PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 09-08-2009, 01:15 AM   #81
warrenpenalver
Puma Nutter!!!
warrenpenalver's Avatar
Trader Score: (3)
warrenpenalver will become famous soon enoughwarrenpenalver will become famous soon enough
Send a message via MSN to warrenpenalver
While im sorting out various bits and bobs ive decided to start my digital dash wiring plans. Ive had to put my "3 button remote" conversion on hold as im struggling to find a second hand mk4 fiesta/early puma alarm module as my local scrappys only seem to have base spec fiestas with no alarm system!!!!
anyhow.... i have aquired a digital dash from a late puma:
And the connector with it:
I also want to try and fit this:
An ST170 focus dash!! Same level of technology and uses same kind of data inputs as the puma digital dash so i should be able to make it function. Primarily want it for the 160mph clocks and the fact its different!! Also going to rewire the dash illumination to utilise the dash dimmer switch from the focus.
Looking at the focus plug:
its simple computer pins and socket technology in the connectors so easy to connect up once ive done the wiring diagrams i need.
Ive got some pin strips for the loom:
and some connectors for the plugs:
__________________
Medically Discharged!! Officially insane!!!
My Project Thread: http://passionford.com/forum/restora...e-job-fix.html
warrenpenalver is offline   Reply With Quote
Old 09-08-2009, 09:00 AM   #82
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Wow ive just read all the way throught this thread.Top work and loving the puma.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 11-08-2009, 12:58 AM   #83
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Well i been working out some of the wiring for my dash.
This is the 2 connectors on my current loom:
I have worked out all the pin functions and stuff i need to transfer accross and labelled each function.
Ive then done the same on the puma digital dash plug:
Labelling all the functions then transferring across functions i already have on analog loom so i know which pin to connect to which and where new wires need to be made into my loom.
Ive done the same on the focus plug:
Next step is to turn them into loom plans and get some spare connectors to hack up!!!
__________________
Old 18-08-2009, 10:03 PM   #84
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Well ive finally finished the wiring diagram to run a puma digital dash in an analogue car!! So just the loom to make, then send it to a guinea pig with an early car to test it (my car doesnt have speed sensor as standard and i dont want to fit a part if there's fundamental flaws with my plans, where as a normal car theres no permenant changes).
first of all i need to make a plug to go into analogue loom plugs. These are not available as they are an integrated part of the dash clocks so ive made my own using 2 sided copper clad board.
First i cut rough shapes then filed them down to fit:
Then tweaked them to fit the connectors:
The next stage is to separate the individual pins which i can do with a cutting wheel on my dremel (the quick easy way ) or by buying etch resist pen and acid etching the board, proper PCB style like i was taught years ago!!! Not made my mind up yet!!! I might just use cutting wheel for the prototype and if its something people want me to make for thier cars then i might then do it properly!!!
This is the wiring diagram!
Also been checking a few bits and bobs ready for MoT and getting the car back on the road.
__________________
Old 19-08-2009, 03:47 PM   #85
focus 4x4
focus 4x4's Avatar
Trader Score: (0)
focus 4x4 is on a distinguished road
Quality!!!
focus 4x4 is offline   Reply With Quote
Old 19-08-2009, 09:03 PM   #86
Moonstone Mart
Trader Score: (1)
Moonstone Mart is an unknown quantity at this point
thats some quality wiring design and knowledge Warren!!
Good work.
Mart.
__________________
Check out my 2WD sapphire Cosworth resto thread right here >>>>
http://www.passionford.com/forum/viewtopic.php?t=297533
Moonstone Mart is offline   Reply With Quote
Old 20-08-2009, 03:10 AM   #87
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Attacked the connectors with the dremel tonight!!!
Cut them a bit shorter and seperated each track on both sides:
Fits fine into the connector leaving me space to solder the wires on:
as you can see i have good contact on the tracks from the connector:
Also found an interesting part today. Im looking to fit a part from a range rover sport to my car for ultimate bling factor
this is it:
Notice the similarity between the ford equivilent:
Been doing more work on the focus dash conversion plans too. Its getting a bit more complicated now as i need to fit the trip computer module and also need to work my head around the Standard Coorporate Protocol BUS that comminicates between the dash and the ECU so i can get speed, tacho and engine temp feeds!!!
This is the sort of stuff ive been getting my head round:
Quote:
Ford SCP message construction
Message byte # Description
1 Upper nibble is message priority, low number is high priority.
Lower nibble is message type (see next table).
2 Destination address, physical or functional.
3 Source address, physical address of the node that transmitted the message.
4 - 11 Message data, if present.
12 (or last byte) CRC byte.
Ford SCP Message Types
Message Type Description
0 Function message.
1 Broadcast, a type of functional message.
2 Function query.
3 Function read.
4 Node - to - Node. A physical message.
5 BCC access.
__________________
Old 20-08-2009, 07:25 AM   #88
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Wow your a clever man.I hate wiring.
__________________
Old 22-08-2009, 03:06 AM   #89
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Been doing a bit more wiring diagrams tonight.
