PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 15-05-2009, 11:23 AM   #121
Shonky
V6 Ka of Love
Trader Score: (0)
Shonky is an unknown quantity at this point
Quote:
Originally Posted by massivewangers View Post
I hope you make it to FITP mate, would love to see it in the metal.
Bonkers, and silly, but I love everything about it!
I'll be there regardless but really hoping to take this I'll probably be sleeping in it lol
__________________
Shonky is offline   Reply With Quote
Old 15-05-2009, 12:44 PM   #122
cjwood555
Trader Score: (0)
cjwood555 will become famous soon enough
Send a message via MSN to cjwood555
There's a bit of a trade-off to be made with pipe sizes:
- Bigger diameter = slower velocity and large volume so will see you more lag, but lower pressure drop
- Smaller diameter = higher velocity and lower volume gives less lag, but higher pressure drop
The other side to it is of course that ultimately you will not be able to push anymore air down a narrow pipe due to pressure-drop/resistance increasing with velocity/volume, so you'd have a response like a wrc car with decreasing torque and slowed/flat power curve beyond whatever the critical rpm/boost point worked out to be.........and resulting in compressor stall quite possibly.
Chris
cjwood555 is offline   Reply With Quote
Old 27-05-2009, 11:41 AM   #123
Shonky
V6 Ka of Love
Trader Score: (0)
Chris
I have a 2" and a 1" run from the turbo to the engine, the plan was to only use the 2" for now and open up the 1" if I needed when the boost gets turned up, would it make sense to use both pipes from the start so I can deliver low pressure high volume (relatively speaking) from the 2" and high pressure low volume from the 1" at the same time? Both pipes go into a collector with a 3ft run of 2.5" pipe to the engine so it'll have time to normalise
__________________
Old 27-05-2009, 11:46 AM   #124
Shonky
V6 Ka of Love
Trader Score: (0)
I tried my best to get it to FITP, it was nearly back together but needed a few more hours so we took my mate's Ka
This weekend was spent sorting out an issue with some captive nuts in the chassis, we had to cut them out and weld a new plate back in, this is how it looks now also sporting the new oil cooler, it'll all be back together for the weekend so I can crack on with the turbo again
__________________
Old 27-05-2009, 12:16 PM   #125
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (3)
Chip will become famous soon enoughChip will become famous soon enough
Bring it to the performance vauxhall show weekend after next at santa pod, I can probably even find you a decent stand space for it!
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is offline   Reply With Quote
Old 27-05-2009, 12:25 PM   #126
Shonky
V6 Ka of Love
Trader Score: (0)
Quote:
Are you there all weekend? If the weather is good I'll be up early doors Sunday I really want to put it on the strip whether it's turbo'd or not
__________________
Old 27-05-2009, 12:38 PM   #127
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Trader Score: (1)
CossieRich is an unknown quantity at this point
Send a message via MSN to CossieRich
Fantastic read and project. Well done. Look forward to reading the updates
__________________
Rich
MAD Built, GT30, 2.5 bar, MAD Spec inlet cam, Pro Alloy RS500 Intercooler and Rad, Bara Diff, AP 330's, Vi-PEC ECU, 2WD. 480 bhp. 474 ft/lb. Click HERE for my Cosworth Project. Big Thread
CossieRich is offline   Reply With Quote
Old 27-05-2009, 12:51 PM   #128
Chip
Chip's Avatar
Trader Score: (3)
Yes mate im there all weekend
__________________
www.VauxSport.com
Old 27-05-2009, 03:00 PM   #129
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Top progress.How is the turbo coming along.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 27-05-2009, 05:06 PM   #130
Shonky
V6 Ka of Love
Trader Score: (0)
Cool, I'll come find you
__________________
Old 27-05-2009, 05:07 PM   #131
Shonky
V6 Ka of Love
Trader Score: (0)
Quote:
Not done much TBH, been busy putting the 3 litre in but I'll be ordering all the silicon tomorrow so I can crack on
__________________
Old 28-05-2009, 01:16 PM   #132
Jonzy
Jonzy's Avatar
Trader Score: (0)
Jonzy is an unknown quantity at this point
Send a message via MSN to Jonzy
I thought you'd died in it!
Jonzy is offline   Reply With Quote
Old 28-05-2009, 03:28 PM   #133
Shonky
V6 Ka of Love
Trader Score: (0)
Quote:
Just like you thought you died in the bull run, moooo! lol
I might be up your way next weekend, I'll give you a shout butt!
