Mk6 JWRC fiesta cosworth
Old 05-12-2011, 08:36 AM
  #2001
massivewangers
massivewangers's Avatar
Originally Posted by M K
Sorry mate i missed that 1
Yeah it is definitely 2 different pairs, Andrew supplied these and they were both new pairs but maybe he already had a new set laying around from another build supplied by someone else or something, i am not too fussed as they are mounted front and rear so as long as they are matching pairs im happy, can't warrant another £80 just to have exact ones lol
Not a dig at all matey, just curious, as they look different so wondering what they were, be interesting to find out if they're both Compbrake ones. I could do with buying some top mounts at some stage, so interested in what options are out there.
It's a shame you've fitted them, as I would have quite liked some measurements off them Does look ace built up though
Old 07-12-2011, 04:48 PM
  #2002
M K
M K's Avatar
Cheers mate
Re fitted the rad and cooler tonight to see how big i need to machine up some spacers to lower the cooler as if it is fully bolted up it touches the bonnet so i need to drop it approx 25mm, the only pain with that is the inlet to cooler pipe is then gonna be well out of line so at a later date the cooler will need cutting that side and pointing up a bit before being re welded
Old 09-12-2011, 07:44 AM
  #2003
M K
M K's Avatar
Machined some small alloy spacers to lower the intercooler mounting
That drops it enough to clear the bonnet, so will just need to send the cooler for modding at a later date when engine is eventually in and i know the correct angle the outlet pipe needs to be.
Sorry for the poor quality photo, the iphone does not like the strip lights in the background
Old 09-12-2011, 08:29 AM
  #2004
whizzisat114
whizzisat114's Avatar
Car look's awsome Mark
Will you be rubber mounting the rad/intercoolers aswell ?
Just thought they might crack prematurly from vibrations
you could machine 5mm of each end and have a disc of rubber top and bottom
Old 09-12-2011, 08:35 AM
  #2005
M K
M K's Avatar
Good thinking Dave, it could come down a bit more anyway so i will do that when they get mounted for good
Thanks
Old 09-12-2011, 08:55 AM
  #2006
JonnyBravo
JonnyBravo's Avatar
Looks great Marc. I'll second the rubber mountings as I removed one the other day that had cracked around all the mounts.
Also there is a guy on the Audi forum I use that has a golf with a spaceframed front and apparently he now can't use it on the road due to some law. I'd imagine you can get a test done but would be a mission to have sva'd I'd imagine.
I'll dig out the link if you want
Old 09-12-2011, 09:54 AM
  #2007
turbo m
turbo m's Avatar
Looks awsome.
Old 09-12-2011, 11:36 AM
  #2008
M K
M K's Avatar
Won't make much difference as i will get it road legal 1 way or another im sure as there is always a way round it, but it will hardly if ever be used on the road, just makes it easier to move about if needed.
Also made up the other fuel line between the pumps today, not over the moon with it to be honest as the braided teflon doesn't flex enough so i will do the rest of the car in convoluted stuff from thinkauto as i used on my old car
Old 09-12-2011, 11:52 AM
  #2009
jonfoc
jonfoc's Avatar
Christ on a bike Marc that is one epic build. I thought the XR2 was impressive but this is something else. By the way most of the old XR is shared amongst some friends of mine. The shell is running and turbo'd again, the fuel system is in another XR2 Foc rs powered and the management is in an S2.