Finished the focus wiring loom to fit ST170 dials to an analogue dash puma. These are better as they come with a separate oil pressure/temp guages which will save me fitting expensive ones!!
ive had to go onto 2 pages with these diagrams due to the complexity:
Still a few bits to be worked out before i can begin to make the loom. First of all i need more info on the workings of ford's EECV and the SCP databus!!! on the focus and other EECV cars, the ECU feeds the digital dash with various info via the SCP databus. On the Puma, the databus is not connected to the dash (even on the digi dash cars) so i have concerns on if the SCP databus is able of communicating with the dash or not. The databus on the puma only feeds the Data Link Connector for diagnostics purposes, so i need to find out if the ECU requires another wire feed to "trigger" the databus.
The joy of a databus is once ive got the databus live, then it doesnt matter that its only the dash sending info requests as the ECU will just respond with the required information or an error code if theres a problem.
But i wont really know this until i get to play with it properly once a prototype loom has been made.
__________________
Old 22-08-2009, 12:18 PM   #90
dingla rs
dingla rs's Avatar
Trader Score: (1)
dingla rs is on a distinguished road
omg hw the hell u work that lot out ,u sum kinda wire wise lol
dingla rs is offline   Reply With Quote
Old 22-08-2009, 05:50 PM   #91
focusjohn
St.
Trader Score: (0)
focusjohn is an unknown quantity at this point
If that works your officaly a genius as well as a nutter lol.
focusjohn is offline   Reply With Quote
Old 22-08-2009, 07:36 PM   #92
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
most of its quite simple really, you just have to be very systematic, work out what each function is on your current dash, what each function is on new dash and match accordingly.
the difficult bit is that some outputs are supplied differently so you need to work around that. eg speedo being on a cable or speed sensor on early/late puma but being based around a speed sensor output down a databus on the focus!
__________________
Old 22-08-2009, 08:13 PM   #93
parcs
parcs's Avatar
Trader Score: (0)
parcs is on a distinguished road
Send a message via ICQ to parcs
From the amazing quality of work shown in this thread; I think you may already know that a nibble is 4 bits and a byte is 8 bits. I have been in the computer analysis business for 42 years and it has probably been 30 years since I have heard anyone refer to a nibble. So I thought I should say something just in case.
parcs is offline   Reply With Quote
Old 23-08-2009, 01:03 AM   #94
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
lol parcs. Im hoping i dont have to get anywhere near actually doing any programming. Im hoping to be able to use the SCP databus without software changes. But we shall see.
Well i bought myself some wire today!!!!
__________________
Old 23-08-2009, 03:16 AM   #95
focusjohn
St.
Trader Score: (0)
Pardon me for sounding thick its all the same colour?
Old 23-08-2009, 08:12 PM   #96
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
yeah it is Im not buying like 22 reels of wire to get the colours i want.
__________________
Old 23-08-2009, 09:06 PM   #97
focusjohn
St.
Trader Score: (0)
Quote:
Have fun then iuve tried that before and its confusing. Id sugest buying trailer board cable cheap and has 12 different colour inside it.
Old 23-08-2009, 09:46 PM   #98
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
I just do 1 wire at a time so theres no confusion.
__________________
Old 24-08-2009, 03:36 AM   #99
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
done a bit of soldering tonight!!
double insulated everything, first with heatshrink:
then with tape to finally seal it in and hold the shape.
__________________
Old 24-08-2009, 04:34 PM   #100
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
fitted the new tyres ive had for a while:
__________________
Old 25-08-2009, 12:03 AM   #101
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
well ive finished the prototype loom for the puma dash:
its not as tidy as i want it to be but is fine for a prototype. Id do a couple of things different when i make another and probably put nice braid and stuff over it to make it look nice but otherwise its basically same.
__________________
Old 25-08-2009, 01:13 AM   #102
Mister G
Trader Score: (0)
Mister G is on a distinguished road
Awesome project, hats off for attempting the wiring! I had an escort once where somebody had actually twiddled together the wires and taped them to the bottom of the fuel tank with gaffa tape. I was shocked when I saw it!
__________________
_____________________________
'90 Orion Equipe Mk2 2.0 Sleeper project
'96 Escort RS2000 - A/C
--Previously---
Fiesta Mk6 'The Lady', Mk3 Fiesta, 3x XR3i's '06 Ink Blue Mondeo STdci, '89 Orion 1600E, '90 Orion Equipe x2, Fiesta RS1800
Mister G is offline   Reply With Quote
Old 26-08-2009, 12:39 AM   #103
Moonstone Mart
Trader Score: (1)
Nice work Warren.
__________________
Old 26-08-2009, 01:16 AM   #104
lanfire
lanfire's Avatar
Trader Score: (0)
lanfire is an unknown quantity at this point
them clocks are going to be very cool when there all working is there much of a size difference to the clocks? or does it just fit straight in the puma dash?
