YB rebuild after bearing failure update 16-04-09
Old 08-04-2009, 09:54 PM
coswurv
coswurv's Avatar
Default YB rebuild after bearing failure update 16-04-09
Right people after my Dilemma thread I decided to repair the engine, im not going for more power as I was happy with what she had, but I have added a bd14 inlet cam just for good measure !!, here's some pics of before and how it is now, hope you like,
Bro painting my bits
Going black inlet this tiem just to be different, think it will look good against the yellow,
Old 08-04-2009, 10:09 PM
hai07222
hai07222's Avatar
Looks great with a mix of yellow and black
Old 08-04-2009, 11:14 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
nice colour choice fella
can i have your bd 14 pleeeeeeeeeaseeee
beef
Old 09-04-2009, 02:14 AM
katers
katers's Avatar
loving the yellow mate!
Old 09-04-2009, 03:22 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Hope you have valve cutouts for the cam
Steve
Old 09-04-2009, 06:44 PM
coswurv
coswurv's Avatar
Steve
I have no cut outs but the pistons had the outer lip skimmed down a while ago, will this be enough ? head measures 138.8.
Old 09-04-2009, 07:22 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
No idea, would be best to check.
Steve
Old 09-04-2009, 08:07 PM
mk2rstaff
mk2rstaff's Avatar
what paint did you spray your gear with mate please????
Old 09-04-2009, 08:10 PM
KSA-Cossie
KSA-Cossie's Avatar
Good choice of colours m8.
Old 09-04-2009, 08:25 PM
col cos1
col cos1's Avatar
your pistons will be fine
Old 09-04-2009, 08:30 PM
Barry R
Barry R's Avatar
Was that colour straight off a scheme just the 1 tinter
That what i done some of my bits in last year looks lush
Wish i done the block aswell now
Old 09-04-2009, 08:34 PM
coswurv
coswurv's Avatar
Done some more today and layed a few bits on to get an idea of what its gonna look like, rocker cover has come up really well i think, should all look good once under the bonnet, wrapped the turbo and exhaust manifold also today which took ages to do and get right,
Old 09-04-2009, 08:37 PM
coswurv
coswurv's Avatar
Is this a definate, wont get any contact even at high revs with this inlet cam ?
Old 09-04-2009, 08:38 PM
Barry R
Barry R's Avatar
Wow it really does look the nuts
Damn I wish i painted more parts now
Simmo
Simmo's Avatar
I'm liking that... the yellow and black looks good!!!
Old 09-04-2009, 08:40 PM
coswurv
coswurv's Avatar
I used etch primer and then hammerite smooth black in aerosol
Yes mate its the tinter like you say, well bright
Old 09-04-2009, 08:42 PM
Barry R
Barry R's Avatar
Yes mate its the tinter like you say, well bright [/quote]
Its so bright the pics dont quite show how bright it really is it proper glows
I just done my crossmember in it
Old 09-04-2009, 08:48 PM
coswurv
coswurv's Avatar
Forgot to put the picks of the turbo up, all wrapped in thermo-tec black wrap, took 5 15ft rolls to do this, never again
Old 09-04-2009, 08:49 PM
coswurv
coswurv's Avatar
I just done my crossmember in it[/quote]
Yeah i know the camera cant handle it, definatley doesnt do the colour justice, you can get a suntan from it lol
Old 09-04-2009, 08:52 PM
Love the colours.I hope you have better look this time.
Old 09-04-2009, 11:03 PM
COLEYST200
COLEYST200's Avatar
these are my pistons when i got them back from MARTIN
Old 10-04-2009, 08:52 AM
mk2rstaff
mk2rstaff's Avatar
how come its all back together and now you got your pistons???
Old 10-04-2009, 12:54 PM
coswurv
coswurv's Avatar
Ay ??
