Mk6 JWRC fiesta cosworth
Old 02-09-2015, 05:10 PM
  #4241
Fudgey
Baby Cheesus
Fudgey's Avatar
Good progress Marc
Originally Posted by RUBY123
what is that red/orange stuff you dot on all your bolts
Its a tamper evident seal, you brush it on and it dries hard. If the nut or bolt or whatever is loosened it will crack and you can see that its moved etc.
We use this stuff at work
http://uk.rs-online.com/web/p/epoxy-coatings/1965245/
Old 02-09-2015, 07:19 PM
  #4242
COLEYST200
COLEYST200's Avatar
Looking very good as all ways any news on the prop shafts yet
Old 02-09-2015, 07:55 PM
  #4243
M K
M K's Avatar
We're supposed to be done today mate but as always they have been busy lol really annoys me when people give bullshit timescales but what can you do lol
Going to aim to get the other 2 holes all welded up tomorrow if I have a good run at it with no set backs but we will see
Old 03-09-2015, 07:26 PM
  #4244
M K
M K's Avatar
Bit more done today
One more piece to go that needs a bit more jiggery to clear the seat
Props are all done and ready to collect so going to go get them tomorrow
front prop I had re made from 1 new piece and balanced and it needed 1 new joint
The rear section that I made needed a fair bit of work to get balanced up properly but that is all done too
Old 03-09-2015, 08:05 PM
  #4245
sgracing
sgracing's Avatar
Originally Posted by M K
Bit more done today
Tig broken ?..
Old 03-09-2015, 11:02 PM
  #4246
M K
M K's Avatar
Lol no Steve just some of it would be too awkward to get to with the tig so Mig was the more sensible option
Old 04-09-2015, 05:37 PM
  #4247
M K
M K's Avatar
All welding finished today
Done a bit of primer on 2 bits but ran out of time
Props all done
Old 04-09-2015, 07:31 PM
  #4248
brooksy898
brooksy898's Avatar
how in fcking jesus have u afford all this.
Old 04-09-2015, 07:40 PM
  #4249
M K
M K's Avatar
Lots and lots of long crappy shifts at work mate
Old 04-09-2015, 08:55 PM
  #4250
Fudgey
Baby Cheesus
Fudgey's Avatar
Good progress bud, should be done in no time!
Old 04-09-2015, 10:22 PM
  #4251
COLEYST200
COLEYST200's Avatar
Looking very good but with one week to go it's going to be a tall order to get it up and running with the skyline setup do you think you can make it ??
Old 04-09-2015, 11:06 PM
  #4252
M K
M K's Avatar
Hi Ian
Tomorrow will see it all in paint, and the box properly sealed back together ready to go back in, then Monday I will machine a new cylinder mount for the Tilton
The only things that would not be done would be the attessa pump set up and potentially the exhaust but I was not planning on running the strip at pod anyway so if they are not done and the car drives then Il take it,
Worst case I have everything untouched to put the cossie box back in, which will take me a max of 3 hours, that's the handy thing about not touching the old props/clutch/grearbox mount or exhaust parts
What would the skyline gearbox be running with no pressure set up to the center diff?
Old 04-09-2015, 11:19 PM
  #4253
markk
markk's Avatar
Rear wheel drive
M K (05-09-2015)
Old 05-09-2015, 12:55 AM
  #4254
ossie cossie
ossie cossie's Avatar
Awesome work, you got me thinking as well about making modified mounts and parts to be able to put the standard 4x4 cosworth box back in if ever i had to. Makes sense really.
Old 05-09-2015, 01:18 AM
  #4255
M K
M K's Avatar
In theory I shouldn't ever have to but until I'm 100% happy with the skyline conversion I didn't want to chop anything up and the car not be useable, if a track day comes up and theres issues with the skyline box or I don't have the attessa pump in etc I can put the Cossie stuff back in
Once the attessa and controller etc are in I shouldn't need to swap back
Old 05-09-2015, 06:34 AM
  #4256
COLEYST200
COLEYST200's Avatar
It would be nice but as we both have Cosworth gearbox tunnels I'm sorry but you will have to remove one of the gearbox mounting points from the tunnel to make the skyline gearbox fit . Mark did not have this problem as his gearbox tunnel is a one off so his mounts are in a diforent place to start with
Old 05-09-2015, 06:37 AM
  #4257
COLEYST200
COLEYST200's Avatar
As said with no oil psi to the clutch setup in the gearbox it will run 2wd / rear wheel drive
Old 05-09-2015, 10:17 AM
  #4258
M K
M K's Avatar
Would that damage the box at all running/driving the car with no pressure at all ?
Old 05-09-2015, 12:46 PM
  #4259
ossie cossie
I have cut out the floor to fit the GTR box and while i did 2 off the standard 4X4 cosworth mounting holes were cut out. So i will need to modify the gearbox mount as you said to mount the GTR box. I will hopefully use parts of the cosworth and GTR gearbox mountings.
Then when i put the standard 4X4 cosworth box in i will have to make a different custom gearbox mount using the same holes hopefully, and make it out of another cosworth and GTR mountings. something like this one.
