Mk6 JWRC fiesta cosworth
M K (20-04-2015)
#3809
Seriously this is pure art, love it, well done
M K (20-04-2015)
#3812
Another small thing finished now
I had to have a larger hole than needed to allow me to tilt the gearbox during fitting and removal other it fouled on the tunnel so the hole was cut larger but this will allow dirt/debris/water/ fumes into the cab so it had to be sealed but easily removable
So I fitted some DZUS slide latch bobbins to the tunnel and made up a cover piece in ally and riveted on the slide latch then covered with the same 3m carbon look vinyl that I done the door bars in, then on the underside its padded out with adhesive battery tray foam to give a flexible but total seal
Job done,
Maybe not to everybody's taste but as always it is function over form allow easy removal of gearbox
It does not sit flush and is not supposed to as it allows the foam to compress to create the seal
Thanks
Marc
Job done,
Thanks
Marc
#3813
With all the labels such as diff, fan etc on the switches, is that dymo label white on clear? Looks good and I like the quick release gearbox cover....I guess you expect to be taking the box out again? I have not decided how to seal mine yet, was thinking of using riv nuts and out a cover over, I too want the box to be easy to come out, I am having my carpets made up so that they can easily come out there too.
Billy_RS (25-04-2015)
#3815
What's a pd box?
#3819
Awesome work mate just gets better
#3822
Hello Everyone!
It is lovely to see all the different uses of Dymo tapes and just how well they can look when used in these types of projects!
Big thanks for all your continued support and of course we are readily available if you run into problems or have questions!
With best regards,
Jesper K
DYMOSupport
With best regards,
Jesper K
DYMOSupport
#3824
Hello Everyone!
With best regards,
Jesper K
DYMOSupport
With best regards,
Jesper K
DYMOSupport
I now realise I need white on clear!
#3826
Big thanks for your support and on your purchase.
Now regarding the tape you mentioned (1805440) I checked in from our end it is correct it is supposed to be black on clear, not black on white. So it would seem like something has gone a little bit wrong there and I do apologize for the inconvenience.
However in this case I would like to advice you to contact us directly (see contact info below) and we will see if we can't get you the correct cassette as well as a white on clear one.
Contact information:
GB: 020 3564 83 54 (Monday to Friday: 9am - 5pm)
IE: 015 17 18 56 (Monday to Friday: 9am - 5pm)
With best regards,
Jesper K
DYMOSupport
#3827
Hiya Caddyshack,
email
With best regards,
Jesper K
DYMOSupport
With best regards,
Jesper K
DYMOSupport
#3832
It's on the chunky side but never expected it to be light with all the cage work
With me and 45 Litres of fuel its roughly 1300kg
It has been set up geometry wise with a passenger in weighing the same as me as mostly have somebody in it on track days so with that it's around 1390kg
