PassionFord
Welcome to Passion Ford!
Welcome to Passion Ford.
Thread Tools Display Modes
Old 22-04-2009, 11:49 PM   #1
warrenpenalver
Puma Nutter!!!
warrenpenalver's Avatar
Trader Score: (3)
warrenpenalver is an unknown quantity at this point
Send a message via MSN to warrenpenalver
Default Puma Cosworth restoration/bodge job fix!
Well i decided to do a thread now ive started to mess around with the car. Theres a few things need doing, mostly from bits rushed at the end of the build and i want to tidy things up and tweak a bit.
Here she is resting in her nice dry garage!
Some shots from the original build:
Few shots of the car in general:
Unfortunately Tony didnt make any record of how he wired the two looms together which is annoying!!! Everything works at the moment except the heated windscreen which i think is the relay.
Have got a few issues with exposed relays and spare plugs.
These two are the relays used to run the cosworth engine loom. Personally i would have integrated the wiring with the fuse box, but thats just me, plus id run the circuits off the original ignition relay.
This is just an untidy mess to be sorted and horrible clips on the coil!!!
And some shocking bodges on fuel system!!! No wonder i was only getting 6V at fuel pump!!
yes this is cable ties holding pump!!!
Also the boost control is erm... dodgy as fuck!!!!
Saw this screw under the air filter 90 degree hose:
on closer inspection saw that its blocking the hole in compressor to actuator pipe where a boost control valve once was
and the pin hole to let air bleed off
and some banjo thing on end of actuator rod:
Also needs some heat sheilding:
and this canister actually connecting rather than doing nothing:
needs a new gasket by looks of things on inlet manifold:
And also a manifold bolt which is randomly missing for some reason
Im quite pissed off with a lot of these bodges as quite frankly they were totally unessecary. Hes spent a lot of money getting shell done, custom alloy tank aeroquip etc etc etc then hasnt spent the extra few hours putting it together properly!!
Still i cant argue too much because i got it cheap and certainly a hell of a lot cheaper than building one from scratch which was my alternative plan.
The first thing i have had modified is the clutch cable arrangement:
The old clutch was VERY heavy due to kinks in the cable routing and also not quite enough travel making it hard to engage/disengage gears unless road and engine speed matched. That was because the modiefied clutch pedal has slightly less travel than a standard escos pedal and the cables were stretching due to heavy pedal and the auto adjusting ratchet was at limit of travel. Ive now got a stronger cable and also removed the rubber gromit at gearbox end of cable which reduces all the wieght on the pedal as the rubber used to be compressed tightly to get enough travel to use clutch. But alls fine now!! Curtesy of reyland!!! Eventually i will go hydraulic but its finance dependant!!!
Also fitted a cambelt cover as seen above as the cambelt used to be exposed with a turbo pipe running very close to it. Technically it was fine but it only takes a cable clip to come loose or when tweeking things to put finger in wrong place!!!!
I then started my project to fit a variable intermittant wiper stalk from hispec mk6/7 escorts.
compare the two indicator stalks!!! ones escort, ones puma!!
They are made from the same moudings and appear identical (except variable wipe resister). Taken apart an escort and puma stalks to look at internal electrical differences.
They are basically the same circuit board inside with only minor differences, being the lack of variable resistor wired into the puma stalk and one less pin on the puma stalk (the variable resistor timing pin on escort stalk!).
The differences are circled in red. Also means i can easily swap around stalks if bits are broken by soldering on the new stalk.
It also means when later on i remove the factory steering wheel i can fit a fiesta mk3 left side stalk with horn button on the end.
Here is the scribbled wiring diagram i did:
and the neater version drawn into my wiring diagrams:
I got my variable intermittant wipe fully working by making a sub loom to fit into the fuse box on one of the spare relay holder positions to the side of the box.
the wire in the back of the stalks is just inserting the extra pin into the back of the stalk where there is an empty hole so dead easy to do.
So far ive made it as a removable subloom incase i do some more fusebox wiring:
Ive used connectors to plug directly into the original relay holder so no changes to car fuse box. Tidied it since that phot which was test fitting!! Have a nice relay holder clipped on side of fuse box and the wires are all threaded neatly!!