Old 05-09-2015, 02:48 PM
  #4260
COLEYST200
COLEYST200's Avatar
It will be ok as the skyline runs 2wd until the gearbox is told to bring it into 4x4 so no problem
Old 05-09-2015, 03:04 PM
  #4261
M K
M K's Avatar
Old 05-09-2015, 03:11 PM
  #4262
M K
M K's Avatar
Sealed and stone chipped the underside, just needs a few hours to dry out before a bit of paint but paint coverage is not essential here as will be completely covered by heat shielding
Got a bit of paint inside quickly as weather is turning shit,
Il have to leave this masked up till Monday then I will seal the welds properly and then give it another coat
Not sure how well it will all match but the floor areas get grubby and battered quickly so in a few months you probably won't even notice
Old 05-09-2015, 04:14 PM
  #4263
M K
M K's Avatar
Underside done, plenty good enough for under there lol
Old 05-09-2015, 07:24 PM
  #4264
Hellraiser
Hellraiser's Avatar
Looking good mate, awesome project
Old 06-09-2015, 07:51 AM
  #4265
M K
M K's Avatar
Thanks mate
Old 06-09-2015, 12:41 PM
  #4266
stu21t
stu21t's Avatar
What's with all the silver tape?
Is it to blank off holes?
And did you buy pre cut circles?
I used the silver tape to cover holes inside my car but haven't seen anyone else do it? Is this a proper way of doing it?
Old 07-09-2015, 11:31 AM
  #4267
M K
M K's Avatar
Silver tape is used to cover all holes you don't want dirt and water etc getting in also it is great to go over heat proofing with as if you have decent stuff it sticks likes glue and stops edges of heat proofing from peeling and lifting
Used by most wrc teams
Old 07-09-2015, 11:52 AM
  #4268
M K
M K's Avatar
Ended up going over all welds with Tiger Seal as the brushable seam sealer was horrid, this is not the best or prettiest finish but it completely seals everything and is over paintable, and is how I done the entire underside
Maybe 1 day il get the car re painted and then properly dress all the welds nicely and re seal but with everything still in the car I was worried about the grinding sparks and everything
Colour match is clearly visible but when all floor plates are re cut and back in you won't notice that much
Function over form
Re shielded the new tunnel cut outs but ran out of tape to cover the left side in the picture so will finish when I get some more
Old 07-09-2015, 04:25 PM
  #4269
COLEYST200
COLEYST200's Avatar
Nice work mate the tape your on about used in the duckting game we use it at work and the better stuff like you have use is the winter one of the two and stick a lot better
Old 07-09-2015, 05:36 PM
  #4270
M K
M K's Avatar
It's good stuff and super tough and super sticky lol
Cut the floor plates to refit today
This is a temp bodge until I make some more but not going to bother till after the next 2 track days in November
Drivers side 1 can stay as it is as it still looks ok
Old 07-09-2015, 07:29 PM
  #4271
COLEYST200
COLEYST200's Avatar
You will have to let me no witch track day your doing and ware .
Have you started on the clutch setup yet ?
Old 07-09-2015, 08:02 PM
  #4272
M K
M K's Avatar
Hi mate
Monday 2nd November is brands hatch performance ford track day
Monday 9th is snetterton 300 circuit track day
Get booked up
Not started on clutch set up yet
Tomorrow I'm putting the Cossie box and stuff back in for the weekend for pod
Then rest of week il do the skyline clutch set up etc
Old 07-09-2015, 08:10 PM
  #4273
stu21t
stu21t's Avatar
That's good to know about the tape.
Yea I bought it to stick the edges of my heat Matt down.
Then just starting going over the holes lol.
Old 08-09-2015, 05:34 PM
  #4274
M K
M K's Avatar
Done the clutch set up today
Checked the measurements and worked out I needed a spacer of 10.5mm so machined up a new 1 as I did not want to modify my Cossie mt75 one
Then once that was done I had to figure out how to secure the spacer so I utilised the original clutch mount bracket, cut up a bit of billet, drilled it and welded it to the spacer
All worked out perfect and after some careful clamping and welding it sits perfectly over the nose piece with zero tilt as far as I can see
Anyway let the pics show the story
Box ready to be fitted
Will fit the box tomorrow hopefully
Thanks
Marc
Old 08-09-2015, 06:34 PM
  #4275
M K
M K's Avatar
Clutch pack back on and lined up
Old 08-09-2015, 06:55 PM
  #4276
Caddyshack
Caddyshack's Avatar
Looking good.
Where is the best place to get the silver tape? I wouldn't mind doing my tunnel before I put the box back in.
Old 08-09-2015, 07:02 PM
  #4277
markk
markk's Avatar
The biggest problem i had was getting my multiplate clutch lined up onto the skyline splines, they are very short compared to the MT75.
Do yours sit in the right place?
Old 08-09-2015, 07:25 PM
  #4278
Caddyshack
Caddyshack's Avatar
I am using a skyline paddle behind helix cover and I have been massively struggling with the line up.
Have you not had to swap the plates to skyline splines? I thought they were different to the Cossie ones?
Old 08-09-2015, 07:47 PM
  #4279
markk
markk's Avatar
Clutch alignment was no issue at all, mines a triple plate, just made an alignment spline, and yes of course the splines had to be changed to Datsun ones 😉
Old 08-09-2015, 08:03 PM
  #4280
Caddyshack
Caddyshack's Avatar
Eh, your previous post says the biggest problem was getting the splines aligned?
I actually mis read who the poster was and thought MK had forgotten to swap to Datsun splines.
Quick Reply: Mk6 JWRC fiesta cosworth
