PassionFord
Welcome to Passion Ford!
Welcome to Passion Ford.
Thread Tools Display Modes
Old 28-04-2009, 09:42 PM   #41
Kev83
2.1 ZVH build underway...
Kev83's Avatar
Trader Score: (0)
Kev83 is on a distinguished road
Quote:
Originally Posted by fastrob xr2i View Post
I would check plugs, leads.
Which injectors are you using?
just running standard blues mate
Kev83 is offline   Reply With Quote
Old 28-04-2009, 11:01 PM   #42
Robs Frst
Robs Frst's Avatar
Trader Score: (0)
Robs Frst is an unknown quantity at this point
Quote:
Like I said mate on the Phone
Going to have to upgrade the injectors to reach the bhp figures you want.
also a Lsd gearbox will help alot.
Should be interesting to see where the car is now once you get it RR.
That way you know what to upgrade make sure the lump healthy.
__________________
Robs Frst is offline   Reply With Quote
Old 29-04-2009, 07:12 AM   #43
Kev83
Kev83's Avatar
Trader Score: (0)
yes mate for sure. found out an interesting fact last night. The beige injectors that you upgrade to on FRST are the same as what punto GT's have in as standard........how cheap!!!
Old 30-04-2009, 06:38 PM   #44
ram
Has a large member
Trader Score: (0)
ram
Send a message via MSN to ram
this is a great car mate i watched brammers resto thread of this car was done properly
as for injectors yeh beige 701's, there was a punto gt at my scrappy when i got mine, £15 quid lol. usually bout £70 on ebay
__________________
1.8ZVH FRST
MK4 cabby turbo
E36 328i vert on 19's
ram is offline   Reply With Quote
Old 01-05-2009, 08:03 AM   #45
Kev83
Kev83's Avatar
Trader Score: (0)
cheers ram mate. After speaking with few people, seems the beige ones will be on the limit with where im probably going to go with the car, so have to re-think on the injector front. As for the resto.....got a CD full of photo's of the restoration and i must say i was blow away with the level of detail that went into the car!! It was one of the deciding factors that changed my mind regarding stripping it out and making it into a track orientated car. As much as i would like to, i just cant bring myself to pull it apart like that.
It will be having a fresh engine dropped in however, and the chassis will be tweeked, but reagrding the interior and exterior, that will be being pretty much untouched. Its not ever going to be concours whilst own the car, as its just not my cup of tea, but the car will certainly be well looked after and will want for nothing as any of my cars have.
cheers
Old 01-05-2009, 10:24 AM   #46
Zetecfiesta
Trader Score: (0)
Zetecfiesta
Send a message via MSN to Zetecfiesta
still looks like a really good car!
Zetecfiesta is offline   Reply With Quote
Old 02-05-2009, 12:06 AM   #47
ram
Has a large member
Trader Score: (0)
ram
yeh mate beiges are maxed out at about 220bhp tops. im just running mine with these and a 195 chip on low boost as i cnt afford to get an ahmed chip and cossie injectors. would rather save up abit more and go full cossie management. what sort of chip & injectors you planning on running?
__________________
1.8ZVH FRST
MK4 cabby turbo
Old 02-05-2009, 07:16 PM   #48
Kev83
Kev83's Avatar
Trader Score: (0)
ram mate, going to go with either omex or pectel i think. However plans now changed.....read below mate
Old 02-05-2009, 07:30 PM   #49
Kev83
Kev83's Avatar
Trader Score: (0)
Thumbs down EPIC FAIL!!!
Right then, sent my car in this morning to be diagnosed, setup and replacement parts where required for its running issues. The bloke I took it to is local bloke, but has (had) a reasonable reputation. Gues there would be no harm in him having a look and seeing if he can work his magic......
Dropped the car off at 8.30 this morning, running fine albeit with it hesitation whilst of boost and idle problem. Left the car with him and told him to give me a shout once the car was ready for picking up. Anyhow heard nothing all day till i phoned him at half time ddring the united match (come on you reeeeeds). Said he had checked a few things but the ECU wouldnt let him in and he was purely using the exhaust probe to try and find the issue. No problem i though. Anyhow, come 4 o'clock, i get call to say he has done all he can and to come collect the car. Get to his garage, where he tells me he hasnt really been able to do a deal but has found the reason for the hesitation (lack of fuel on initial throttle response). Bit cheesed off really to say he has the car all day, but he only charged me one hours labour £45.69. Start the car, let warm up whilst disccussing possible solutions to the problem, then set off my way home. As i drive, its still flat at the bottom and delayed throttle response is still evident, but the boost problem seems to be sorted. Boosts nicely to 9psi in all gears HOWEVER, and i do mean HOWEVER!!! As i pull up to a set of lights i notice a touch of blue smoke at the back of the car.......hmmm wasnt ever there before, possibly the car next to me. Continue driving but keep noticing a nice touch of blue smoke coming out the back of the car Now, to say this in polite manner would be best, so here goes...