Eventually im thinking once im happy i will dismantle the relay holder and swap all the pins over and hard wire in the extra timing wire to the stalk. that way it will be both permenant and totally factory look.
Stalk fitted looks factory:
Interior all fitted up again and the intermittant wipe looks factory!!
Got plenty of other bits and bobs to do like sort out stupid actuator hose and make permenant changes to fuel system like proper mounts and rewireing the pump. Im getting a full 12v at pump now following repairs, but the wiring outside the car from the gromit to the fuel pump is potentially a liability and Im not prepared to trust that it will be ok so its getting replaced to be on safe side.
__________________
Medically Discharged!! Officially insane!!!
My Project Thread: http://passionford.com/forum/restora...e-job-fix.html
warrenpenalver is offline   Reply With Quote
Old 22-04-2009, 11:53 PM   #2
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (2)
Chip is an unknown quantity at this point
The laptop im on at the moment just doesnt go anywhere near that resolution, maybe you could make them a bit smaller, as I suspect most people will struggle with that.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is offline   Reply With Quote
Old 22-04-2009, 11:55 PM   #3
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
yeah just noticed
__________________
Old 23-04-2009, 12:02 AM   #4
katers
Trader Score: (0)
katers is on a distinguished road
makes my old puma look terrible.
love it :P
__________________
katers is offline   Reply With Quote
Old 23-04-2009, 12:29 AM   #5
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
pics fit screen now
__________________
Old 23-04-2009, 06:10 AM   #6
RSRoy
RSRoy's Avatar
Trader Score: (0)
RSRoy
Thats some annoying work you got there, good luck with it. It's a cool car
__________________
Roy
RSRoy is offline   Reply With Quote
Old 23-04-2009, 06:21 AM   #7
cossie4i
Trader Score: (4)
cossie4i is an unknown quantity at this point
Send a message via MSN to cossie4i
I cant believe all the good work thats gone into the car then all the bodges
Good luck with sorting it all out
Steve
__________________
Cosworth Turbo XR4i, TT T38, ST Escos Inlet, 83lb Injectors, Ported Head,Turbosystems Mapped
330mm Front & 300mm Rear CompBrake kit.
12.91sec 1/4 @ 114.77mph (T34 & 400s)
cossie4i is online now   Reply With Quote
Old 23-04-2009, 07:34 AM   #8
Daveysaff
Skint Passionford User
Trader Score: (8)
Daveysaff is an unknown quantity at this point
Send a message via MSN to Daveysaff
Looks like you're making it into a good 'un
I'd love to do one of these one day
__________________
The Mk3 Cabby WILL be hitting the streets before next summer!!!!!!
xBox360 Gamertag - Daveyc1979
GSXR 750 SRAD in the garage.... Lambchop was right
Daveysaff is offline   Reply With Quote
Old 23-04-2009, 07:53 AM   #9
Brian
Brian's Avatar
Trader Score: (2)
Brian
Brian
__________________
www.fiestaclubgb.co.uk
Brian is offline   Reply With Quote
Old 23-04-2009, 08:47 AM   #10
Matt Evans
Black Country RSOC
Matt Evans's Avatar
Trader Score: (0)
Matt Evans
At least going through the car with a fine toothcomb means all these silly jobs can be done out the way and you can enjoy it properly.
Cool Puma as well!
__________________
Visit our local group (Black country) RSOC web site www.bcrsoc.ipbfree.com
Matt Evans is offline   Reply With Quote
Old 23-04-2009, 08:54 AM   #11
smila
smila's Avatar
Trader Score: (1)
smila is an unknown quantity at this point
Send a message via MSN to smila
good luck mate it will all be worth it,and you will have piece of mind
__________________
keep old fords alive!!!!!!
smila is offline   Reply With Quote
Old 23-04-2009, 09:05 AM   #12
Robs Frst
Robs Frst's Avatar
Trader Score: (0)
Robs Frst is an unknown quantity at this point
Nice, its annoying when things are bodged, It will be worth it when its finished.
