escort cossie rebuild i update 8/4/16 supra diff fitted
Old 22-12-2008, 06:49 PM
  #121
xr4x4rs
xr4x4rs's Avatar
little bit more, as its so close to xmas i havnt bothered ordering anything incase it never turns up, sp started on the rear diff
so here it is nice and filthy
back plate off to look inside the diff
3.62 so at least i know its the correct diff
driveshaft joints out, i wanted to see if one of them would fit in the front diff so i can get rid of the std pop joint that always break but its slightly too big, but i think if it coudld be machined down i could get it too work, but ill look into this at a later date
all cleaned up and a nice bit of paint on it
alls i need to do is get some new bolts for the diff late, and send the drive flanes in for elcetro plating, so this iwll be after xmas now
also as i mentioned earlier on in the thread i was thinking of cutting the boot floor out for easier access to the fuel pump incase ieve need it well, out came the jigsaw!!!
before
after
just got to give it some sealant underneath and a lick of paint, then get some carbon sheeting and some rivinuts
Old 22-12-2008, 07:37 PM
  #122
The Youth.
The Youth.'s Avatar
brave man taking a jigsaw to an esc cos!
it's coming on great btw
steve
Old 22-12-2008, 07:43 PM
  #123
Simmo
Simmo's Avatar
Good stuff!!!
Old 22-12-2008, 07:45 PM
  #124
xr4x4rs
xr4x4rs's Avatar
steve
that is true mate, and i was sweating a bit doing it lol, but if the fuel pump does fail at least i dont have to drop tanks to get to it, i can just tae a cover off and its there
Old 22-12-2008, 09:43 PM
  #125
RSLUBBY
RSLUBBY's Avatar
Nice work cant wait to see it done mate
Ian
Old 24-12-2008, 07:05 PM
  #126
xr4x4rs
xr4x4rs's Avatar
little bit more done
hole is no all seam sealed up and painted again
and i cleaned my stub axles that go in the diff, you can see the difference between the one that hasnt been cleaned, but both are ready now for elcetro plating, just my batts went flat in camera
Old 24-12-2008, 07:11 PM
  #127
Nice work mate.Its nice to see another escos getting restored.Keep,you the good work.
Old 27-12-2008, 07:12 PM
  #128
xr4x4rs
xr4x4rs's Avatar
little update, over xmas ive been geting things ready for electroplating for the new year, so started off with my steering rack and dismnatling it
all dismantled ready
cleaned up and ready for the platers
steering racked all cleaned and painted
and today, i decided i need a vice lol, so went and bought this one
next was rear driveshafts
gaitors cut off as ill replace with new ones
had to buy some circlip pliers for this clip (copper colour ring in middle)
joints all off, these wont be sued as they have a lot of play in them for my liking, so ill get some new ones
grease al cleaned off
then i gave it a good clean as best as i can to get a decent finish from the platers, didnt want to have them blasted due to being a rough finish, you can see the diffference bewteen the cleaned on and the one that needs to be done
Old 27-12-2008, 10:32 PM
  #129
Nice work mate i will be watching this post till its finished.
Old 28-12-2008, 03:34 AM
  #130
fezzajsy
fezzajsy's Avatar
looking good
Old 28-12-2008, 10:16 AM
  #131
Kezmo
Kezmo's Avatar
Niceee!
Old 09-01-2009, 08:30 AM
  #132
xr4x4rs
xr4x4rs's Avatar
another little update
my abs pump arrived, so i started to strip this down to be cleaned
i was a bit nervous at this bit as i didnt know if it had pressure in it or not, luckily it never
all stripped down
started to mask and paint things then
got some stuff back from electro plating so was time rebuild it
also, i noticedf all the wiring had melted, so this item was changed from a spare unit i was using for bits mine was missing
new one
starting to take shape as a pump again
others bits ive had electro plated
rear diff all built back up, just need to put the tag on as i forgot, got new bolts from ford aswell
steering rack next
ends back on, loctited in and then punched back to hold them
new gearse applied on the ball joint ends and inside the rack as original stuff was a bit dry
gaitors back on with new cable tie
all pipes back on aswell
overall its come out better than id imagined
abs pump all fitted up aswell, just need to fit accumulator, but this was being painted at the time, also if anyone has a abs cap i need one as 2 of mine have snapped
Old 09-01-2009, 12:13 PM
  #133
Dunc Maclean
Dunc Maclean's Avatar
keep up the top work mate, love a good escos build thread!