'WHAT A F&$£ING W@NKER'
Pulled up at my mates and told him to have a look out the back, car smokes slightly on tickover and more so when the car has been revved and is coming back down the revs
I can only assume that the muppet who took the car out has given it some cainage and somthing is letting go. Not had a feel of the shaft in the turbo yet for play, but im pretty sure its going to be seals gone in there
So as it stands now, the car is being taken off the road. Im going to be building a a new engine for it using the good old 2.0 zetec bottom end and the stage 3 head i have. Hopefully sorted the zetec block this afternoon, so going to make a start immediately.
Really gutted as things some to be going from bad to worse, but im not one to give up, and will make sure it gets everything it needs to be perfect again
Keep an eye out for updates
cheers, kev
Old 02-05-2009, 09:05 PM   #50
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
Trader Score: (0)
zetaboostboy522bhp is on a distinguished road
soz to hear about the car kiddo, but i think you will be needing the pectel to make that zvh run spot on mate , give us a shout if you are going with it and i will have a word with ian howell
zetaboostboy522bhp is offline   Reply With Quote
Old 03-05-2009, 01:36 PM   #51
Kev83
Kev83's Avatar
Trader Score: (0)
cheers dude, get ian to wave his wand over it Also be having one of those tasty looms mate
Old 03-05-2009, 01:40 PM   #52
zetaboostboy522bhp
Trader Score: (0)
whenever your ready chief
Old 03-05-2009, 04:10 PM   #53
Kev83
Kev83's Avatar
Trader Score: (0)
nice one dude. Pick the mondeo engine up next weekend...£100
Old 03-05-2009, 05:35 PM   #54
BRAMMER
Passionford.com
BRAMMER's Avatar
Trader Score: (4)
BRAMMER is an unknown quantity at this point
Well Kev i'm glad to hear you bought the car from Mark
Sorry to hear that you've had the dreaded problems when you buy a new RS, just a little information that the turbo fitted to that car is a hybrid and had less than 1000 miles on it when i sold it to Mark.
The car is well know or used to be to the North staffs group and before my ownership had all it's original panels including the fuel cap which had been lead loaded by moorland classics. The car was then bought by streetdragster from Blackpool way where it was fitted with a zetec engine and ran big power hence why the front panel was cut out.
The radiator is always a issue when fitting a T3 but if yours smacked the rad then it's more to with the gearbox mounts so they're a must job on a fiesta to fit vibrotechnics.
Do you still have Marks number mate as i lost it when i changed phones??
Heres what it looked like before i bought it
__________________
Cosworth Photoshoot
BRAMMER is offline   Reply With Quote
Old 03-05-2009, 06:56 PM   #55
Kev83
Kev83's Avatar
Trader Score: (0)
cheers brammer mate, got the CD with the build pics mate, absolutely tip top. Got some vibrateknic mounts ready for the new engine. Not had the inlet boost hose off yet to check for play, but got a feeling the seals have gone in the turbo.
Not too sure what power to go for, but will probably be mid 250 to 300 bhp i think. PM's marks number mate
Old 03-05-2009, 07:10 PM   #56
Robs Frst
Robs Frst's Avatar
Trader Score: (0)
Unlucky mate, Atleast your going to build a engine your happy with to your spec.
Give me a shout if you have any problems.