__________________
Robs Frst is offline   Reply With Quote
Old 23-04-2009, 10:23 AM   #13
Zetecfiesta
Trader Score: (0)
Zetecfiesta
Send a message via MSN to Zetecfiesta
very nice puma mate, pitty about those little niggles!
Zetecfiesta is offline   Reply With Quote
Old 23-04-2009, 10:30 AM   #14
BIG.GEOFF.H
BIG.GEOFF.H's Avatar
Trader Score: (0)
BIG.GEOFF.H is an unknown quantity at this point
Send a message via MSN to BIG.GEOFF.H
how much u give 4 it if you dont mind me asking would love that car in my collection
__________________
BIG.GEOFF.H is offline   Reply With Quote
Old 23-04-2009, 10:58 AM   #15
OldDan
aka YoungDan
OldDan's Avatar
Trader Score: (0)
OldDan
Send a message via AIM to OldDan Send a message via MSN to OldDan
Looks really good bet it'll be a hoot to drive once it's done.
Another Tony McQuire special eh!
__________________
"On that occasion I said to him 'why do you do a tackle like that?' And he said 'because I don't like you'.
Patrice Evra speaking of tussles with Super Kevin Davies.
12.5:1 CR - 1600CC - 9000RPM
ShawSpeed.com
SELF-PROCLAIMED ZETEC-SE EXPERT.
OldDan is offline   Reply With Quote
Old 23-04-2009, 11:12 AM   #16
jeans43
jeans43's Avatar
Trader Score: (0)
jeans43 is on a distinguished road
Send a message via MSN to jeans43
Looks like it was a bit of utter bodge to me . You've got abit of work to be doing there Warren. Keep the pics coming and good look mate
P.S Have fun figuring the wiring
__________________
Adrian aka AJ
jeans43 is offline   Reply With Quote
Old 23-04-2009, 11:16 AM   #17
hai07222
Trader Score: (0)
hai07222
Looks nice except for the little bodges, my mk5 escort is the same so i know how much of pain it is lol.
Good luck with it
__________________
hai07222 is offline   Reply With Quote
Old 23-04-2009, 11:44 AM   #18
cjwood555
Trader Score: (0)
cjwood555
Send a message via MSN to cjwood555
Sounds like a typical pumaspeed job to me - never mind eh! It's a nice looking car and bet it goes like stink Will be following your updates - good luck fella
cjwood555 is offline   Reply With Quote
Old 23-04-2009, 01:29 PM   #19
AquariousRS
AquariousRS's Avatar
Trader Score: (1)
Location: Skelmersdale @ Home, Preston for Myerscough College
AquariousRS
Send a message via MSN to AquariousRS
We love Puma Cosworths dont we buddy
__________________
Tim
909sport ~ For all your braking and Suspention needs ~ Contact NUTs RuS for any questions or enquirys.
AquariousRS is online now   Reply With Quote
Old 23-04-2009, 01:45 PM   #20
Rich_bloor
rich_bloor@hotmail.com
Rich_bloor's Avatar
Trader Score: (0)
Rich_bloor
love it m8!
__________________
I CAN HELP YOU EARN EXTRA MONEY IN YOUR SPARE TIME... PM me
WWW.WATCH4INCOME.CO.UK
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford.
Rich_bloor is offline   Reply With Quote
Old 23-04-2009, 02:22 PM   #21
jeans43
jeans43's Avatar
Trader Score: (0)
Quote:
Don't Go there Tim!!!
That wasn't so much the car tho that was the Kn*b head owner!
__________________
Adrian aka AJ
Old 23-04-2009, 04:19 PM   #22
smitsturbo
smitsturbo's Avatar
Trader Score: (0)
smitsturbo
stunning car, love it
__________________
www.sitechracing.co.uk
pinkys back at crail 11th april
new white 4x4 cosworth coming soon
smitsturbo is offline   Reply With Quote
Old 23-04-2009, 07:53 PM   #23
purplemonster
RWD PUMA :)
Trader Score: (0)
purplemonster
Send a message via MSN to purplemonster Send a message via Yahoo to purplemonster
nice looking puma
__________________
"AWESOME CAR IN THE MAKING"
http://www.passionford.com/forum/vie...er=asc&start=0
purplemonster is offline   Reply With Quote
Old 23-04-2009, 08:12 PM   #24
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Quote:
It does go like stink, just not at the moment im taking it easy especially with those bodges on the boost control
Thats not too bad to be honest. I know where the cossy loom connects to puma so thats easy ish. Just need to trace all those connectors back to the puma loom so i can hide them behind dash and then work out which one of those connectors is for boost control from the P8 so it can be sorted out eventually.
