| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
V6 Ka of Love
#2 |
Shotgun Bunter
Good golly!
Not seen a project like this before. Please keep the updates and pic's coming |
#3 |
there is something missing up stairs with you lol
#4 |
Cossiemodo
Yep you need your head looking at mate
__________________
TF2 name TurboShed - 2Fort only servers usually. Left4 Dead - TurboShed - I hate zombies! |
#5 |
V6 Ka of Love
#6 |
The ADD/ADHD way!
#7 |
sounds fucking nuts! only thing i will say is is the pump gonna be able to pump enough oil to the turbo to keep it happy? can u not run an oil line from the engine and then use the scavenge pump to pump the oil back to the sump?? im sure ive seen this set-up before working well.
__________________
#8 |
Crazy project!!!!
__________________
#9 | |
V6 Ka of Love
Quote:
The particular pump works at 2 bar and will flow 28 litres per minute, I don't know if that's a lot or not etc. but 28 litres sounds a lot and the turbo will see far less temps that if it were on the manifold |
#10 |
lol this is mad
what boost will that engine take |
#11 |
V6 Ka of Love
I'm going to try 5-6psi, I want to prove the setup on a standard 2.5 (with standard CR to keep things simple and cheap) so if it breaks I don't mind replacing it, the goal is to build a low compression motor based on the 3 litre omega unit next year and use aftermarket managment
I don't care much for power figures, I just want something that goes like fcuk on the road |
#12 |
Too many projects........
I am a big vectra nut and hope you know that turbo'ing the vauxhall v6 won't work at all. The rear bank gets to hot as standard and turbo'ing it will just keep melting the rear bank. The best way to get power from these motors and the cheapest is supercharing it.
You can use a supercharger of the new mini's with a few custom brackets and omex standalone management. Can get more info if you want from people who have already done this conversion if you want. But this deffinately will not work especially with the size of the bay and the amount of heat the engine produces as standard.
__________________
Maaa Rides: Mondeo LX Vectra St2.5v6 (Restoration) Vectra SRI 2.8v6Turbo 4x4 (Long Term Project) Vectra CDX 2.5V6 And..... The WIFE....hahaha |
#13 | |
Quote:
#14 |
I can get you links but there off a owners club forum and you might have to be a member to view.....
__________________
#15 |
im a member on the vvoc for some reson
#16 | |
V6 Ka of Love
Quote:
The charger from a new mini probably won't push enough air, they only rate them for up to a 2.0 displacement though I'd love the sound of one there's really no where to put one |
#17 |
This guy fitted a supercharger....
http://www.vvoc.com/forum/showthread.php?t=124814 Never herd of anyone turbo'ing one tho. Might give you some idea's on getting rid of the bulky plenums at least tho if you go the turbo route which will give you more space in the engine bay. Someone has also fitted 6 throttle bodies on one aswell (or still in the process) if your interested in that too.
__________________
#18 |
this is fantastic, i'm loving the stand alone oil system for the turbo
__________________
#19 |
Other things to look at to get more power, but don't expect huge bhp increases are custom manifolds, equal length downpipes etc, then you need to look at the injectors and what they flow to make sure the engine does'nt run to lean.
The most psi a standard engine can take is around 6psi, anything more then you have to start looking at upgrading the engine components. You can use c20let pistons in the v6 but obviously you'll need to buy 2 sets or get some custom made, then the crank upgrading, oil spray jets and more. Can end up spending a fortune for just a little power. Get the turbo set-up built and running on the 2.5 lump then fit a 3.2 block out the new vectra's. All you'll need is the block and heads for the swop.
__________________
#20 |
get it down a strip first! before and after runs
#21 |
can you get big power out of these v6s
it seams like loads of money and hard work for not alot of gain |
#22 | |
V6 Ka of Love
Quote:
There's no way I'd fit a turbo or a supercharger in the bay, there's just not enough room! It's a turbo I really want |
#23 | |
V6 Ka of Love
Quote:
I've been told 6-7psi is the limit hence trying something a little under for now on the standard pistons and compression ratio I had thought about the 3.2 because of the base power it produces but if the piston diameter is not the same as the LET I'd be spending a lot on pistons which I don't want to do and the 3.2 itself isn't going to be cheap |
#24 |
Here's the TB project thread....
http://www.vvoc.com/forum/showthread.php?t=192013 I think you would deffinately benefit from making a custom inlet of some sort to give you more space and clearance in the engine bay tho.....