Keep up the awsome work pal
Old 09-12-2011, 12:59 PM
  #2010
COCHYN
COCHYN's Avatar
I wouldn't be too dissapointed with that fuel setup pal, it looks epic, neat and clean. Nice touch
Old 09-12-2011, 02:26 PM
  #2011
gus
gus's Avatar
and unless your getting a glass cover for the lid then who will see it
the stuff in mine has a bit of give to it (goodridge 811 i think it is)
Old 09-12-2011, 02:40 PM
  #2012
COCHYN
COCHYN's Avatar
That would be a nice idea, a perspex cover to keep the shit out of the box
Old 09-12-2011, 03:39 PM
  #2013
stu21t
stu21t's Avatar
Perspex would look cool
And for the cooler mounts just use cotton reels. They come in various lengths/thicknesses
Old 09-12-2011, 03:53 PM
  #2014
focus 4x4
focus 4x4's Avatar
I had the same conversation with pro alloy with my intercooler , the outcome was that the mounts for the pro alloy intercoolers were that heavy duty that you are able to mount them solid to the chassis. my cooler is mounted solid. ;o)
Old 09-12-2011, 06:05 PM
  #2015
whizzisat114
I was'nt thinking of the area arount the mounts Simon
i was thinking of the area where the cores meet the side tanks on the cooler/radiator (i would of thought that they were the weakest part ?)
i would think that this car will be running hard suspension / low pro tyres and will driven like it's stolen
and most components would be shaken to bit's
All only my opinion of course
Old 09-12-2011, 07:00 PM
  #2016
focus 4x4
focus 4x4's Avatar
Yep , thats the areas we discussed too . good thinking batman!
Old 14-12-2011, 08:45 PM
  #2017
M K
M K's Avatar
Cheers for the comments guys
I think i have some rubber mounting bobbins so may use those as suggested just to be safe,
Got the car on it's wheels the other day to check a few things, had to jack it up and get it off the stand first though lol
A few pics of the car sat on it's own wheels and suspension for a change
Hopefully have the rear diff all built up in the next week or so and the rears brakes all fully fitted as i have just purchased a used rear ap set up
More updates soon
Old 14-12-2011, 09:02 PM
  #2018
focus 4x4
focus 4x4's Avatar
Awesome mate!
Old 14-12-2011, 09:28 PM
  #2019
stu21t
stu21t's Avatar
such a cool car
something you probably already know but thought id mention.
you can get boots for the rose joints to keep them clean, and also washers with rubber surrounds that also cover the joints but dont really seal them.
might be worth trying some just to keep it clean/grit free
Old 14-12-2011, 09:41 PM
  #2020
Gatecrasher
Not welcome...
Gatecrasher's Avatar
Looks great mark
Have you got a finish date you are aiming for?
Old 14-12-2011, 10:35 PM
  #2021
JonnyBravo
JonnyBravo's Avatar
SOOO nice.
Great work Marc, coming together nicely now.
Old 16-12-2011, 04:53 AM
  #2022
M K
M K's Avatar
Awesome mate!
Cheers Simon
Originally Posted by stu21t
such a cool car
Yeah i have seen the boots and i will buy and fit them last thing before the car is finally set up mate, there quite expensive for a bit of rubber so didn't want to spend out just yet as i may split or damage them when i keep removing stuff
Originally Posted by Gatecrasher
Looks great mark
Around the middle to end of next year would be good, would like to catch ford fair maybe if im lucky and my work stays steady
SOOO nice.
Cheers mate, it's looked like a load of parts for so long it's nice to see a car coming together finally
Old 16-12-2011, 04:55 AM
  #2023
M K
M K's Avatar
Picked up my shot peened and super finished 3.9 crown wheels and pinions so i should have the new rear gripper diff built up back to me after the xmas break
Old 16-12-2011, 05:03 AM
  #2024
COCHYN
COCHYN's Avatar
Epic stuff Marc
Old 16-12-2011, 05:51 AM
  #2025
Must pop over for a looky
Old 16-12-2011, 06:17 AM
  #2026
whizzisat114
They look great Mark
Gonna be one hell of a special car
Old 16-12-2011, 08:22 AM
  #2027
massivewangers
Build up is great, as you say, finally stops looking like a load of bits!
Looking brilliant Marc, can't wait to see it come together
Old 16-12-2011, 12:22 PM
  #2028
cossiedevil
cossiedevil's Avatar
Looking good Marc
Old 16-12-2011, 08:45 PM
  #2029
Fudgey
Baby Cheesus
Fudgey's Avatar
awesome stuff marc, it just keeps getting better and better!
ps loving the rad fans too, they are the best bit on the car lol
Old 17-12-2011, 12:21 PM
  #2030
fezzajsy
fezzajsy's Avatar
Old 24-12-2011, 07:38 AM
  #2031
M K
M K's Avatar
Thanks for the kind comments guys
Dave - give me a ring if you want to pop over at any point.