__________________
Old 28-05-2009, 07:08 PM   #134
cjwood555
Trader Score: (0)
Quote:
Hi mate,
It wouldn't work like that - pressure-drop / backpressure would be probably reduced by using the two pipes as you are offering additional cross sectional area compared to using the one, although pressure drop for a 2" and 1" pipe would be more than for a single pipe of equivalent area. The pressure drop / backpressure would also depend on the design of your collector.
I would suggest the best thing to do is work out the air consumption of your engine for the power you are looking to produce and the pressure you need to see at the manifold.
You can then calculate for the pipe sizes you have, what pressure drop would be seen across the length of pipe @ the flow rate calculated previously.
Adding the pressure drop of the pipe to the pressure at the manifold would tell you what the pressure at the turbo needs to be, and you also have your consumption/flow rate. Using this info you can look at your compressor map and see whether the turbo will work without surging or stalling/struggling.
Obviously you could look at the figures with pressure drops calculated for different sizes of pipe and pick the best to suit your turbo...
These calculations won't tell you much about lag, but in general, you'd have least lag with a compressor wheel/housing combo that can provide your air flow/pressure requirements through the smallest pipe (due to their being less un-compressed volume in the pipe)....BUT that might not necessarily be a turbo that gives you the power band you're after so there might be some compromise required!
Plenty of sources on the web (and probably online calculators) for the equations you need to work this stuff out
P.S. looking good - can't wait to see it finished!
Chris
Old 28-05-2009, 07:46 PM   #135
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
madness utter utter madness ,love it
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
Old 28-05-2009, 10:35 PM   #136
Shonky
V6 Ka of Love
Trader Score: (0)
Hi mate,
Chris
I've found an online calculator for air pressure drop but of course it needs the CFM so I'll try to find the specs/compressor map on garret's website then work from there Cheers for the steer, I'll have fun working it out Im sure lol
__________________
Old 13-06-2009, 08:11 PM   #137
Shonky
V6 Ka of Love
Trader Score: (0)
I've not done much recently on the turbo side so I decided to pull my finger out
Boost pipes, collectors and some exhaust stuff
Poked a hole through
Mocking up the pipework
I'm doing a little rewiring in the bay while the engine is out, fingers crossed I'll get the 3 litre back in this coming week and get some miles on it without the turbo so I know the engine is sound then finish plumbing the bad boy in!
__________________
Old 13-06-2009, 09:31 PM   #138
ScORTED
Project Money Pit
ScORTED's Avatar
Trader Score: (0)
ScORTED is an unknown quantity at this point
you sir are a true mentalist... I salute you
__________________
CLICK MY SIG
© ScORTED 2005-2009
ScORTED is offline   Reply With Quote
Old 13-06-2009, 10:55 PM   #139
RS-Joonny
Trader Score: (0)
RS-Joonny is on a distinguished road
Hey great project you got there just a little question though with the air filter being that close to the turbo is there not going to be heatsoak problem with the filter sucking hot air?
Anyway keep up the good work.
RS-Joonny is offline   Reply With Quote
Old 14-06-2009, 12:42 PM   #140
ghigo
ghigo's Avatar
Trader Score: (0)
ghigo is on a distinguished road
coming along nicely
we gonna see this at ford fair???????
ghigo is offline   Reply With Quote
Old 20-06-2009, 02:47 PM   #141
ScORTED
Project Money Pit
ScORTED's Avatar
Trader Score: (0)
given that it'll be exposed to air passing by the car i'd have though not?
__________________
CLICK MY SIG
© ScORTED 2005-2009
Old 24-06-2009, 10:52 PM   #142
dois
Trader Score: (0)
dois is on a distinguished road
news?
dois is offline   Reply With Quote
Old 01-07-2009, 12:56 PM   #143
Shonky
V6 Ka of Love
Trader Score: (0)
I thought I'd be at FITP but couldn't finish it, I don't want to jinx saying it'll be at Ford Fair lol
The head gasket is completely fucked on this 3 litre so it's coming apart early next week and these bad boys going in, CR will be 8.4 to 1 if everything is as it should be:
Progress has been really slow but as soon as the HG is done I'll be taking a week off and probably cane a credit card lol
Fair play to Ferriday engineering, I phone them Monday and they turned up today even though he's broken his arm!
__________________
Old 04-07-2009, 02:56 PM   #144
Shonky
V6 Ka of Love
Trader Score: (0)
Another little update..
Boost pipes mocked up retaining the MAF as it'll be on the standard ECU until I can put some cash together to fit some aftermarket management I already have
Pipe goes behind the master cylinder..
