Ukrainian cosie
Ukrainian cosie
Hi, welcome to my galery.
My sierra was made from 4x4 and 2wd cos versions, but still 2wd.
spec: std engine, little ported head, greens, t34.48, grA coil, 80mm custom exhaust, walbro pump 255lph, aluminium light propershaft...
peak 1.92bar, hold 1.75bar.
best 1/4mile = 13,2s on road tyres 225/45/17.
I'm waiting for large intercooler and siemens'55 from USA for installation MSD chip.
https://passionford.com/forum/album.php?albumid=615
chatter 4 life
think ya will all find it a mk2 sierra 3 door
Hi.
Have put siemens'55 + MSD chip + big intercooler. Set boost controller to 2.2bar peak, hold 2bar. Now it run very fast. But clutch sliping at 4 and 5 gears: new AP organic + new ford cover
And my new intercooler, it big, but not RS500 style.
http://87255.users.photofile.ru/phot.../126417019.jpg
http://87255.users.photofile.ru/phot.../126417031.jpg
After installation:
http://87255.users.photofile.ru/phot.../126482120.jpg
http://87255.users.photofile.ru/phot.../126482117.jpg
http://87255.users.photofile.ru/phot.../126482123.jpg
Sory, I can't put pics here
After installation:
boost peak 1.8bar, hold 1.6
boost peak 2.2bar, hold 2-1.8
now waiting for helix paddle clutch kit.
And week ago was crash of my rear diff on the road. main shaft of it was damaged after quick start and propshaft lose connection with diff. Now I use another one.
Have receive from U.K. Helix Kit.
Seems very strong and with good quality. disk thickness 8.5mm, the same with my slipping AP organic. So, I plan to put this helix cover with AP first, then with paddle helix after it will start to slip.
Have put helix kit, clutch holding torque now! ))
Bought ENKEI SPORT wheels from Ukrainian rally team, R16/8J. Heavy, but shoud be strong.
spliter from renault laguna:
spares for T34 turbo by Mellet for turbo rebuild(old wheels compared with new one):
Now car slipping at 3-d gear when on full boost. I like it ))
Some upgrade
EVO 9 calipers + FRS disks + Hawk performance pads + technafit brake lines:
Wheels R16:
Rear slick - AVON 9J, now 3rd gear not slipping on the road )) :
Custom brace:
common view:
Wheels R16:
Custom brace:
common view:
I have a problem now - 15 valves is dead. The reason is tension pulley - it wasn't installed correctly little time ago((
I have in spares 14 used valves in good condition. My mate from Moscow promised to give me another 2.
Now the head is off the engine and I removed all guides to suit new one. They will be custom made from special bronze.
Now I'm thinking about full rebuild.
For rebuild I want to use 4x4 bottom end with millage less then 100k. In spares I have a 200 block(std size), crankshaft+connecting rods std size, oil pump 4x4 etc.
Also for rebuild there are spares on the shelf:
Wiseco forged piston set
ACL Race bearing kit
Cometic full gasket set
Some seals etc
I have the following plan:
To re-bore block to 91.5mm to fit new pistons.
To use crankshaft+connecting rods in std size. Just re-balance it together with 2wd flywheel+clutch cover+pulley. But I doubt whether to polish it or now.
To reuse thrust half washers - they are OEM Ford and in good condition.
To reuse 4x4 oil pump with new uprated spring and new drive. But I doubt how to use it with 2wd sump. Need to fit 2wd pump cover for this?
I think I will use again std head bolts with gr.A gasket. Because I don't want to skim again the head. I measured it - the bow is less then 0.05mm.
I found some damages for exh. camshaft, is this bed, can I reuse it?
Any comments and suggestions will be great!
Some seals etc
little updates.
new custom guides. material - beryllium bronze.
new seats, radial type
after porting:
new rear tyres 245/45/16
head bolts. cosworth bage. thrust washers - ACL. uprated spring and drive for oil pump...
some other stuff:
gaskets for t34 turbo
turbo comes after rebuild:
rebuild kit for T5
perfomance folks, 3-4 billet inserts
after porting:
some other stuff:
rebuild kit for T5
Camshaft
A crankshaft is produced to have an extreme hard surface. If the surface is damaged it is in general broken. Maybe you can repair it but it will need the same prosess like a new one to manage to be hard in the surface again.
The most easy will be to get a new one i think. Or maybe yoy shold change them bouth and get more power?
I have also send you an PM.
Didn't find that pic with the 3dr headlights on a notchback (it was a photomontage I guess) but it looked fine. And your car too mate, unusual but nice. Many would only expect "oh a cossie spoiler on a standard car, how boring" but then proper cossie power will kick ass
Nothing can beat a nice looking 3dr but Ford had could do this ex factory IMO.....
