Mk6 JWRC fiesta cosworth
Old 09-10-2015, 06:15 PM
  #4361
M K
M K's Avatar
Also if anybody can help I'm after an older style Tial spring
I am after one the same as the Middle 1 in this photo but it needs to be the yellow version which is rated at 2.9psi
It is 1.875" outside diameter and roughly 3.75" long
I can't find 1 anywhere
Thanks
Marc
Old 09-10-2015, 07:40 PM
  #4362
whizzisat114
whizzisat114's Avatar
Great work yet again Marc
This car just keeps.on evolving
Where will it end
Old 09-10-2015, 07:48 PM
  #4363
M K
M K's Avatar
Cheers Dave and Toby
Old 12-10-2015, 08:03 PM
  #4364
sgracing
sgracing's Avatar
Old 13-10-2015, 07:12 AM
  #4365
M K
M K's Avatar
Originally Posted by sgracing
You know
Old 14-10-2015, 08:39 AM
  #4366
Punter
Punter's Avatar
Location: in the workshop rebuilding my car for many years now
Originally Posted by frayz
Yeah I'm gonna take the Mini GP and see how it goes.
Tom kept nagging me to go
Happy days another mini going on the 9th
Old 16-10-2015, 07:10 PM
  #4367
frayz
Boost Junkie
frayz's Avatar
Can I get a sit in this on the 9th please Marc?
Old 17-10-2015, 08:49 AM
  #4368
M K
M K's Avatar
Yes mate as long as i do not break anything at Brands hatch the week before that can't be sorted by Snetterton
Old 17-10-2015, 04:06 PM
  #4369
M K
M K's Avatar
Topped up the attessa red today with dexron II atf and pressure bled with compressor
Not ran the pump yet as not wired up but seems to be air lock in middle of reservoir but hopefully will go when we run the pump up
See here what I mean
There's some kind of filter in the middle of the res too so that may also have something to do with it
Going to SiLECK Motorsport wiring tomorrow to get the pump and ets pro wired in in full dr25 and deutsch dtm connectors etc
Pics to follow tomorrow
Old 18-10-2015, 06:49 PM
  #4370
M K
M K's Avatar
Went down to Simon @ Sileck Motorsport wiring today for the loom to be made up for the ETS PRO diff controller
It's 80miles each way give or take a mile
Glad I took ear defenders as the car noise is not long journey friendly lol
Got there nice and early about 9:30am
At the end of the day the control box loom was done and in and all seems to be working ok
Deutsch plugs for attessa pump
Loom plug for handbrake release, this has not been added yet as we did not have a switch I liked that I thought would go well, needs to be an open circuit normally and closed when pressed
New breakers
40amp for attessa pump and 10amp for the ets unit itself
Also the switch to ground for instant 2wd or 4wd this output is what we split for the handbrake release
And lastly the manual/auto button and diff control gain knob all lit and working
And lastly a nice shot of some perfect lambda 1 when cruising on the way home
Old 18-10-2015, 07:30 PM
  #4371
Fudgey
Baby Cheesus
Fudgey's Avatar
Tidy.
So all done then, except being able to use the wand in 4wd mode?
Old 18-10-2015, 07:39 PM
  #4372
markk
markk's Avatar
Make sure you use a proper proximity switch, no messing then.
How does the box feel compared to the MT75?
Old 18-10-2015, 07:59 PM
  #4373
JonnyBravo
JonnyBravo's Avatar
Is the 4wd controlled by the ecu or just manual switchover ?
Ignore that. Spotted your box of tricks on your Facebook page
Old 18-10-2015, 10:44 PM
  #4374
COLEYST200
COLEYST200's Avatar
Looking good mate and as to the air it's a pane in the ass but when I did my setup I just ran the pump and flicking the switch from 2wd to 4x4 then all of a sudden the pump sounded funny and air shut up in to the oil tank job done but it did take 10/15min to get it to prime and that's it you will never need to do it again
Old 19-10-2015, 06:47 AM
  #4375
JonnyBravo
JonnyBravo's Avatar
edited
Old 19-10-2015, 07:20 AM
  #4376
M K
M K's Avatar
Originally Posted by Fudgey
Tidy.