__________________
2.1 Zetec Turbo - Now on the road and been run in !
lanfire is offline   Reply With Quote
Old 26-08-2009, 08:21 PM   #105
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
The focus clocks are very similar sized but slightly wider at the corners but i should be able to fit them anyway or trim a little bit of plastic.
today i decided to pull out my idle control valve for a bit of a clean!!
__________________
Old 27-08-2009, 10:06 AM   #106
Jackstrath
Trader Score: (0)
Jackstrath is on a distinguished road
i love the look of these! ,and the fact yours has a cossy in it is ace! , must go like stink! , some scary bodges there tho!
Jackstrath is offline   Reply With Quote
Old 02-09-2009, 11:33 PM   #107
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Ive finished another wiring diagram!
This one is for me to be able to fit a 3 button remote alarm module to an early 2 button IR remote alarm car.
__________________
Old 03-09-2009, 12:12 AM   #108
CarbonRick
PF Village Idiot
Trader Score: (0)
CarbonRick is an unknown quantity at this point
Send a message via MSN to CarbonRick
Lookin good mate. Keep it up!
__________________
CarbonRick is offline   Reply With Quote
Old 03-09-2009, 01:28 AM   #109
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
Well been doing a little bit of minor fiddling and MoT checks.
Been looking at my ISCV and i still cant work out how this hole gets sealed by the ISCV plunger??
Also been playing around with my rear struts. Thought id have a look at the rear mounts to see whats what for when i get round to replacing them.
As far as i know thats a mk2 escort rear top mount assembly!!
__________________
Old 03-09-2009, 07:49 AM   #110
lanfire
lanfire's Avatar
Trader Score: (0)
JESUS ok that rear strut is not good !!
__________________
Old 03-09-2009, 11:09 AM   #111
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
why is it not good?? its structurally soundand is braced in the corner with reinforcements.
The only concern i have is its a potential place for rust to form being unprotected from spray plus the fact ive got different dampers front and rear which is pain in the arse for replacing things!!
I'll probably get cossie rear turrets fitted over winter so i can fit the longer escos rear coilovers so it all matches up and cheaper to replace in future. Will probably need the rear of the inner arch extending a bit so that i can avoid contact between coilover and inner arch. (which is probably why it was done this way in first place.)
__________________
Old 03-09-2009, 11:33 AM   #112
Lee_R21Turbo
Trader Score: (1)
Lee_R21Turbo is an unknown quantity at this point
I think he means the big chunk of metal missing in the top spring carrier - unless its supposed to be like that??
Fair play for all the wiring mods - very impressive stuff!!!
__________________
Lee
'Just Modify It'
Renault 21 Cosworth, Volkswagen Bora Daily Drive, Renault Clio 172 Track Toy
Lee_R21Turbo is offline   Reply With Quote
Old 03-09-2009, 11:51 AM   #113
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
that metal is meant to be missing. I think its so you can remove it when disassembled. Even the pics of similar gaz coilovers show the same.
see:
__________________
Old 03-09-2009, 07:53 PM   #114
e30cossie
E36 cosworth
e30cossie's Avatar
Trader Score: (0)
e30cossie is on a distinguished road
Keep up the good work warren. I have always liked this car and in my opinion it is in the top 10 cars on passion ford.
e30cossie is offline   Reply With Quote
Old 03-09-2009, 08:14 PM   #115
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
thanks LOL although at the moment it also has the top ten bodges on passionford too
__________________
Old 03-09-2009, 08:18 PM   #116
focus 4x4
focus 4x4's Avatar
Trader Score: (0)
Cant wait to see the clocks all finished and working!!
P.S watch out for the leaks in those Gaz shocks!
Old 03-09-2009, 10:39 PM   #117
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
those arent my gaz shocks in the pic just a google robbed pic!!!
My car has AVO's at present. i thought AVO's are worse than Gaz or are they all just as bad as each other??
__________________
Old 03-09-2009, 11:26 PM   #118
lanfire
lanfire's Avatar
Trader Score: (0)
yes i was meaning that hehe, iv not seen top cups like that, you learn something new everyday
__________________
Old 11-09-2009, 08:20 PM   #119
J98 FYA
J98 FYA's Avatar
Trader Score: (0)
J98 FYA is on a distinguished road
x th3 hollow x
any update on this warren u electrical whizz
J98 FYA is offline   Reply With Quote
Old 18-09-2009, 04:26 PM   #120
DanCossie
Post Whore
Trader Score: (1)
DanCossie is an unknown quantity at this point
Warren.....Do you want to sell me this as it is ??? Genuine Question Mate
DanCossie is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Escort cosworth rear bumper fix? Ninosv Ford Escort RS Cosworth 2 01-03-2008 11:50 AM
can you fix way to fix a dripping radiator? Gra General Car Related Discussion. 6 07-02-2007 09:09 PM
cosworth diff problem who can fix ? Doug General Car Related Discussion. 9 05-03-2006 10:32 PM
quick questiona about starting a restoration job Gra Restorations, Rebuilds & Projects. 3 13-04-2005 06:55 PM
4x4 Cosworth Restoration - advise please.. boostman Restorations, Rebuilds & Projects. 2 23-02-2005 09:45 AM