Old 10-04-2009, 02:53 PM
-beefy-
-beefy-'s Avatar
if i was you mate id double check the piston to valve clearance before you run the motor ,
i wouldnt assume its going to clear ,
at least that way if it dont clear you can send it to me
for what it takes to check ,
cheaper then a new head thats for sure ,
beef
Old 10-04-2009, 04:55 PM
LHD220Turbo
LHD220Turbo's Avatar
as beef said, check the clearence, do a dummy build up with plasticine to make sure it clears
also, i assume you've got a breather pot cos i can see a hole in the cam cover - if you have you dont need to use the kidney box, get rid of it completely and just use an adapter from the block to the pipe of the breather pot ( http://cgi.ebay.co.uk/RS-Cosworth-Pi...1%7C240%3A1318 )
Matt
Old 10-04-2009, 05:12 PM
coswurv
coswurv's Avatar
Matt
Ok mate i did use it before but ill look into removing it all together this time.
Old 11-04-2009, 03:40 PM
andy escos
andy escos's Avatar
that looks well nice fella exhaust manifold looks very nice
Old 12-04-2009, 08:24 PM
coswurv
coswurv's Avatar
cheers for the good comments guys, has anyone got a set of verniers for sale ?
Old 12-04-2009, 08:28 PM
Barry R
Barry R's Avatar
If you get some verniers can i have the ones on it
The Youth.
The Youth.'s Avatar
I would remove the heat protective covering from the turbo as you need as much heat away from it as posible, if you leave it on the exhaust housing will crack!
the manifold will be fine just the turbo needs sorting.
steve
Old 12-04-2009, 08:30 PM
coswurv
coswurv's Avatar
yeah if you want, may need painting again though
Old 12-04-2009, 08:36 PM
coswurv
coswurv's Avatar
steve
Oh great now you tell me, ive seen loads of cossies with wrapped exhausts so not syaing you dont know what your on about but its done now and taking it all off would heart !!
Old 16-04-2009, 09:17 PM
coswurv
coswurv's Avatar
Little update, i recieved my new donar pistons today which im gonna use the gudgeon pins out of, there 1.6 pinto ones, i fitted one of the pins in my cossie rod and it fits perfect no play at all. They are ever so slighlty to big to fit in the piston so a tiny bit of honing to do then they should be a perfect fit aswell, crank, flywheel and pistons are going off tomorrow to be machined, so all i have to do at the minute is make some templates on the outside of the sump so i can have my ally welder friend turn it into a big winged sump, whilst i make the inetrnal gated baffles for it, should eliminate any further oil starvation and this happening again, wish me luck.
Old 16-04-2009, 09:24 PM
BigErn
BigErn's Avatar
Is the block and cam cover 2 different shades mate? When I did the cover in G454 I took a samco and got it colour matched. Looked pretty much bang on in the flesh.
Old 16-04-2009, 09:27 PM
coswurv
coswurv's Avatar
Ay up my old car lol, , No mate they are all painted with the same yellow out the same tin, samcos matched pretty well last time around with the cam cover when they were all cleaned up, so that will be another job on the list, was thinking of welding all the holes up under the bonnet and smoothing it all what you reckon ?
Old 16-04-2009, 09:41 PM
Barry R
Barry R's Avatar
You have a pm coswurv
Old 16-04-2009, 09:54 PM
BigErn
BigErn's Avatar
paul, it looks ok but not something I would do though.
Old 16-04-2009, 10:50 PM
-beefy-
-beefy-'s Avatar
paul you going for valve cut outs then fella ?
did you plastigauge the motor ?
beef
Old 18-04-2009, 09:01 AM
coswurv
coswurv's Avatar
beef
Im waiting for the pistons to come back then yeah i will build it up with 1 piston in and the old gasket and check for clearance, Ian what dont you like mate i thought you was a fan of the yellow
Old 20-04-2009, 02:51 PM
-beefy-
-beefy-'s Avatar
gd gd , nice to see you at the weekend mate m
let us know how u get on with them cams and gauging ,
beef
Quick Reply: YB rebuild after bearing failure update 16-04-09
