PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 29-08-2009, 09:45 PM   #241
xr4x4rs
Trader Score: (5)
xr4x4rs is on a distinguished road
Send a message via MSN to xr4x4rs
the wings i went through mike rainbird
im going to start cracking on next week as the car will be back to a shell as im not happy with a few things so starting again lol
__________________
xr4x4rs is offline   Reply With Quote
Old 30-08-2009, 07:09 PM   #242
tezmanian devil
Trader Score: (8)
tezmanian devil is an unknown quantity at this point
Send a message via MSN to tezmanian devil
them wheel's are maaHOOsiv
what ET are the rear one's?
looking good though dude, cant beleive your taking it back to a shell again though lol, your nut's!!
good luck
__________________
my 300+bhp mk5 escort zetec turbo project http://passionford.com/forum/restora...engine-in.html
tezmanian devil is offline   Reply With Quote
Old 12-09-2009, 02:26 AM   #243
xr4x4rs
Trader Score: (5)
update time again
ive finally gotthe wrc wings on thanks to my mate rich (twellsie) he came round and panel beated the creases out i put in and shaped them better so they fit better
managed to get teh side skirts fitted lovely aswell
door gaps
skirts
as you can arch liners dont fit anymore
bumper gap
i have also stripped teh car bare, as i want to start again but make it better, so all looms, sound deadening, heat tape etc alll been taken off, my glass has been removed aswell, and tailgate is off
heres somepics of the sound deadening
all cleaned up
started to re seal where i pulled sealent off
then re sound deaden teh boot area
and some random pics lol
monster truck anyone?
and to see what the wheels would look like on coilovers fully down lol
oh and i borrowed this aswell
next is to widen the rear quarters for the wheels
__________________
Old 12-09-2009, 02:33 AM   #244
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
looking good mate
fezzajsy is offline   Reply With Quote
Old 16-09-2009, 06:21 PM   #245
M K
M K's Avatar
Trader Score: (8)
M K is on a distinguished road
Send a message via MSN to M K
Hello mate, awesome work with the car for a start
wanted to ask, with the electro plating i assume it doesnt matter if you plate over the threads and bearing faces etc?
also if thats the case is there any reason why you couldnt get the complete front hub and hub flange electro plated?
how durable is it once done?
thanks
marc
__________________
M K is offline   Reply With Quote
Old 16-09-2009, 07:41 PM   #246
xr4x4rs
Trader Score: (5)
i wouldnt get the bearing faces electro plated on hubs or inside carriers, if you mask them up then they can be done
its fairly durable but like anything metal plated a slight scratch and it wil go rusty
__________________
Old 16-09-2009, 10:06 PM   #247
jona bona
Trader Score: (0)
jona bona is on a distinguished road
Send a message via MSN to jona bona
Ive had mine done
jona bona is online now   Reply With Quote
Old 02-10-2009, 10:37 PM   #248
xr4x4rs
Trader Score: (5)
ok time for another update
finally got round to widenening the arches
what idid was clean up the insides, drill all the spot welds from inner and outer and pull them apart
now i wanted to keep the original lines of the car and ive just managed to do it but i have at least 3-4 mm clearence now of the wheels which is enough for me
so heres some pics
after widenening bare in mind these over lapped and now they sit flush
then i seam welded the joins together and then put extra plates round the lot to give its strength back
then it was primered and seam sealed
to give the clearence i was after
not much but next is skyline gearbox
__________________
Old 02-10-2009, 11:08 PM   #249
Tev
Tev's Avatar
Trader Score: (2)
Tev is an unknown quantity at this point
looks ok,
__________________
Tev is offline   Reply With Quote
Old 02-10-2009, 11:11 PM   #250
fezzajsy
Trader Score: (9)
nice one,still looks tight..
