Mk6 JWRC fiesta cosworth
M K (26-12-2015)
#4536
Great work mate just gets better
#4538
Got the car out today and fired up
Exhaust doesn't really sound any different as I've only added the tailpipes but it was only meant to direct any gases away from the underside anyway
Sound on the iPhone not great but here is a clip anyway
http://smg.photobucket.com/user/CHIC...yw4os.mp4.html
#4545
Ben
Ohhhh I am a sucker for letterbox exhausts! Sounds healthy too.
#4546
Originally Posted by MK
Believe it or not I would actually like to try it on a loose surface but not just yet lol also I doubt it would be allowed in any classes due to its type of build
However, having said that, I personally think it would be a shame to take your car rallycrossing: with all the thought and effort you have put in, it would be a terrible shame to see it get crashed into!
#4547
Exhaust now mounted on its rubber bobbins so it's stiff but not solid and hopefully will have no cracking issues
I also gave the area a coat of oxide then stone guard where I had welded the bosses in, will give this a lick of matching paint when the bonnet is done a bit later in the year but will protect it for now
#4553
Forgot about this
http://www.fastfordmag.co.uk/2015/12...r-of-the-year/
Please vote if you haven't already and think my fiesta is worthy
Thanks
Marc
Thanks
Marc
#4557
Not done anything on the car in a few months but had the urge to do something with it today so thought I would tackle the alternator heat shield ......
This is what happened after a 250mile round trip and half a track day when I drove the car to Snetterton
Can't be having that so a heat shield was needed
Needed to make something up to go here
So made a cardboard mock up
Trial fit
Cut out of ally sheet and bent in the box pan folder
Also cut out a tab for mounting that needed to be welded on
Another trial fit
All welded up
Had to be careful when welding not to melt the edges back, can be tricky
Fitted
Just need to get some gold heat reflective material to cover it with,
Should do the trick nicely
Thanks
Marc
Trial fit
Another trial fit
All welded up
Fitted
Thanks
Marc
