PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-04-2009, 08:45 PM   #1
Ebonycossie4x4
Ebonycossie4x4's Avatar
Trader Score: (4)
Ebonycossie4x4 is an unknown quantity at this point
Send a message via MSN to Ebonycossie4x4
Default Here We Go Again.... Strip down Commences. Smokestone K Plate
Right.
ive quickly got fed up with the timewasters and messers bidding me down constantly on this car, so ive decided to keep it (for a while) and buy my escos when i have enough money from other means.
In my opinion its the best colour and its a reasonably tidy shell (a good base to start from anyway) so im going to sort the problems.
This is not going to be a big money project and although im mechanically competent i am no wizz when it comes to a set of spanners!
I do however have a big double garage with adequate lighting and time on my hands.
So lets get going.
Right. The issues.
BLUE SMOKE ON BOOST!!!!
Annoying the hell out of me and extremely embaressing.
I wont go into other niggly problems until this problem is atleast diagnosed.
Tonight i started stripping down.
heres the car.
Heres The Bay
All comments welcome.
Whos betting im going to see a puddle of oil when i lift the head off....
__________________
2011 Mercedes C220D Sport In Essex Boy White!
360 Gamertag is Robbo Fandango
Glad to be Back Viewing you in 27inch I7 Imac Greatness.
Ebonycossie4x4 is offline   Reply With Quote
Old 20-04-2009, 08:47 PM   #2
Ebonycossie4x4
Trader Score: (4)
heres whats happened tonight.
This is a gasket apparently...
heres the head so far.
And heres how we are left tonight
Ive hit a stumbling block as i cant get head off as its weird socket star key thing.
Anyone know what i need to buy asap so i can get head off tommorow.
__________________
Old 20-04-2009, 09:10 PM   #3
timster
Trader Score: (0)
timster is an unknown quantity at this point
It is the correct gasket but when you refit put some sealer either side of the seals to hold them in place when re-fitting the rocker cover.I know they're torx on them can't remember the size though.Haven't done a cossie head gasket for over five years.Hopefully someone on here will help you out
timster is offline   Reply With Quote
Old 20-04-2009, 09:18 PM   #4
Ebonycossie4x4
Trader Score: (4)
Cant be correct gasket as it really wasnt a gasket lol....
Just looked like orange mastic.
Thanks for the input, i thought it was gonna be normal bolts but torx bits instead.
maybe if i go to halfords and get a set.
Anyone with some help would be good.
__________________
Old 20-04-2009, 09:25 PM   #5
cossie*mad!
Fucked On Race Day!!
Trader Score: (0)
cossie*mad! is an unknown quantity at this point
Blue smoke on boost - I take it youve inspected the turbo for seals gone / play in the shaft before trying to take the head off? It would smoke all the time if it was the rings gone surely...not just on boost (that was my symptoms anyway)
__________________
WHEN THE FLAG DROPS, THE BULLSHIT STOPS.
cossie*mad! is offline   Reply With Quote
Old 20-04-2009, 09:27 PM   #6
timster
Trader Score: (0)
Shit thats bad Just surfing the net to see if i can find any info on the torx size.The orange seals you can still get from fords or any of the traders on here
Last edited by timster; 20-04-2009 at 09:31 PM. Reason: better description of part
Old 20-04-2009, 09:34 PM   #7
Ebonycossie4x4
Trader Score: (4)
there is tiny side to side shaft play in the turbo but nothing major.
im pretty sure that it can be piston rings and not smoke until on boost.
The main aim is to whip the head off and inspect as best as i can for valve guide issues. Or take to Joe and ask him (pay Him) to give me the low down.
Also once ive got head off have a look at pistons and bore etc etc. see if oil is in chamber above pistons.
Then rebuild bottom end lol....
Not going mega though.
This is budget build as money is saving for escos.
__________________
Old 20-04-2009, 10:57 PM   #8
C8SEE
Trader Score: (2)
C8SEE is on a distinguished road
Did you try putting on a breather system?
C8SEE is offline   Reply With Quote
Old 21-04-2009, 12:41 AM   #9
AJC
Lord of Longridge
Trader Score: (4)
AJC is an unknown quantity at this point
Andrew Cross fuck twitter wtf M400 AJC
Send a message via MSN to AJC
good to see another getting some tlc
__________________
Cheers, Andy
11.93 1/4 mile @ 116.9mph - Santa pod
Lancashire RSOC Group Chairman
AJC is offline   Reply With Quote
Old 21-04-2009, 07:32 AM   #10
Ebonycossie4x4
Trader Score: (4)
spoke to lots of people that said breather system will make no difference as its only stag 3 running 20 psi.
When cold it fills the road behind with blue smoke, This is not just a little bit. I like the car its reasonably clean so i thought why not.
Saves another one from the breakers.
Have got 4 days off so i will be updating the thread a lot hopefully.
i dont know whether to hope for valve guides or rings....
Rings means ive gotta take the engine completely out and i cant say i fancy that lol...
