My 3dr Cosworth
My 3dr Cosworth
Time for an overhaul. 3dr Cosworth with 40k miles from new. Currently restoring the underside. Awaiting delivery of Konis, Mongoose exhaust, Powerflex bushes, Group N Beam mounts, Prodrive Hoses. All arms, rear beams etc currently getting powder coated. Watch this space
Before
The following pictures are all of the original underside. Cleaned with G101, still mint after all these years, with not a hint of rust or rot to the floorpan
Tank Stripped
Tank Rubbed Down
Underside G101'd
Original Brake Lines
Spring Seats Cleaned
More to come next week.
Before
Tank Stripped
Tank Rubbed Down
Underside G101'd
Mmmm. Nice and clean. I cant get over the rust that you guys see over there. Driveline parts, beam etc. I know where I will be looking to advertise my 3dr if I sell.
Keep up the good work Jeff
Thats a nice looking new fiesta bonnet behind the diff, You must have good taste if you have a pal with an xr2
On another note what numpty painted the bolts on the diff silver
i knew you would not resist !
the floor looks mint jeff
you little polisher!!!!!!!!!!!!!!!!
will pop in and have a look
heres mine at the minute https://passionford.com/forum/restorations-rebuilds-and-projects/223093-red-escort-cosworth-resto-number-3-a.html
Dave e
ps. i blame you for starting me with all this anyway, its all your fault!!!
Dave e
heres mine at the minute https://passionford.com/forum/showthread.php?t=223093
Dave e
Dave e
Give him a call, hes all excited.
updated
Underside painted in two tone grey/black.
Tank and fuel pump fitted
Driveshafts etc painted
Brake pipes, bolts and pistons painted.
Brakes calipers stripped, painted and laquered
New Bolts and braided brake lines
Rear beam, arms and other bits due back from the powder coaters any day, then it all goes back together with new Koni Sport kit, Genuine drop links, Mongoose turbo back exhaust, Powerflex poly bush kit and Group N Beam mounts. Then when thats done, on with the front.
Assembly
Everythings back from the powder coaters. Heres a nice little collection to go back on the car.
Rear beam and diff installed
All the other rear end parts going back, all bolts renewed and really happy with the results. Just needs brake calipers etc to go back on.
