PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-12-2009, 06:32 PM   #161
A16X_TM
Trader Score: (0)
A16X_TM is an unknown quantity at this point
Send a message via MSN to A16X_TM
i remember this car, my mates black escort rs turbo was featured in the same copy of fast ford.
good to see the bodges being sorted, nothing worse then unreliable `make dos` when it wouldnt take much to sort it in the first place!! no need for things to be unreliable when they dont have to be.
top effort mate, il keep an eye on this one
A16X_TM is offline   Reply With Quote
Old 25-12-2009, 08:33 PM   #162
warrenpenalver
Puma Nutter!!!
warrenpenalver's Avatar
Trader Score: (3)
warrenpenalver will become famous soon enoughwarrenpenalver will become famous soon enough
Send a message via MSN to warrenpenalver
Carrying on with the stalk mod!
I have now fitted the horn unit to the stalk. It just slides in and you fit the retaining pin to hold it in:
At the other end i have crimped on the correct sized connectors.
Now to fit the stalk attach a wire extension onto the horn wire which is the black wire with yellow stripe. All the other wires plug onto the same connector as when you took off the the old stalk. The original black/yellow wire is now grey/red as the horn wire has taken that colour on the new stalk unit. Also the earth on the original puma stalk will sometimes be black or green/yellow.
In essence the horn stalk mod is now almost done. All that needs doing is connecting the horn wire to the horn prongs on the circuit board. in essence the extra horn switch is in parallel to the original ones. The horn prong we are connecting to, is the one on the right of the circuit board. The wire will have to be run along the edge of the circuit board below where the hazard flasher unit goes as there is just enough room!!
Mext now looking at the right hand stalk unit, we want to fit the variable intermittant wipe stalk unit. The wiring and fitting is indentical to the original stalk except with the addition of 2 extra wires, one green, one green/grey for the intermittant wipe unit.
On the escort stalk unit circuit board you will find two extra tags for those wires. The puma stalk circuit board does not have the tags!
Luckily the actual circuit board is a common design with changes between the two by drilling through, breaking tracks and adding tags. In essence we are going to attach the variable wipe unit to the spare pin which will go to escort relay and the intermittant wipe contact point.
In the wiring diagram in essence we are connecting to pin connector P (54-9) and 53-2.
For pin connector P, check between the pin and the circuit board holes to find out which one connects to it. The area that works has been circled in red below:
Then for the other connector do the same check with a multimeter and you will find the hole we will be poking wire through in red. The green circle shows where to solder the horn wire.
Now turn board over. There is no room on the main side to solder the wire so i intend to poke it through and solder on the reverse side of the board.
Then attack each area with a dremel tool to remove some plastic exposing enough brass board to solder the wire to:
This was done the same on the reverse:
Then clean up the board and tin the brass pads and the wires with solder to make it easier to connect as its quite fiddly!
The first wire to solder is the horn wire.
Circled in red you can see where the horn wire passes close to the hazard flasher. In hindsight i would do the solder joint in the left stalk itself but with the wire glued down there is just enough space for the flasher to work.
Then solder the wire on the rear:
If needs be file the solder level with the plastic but careful soldering and you should be fine.
Then plug in the wires on the stalk and solder the final wire:
Once the stalk is located it should look like this:
and is now ready for reassembly. You will find you need to poke a screwdriver through this gap:
to manipulate the spring wheel on each stalk so that it can make its interferance fit with the contact point as shown below in white:
Then it should slide together although ensure the stalk studs fit into thier holes (in red):
rescrew together and the stalk is ready to fit to my car:
__________________
Medically Discharged!! Officially insane!!!
My Project Thread: http://passionford.com/forum/restora...e-job-fix.html
warrenpenalver is offline   Reply With Quote
Old 25-12-2009, 08:38 PM   #163
dingla rs
dingla rs's Avatar
Trader Score: (1)
dingla rs is on a distinguished road
is there that much difference from old one ?,think you like wiring to much lol
__________________
loysport
http://www.bafabrications.co.uk/
PM MONSTER FOR CUSTOM VIN TAGS
carpartsexpress mail order ford parts 01914272186
dingla rs is offline   Reply With Quote
Old 25-12-2009, 09:10 PM   #164
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
nah its because pumas have horn on steering wheel, and its easier having it on the stalk if your planning on doing a aftermarket wheel.
Also intermittant wipe is 1 speed which is either too slow or too fast so variable wipe means you set the time.