Yes mate, this gearbox is very noisy though and needs a rebuild so il leave for brands and snetterton if it will last then rebuild box over winter
Hi Mark, is there any specific switch you would recommend to use?
The box feels good but this 1 I bought second hand as it very noisy and in need of a rebuild so will be better to compare with a fresh box
All controlled via the ETS PRO unit, the handbrake and 2wd/4wd switch just grounds the relay to cut the pump pressure giving instant 2wd
Il give it a try mate, some also suggested car idling on stands in 3rd gear and bleeding so will try that as well
Old 19-10-2015, 07:26 AM
  #4377
Fudgey
Baby Cheesus
Fudgey's Avatar
Nice one Marc, so you can almost enjoy it now, except for a box rebuild lol.
all that hard effort has paid off, and you nkow you have built something pretty damn special!
just dont bin it
M K (19-10-2015)
Old 19-10-2015, 11:03 AM
  #4378
stu21t
stu21t's Avatar
just dont bin it
I think even I would cry if he did that😂
And I've never even met him or seen the car in the flesh lol
And am I asking a daft question when I say, why does the handbrake switch the car to 2wd? Why do you want it to I mean?
M K (19-10-2015)
Old 19-10-2015, 11:55 AM
  #4379
Caddyshack
Caddyshack's Avatar
My reservoir did that but it just seemed to sort itself out after a little of the pump running, as Coley says the pump changes in sound and then the return starts to refil the reservoir.
M K (19-10-2015)
Old 19-10-2015, 12:51 PM
  #4380
Fudgey
Baby Cheesus
Fudgey's Avatar
i think we would all cry!
using the handbrake and locking the rear wheels on a 4wd car is bad.
the centre diff wont like it at all.
by switching to 2wd it will cut power to the front wheels, so as long as the clutch is dipped the rears can be locked with no issues
Old 19-10-2015, 06:04 PM
  #4381
M K
M K's Avatar
I don't plan on binning it but these things happen lol
I forgot a couple of little things
New comms lead as broke the clip on my old 1 which made wills mapping job a mare lol
Finally found a new 2.9psi waste gate spring from Germany and got it fitted
And lastly here's the tps signal wire for the ets diff controller, when I had the loom modded for dbw I kept original tps live so we just connected to the signal wire
This engine loom will be for sale soon if anybody's interested
Old 20-10-2015, 07:15 AM
  #4382
wayne thomas
wayne thomas's Avatar
Surely it will cut the power to the back wheels allowing you to lock them without dipping the clutch and maintaining front end drive.
Old 20-10-2015, 07:25 AM
  #4383
Fudgey
Baby Cheesus
Fudgey's Avatar
See above quote
Old 20-10-2015, 08:11 AM
  #4384
markk
markk's Avatar
It actually opens the solenoid to allow all accumulated pressure to return to the tank thus making rwd, the car/box is rwd, has no center diff other than a wet clutch pack that transfers drive from the rear to the front when loss of traction or low G force is meaured againt high revs/WOT.
Old 20-10-2015, 08:39 AM
  #4385
wayne thomas
Thought it would be a handbrake release mechanism like an escort world car.
Old 20-10-2015, 11:55 AM
  #4386
markk
markk's Avatar
It is except no VC
Old 20-10-2015, 12:26 PM
  #4387
wayne thomas
It is except no VC
So same idea but opposite effect, cutting the drive to front in this application but the rear in the world car?
Old 20-10-2015, 01:24 PM
  #4388
markk
markk's Avatar
iirc the world car does the same, the handbrake release on grpa and valve block via rexroth valves still requires clutch down after front release
Mark
Old 20-10-2015, 01:37 PM
  #4389
wayne thomas
Mark
I was certain the world car cut drive to the rear and can't recall ever having to use the clutch in tandem with the handbrake, the grey cells must be dulling with time.
