2.0 bit slower than you tho.
#109 |
im really liking that
![]() whos is the blue 19 16v in the background???
#110 |
i got them off a mate so not sure have seen the same wheels on a xsara
though thats my step bros 19 is for sale i think
__________________
#111 |
my first ever car the 19 16v,got a real soft spot for them.
#112 |
a little update
have tidied the engine bay and the engine is fine turns out its not bottem end :devil: also sorted the oil leak was crank shaft seal wasnt cheap either from ford Ł45 with fitting kit ![]() ![]() ![]()
__________________
#113 |
Trader Score: (0)
Looks ace!
__________________
#114 |
Looks great
![]() Youre wheels, are they 15" ?
__________________
#115 |
cheers fellas yes they are 15s
they are off a citroen xsara i think
__________________
#116 |
Nice,
Ive got 16" Citroen steelies on my Mk4, look the same Mine are of a C5, i think..
__________________
#117 |
__________________
#118 |
love it!
#119 |
__________________
#120 |
That's real nice tranformation. I like it very mutch. I have that idee for mij mk3.....
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| going from carbed to EFI? | Burnzybubbles | General Car Related Discussion. | 2 | 02-06-2009 12:38 AM |
| 1.6 carbed engine? | mk3matt | Cars & Parts Wanted. | 5 | 01-09-2008 03:13 PM |
| 1.1 HCS Engine in Fiesta's - is it twin carbed? | AGAR-COSWORTH | General Car Related Discussion. | 7 | 01-08-2005 07:57 PM |
| Carbed/Throttle bodies not running airfilters? | MadMac | General Car Related Discussion. | 19 | 15-05-2005 01:05 PM |
| xr3 turbo carbed! does any one no any thing about them? | mmanse | General Car Related Discussion. | 10 | 20-01-2005 06:18 PM |
