Building a 4b track-car,25/9/05 BIG update loads of pics....
#44
Updates are as follows,
Started stripeing engine bay with my brother,we took most things out ready for
inspection and cleaning.
we dropped all the cradle and suspension ditto.
I also cleaned and added a few more bit on the engine.
Here are a few pics as the car stands now
The things we do for fun
i will update some more tomorrow as i am going home now for my tea and i am
nackere, wet and cold jet washing all the bits from under the car.
Catch you all later
Catch you all later
#46
new pis as promised
don't no if i should put a blue rocker cover on or leave this one on
Put new uprated water pump and basically just cleaned most of the other bits.
My brother shaun big thanks to him,mide you if he does'nt get stuck in he
won't get to drive it ,LOL
We dropped all the cross member and suspension today, start to prep the engine bay for painting tomorrow more pics to come.
Cheers Paul
Cheers Paul
#53
#55
Some more pics of the parts i have bought as follows
Adjustable TCAs and compression struts,eccentric top mounts in transit.
GAZ coilovers
Sparco peddles,bonnet pins,turbo insulation kit and boot hooks.
Sparco Passenger foot rest.
Roll cage has come so i will take some pictures tonight.Still waiting on seats should be next week.
I am doing a couple of hours on the car tonight so hopefully post some more updates.
Cheers Paul
GAZ coilovers
Cheers Paul
#57
Burton power richard the no is 020 8518 9120 they are really helpful, just waiting for my eccentric top mounts.
I spoke to Brom mate he told me 750 for the rear beam supply and fitted all ajustable drive in and drive out.
#60
Cheers Richard
Well i started to unwrap my cage to take some pictures and it has took my over a hour to do just the rear cage without sratching it so i'll do the rest tomorrow because it is to cold but heres some pics of it.
I started to unpic all the wireing loom out of the engine bay so i can prep it for cleaning and then painting,this project is bigger than i thought.
I hope to have the engine bay done by next week end.
Cheers Paul
Cheers Paul
#62
I am starting to clean engine bay now so many wires in the way
All the cross member cleaned and steering painted and fitted plus TCAs
Got my rear beam all powder coated
Got a few more pics
Got a few more pics
#63
TCAs all painted
Cross member cleaned as best as i could with steering rack and TCAs fitted
Engine bay,alot off cleaning to doas you can see
Same this side
As you can see i started to remove the wireing to prep the engine bay,just haveing a coffee break and thought i would update my post.
So back to it
Cheers Paul
#64
what happened to you today i got to j.c,s about 5.15,i thought you had a bad back anyway ill be round tomorrow debt collecting,so get a stash from under the matress,or ill set the dog on ya!!!
p.s i bet you,ve been w*nking over your new diff hav,nt you
#65
How did you no have you been spying on me
I thought i would beat the traffic foz and make a start on the car and yes my back is still bad mate but the car still has to be done for bedford mate and if you were som sort of mate you would help me
#70
A few more pics for you of some of the bits i have got for my car
Flocked dash from JC Motorsport
T4 turbo from JC Motorsport second hand but only done 500 miles
Alloy pullys from A1 Rallysport
And last of all WRC 8 injector inlet manifold and feulrail plus wireing.suplied by jonfoz
Just need air to air injectors now and ECU sorting.
The head is going to A1 to get machined and my sump is at GNT Motorsport to recieve the big wing treatmant.
#73
We did a bit of stripping out inside yesterday,removed the alarm,ford stereo amp,stereo loom,stereo,etc.......saving 5.5 kilo just in those items....
Gonna strip out a bit more of the redundant stuff soon so Paul will put some pics up of all the junk weve removed when its finished
Cant wiat to see how much weight we save taking out all the trim..
Well have to tie it down so it dont float away...
#77
Cheers Neil
Mr C Jonfoz does them give him a ring o7776135999
Engine bay is getting spayed tonight heres a few pictures
All prept up for painted,big thanks to my brother shaun for sunday
And heres another of the engine with the T4 and sum other bits.
Will post some more pics tonight of engine bay when it is sprayed
Cheers Paul
Cheers Paul