__________________
Old 26-12-2009, 10:26 AM   #165
cossiejsy
cossiejsy's Avatar
Trader Score: (0)
cossiejsy is an unknown quantity at this point
Send a message via MSN to cossiejsy Send a message via Skype™ to cossiejsy
doing a top job mate
__________________
Dont like my drivin then stop watchin me
Jersey Rs Owners Club
member of the daytime pf talk bollocks and random shite club #65
cossiejsy is offline   Reply With Quote
Old 28-12-2009, 12:28 AM   #166
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
The intermittant stalk you have do you know if its just a straight swap over or do you have to fit some more wiring or fit a different relay.I would like to fit one to the wifes mk5 fiesta ghia.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 28-12-2009, 10:13 AM   #167
Rossco
Rossco's Avatar
Trader Score: (0)
Rossco is an unknown quantity at this point
Send a message via MSN to Rossco
Good work mate.
Rossco is offline   Reply With Quote
Old 29-12-2009, 01:52 PM   #168
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Quote:
its an escort relay - see earlier in thread for subloom i made! Is your wifes car a digital dash? if so you probably cant fit it. do you have a 3 button remote for for the car? If so the whole fusebox under the dash is different and on mk5's was replaced with a combined alarm unit and fuse/relay box all based on modern miniture relays on a PCB! So not easy to wire around! You can change the wiper delay on later cars anyway, it should say in the handbook.
Old 05-01-2010, 05:43 PM   #169
Oppliger Motorsport
Romain
Oppliger Motorsport's Avatar
Trader Score: (0)
Oppliger Motorsport is an unknown quantity at this point
Oppliger Romain
Send a message via MSN to Oppliger Motorsport
Default Oppliger engine and GEARBOX....
first road test of our powerful Cosworth car....1.6 bar of boost....we have to finish the map for 2.2bar...
engine spec:Nikasil liners on 200 block,10 long studs,Arrow cranckshafts,Arrow rods,forged pistons,ported head,double valve springs,Nimonic valves,solid followers,wild camshafts,wrc 8 injectors manifold,swedish plenum,70mm body,tubolar exhaust manifold,gt35 turbo,external wastegate,coil pack,pectel super 8,twin 044 fuel pumps,etc....ops....Oppliger BIG TOOTH GEARKIT
videos:
__________________
Oppliger Romain
COSWORTH SPECIALISTS
web: www.oppligermotorsport.com
email: oppliger.cosworth@tiscali.it
facebook: http://www.facebook.com/pages/Opplig...31522163564280
Oppliger Motorsport is offline   Reply With Quote
Old 06-01-2010, 05:00 PM   #170
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
well ive sorted the wiring harness for the 3 button alarm conversion!
First we need some connectors to connect the loom to the car. Easiest way is to butcher a spare 2 button alarm module to get the connector blocks!
Butcher the motherboard so youve got room to access the pins:
then using a hacksaw carefully chop off excess plastic then desolder the connectors:
Trim off any excess plastic to make it neat then straigten the pins on the small connector:
Do the same for the large connector and once tidied up you will have your two connectors ready to plug into car loom:
Then you need to make the harness itself. You should have kept the connectors on the 3 button alarm module. As you can see in the pics below, the alarm module is considerably bigger than the old one:
So plan to either trim off excess plastic or make loom longer to relocate the alarm module behind the dash.
I chose to extend my loom to 1m length so i can relocate the module where convenient to me. Extend wires as necessary then label them so you know which is which, then wrap up to protect. This is also done now so that all the wire lengths are the same ready for connecting the connectors at the other end!!
Then find the shortest wire. This will be the first one connected and governs the length of the loom. Its easier to cut the other wires to length than find youve a wire 2mm too short when your halfway through!!
Solder on the wires and wrap in heatshrink to protect the joints. i find tinning the contact and the wire first makes it easier to get a good joint plus it means you put less heat into the plastic so are less likely to melt it making a pin loose in the connector!
be careful to adjust the lengths to suit so you wont get strange lumps or kinks.
Once you are done you can add some braided sleeving or other protective coating to the loom. I used convoluted tubing common in ford looms. You could just double wrap in tape but if your feeding it behind dash there are some sharp bits of metal and you may not be able to see what you are doing so you dont want to risk damaging the wiring!
Loom now complete! the next stage is to test it which i will do soon!
__________________
Old 26-01-2010, 05:11 AM   #171
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Done a few more bits and bobs!
First the electrics... Started to make a subloom for the focus ST170 dash i want to try and fit.
Trimmed and labelled all the wires on the focus dash plug i aquired:
Then i had to manufacture a connector for the puma connectors. as these dont exist seperate to dash units i have had to make my own using double copper sided fibre board. First i rough cut with a hacksaw a piece of board.
