Mk6 JWRC fiesta cosworth
#4201
It looks like you will be up and running soon.
#4202
Always helps having an extra pair of hands just that I work nights a lot and usually nobody around to help me ,
Think I will struggle with the extra weight of the skyline box on my own but il try it lol
Got my skyline clutch alignment tool through today so I can fit the new paddles and line the clutch back up on the flywheel,
Also just dropped off the props to be sorted and should be done for next Wednesday
All coming along nicely so far
Thanks
Marc
Thanks
Marc
#4203
I wil have maybe have to make 2 rear props one for the standard rear diff and a custom made one for when I do the supra diff conversion. Just can't seem to make up my mind. I really want the supra diff put in. But time is getting on. And I have an escos prop in the garage. The only thing stopping me is I have another COSSY and the standard bits would come in handy for that if ever I brake anything.
#4204
If you get custom shafts made up and you want to sell the ones you have made already I would love to take them off your hands.
#4205
Not just the props but any prototype bits you have done for the skyline box conversion. As I can see your workmanship and quality are second to none. But I don't mind the odd bodge part on my race slag. .
#4206
Il help where I can mate but most of my stuff inc props etc will be different due to being in a fiesta
They are using the props I made to refresh and balance etc so won't have them to spare I'm afraid
Had a few issue aligning the box as said before where it has warped during welding and the holes are slightly out now for the dowels so to hold the box in line I made up some alignment studs to guide the box on, hold it and allow me to bolt up both box holes onto the dowels then the bottom holes then remove dowels and finish bolting up
Makes life a lot easier
On with aligning the clutch pack now
#4208
Great pics and the aligning tools are a good idea! Looks like we both have a similar problem lining up although I can do the first bit easily, it is when I introduce the paddle clutch and input shaft I struggle the most.
#4213
Decided to get the messiest part out the way today which was cleaning up all the metal around the holes where I'm going to weld in new sections, it made a right mess but all done now so tomorrow I think il start cutting and folding the new pieces if I get a chance
All cleaned up
Doesn't look like much done but that along with cleaning up afterwards took me 5 hours
All cleaned up
#4216
As said mate it's a shame you have had to cut the tunnel up so much but needs must and it will be worth it when it's done . Just sorry to say it but then it will be the next weakest part with your bhp you have got . The rear diff as you well no I'v only got 400bhp and I'v smashed two diffs a 7.1/2 and a 7 .
I'v just sent my rear beam in to be powder coated and arms as I'v modded them to hold the suppra 3.9 diff . When it all comes out I'm going to have a new prop made and loose the center bearing .
Keep the good work up mate your doing a fab job
#4217
Yeah coley I've wondered about the rear diff so will have to see although I have more fair in that then the standard box lol, it's a gripper rear diff with shot peened and super finished CWP but as you found out it's the planet gears that don't last
As I have no beam to worry about, if I look at changing diffs il try and look for something even stronger than the old supra item if there is such a thing with the right ratio
#4218
cossie fan (unluckerly)
I've a gripper diff in mine but changing to a supra one. Your not brake the gripper diff it's self but the c.w.p is made of glass lol they don't like high torque. I ripped the teeth off mine flooring it off a roundabout in second I've r888's on mine and it just gripped! Mine now has a hewland shot peened and super finished c.w.p but the diffs worth a fair bit so I'd rather sell it and fit the supra one
#4219
#4220
Isn't the 9inch over Ł3000? I don't know of anyone on here breaking a supra diff in terms of the gears, just the casing where it needed a rear cover...as yet nobody has Broken a covered one tha I know of.
#4221
The gripper and any other good diff has 4 of them.
I think that rear will be ok for a while.
#4223
Don't know. Makes sense. If I was building from scratch I would now consider skyline for engine too, that or Mitsubishi evo engine and gear. Nothing comes close to the history and nostalgia of a Cossie though.
#4226
It's funny you say that,
This guy
[img]https://turborenault.co.uk/attachments/9055/[\img]
Is using an evo engine with cossie gearbox and diffs.
I've asked why he doesn't run a skyline box with supra diff and he's happy with the cossie stuff he's got.
This guy
#4227
Cossie stuff is fine until you make 400lb ft at a decently low Rev range and the add some grip...if it were 2wd on road tyres I suspect you would be fine.
#4230
Hooked up or not the 7.5 inch ford c.w.p is crap and will brake with high torque if it don't you have no high low down torque lol
#4232
No updates as I've had the bank holiday weekend away from the car for a change, will be back on it tomorrow where I hope to start welding in the new sections for transfer box and exhaust tunnel as I borrowed some argosheild light off my brother in law today for my mig
#4236
Will you weld from both sides or just top? I did both sides on mine with 2 mm steel and I don't ever want to weld under a car again if I can help it! I assume that as long as it penetrates well you only need one side?
#4238
Caddyshack (02-09-2015)