__________________
Old 03-05-2009, 07:19 PM   #57
Kev83
Kev83's Avatar
Trader Score: (0)
cheers rob mate. Will be building the 2.1 ZVH in house mate so will be after picking people's brains for info and advice. Will be running some tasty engine management too courtesy of mr area six himself
Old 03-05-2009, 08:44 PM   #58
zetaboostboy522bhp
Trader Score: (0)
if your gonna email him on tech@fiestafrenzy.co.uk it might be worth talking to him about a set of arias pistons and a rod package but he gets them from america custom built to his spec and the pound isnt the greatest at the mo so see what he can do for you tell him paul sent you
Old 10-05-2009, 10:34 AM   #59
Kev83
Kev83's Avatar
Trader Score: (0)
Bit of an update people. Not managed to get down to collect my engine as the van i was borrowing from work was in for a service over the weekend but not to worry. Been busy getting my new 'Workshop' ready for stripping down the zetec engine and then building back up once have back from the machine shop Now when i say 'workshop' i actually mean my mum's summerhouse Not ideal admittedly, however i have an compressor in there, electric, plenty of space, and most importantly a fridge full of 'bevvies'
As said earlier, i have got the zetec engine sorted, and have the head here already with the newman cam and solid lifters. Bought a ZVH conversion kit of fleabay for £125 which comes with:
Felpro Headgasket
Headbolts
Brass Gallary Bungs for oil way on block
Water pump conversion Plate
1.3 Tensioner
Breather Bung (for original zetec breather)
Oil Return and Breather Fittings
On the rods and piston front, im going to see what Ian can sort for me
Before the clearout
Nice and tidy and ready to get my hands dirty
Engine being collected next weekend along with an engine stand and will start stripping down the zetec ready for the machine shop
Old 10-05-2009, 10:42 AM   #60
JezSierra
happy with that
Trader Score: (0)
JezSierra
Send a message via MSN to JezSierra
will be looking forward to watching this come together
__________________
i only drink beer on days that end in Y!
JezSierra is offline   Reply With Quote
Old 30-05-2009, 09:22 AM   #61
Kev83
Kev83's Avatar
Trader Score: (0)
car now totalled will post pics soon...
Old 30-05-2009, 10:19 AM   #62
zetaboostboy522bhp
Trader Score: (0)
hope by what youve said above is that the engines givin up and not the cars been involved in a crash
Old 31-05-2009, 09:01 AM   #63
Kev83
Kev83's Avatar
Trader Score: (0)
As written off mate. Proper gutted. Some dozy old twit rear ended me and pretty much caved in the bank end of the car
Old 31-05-2009, 09:32 AM   #64
Kev83
Kev83's Avatar
Trader Score: (0)
****edited by webteam****
Old 31-05-2009, 12:40 PM   #65
bennyboy
Trader Score: (0)
bennyboy
gutted for you mate, that is proper shit
bennyboy is offline   Reply With Quote
Old 25-06-2009, 04:15 PM   #66
Christian and Beccy
Trader Score: (14)
Christian and Beccy is an unknown quantity at this point
Send a message via MSN to Christian and Beccy
What happened with this? Game over?
__________________
Christian and Beccy is offline   Reply With Quote
Old 04-07-2009, 02:16 AM   #67
BRAMMER
Passionford.com
BRAMMER's Avatar
Trader Score: (4)
No way mate i can't believe it, was the car completely wrecked or is it poss to get back on the road?
__________________
Cosworth Photoshoot
Old 19-07-2009, 01:31 AM   #68
BRAMMER
Passionford.com
BRAMMER's Avatar
Trader Score: (4)
CLICK HERE FOR EBAY LINK OF DAMAGE
It's repairable for less than £500
__________________
Cosworth Photoshoot
Old 19-07-2009, 01:38 AM   #69
murfs frst
murfs frst's Avatar
Trader Score: (0)
murfs frst
little bit of tlc and this would be a mint car again.
__________________
ford fiesta rs turbo
honda civic type r
If it dont fit dont force it.......
murfs frst is offline   Reply With Quote
Old 19-07-2009, 01:31 PM   #70
Glenny Boy
Glenny Boy's Avatar
Trader Score: (1)
Glenny Boy is an unknown quantity at this point
Thats a bargain.It only needs a rear quarter.I love fiesta turbos.
__________________
SCOTCH CORNER ALL FORD MEETS IN THE NORTH EAST/NORTH YORKSHIRE,PM FOR DETAILS
Glenny Boy is offline   Reply With Quote
Old 19-07-2009, 02:34 PM   #71
Robs Frst
Robs Frst's Avatar
Trader Score: (0)
He went to the dark side and bought a Impreza RB 320
__________________
Old 20-07-2009, 01:19 PM   #72
Matt carter
im dyslexic but i do try
Matt carter's Avatar
Trader Score: (0)
Matt carter is on a distinguished road
Quote:
Thats a bargain........... is it £2000 starting bid
Matt carter is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
anything car orientated in n.w tomorrow Carlsworth General Discussion. 0 07-07-2007 12:52 PM
Breaking well Broken 1991 Mercury Grey FRST fernando_khan Ford RS Turbo parts for sale 1 27-02-2006 06:39 PM
moderaters....stay or go??? (not gus orientated) the strut brace General Discussion. 63 29-07-2005 06:19 PM
Content Relevant URLs by vBSEO 3.3.0