Then i trimmed it precisely and notched it to lock in position on the connector! I also inserted anf removed it several times including wiggling it. The contacts left a mark on the copper which is ideal as i then take a dremel to the board to seperate each contact.
Then i mark up the board and start to solder on the wires to both sides from the focus connector.
Once thats done its insulated, taped up and then marked up for its respective connector:
Few things i need next is to source the oil guages and connector so i can connect up the remaining wires, then source a 36-1 wheel to go on crank pulley with a zetec sensor so that i can recreate the PIP signal to my EEC V ecu. then as it has the pip signal the ECU will be alive enough for it to do databus communications with the ST170 dash! The pip signal will drive the tacho.
Also fitted a ford speed sensor to drive the speedo:
Need to finish wiring that into the puma loom!!
In light of the adverse weather ive decided to finally sort the heated washer jets id got off another ford! They were in good condition but the typical untidy insulating tape for wiring protection. I decided to braid the loom to make it neater and more protected.
Also finally sorted some floor mats!! Standard mats dont fit my car so i sourced some cheapo mats to cut up to fit!
You can see how much smaller i needed to make the mat!!
Decided to replace my front TCA to ARB bushes as they were crap and also pumaspeed had fitted too many washers to rear:
Getting them off was easy enough with a bit of hammering on the bolt!!!
Quickly fitted the new bush itself:
ooohhh shiney new bolt and washer!!
Then putting it back together is the hard bit!! The TCA wont go any further than this due to the spring tension:
Me and my neighbour couldnt get it done so i got a cossie expert cossiecrazy and his work colleague from the garage he owns to come give a hand and in 10 minutes had the bolts back in as id pushed the wheel the wrong way
Got it back together and then went to get it tracked. decided to have a good look underneath while properly up in the air and all seems sound just needs the odd lick of paint here and there. The garage were impressed with the shell fabrication chassis points so at least i know all is good there! I did find quite a bit of rust on my backbox though:
Its a complete custom exhaust system supposedly stainless steel when quite plainly its not stainless!!!! So im going to need to grind that rust back and paint it with some high temp exhaust paint!!!
__________________
Old 26-01-2010, 06:29 AM   #172
M K
M K's Avatar
Trader Score: (8)
M K is on a distinguished road
Send a message via MSN to M K
heated screens and washer jets are a godsend in this crappy weather we are having,
i just retro fitted the screen and jets to my escort mk6 but its simple plug and play thank god lol
great work mate
__________________
M K is offline   Reply With Quote
Old 26-01-2010, 06:18 PM   #173
dingla rs
dingla rs's Avatar
Trader Score: (1)
there lota trick wiring hear fella lol ,wish i had a clue bout wiring i could do me focos then you just puting st170 clocks in then or dash?
__________________
loysport
Old 26-01-2010, 08:57 PM   #174
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Just the clocks and the guages is the plan. A focus dash would never fit!!
Might fit a fiesta mk6 dash one day for a change.
__________________
Old 26-01-2010, 09:07 PM   #175
cossiejsy
cossiejsy's Avatar
Trader Score: (0)
looking very nice mate
__________________
Old 26-01-2010, 09:19 PM   #176
dingla rs
dingla rs's Avatar
Trader Score: (1)
alota people say never but i not heard that word lol
__________________
loysport
Old 27-01-2010, 01:55 AM   #177
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
its too wide mate. Im sure i could hacksaw it but it would look wrong.
__________________
Old 27-01-2010, 02:52 AM   #178
stephen osbourne
st170steve
Trader Score: (0)
stephen osbourne is on a distinguished road
warren best puma i have seen yet. hope all goes will.
stephen osbourne is offline   Reply With Quote
Old 03-03-2010, 06:27 AM   #179
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Just a minor update!
Removed all the annoying stickers from the side:
and the rear window.
looks much better now its not a pumaspeed moving advertisement!!! Just need to polish out the edge marks.
Also had the tracking done and while it was in the air took a few photos! This is of the rear beam box mounts which you can see have been totally fabricated from scratch!!
The fuel filter:
I might replace the mount with a new painted one at some stage just so i dont have problems in the future.
This is the fuel pump mount built into the tank. this is going to change with a better metal clip attachment and also i will be tidying the hoses and wiring up as its just messy really.
You can see here how far back the tank extends and the fact it needs a clean and polish!! there is a bit of bufty in me yet!!
And here is the front anti-roll bar mounts which have been modified and strengthened as its just the rear of the subframe on a normal puma.
once the weathers a bit better i shall wire wheel the underside and redo the paint and under seal so it does rust away over next few years!!