__________________
Old 21-04-2009, 07:45 AM   #11
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Good luck with it mate
Brian
__________________
Brian is offline   Reply With Quote
Old 21-04-2009, 01:54 PM   #12
Ebonycossie4x4
Trader Score: (4)
Right quick update.
head is now off and waiting to go to GS Motorsport. To be honest i cant really see any problem other than it being a bit coked up on the bottoms of the valves.
Have some pics that i will share later.
__________________
Old 22-04-2009, 09:36 PM   #13
RST
RST's Avatar
Trader Score: (2)
RST is an unknown quantity at this point
Send a message via MSN to RST
Good luck with it mate keep the pics coming.
__________________
RST is offline   Reply With Quote
Old 22-04-2009, 09:44 PM   #14
hai07222
Trader Score: (0)
hai07222 is an unknown quantity at this point
As said above, nice to see another one being kept alive. Good luck with it
__________________
hai07222 is offline   Reply With Quote
Old 22-04-2009, 09:46 PM   #15
Robs Frst
Robs Frst's Avatar
Trader Score: (0)
Robs Frst is an unknown quantity at this point
Nice to see 1 getting looked after, good luck
__________________
Evo 6 - 410 Bhp
Ford Puma - Sold
Robs Frst is offline   Reply With Quote
Old 23-04-2009, 03:45 AM   #16
TurboShed
Cossiemodo
TurboShed's Avatar
Trader Score: (0)
TurboShed is an unknown quantity at this point
I'll give you Ł400 and my Corsa for it
Yes nice to see another getting looked after. I'm currently scrapping a rotten one, and reshelling into a lovely straight car, top banana, just wish it wasn't taking so long
__________________
TF2 name TurboShed - 2Fort only servers usually.
Left4 Dead - TurboShed - I hate zombies!
TurboShed is offline   Reply With Quote
Old 24-04-2009, 07:41 PM   #17
Ebonycossie4x4
Trader Score: (4)
picking up my escos shell in the morning so looks like this shell is going to be redundant.
Will update with pics in the morning.
Engines out and head is with joe already. he will be receiving bottom end soon too.
Looks like its going to be a long one though lol.
Take my time and make it a real nice one.
hoping for maybe realistic 450hp in the long run...
__________________
Old 04-05-2009, 08:52 PM   #18
Ebonycossie4x4
Trader Score: (4)
Right...
Escos deal didnt come off due to seller being just too unreasonable for me.
Anyway onwards and upwards...
Head is out the car and stripped. Found head to be in a good condition and far too cleaning leading us to beleive that someone had already been up that garden path. So i got back from joes and started stripping the bottom end out.
bottom end is out and sump is off...
I found a quarter of a rubber glove and loads of like masticy rubbish all stuck to the pick up pipe...
What is it with me and cossies. Gotta stop buying cheap ones.
I dont want to go spending thousands on it and joe being the kind of guy that he is has said that i can do as little or as much myself as i want.
im now just going to go for a nice usable stage 3 build so i dont think i will even be going low compression.
honestly cannot praise GS Motosport enough, So understanding and Joe is a top Bloke...
Will grab some more pics when i can. Car is currently looking very sorry for its self in my garage.
Anyone know where to get the bits of the front wings that the bupper attaches too as they are quite rusty and ive heard you can buy them rather than new wings.
Rob
__________________
Old 04-05-2009, 09:00 PM   #19
RONNIE AMIS
RONNIE AMIS's Avatar
Trader Score: (16)
RONNIE AMIS is on a distinguished road
good luck with it mate, joe is very good aint he, he doesnt get as much praise as he deserves i think
could go the breakers and cut some bumper mounts off couldnt u?
RONNIE AMIS is offline   Reply With Quote
Old 05-05-2009, 07:34 AM   #20
Ebonycossie4x4
Trader Score: (4)
Thanks Ron...
No he does not get the praise he deserves. I wish i could get the engine built by him but just cant warrent going the whole hog on it until i get something nicer.
I suppose i could go to the breakers but i need to find a breakers with a sierra and that aint as rusty as mine are lol.
Good idea though, ill give it some thought.
__________________
Old 07-06-2009, 09:12 AM   #21
Ebonycossie4x4
Trader Score: (4)
Right well i better resurect this thread as work is starting to commence.
After yet another deal falling through its time to rebuild the engine for definate.
First and foremost i need to thank LambChop, I have bought near enough new pistons with new rings in fantastic condition in exactly the right size for Ł200.
The bottom end is 0.08 too large on cylinder 3 so block will be bored to 0.5 so i have bought .5 pistons.
Just bought multi layer head gasket and gasket kits, I dont know wether to go for the stud kit or standard head bolts. im going to be running about 26Psi and to be honest the car will probably be sold not to long after knowing me lol.
I have my escort turbo too so this thread will be slow going. I will update with pics as the bits arrive.
Im going to be running standard cams, T34 turbo, Standard compression, greens etc
if i wanted to max the turbo say 30psi I cant do that on standard head bolts can I?
Would i need light blues too?
Sorry about all the questions, Hopefully you guys can help as this is my first engine build.
Will update with pics soon.