__________________
#25 |
Things which you could custom make yourself like the custom inlet manifold and larger TB would be a good cheap mod, a de-ridged throttle body with a larger butterfly can be bought on an exchange basis for less than £50 which is good, then blank of the egr valve by simply fitting a blanking plate or 5p coin i think fits in the hole.
Fit a oil catch tank too as the plenums get filled with oil due to the oil breather pipe which runs from the right side of the engine across the top of the front bank and into the throttle body on the front. Few of these daft cheap mods don't have make a diffence and help you gain a few bhp here and there for a few hours work and less the £100. 3.2 pistons are deffinately bigger and different than the 2.5/3.0 ones but i think not 100% that the heads are all the same tho.
__________________
Maaa Rides: Mondeo LX Vectra St2.5v6 (Restoration) Vectra SRI 2.8v6Turbo 4x4 (Long Term Project) Vectra CDX 2.5V6 And..... The WIFE....hahaha Last edited by RUSSELLB1904; 26-03-2009 at 10:54 PM. |
#26 | |
V6 Ka of Love
Quote:
Im not looking to get masses of power, Im sure 300bhp of v6 turbo in a Ka would be quick enough for me |
#27 |
V6 Ka of Love
#28 | |
V6 Ka of Love
Quote:
#29 |
yes mate, another mad addition, look forward to seeing it complete
#30 |
V6 Ka of Love
#31 |
Standard Cooper-S Supercharger runs at 11.4PSI
#32 |
Ginger Welsh Boy
Trader Score: (0)
Rep Power: 16 ![]() |
Fook, this will be funny to see! Good luck
__________________
![]() Focus Cosworth Projecthttp://passionford.com/forum/restora...7-10-09-a.html Focus RS Toyhttp://passionford.com/forum/restora...on-the-go.html |
#33 |
![]() ![]() Nuts, but looking forward to seeing the end result
#34 |
*** Sierra RS Custard ***
Cool project.
I went out yesterday in a Tigra V6 using the same engine, but fitted with a supercharger. The management light was coming on as soon as you went past about 20% throttle as it was running off the end of the map (he's going to put it on aftermarket on it, he was just showing me what it went like for now) but providing you kept it within the map, it really did go like fuck, must have been at least 250bhp the standard management could cope with, so I reckon if you keep the boost low on your setup, it will work fine without needing aftermarket, so good for now.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
![]() Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff 2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused ![]() www.VauxSport.com Last edited by Chip; 27-03-2009 at 11:40 AM. |
#35 | |
Quote:
The standard V6 thottle body flows about the same as an RS200 one, you will NOT find it restrictive on your project.
__________________
![]() Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff 2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused ![]() www.VauxSport.com |
#36 |
V6 Ka of Love
Cheers Chip
I have an un-used SMC in the house so you might get roped into mapping the 3 litre that at some point! |
#37 |
will this not have alot of lag as turbo is in boot
cool project tho
__________________
#38 |
[quote=RUSSELLB1904;4039071]I am a big vectra nut and hope you know that turbo'ing the vauxhall v6 won't work at all. The rear bank gets to hot as standard and turbo'ing it will just keep melting the rear bank. The best way to get power from these motors and the cheapest is supercharing it.
You can use a supercharger of the new mini's with a few custom brackets and omex standalone management. Can get more info if you want from people who have already done this conversion if you want. But this deffinately will not work especially with the size of the bay and the amount of heat the engine produces as standard.[/] the way its being done wont increase the engine bag temp any more then a supercharge would neway. if the back bank gets too hot then any sort of force induction will give rise to the same problems. |
#39 |
Great project and well done for going against the grain. Too many people are quick to put different things down without trying them!
Where did you get the wastegate take off/spacer by the way?
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far... Classic Fords FTW! |
#40 |
V6 Ka of Love
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Remote turbo conversions | Chip | General Car Related Discussion. | 40 | 26-03-2009 03:26 PM |
| Interesting 205GTI sprint car with rear/remote mounted turbo | Stavros | General Car Related Discussion. | 6 | 07-05-2008 01:00 PM |
| Top of the range clifford alarm. Remote start/remote lights | DaveEscos | Non Ford parts & other stuff for sale | 3 | 10-08-2006 06:17 PM |
| Remote mount turbo | RaVeR | General Car Related Discussion. | 1 | 17-02-2005 03:49 PM |
| Remote mounted Turbo Kits Only in America. | 88_WRC_Replica | General Car Related Discussion. | 11 | 27-07-2004 08:20 PM |