__________________
Old 06-03-2010, 03:12 AM   #180
JamesXP
Trader Score: (0)
JamesXP is on a distinguished road
Send a message via AIM to JamesXP Send a message via MSN to JamesXP Send a message via Skype™ to JamesXP
animal project, looks mean.
__________________
Focus 1.6
JamesXP is offline   Reply With Quote
Old 06-03-2010, 05:31 AM   #181
turbotoaster
turbotoaster's Avatar
Trader Score: (0)
turbotoaster is an unknown quantity at this point
Send a message via MSN to turbotoaster
looks like im gonna have some late nights on this with you in the next few weeks dude, we need to start sweet talking that old lady to borrow her garage i think, work your charms buddy!
__________________
It's a basic truth of the human condition that everybody lies. The only variable is about what!
turbotoaster is offline   Reply With Quote
Old 07-03-2010, 04:00 AM   #182
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
mate ive got a spade and petrol can plenty of places in the country side to hide the body
__________________
Old 07-03-2010, 09:23 AM   #183
LINCOLN
Trader Score: (1)
LINCOLN is an unknown quantity at this point
Look great w/o stickers.
Great patience and attention to detail
LINCOLN is offline   Reply With Quote
Old 20-03-2010, 06:45 PM   #184
ballin
ballin's Avatar
Trader Score: (1)
ballin is an unknown quantity at this point
never knew your car was this awesome looking!!!!
__________________
--- cheeRS, Rich
ballin is offline   Reply With Quote
Old 20-03-2010, 07:40 PM   #185
massivewangers
massivewangers's Avatar
Trader Score: (0)
massivewangers is on a distinguished road
Send a message via MSN to massivewangers
Just read through all this. Impressive stuff. I've seen another one of PS' ex-demo cars and that was just full of bodges too; must be a theme!
Cars looks awesome though I must say, and only up the road from me! I have to ask though, how do you afford it as a student? What and where you studying out of interest? My student budget certainly isn't stretching to anything that exciting
I've been thinking of getting a Puma for a bit of a track-hack, as they seem to cost pennies at the moment. Probably be left fairly standard initially, but I do love the look of the big arches. Obviously you didn't have a hand in the build up of the shell, but what's the quality like of the arch kit? I've seen a couple of FRP replica kits advertised, and the S1600 style kit you've got from PS, just wondering if it's nice quality, as if I had one, that would be a big temptation!
__________________
Q. What's the difference between a Saxo and a porcupine?
A. The pricks are on the outside of a porcupine.
massivewangers is offline   Reply With Quote
Old 01-04-2010, 03:10 AM   #186
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
I was earning over Ł50k PA when i bought the car not any more though! Hence most of what gets done is relatively cheap stuff at moment. alarm modules, tins of paint, wiring, odd bushes etc are all few quid here and there.
been really busy of late with moving house, uni and breaking down!! LOL!! So not done much really.
Fuel pump died so replaced that and decided to cut out the old wiring and wire in a new fuel pump wiring loom complete from battery to pump.
Cutting out the grotty old stuff:
Made up my own new loom and luckily had a new uprated pump to be fitted eventually anyway so this repair has cost me nothing but time:
Also been manufacturing a couple more loom bits and bobs. This loom is for fitting my speed sensor and refitting the ford crank sensor ready for my focus dash:
Unfortunately 3rd gear has died and my box sounds like a bag of spanners!!! So over next week or so i need to pull it out and send it off to a guy i know at Quorn Car Services for a strip down and rebuild (if worth it).
While its out i think i shall do some underside painting. I'll have access to the tunnel so will paint that and also heat wrap the exhaust down pipe while its off and if i can find some heat proof tape, may fit some to the footwell where the exhaust goes by.
__________________
Old 02-04-2010, 06:36 AM   #187
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
done some more bits tonight.
I wanted a bit more flexibility on my alarm wiring so i can feed it through the dash better. The ford convoluted tubing i was using before was too rigid so ive stripped the loom down to wires and replaced it with braiding and heatshrink so ive now got more flexibility.
Ive also decided to refit one touch windows which i did for my previous pumas, so have got hold of the relays off a mondeo and started to prepare sublooms for that.
Each relay pair has been bonded together and 3m tape attached so they can be fitted behind the door card in the space that already exists.
__________________
Old 05-04-2010, 12:35 AM   #188
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Done a few more bits and bobs.
On all my Puma's ive had before i had "one touch" windows by adding the one touch relays from a mk 1 mondeo.
In effect if you look in the puma wiring diagram above, all that is being done is to put the relay into the motor wires, one relay for up and one for down and then a power feed taken for the relay and an earth using existing power supply and earth.