... through the bulkhead
__________________
Old 04-07-2009, 05:30 PM   #145
Zetecfiesta
Trader Score: (0)
Zetecfiesta is an unknown quantity at this point
Send a message via MSN to Zetecfiesta
its just mad how it all fits in a tiny little KA!
Zetecfiesta is offline   Reply With Quote
Old 04-07-2009, 05:35 PM   #146
doctor stavros
Punto GT Owner
doctor stavros's Avatar
Trader Score: (0)
doctor stavros is on a distinguished road
Quote:
it doesnt.... lol.... thats why its a remote turbo lol
__________________
Paul
doctor stavros is offline   Reply With Quote
Old 06-07-2009, 08:08 PM   #147
sierra1off
Trader Score: (0)
sierra1off is on a distinguished road
Brilliant mate, a proper 1 off
sierra1off is offline   Reply With Quote
Old 13-07-2009, 02:34 PM   #148
Shonky
V6 Ka of Love
Trader Score: (0)
Heads skimmed ready for a clean and refit, I'm getting excited now
__________________
Old 13-07-2009, 08:18 PM   #149
Little_Hoss
Little_Hoss's Avatar
Trader Score: (0)
Little_Hoss is an unknown quantity at this point
you maniac, love this project
Little_Hoss is offline   Reply With Quote
Old 13-07-2009, 11:57 PM   #150
ghigo
ghigo's Avatar
Trader Score: (0)
coming along great keep up the good work
Old 16-07-2009, 10:09 PM   #151
Shonky
V6 Ka of Love
Trader Score: (0)
Little update
Totally knackered (literaly in bits) head gasket
Looks like it's been knackered for a while, there was a lot of pitting
Had the head skimmed then pressure washed
Ive not ventured into the world of timing so I got my mate to fit the spacer plates, new head gasket and do the timing
As the heads have now moved slighty we had to modify the inside cam cover to be able to bolt it up and also peel back the tops allowing clearance for the cambelt
__________________
Old 17-07-2009, 02:29 PM   #152
Shonky
V6 Ka of Love
Trader Score: (0)
I've fitted an oil cooler, radiator for the coolant and the water pump, I'll hopefully get it the oil and water plumbed in Monday
I've put a ball valve in the 1" pipe so I can play around with the air supply characteristics
__________________
Old 20-07-2009, 12:12 PM   #153
Jonzy
Jonzy's Avatar
Trader Score: (0)
I didnt think it would more get more ghetto than it was already, but fuck me its getting worse
Old 20-07-2009, 01:30 PM   #154
smithy20vt
Trader Score: (0)
smithy20vt is an unknown quantity at this point
Awesome project
smithy20vt is offline   Reply With Quote
Old 22-07-2009, 01:49 PM   #155
Shonky
V6 Ka of Love
Trader Score: (0)
I'm reaching new levels of ghetto by the day!
Have you got a spare recirc dump valve?
__________________
Old 22-07-2009, 01:50 PM   #156
Shonky
V6 Ka of Love
Trader Score: (0)
I've finished the boost pipe to the intercooler and put the engine back together, I'll find out if it runs tomorrow night
__________________
Old 22-07-2009, 01:54 PM   #157
stevenebm
post whore
stevenebm's Avatar
Trader Score: (6)
stevenebm is an unknown quantity at this point
crazy project.love it.hope it runs for you mate
stevenebm is offline   Reply With Quote
Old 22-07-2009, 01:55 PM   #158
Shonky
V6 Ka of Love
Trader Score: (0)
I had a bit of help from my Nephew too...
__________________
Old 22-07-2009, 01:59 PM   #159
Chip
Chip's Avatar
Trader Score: (3)
Lol @ the 5 year old welding.
Coming along nicely though mate
__________________
www.VauxSport.com
Old 30-07-2009, 08:52 AM   #160
Jonzy
Jonzy's Avatar
Trader Score: (0)
updates?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Remote turbo conversions Chip General Car Related Discussion. 40 26-03-2009 03:26 PM
Interesting 205GTI sprint car with rear/remote mounted turbo Stavros General Car Related Discussion. 6 07-05-2008 01:00 PM
Top of the range clifford alarm. Remote start/remote lights DaveEscos Non Ford parts & other stuff for sale 3 10-08-2006 06:17 PM
Remote mount turbo RaVeR General Car Related Discussion. 1 17-02-2005 03:49 PM
Remote mounted Turbo Kits Only in America. 88_WRC_Replica General Car Related Discussion. 11 27-07-2004 08:20 PM