Well now ive got 12v at the pump I'm content that the wiring repair is satisfactory!! It will do for a couple of weeks until i can make a complete new loom to go from the in car connector (which i shall rebuild to be safe) under rear seat all the way to the pump.
I might buy a new pump at the same time as the current pump is a standard escort cosworth one which is ok for my spec but its a few years old so cant hurt to replace it with a sightly uprated one, and as i understand it, aftermarket pumps have posts for ring terminals so id be better off replacing pump with loom so i can put rings on the new loom.
While i was dirty i decided i might as well fit the carbontec strut top mounts i bought ages ago, just hadnt got round to sorting.
Things didnt go quite to plan on the passenger side!! for a start i noticed the AVO hex bolt for adjusting dampers is missing...... and secondly the strut top bolt decided to jam at top of the thread!!! This is despite me cleaning thread and WD40 ing the lot. heat wouldnt loosen it and i didnt want to clamp the thread as it will be damaged so i gave it one more warning and gave the bolt strict words. I did warn it that if it didnt loosen i would cut it off!!!
hahahahaha that'll teach the bolt!!! doing the last bit by hand with hacksaw blade so i dont cut down to thread then i shall lever it apart once ive done the same on other side!! Good job i have new bolt to go on!!!
__________________
Old 23-04-2009, 08:23 PM   #25
graham c
Trader Score: (2)
graham c
i dont no why people just do the job once and do it rite! it takes twice as long to sort it out!
__________________
just dont tell the wife how much it really cost
graham c is offline   Reply With Quote
Old 23-04-2009, 08:40 PM   #26
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
frustrating as hes spent loads of money on some decent parts to then ruin it with some 2p bodges
I could understand if it was a Ł500 crusty RS turbo but doing such bodges on a relatively expensive cosworth is just stupid IMO.
__________________
Old 23-04-2009, 10:20 PM   #27
Trader Score: (7)
Car looks great ,shame about the bodges ,but you are putting them right
__________________
Twins is offline   Reply With Quote
Old 24-04-2009, 06:42 PM   #28
andy escos
Capt Chaos
Trader Score: (1)
andy escos is on a distinguished road
car looks excellent got a real good stance ,keep the updates coming fella
__________________
500+BHP 4X4 ZAKSPEED ESCORT FULL REBUILD,NEWFLOORS,BODY KIT,COLOUR, STARTED
http://www.passionford.com/forum/sho...?t=263882major
DEVON RSOC MEMBER MEETS SECOND SUNDAY OF MONTH AT LYNHAM PUB PLYMPTON
andy escos is offline   Reply With Quote
Old 24-04-2009, 06:50 PM   #29
Munch
Mr. Sparkle!
Munch's Avatar
Trader Score: (0)
Munch is an unknown quantity at this point
i do like this car, all the best with it
__________________
CHEERS, LEE
Onslow Loves COD!
Arguing on the internet is like racing in an impreza, even if you win, you're still a twat.
Munch is offline   Reply With Quote
Old 24-04-2009, 07:01 PM   #30
sapph1
sapph1's Avatar
Trader Score: (2)
sapph1
I had a look round this today when you were outside Bristol Street (i work there),
Does look very nice mate, couldnt believe how wide it is tbh!!
What size are your rear tyres if you dont mind me asking?
Good luck with sorting the niggles, will be awsome when its done!!
__________________
sapph1 is offline   Reply With Quote
Old 24-04-2009, 09:56 PM   #31
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
10" rear wheels with 255/35/R18 tyres!!! tooo expensive!