Old 24-12-2011, 08:00 AM
  #2032
M K
M K's Avatar
No Massive updates lately as i had a few set backs, mainly the rear brake set up situation
First off i must say a quick thanks to Mark @ MT-MOTORSPORT who sorted me the brakes, very helpful guy with great parts and great prices to match, thanks mate
I purchased a 295mmx25mm ap 4 pot kit for the rear of the car
Was well happy with that but unknown to me it turns out that with the ag style steering arms i can't run a discs that small as the caliper fouls the steering arm no matter what you do and i didn't realize this
Had a quick measure up and spoke to Andrew and he confirms that he used a 330mm discs on the rear and positioned the caliper at 10 o'clock and that way it clears everything so unfortunately the brakes must be sold and i have to go for a 330mm rear set up, and i can't just buy new discs as the 5100 caliper is only for a 25.4mm discs with a 295 dia.
So anyone selling a 330mm kit let me know
Next up is a bit more lathe action,
I wanted to run the proper stud sleeves on the M14 wheel studs to give them the extra strength as per the grpa/wrc cars but after speaking to dewitts i found out the ones they sell are not threaded as the studs they supply have a shoulder so there sleeves i assume are heated up then slid over the shoulder then once cooled down they shrink tight,
As my studs are threaded all the way i made up some sleeves that were threaded with M14x1.5 instead so they can be screwed on and tightened using stilsons or similar
So ideally i needed some 18mm round bar as that is the diameter needed but i had some 19mm laying around so turned that down instead to save a few quid
Round bar in mild steel, ideally stainless would be better but the lathe struggle with stainless so i will get these plated when finished
Rough cut into 30mm lengths once the bar had been turned down to 18mm
Then drilled out to 12.5mm
Threaded to M14x1.5
And voila
Grpa/wrc wheel stud sleeves
I didn't worry about a nice perfect finish on them as they will get scraped etc every time the wheel is taken off and put on but i am happy with them and the total cost was about £10 and 5 hours of my own time making them, but that is just the rear set as the fronts are not done yet
Dummy fitted them to check all was ok
That's it for now
Thanks
Marc
Old 24-12-2011, 08:33 AM
  #2033
whizzisat114
Great work on the lathe Mark
Id love a little lathe in my garage
Old 24-12-2011, 08:39 AM
  #2034
Matt carter
Matt carter's Avatar
Just keeps getting better.
Old 24-12-2011, 08:43 AM
  #2035
Mr RS500
Mr RS500's Avatar
FOOKINELL
this is probs one of the best builds i have ever seen
Love it
Old 24-12-2011, 09:01 AM
  #2036
M K
M K's Avatar
Then get one mate, about £300 will do you what i have probably and it is small enough to put away and get out when you need to use it, it is only about 700mm long by 300mm tall so takes up no room, i would like to out mine for a bigger gap bed lathe so i could turn brake bells and bigger parts but i just don't have the room
Cheers fella
Originally Posted by NORTH YORKS RS SPARES
FOOKINELL
Love it
Thanks mate, the end is kind of in sight with this now so it's the best part of the build
Old 24-12-2011, 09:20 AM
  #2037
Jay,
Sponsor
Jay,'s Avatar
jesus what a car and the detail !!! truley amazing
Old 24-12-2011, 09:34 AM
  #2038
carlo
carlo's Avatar
Ditto all of the above totally awesome mark nice one
Old 24-12-2011, 09:52 AM
  #2039
TimC
TimC's Avatar
Coming on superbly Marc.
Old 24-12-2011, 10:32 AM
  #2040
andy escos
andy escos's Avatar
very nice Marc
Quick Reply: Mk6 JWRC fiesta cosworth