Old 19-10-2009, 11:05 PM   #251
xr4x4rs
Trader Score: (5)
another update, the skyline gearbox tunel is finished to a point where im happy, but it may need a slight mod later on when the time comes to fit it properly, i dont know yet, plus i may have made it a sliht bit higher, but rather do it this way than have it too low
so the 1st bit was to cut the gearstick hole, i made a quick template of and marked where i need to cut
all cut out
i also cut the side of the tunnel for the transfer box
i then put the gearbox into place, only to see that i needed to cut a bit more as the gearbox has a plate on it which is higher than the gear stick, so ended up wwith a hole like this
gearbox now in place
now with a 20mm adaptor plate i need the gearbox to sit 5cm from the bulkhead and ive just done it, i carnt get the gearbox any further back without major mods
i then noticed the rear of the gearbox pushing the metal up, so while the box sat in place i drilled some holes and snipped the metal out until it was free again, and ended up with this
seat all in, and it still moves forwards and backwards easily
how the gearstick will sit
then i welded it all up, as i dont have the special equiptment to form metal i had to do it instages, so it looks a mess, but its strong and you wont see it, all the top and underneath are full welded up
how the gearbox sits under the car
and operating 3 jacks on ya own witha skyline gearbox is a pain but i managed to do it lol
i then dressed the welds up, didnt want to do too much as it loses strength, i then primered, then painted then seam sealed just togive it a bit more protection, after it will have paint again then sound deadening then primered and painted again
the underneath will be done wehn i get the car on its side later this month
next is the rear beam bolts as i have to drill these out and weld nuts into chassis legs as one of the owners cross threaded both main bolts
and a couple of pics of it outside as i had to use the garage to do an engine conversion ona fiesta
__________________
Old 19-10-2009, 11:10 PM   #252
bazzle
Trader Score: (0)
bazzle is on a distinguished road
looking good, keep it up
bazzle is offline   Reply With Quote
Old 20-10-2009, 12:04 AM   #253
AquariousRS
AquariousRS's Avatar
Trader Score: (1)
AquariousRS is on a distinguished road
Send a message via MSN to AquariousRS
Wow thats alot of work. Well done
__________________
Tim
For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys.
For all your stickers ~ Email stickerpaul@yahoo.co.uk
AquariousRS is online now   Reply With Quote
Old 20-10-2009, 04:49 AM   #254
Gav Diamond
Gav Diamond's Avatar
Trader Score: (6)
Gav Diamond is on a distinguished road
A great deal of work there mate, will be great when its finished
Gav Diamond is offline   Reply With Quote
Old 20-10-2009, 11:38 AM   #255
fezzajsy
Trader Score: (9)
coming along nicely mate,keep it up
Old 20-10-2009, 11:58 AM   #256
Munch
Mr. Sparkle!
Munch's Avatar
Trader Score: (0)
Munch is an unknown quantity at this point
keep it up
__________________
CHEERS, LEE
Onslow Loves COD!
Arguing on the internet is like racing in an impreza, even if you win, you're still a twat.
Munch is offline   Reply With Quote
Old 20-10-2009, 06:36 PM   #257
Trader Score: (14)
Twins is an unknown quantity at this point
fantastic project
__________________
My carbon clad s2
Twins is offline   Reply With Quote
Old 20-10-2009, 08:45 PM   #258
Tev
Tev's Avatar
Trader Score: (2)
come on the progress on this car is so slow!!!!!!!!!!!!!!
what the fook r you playing at!
__________________
Old 20-10-2009, 09:02 PM   #259
xr4x4rs
Trader Score: (5)
well if i had help it may go quikcer but as im doing it on my own and other things to do like painting bicycle frames im sure the car would be getting somewhere, but im in no rush lol
__________________
Old 20-10-2009, 09:06 PM   #260
Tev
Tev's Avatar
Trader Score: (2)
Quote:
bla bla bla,
all im hearing is excuses!!!!!!!!!!!!!
im waiting to be asked over to help, the pot of stoppers by the door ready!
oh and you may have to paint the frame again i scratched it
__________________
Old 20-10-2009, 09:07 PM   #261
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
very nice work so far fella what are you doing for a clutch & fly wheel with the skyline box & is the mainshaft long enough to go in the crank spigot still ,or are you cutting off the mounting flange of the skyline bellhousing & welding on the adaptor plate im deffo going to do this conversion on my escort so any info is greatly appreciated andy ps love the wrc front wings .
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
Old 20-10-2009, 10:24 PM   #262
xr4x4rs
Trader Score: (5)
Quote:
befire i did this conversion i spoke to martin at reyland and he said he will be designing an adapator plate hence i went ahead with it, not the main shaft will need maching down slightly by the lucks of things, the clutch etc i will leave down to reyland as i dont know what to do on this part, i have a rough idea but not 100% sure
the adapator plate should be a bolt on, but the skyline bell housing wll need modding for start motors being on the other side to a cossie
an the adaptor plate i will be around 20mm hence ive moved the box back far enough to compensate for the plate
__________________
Old 20-10-2009, 11:10 PM   #263
Richie.
aka Turbosailorboy
Richie.'s Avatar
Trader Score: (5)
Location: Under the water.... .......in a nuclear submarine
Richie. is an unknown quantity at this point
Send a message via MSN to Richie.
Looking good there Rich
Those 10's are so cool Wonder if i can get them on the Ka
Richie. is offline   Reply With Quote
Old 21-10-2009, 12:03 AM   #264
Zetecfiesta
Trader Score: (0)
Zetecfiesta is an unknown quantity at this point
Send a message via MSN to Zetecfiesta
great work!!