Old 21-10-2015, 07:59 AM
  #4390
Fudgey
Baby Cheesus
Fudgey's Avatar
Mark
I didnt know they used Rexroth valves. I work for Bosch Rexroth, but repair electronic drives and controls - nothing to do with the hydraulics side
Old 24-10-2015, 11:36 PM
  #4391
M K
M K's Avatar
Bit of work done on the car today,
Had a problem of the cambelt walking off the pulleys slightly and running against the crank sprocket guide and edge of the tensioner causing it to rub and chamfer the edge of the belt,
Bit dodgy and making a mess of the bay due to the rubber dust
Few pics of problem
Have put this down to a worn tensioner and possibly Jack shaft but just for peace of mind I have change back to a steel crank sprocket and steel aux pulley,
This was the first cambelt change I have ever done so was a bit nervous lol but it's very simple and was easy so no dramas, new uprated dayco belt fitted with new tensioner and I have ran the car up for 5 mins only as no rad fitted yet but all seems ok now,
Belt still runs close to the edge of the tensioner but is not touching now like it was before
Hopefully that will stop it doing it again and is good peace of mind before brands hatch,
Thanks to Jano for the aux pulley and Adamski for the crank sprocket
Thanks
Marc
Old 28-10-2015, 11:05 AM
  #4392
M K
M K's Avatar
Doing a bit of a nut and bolt check as im out on track at Brands Hatch Monday
Rear diff flange locking nut had come completely off and was only being held on by the propshaft!
So took it all apart and toque'd back up to spec and put some torque check paint on it for future reference
Just goes to show how much gets rattled loose etc on the first few hundred miles out as everything on the car was nice and tight before it ever turned a wheel,
Hopefully tonight me and Will shall be out setting up the new boost control to give me a few different settings on the 12 position cal switch
Weather depending!
Old 28-10-2015, 01:34 PM
  #4393
Fudgey
Baby Cheesus
Fudgey's Avatar
those capheads look bloody close to the diff casing too!
Old 28-10-2015, 01:47 PM
  #4394
M K
M K's Avatar
There very close but do not touch
Old 28-10-2015, 04:11 PM
  #4395
Fudgey
Baby Cheesus
Fudgey's Avatar
Until the diff bearings wear a little lol
at least you spotted the other one before something broke!
good luck with the mapping!
Old 28-10-2015, 04:17 PM
  #4396
Caddyshack
Caddyshack's Avatar
Glad you spotted the cam belt as that could have been costly. Also good spot on the loose nut. I will nut and bolt check mine after 250 / 500 miles.
Old 28-10-2015, 09:11 PM
  #4397
M K
M K's Avatar
Well just to make things more tedious the water pump went tonight lol
Developed a leak from this small hole which everyone says is the signs of bearings gone!
So even more annoying is my pump is modified to suit my 10long stud set up
But hopefully Tommy @ FMS will have a new 1 machines for me by lunchtime tomorrow
Seems my last few problem with this pump and the tensioner are down to rust/corrosion issues due to having the engine built about 4 years ago then leaving it sitting in a garage for 3 years
Never mind, hopefully back together tomorrow night
Old 31-10-2015, 06:31 PM
  #4398
M K
M K's Avatar
New water pump fitted after rushing to find 1 and getting the blades machined,
Took it for a drive to run and then check coolant etc so went to see my brother in law who was running his van on the hub dyno
720bhp @ the wheels ain't bad lol
Old 31-10-2015, 07:14 PM
  #4399
gus
gus's Avatar
And I bet his still not happy with that
Old 31-10-2015, 08:02 PM
  #4400
Caddyshack
Caddyshack's Avatar
Is it really that much?
Quick Reply: Mk6 JWRC fiesta cosworth