__________________
Old 07-06-2009, 10:07 AM   #22
AquariousRS
AquariousRS's Avatar
Trader Score: (1)
AquariousRS is on a distinguished road
Send a message via MSN to AquariousRS
I belive NMS run standard head bolts on majority of there builds. Been quite a few debates on it on here if you do a search about it
__________________
Tim
For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys.
For all your stickers ~ Email stickerpaul@yahoo.co.uk
AquariousRS is online now   Reply With Quote
Old 07-06-2009, 12:35 PM   #23
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Top work mate.Im happy your sorting out and not just breaking the car.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is online now   Reply With Quote
Old 12-07-2009, 06:28 PM   #24
Ebonycossie4x4
Trader Score: (4)
Right well i really need to start getting on with this. Block is in getting machined to take the .5 oversize pistons.
Crank is also being balanced and cleaned as oil ways are full of orange shit that some idiot had put the rocker cover on with.
Spec is going to be very light mods as i just want a safe and reliable stage3 +
So
0.5 oversize genuine mahle pistons.
.5 Bottom end rebore
T34 Turbo
Standard Balanced Crank (no need to regrind)
ACL race Bearings
Standard Genuine Ford Head Bolts
WRC Multi layer headgasket
Arp Rod Bolts
Gp A timing Belt.
Head stripped and valve stem seals changed with valve guides checked and replaced as neccesary.
Me and a friend are doing this (im being brave) or tight one or the other, so wish me luck.
Have got all new gaskets and i am going to try and clean and paint all items before going back into car.
I expect it to be all done within a month.
I just hope i dont live to regret this. Curently the car owes me less than what it would sell for so its all good.
Still need to make the decision on keeping when its all done, I am looking forward to driving the first engine ive helped build....
At least i know when ive done it myself i atleast wont fill the sump up with half a rubber glove and orange mastic.
__________________
Old 12-07-2009, 06:51 PM   #25
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Well good luck mate.I hope after fitting all the seals that you dont have oil leaks.
__________________
Old 12-07-2009, 07:30 PM   #26
Ebonycossie4x4
Trader Score: (4)
should be ok, doing it with a good family friend thats probably built 50 engines, Its his second cosworth engine and hes just helping me along when i get stuck.
__________________
Old 13-07-2009, 10:33 PM   #27
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
good luck with your engine build ,your car looks well nice on them rims
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
Old 22-07-2009, 07:51 AM   #28
Ebonycossie4x4
Trader Score: (4)
Bottom end is now built and ready, As usual with me as we started to remove the valves from the head every other one we took out had knackered valve guides.
Loads of oil in there and the stem seals are fooked too. I have new stem seals but the head has now gone back to the machine shop to have the valve guides.
More money lol.
hope fully it will still go back in this weekend. Will have some pics when i get my camera back!
__________________
Old 22-07-2009, 08:37 AM   #29
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Good work mate i hope its all finished soon.
__________________
Old 08-08-2009, 06:18 PM   #30
Ebonycossie4x4
Trader Score: (4)
Well i got the engine back wednesday and ive been painting bits all week and bolting bits back to it.
Today i got it in there. Result.
Not running yet as i snapped the power steering pipe so i have one coming from a guy on here by wednesday.
The aftermarket fan wiring is here and its fantastic quality, will tidy up the bay so much.
Engine being built up, Its tidyer now but unfortunately im no bufty lol.
Engine being rolled in, So much easier this way, i will never take a cossie engine out from the top again!
And in the bay
Just the rad cooler power steering pipe and a few other pipes, Cable on starter motor battery on JOB DONE!
Run in MOT and on PH i think lol. What an effort...
Washed it too just love the colour when its clean.
Im so proud of being able to do it and not pay thousands to someone else.
This is a full rebuild with all new valve guides standard crank no need for grind Mint 500 mile pistons race bearings and new everything that was needed for well under 1K.
Lets just hope its fine and runs as nice as i hope it will lol.
Cheers Guys
__________________
Old 08-08-2009, 06:23 PM   #31
jonnyrsturbo
is half man, half amazin'
Trader Score: (0)
jonnyrsturbo is an unknown quantity at this point
looks nice that matey
jonnyrsturbo is offline   Reply With Quote
Old 23-08-2009, 01:21 AM   #32
cossimc
Trader Score: (0)
cossimc is on a distinguished road
Quote:
its a spline not a torx bit m8t
cossimc is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Smokestone 4x4 saphire rickslack Cars for sale 18 05-09-2007 06:37 PM
Stripping commences tonight Anonymous General Car Related Discussion. 22 31-01-2007 09:44 AM
K Plate Smokestone saff in Manningtree tonight?????????????? JAP CRAP General Car Related Discussion. 0 27-01-2006 12:47 AM
1992 K Plate Smokestone Blue 4x4 Saph *SOLD please remove!!* SmokeStoner Cars for sale 46 03-07-2005 06:11 PM
strip or not to strip?, that is the question bigmatt-s2rst Ford Escort RS Turbo 6 10-05-2005 12:17 PM