You have to do this for each side of the car:
Ive decided to do this loom as a plug and play loom so no cutting the car loom and less hassle down the road so ive needed to get some connectors so ive got these:
Also the male connectors i need for the window switch plugs are not available as seperate connectors so ive got two old window switches from the scrappy to strip down and use as connectors.
Strip the innards of the switches down to access the contacts which will be soldered to later on.
Made the looms up using the wiring diagrams above:
Im sure it could be easily adapted to fit other fords as all it needs is power supply and earth and to feed into the motor wiring.
__________________
Old 05-04-2010, 06:34 AM   #189
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
finished the second loom:
hope to get the gearbox out in next couple days!!!
List of things to do while cars off road:
remove gearbox - send off for rebuild
wrap exhaust down pipe
derust and repaint transmission tunnel while its empty!
derust and repaint both prop shafts
derust and paint gearbox cradle
fit some heatshield tape to footwell and tunnel.
derust backbox and repaint.
refit repaired backbox heat shield.
fit turbo heat shield.
fit a few electronic looms and gadgets
clean the thing
__________________
Old 05-04-2010, 08:11 AM   #190
melinamotor
Farpylee
melinamotor's Avatar
Trader Score: (0)
melinamotor is on a distinguished road
Looking good mate, still remember ogling this parked next to my FRP at FF a couple of years ago, it certainly attracted some serious attention. Good work
melinamotor is offline   Reply With Quote
Old 07-04-2010, 10:05 PM   #191
P412KER
P412KER's Avatar
Trader Score: (0)
P412KER is on a distinguished road
P412KER is offline   Reply With Quote
Old 07-04-2010, 11:31 PM   #192
focus 4x4
focus 4x4's Avatar
Trader Score: (0)
focus 4x4 is on a distinguished road
Excellent progress Warren - keep us updated with the progress on getting the focus clocks to work!! ;o)
focus 4x4 is offline   Reply With Quote
Old 27-04-2010, 11:27 PM   #193
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Well finally got round to sorting the gearbox!
First was the nightmare of removing the old box, which included total removal of exhaust, seats, lowering subframe amongst others
Finally it was off so could compare to the new box:
First obvious difference is the reverse switch:
The second was on the bit that attaches to the prop:
So the bolt frame had to be removed:
Then it was cut to length:
While the box was out, it made sense to inspect the tunnel to see if it needed painting:
The tunnel was then derusted, primed with anti-rust primer and then painted!
Decided to do the same to the exhaust with high temp exhaust paint!
The exhaust was then refitted!
All tested and gearbox seems to be fine!!
Now for the juicy pic! Heres the damage inside the old gearbox:
__________________
Old 28-04-2010, 05:11 PM   #194
CozzyKing
CozzyKing's Avatar
Trader Score: (2)
CozzyKing is an unknown quantity at this point
Send a message via MSN to CozzyKing
Good to see that you had got the car back on the road last night and to have chat again, hope you enjoy driving it now that it is back together.
CozzyKing is offline   Reply With Quote
Old 28-04-2010, 05:33 PM   #195
A16X_TM
Trader Score: (0)
i seen this yesterday when i was on my way home from alton towers, you fixed your front number plate back on properly yet??
Old 28-04-2010, 07:31 PM   #196
Rab
Fucking superstar........
Rab's Avatar
Trader Score: (0)
Rab is on a distinguished road
Send a message via MSN to Rab
Warren were you WE? You seem to be fucking skilled with the wiring shit mate.
__________________
Rab is offline   Reply With Quote
Old 28-04-2010, 07:39 PM   #197
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Quote:
nah, it conveniently "fell off"
Quote:
No mate, was AE then later warfare.
__________________
Old 28-04-2010, 10:22 PM   #198
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Left the car at K&M acoustic place for some security work. And by mid morning it looked like this:
And you can see how much my carpets been cut down when you consider the original is a one piece carpet!
One thing slightly worrying in the loo though:
__________________
Old 28-04-2010, 11:36 PM   #199
A16X_TM
Trader Score: (0)
k&m in wigan?
Old 29-04-2010, 12:34 AM   #200
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
yeah
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Escort cosworth rear bumper fix? Ninosv Ford Escort RS Cosworth 2 01-03-2008 11:50 AM
can you fix way to fix a dripping radiator? Gra General Car Related Discussion. 6 07-02-2007 09:09 PM
cosworth diff problem who can fix ? Doug General Car Related Discussion. 9 05-03-2006 10:32 PM
quick questiona about starting a restoration job Gra Restorations, Rebuilds & Projects. 3 13-04-2005 06:55 PM
4x4 Cosworth Restoration - advise please.. boostman Restorations, Rebuilds & Projects. 2 23-02-2005 09:45 AM
