how to do? fwd to awd
Rally, rally, rally...
Hy!
Sorry to my bad english, i'm hungarian.
I have an 1.8 Zetec project to my mk3 escort, and i thinking about the AWD system... what are you offer to me? rs2000 4x4 AWD system or Cossie or any ideas (sierra 4x4)? my engine is the original cross mounted... sorry to my bad english...
Can I use the zetec engine, which is ~ 170 BHP now, and it was a lot of money... and i love it!! If we rotate the engine to longitudal mode and we make an other custom exhaust system? The Sierra 4x4 gearbox fit to the Zetec (Silver Top) engine?
We have an other idea... just some words: Audi 80 Quattro gearbox, sierra RWD rear axle, Lancia Delta HF Integrale drivetrain... but the idea of you is take it easy.
originaly it is the 130 bhp engine, and for example i have compression 19 so i spent a lot of money.
engine:
custom verner pulleys (not in the photo),
ported, polished head (5mm+),
ported, polished inlet manifold, custom exhaust and inlet cam,
mondeo throttle body,
mondeo 2.0 injectors,
1.5mm- from the head under,
custom exhaust system,
etc... fully rebuilt.
for example:
mitsu oil cooler, s1 rs turbo sperr, the brake system fornt rs2000, rear xr3i (front disc), hydraulic handbrake, etc...
engine:
for example:
http://www.filkornauto.com/sport.htm
It is a hungarian Ford Service and Rally Team...
They have an mk3 Escort 4x4, and not the sierra 4x4 drivetrain i think.
Its is a 2.0 Zetec Turbo, with cross mounting engine, but still AWD...
it uses an mtx75 box and transfer box from an escort rs2000 by the looks of it.
i have a mondeo(very similar to rs2000) 4x4 gearbox, transfer box, prop shaft, fuel tank and drivers side front drive sharft (the important one) for sale if your interested i'll even ship to hungary if your willing to pay the shipping?
cheers,
Phil
cheers,
Phil
so i think i rotate the zetec, i put under the dohc crankcase and a complette sierra 4x4 drivetrain, gearbox, etc...
now, i've got offer an sierra 4x4. so i can buy the sierra 4x4 now 'bout 200-300 USD (conversion of HUF).
the next project next to the AWD system, it is the turbo...
its need turbo, the much power, reason the AWD system.
i waiting any ideas of the turbo both.
if you are looking for rwd? the t9 gearbox from a sierra saphire 1.8cvh should bolt up to your zetec, you could probably use alot of those parts, axles, gearbox tunnel etc.not too sure how much abuse it will take before i was thinking of a similar conversion to my mk4 rs turbo.. you could still keep the engine non turbo and it would still be pretty quick. if you want turbo.. well i`d personally lower the cr myself, but there is so many options/opinions of tuning for the zetec. i`d like to see the progress if you find a way to do it
good luck with it
good luck with it
yeah i know... my friend can weld an dohc (sierra 4x4) crankcase to the zetec, so it can be solvable...
nothing wrong with RWD! and a LOT easier!
and it only being a small engine i doubt it has enough torque to NEED AWD, unless its gonna be raced off-road loads i dont see the point on the extra expense?
RWD zetec is easy =)
nice looking conversion you have there i agree i think rwd would be alot easier.... what gearbox is it you are using in your capri to bolt up to the zetec just out of curiosity?
hm, i like the rwd idea.
you'r right, there is no much power to 4WD, but RWD... yeahhh...
what rear axle do you offer me? a simpli sierra?
i have mondeo injectors, but i have 2 Dellorto DHLA-40 too... injector or carb? the carb sound... ahhh...
the car is now injector, and go fast... but i want to change it to carb...
mark_J
89
12-01-2005 10:42 PM
Kev.H
12-11-2004 04:06 PM