Be good when you get your saff on the road. I popped in to pick up a bolt and came back out to a crowd of mechanics by car
Warren 1 : Nut 0
Fitted this sides carbon cover now!!
__________________
Old 24-04-2009, 10:20 PM   #32
youngben
youngben's Avatar
Trader Score: (1)
youngben is an unknown quantity at this point
Send a message via MSN to youngben
this the same car mate?
http://www.pumaspeed.co.uk/showdetails.php?id=547
looks ace that nice1
__________________
youngben is offline   Reply With Quote
Old 24-04-2009, 10:22 PM   #33
madsi
madsi's Avatar
Trader Score: (0)
madsi
very nice car mate,i hope you dont come across anymore trouble with it
madsi is offline   Reply With Quote
Old 24-04-2009, 10:24 PM   #34
sapph1
sapph1's Avatar
Trader Score: (2)
sapph1
Lol, i'd gone back in by that point, had a job to finish!!
Makes a change to have something interesting on the car park, hence the crowd of mechanics!!
Hoping to have mine back on the road in the next few weeks so hopefull i'll see you about mate!!
__________________
Old 24-04-2009, 10:42 PM   #35
Moonstone Mart
Trader Score: (1)
Moonstone Mart
I also saw this drive past today as i walked out of work (Toyota dealership next to bristol street) Recognised the car as soon as it came round the corner as being the Cosworth powered one!
Looks a nice motor - sounded nice too! Be even better when all the dodgy parts are sorted.
Its a small world.
Mart
__________________
Check out my 2WD sapphire Cosworth resto thread right here >>>>
http://www.passionford.com/forum/viewtopic.php?t=297533
Moonstone Mart is offline   Reply With Quote
Old 24-04-2009, 11:11 PM   #36
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
theres a few nice saphs ive seen around in stoke and a imp blue escos.
__________________
Old 25-04-2009, 10:50 PM   #37
Wellz!!!!
Ka driver
Trader Score: (0)
Wellz!!!!
Send a message via MSN to Wellz!!!!
nice car and great to see all the bodges being sorted out
__________________
www.two-tone-ka.tk
1.8 zetec ka 0-60 in 7.81 secs
Daily Driver: 206 GLX 2.0 Ltr HDI
1800 zetec on ITB in a Ka
Wellz!!!! is offline   Reply With Quote
Old 26-04-2009, 06:40 PM   #38
Puma_dal
www.projectpuma.com
Puma_dal's Avatar
Trader Score: (0)
Puma_dal
Send a message via MSN to Puma_dal
I got a fair few pictures of your car at yesterdays meet mate : hope you don't mind if I post them for all to see your amazing beast.
Mine and yours:
Next to Jacko'd FRP:
Awesome shot:
My mirror full of Warren!
FRP engine fore ground / Cosworth background:
Epic car mate!!
__________________
->ProjectPuma<-
The free non-profit making forum..
Puma_dal is offline   Reply With Quote
Old 26-04-2009, 06:51 PM   #39
turbocabessex
Trader Score: (1)
turbocabessex is on a distinguished road
what a weapon, glad to see your sortin it properly
__________________
turbocabessex is offline   Reply With Quote
Old 26-04-2009, 08:52 PM   #40
BIG.GEOFF.H
Trader Score: (0)
i love it what does it drive like?
__________________
Tags
ace, air, bodge, carbontec, comb, compressor, cosworth, diagram, extra, feet like hobbits, fine, fix, hard, nibble, puma, rubber, tooth, variable, warren does bottom burps, wiring
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Escort cosworth rear bumper fix? Ninosv Ford Escort RS Cosworth 2 01-03-2008 10:50 AM
can you fix way to fix a dripping radiator? Gra General Discussion. 6 07-02-2007 08:09 PM
cosworth diff problem who can fix ? Doug General Discussion. 9 05-03-2006 09:32 PM
quick questiona about starting a restoration job Gra Restorations, Rebuilds & Projects. 3 13-04-2005 05:55 PM
4x4 Cosworth Restoration - advise please.. boostman Restorations, Rebuilds & Projects. 2 23-02-2005 08:45 AM
Content Relevant URLs by vBSEO 3.3.0