Zetecfiesta is offline   Reply With Quote
Old 21-10-2009, 12:07 AM   #265
xr4x4rs
Trader Score: (5)
Quote:
Originally Posted by Tev View Post
bla bla bla,
what you mean you scratched it, i got that near as god dam perfect
rich you know the ka needs 10s
__________________
Old 21-10-2009, 12:42 AM   #266
CarbonRick
PF Village Idiot
Trader Score: (0)
CarbonRick is an unknown quantity at this point
Send a message via MSN to CarbonRick
This will be a truly stunning machine. Keep the updates coming.
__________________
CarbonRick is offline   Reply With Quote
Old 21-10-2009, 01:41 AM   #267
CRAIG HAYTER
Trader Score: (0)
CRAIG HAYTER is an unknown quantity at this point
Send a message via MSN to CRAIG HAYTER
looking good Richy pm and let me know if you sold them fuel lines please?
CRAIG HAYTER is offline   Reply With Quote
Old 27-10-2009, 08:20 PM   #268
xr4x4rs
Trader Score: (5)
another little update
i finished sound deading the whole car again and also strengthened my rear turrets up
the sound deadening
the turrets, basically boxed them in, took me 2 days to work out how to do the plates, looks simple but i couldnt do it and was getting very very stressed as its so simple, got there in the end though, also seam welded the the complete strut before boxing it in
next is to start prepping the inside reay for paint
__________________
Old 27-10-2009, 09:22 PM   #269
Twellsie
Twellsie's Avatar
Trader Score: (1)
Twellsie is an unknown quantity at this point
looking good Rich
you like that seam sealant dont ya, lol
__________________
Twellsie is offline   Reply With Quote
Old 27-10-2009, 09:31 PM   #270
xr4x4rs
Trader Score: (5)
yes mate, just finishes it of lol and smooths out rough edges
__________________
Old 27-10-2009, 09:52 PM   #271
miller3
miller3's Avatar
Trader Score: (4)
miller3 is on a distinguished road
Send a message via MSN to miller3
Do i recognise those dolly wheels?
__________________
www.mattlewismotorsportonline.co.uk NEW ONLINE SHOP
http://www.passionford.com/forum/showthread.php?p=3849679#post3849679
Ronnie amis, sponsored by MOTORSPORT DEVELOPMENTS.
Doug miller, sponsored by PUKKA PIES
miller3 is offline   Reply With Quote
Old 09-11-2009, 10:14 PM   #272
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
any chance of sorting your pics out i really need to see your gear box tunnel cos ive got to do mine this week
__________________
Clicky
Old 09-11-2009, 10:29 PM   #273
graham c
Trader Score: (3)
graham c is an unknown quantity at this point
you going oceanliner box as well andy am thinkin of this but dont need it yet
__________________
just dont tell the wife how much it really cost
graham c is offline   Reply With Quote
Old 09-11-2009, 11:10 PM   #274
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
Quote:
yes i am going to mod tunnel while cars in bits so i havent got to do it later
__________________
Clicky
Old 09-11-2009, 11:25 PM   #275
xr4x4rs
Trader Score: (5)
pics should be back online soon, if not ill re host them as photbucket is wank
__________________
Old 09-11-2009, 11:42 PM   #276
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
thanks rich for the pics much appeciated mate
__________________
Clicky
Old 10-11-2009, 12:03 AM   #277
xr4x4rs
Trader Score: (5)
no probs mate, but you will need a gearbox to make sure the position is ok
im going to be measureing the length of mine as i just got measurements for thr r34 6 speed,so im hoping ive made enough room
__________________
Old 10-11-2009, 07:42 AM   #278
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Boooo i cant see the pics.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is online now   Reply With Quote
Old 10-11-2009, 10:30 AM   #279
M K
M K's Avatar
Trader Score: (8)
bandwidth exceeded!
__________________
Old 10-11-2009, 06:12 PM   #280
graham c
Trader Score: (3)
is it a 32 box your usin ? is their a push type and a pull type?
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Escort Cosworth Full Re-Build - B1 ADD ** Small Update ** AlexD Restorations, Rebuilds & Projects. 141 28-10-2009 04:33 PM
Paul's Focus Cosworth Build (late evening update 16/10/06) PaulCossie Restorations, Rebuilds & Projects. 185 28-04-2009 04:41 PM
S1 Full *CUSTOM* build from shell! *****NOW FINISHED****** Versus_Creations Restorations, Rebuilds & Projects. 131 02-07-2008 11:56 AM
RWD Fiesta Cosworth, FULL RE-BUILD, **UPDATED 21/7** pauldowts Restorations, Rebuilds & Projects. 191 27-12-2007 12:32 AM
Full Cosworth Rolling shell! Switch Ford RS Cosworth parts for sale 1 28-05-2006 05:01 PM