Dunc
Old 09-01-2009, 04:27 PM
  #134
fezzajsy
fezzajsy's Avatar
luving this project
Old 09-01-2009, 04:45 PM
  #135
xr4x4rs
xr4x4rs's Avatar
thanks lads, some things are taking longer than planned as im still getting stuff out the way from xmas and new year
Old 09-01-2009, 05:14 PM
  #136
Tev
Tev's Avatar
looks good fella
Old 10-01-2009, 02:05 AM
  #137
svony
svony's Avatar
Thanks for the updates, you're buildup is few steps ahead of mine and it keeps me motivated. I just took delivery of a ABS unit yesterday, don't think I have the balls to take it aparts as you did yours. Really nice meticulous work...
Old 10-01-2009, 10:57 AM
  #138
Sweet its getting there slowly.
Old 10-01-2009, 07:00 PM
  #139
El Grand Tomismola
El Grand Tomismola's Avatar
Mint stuff - where you sending your stuff for electro plating?
Old 10-01-2009, 11:46 PM
  #140
xr4x4rs
xr4x4rs's Avatar
i just take it down to a local company that does it usually Ł20 a go, so before i go down i make sure what i have is a load of stuff to be worth the money
Old 11-01-2009, 03:02 PM
  #141
El Grand Tomismola
I could do with finding a place like that myself.
Old 11-01-2009, 05:21 PM
  #142
Sonic Boom
Sonic Boom's Avatar
Which company is it mate? Couldn't be to far a journey for me to make as it only takes half an hour to get to yours from mine.
Rich
Old 11-01-2009, 05:23 PM
  #143
Little_Hoss
Little_Hoss's Avatar
cant believe you got the shell for 5k
going to be awesome when finished mate!
Old 11-01-2009, 05:36 PM
  #144
RS-Stian
www.fordclubnorway.no
RS-Stian's Avatar
Quality work mate, love this resto thread. Do you have any finis code on the new bolts to the diff house?
Old 11-01-2009, 08:53 PM
  #145
Moonstone Mart
Moonstone Mart's Avatar
Stian,
The diff plate bolts i got are F1625498 and they were 67p each from my Ford dealership
Mart.
Old 11-01-2009, 11:24 PM
  #146
Jay,
Sponsor
Jay,'s Avatar
looks good u old tart
Old 12-01-2009, 12:54 AM
  #147
xr4x4rs
xr4x4rs's Avatar
lol, thanks lads
jay im not that old, not even in my 30s yet!!!
little hoss, i got more than a shell for that money, dont forget alls it was missing was engine, ecu, exhaust and brakes lol
i also found out it was one of the press cars and there is a picture of it as one of the launch cars going round brands hatch in a book called the cosworth fords just waiting on the book to turn up
Old 12-01-2009, 12:55 AM
  #148
xr4x4rs
xr4x4rs's Avatar
Rich
coma plating mate
Old 12-01-2009, 08:17 AM
  #149
Rs Adz
Rs Adz's Avatar
this coming on very well keep it up
Old 16-01-2009, 07:22 PM
  #150
andy escos
andy escos's Avatar
should be minty fresh when finished ya buftyna love the detail m8 top work.
Old 16-01-2009, 07:57 PM
  #151
xr4x4rs
xr4x4rs's Avatar
ordered a full set of poly bushes off burton wednesday and they turned up today
1st disaster was they never sent the main beam bushes and on the reciept said out of stock
i even asked if they had them all in stock before i amde the ordered
so with half the day gone and i had a lad on his way round from gloucester to buy some rouse bits i was a bit stuck as i wante dthe beam in today
so quick phone call to lloyd of passionford as i seen he was advertising some bushes, and he sold me the 2 main beam bushes, these are not the usual bushes aswell, they may aswell be metal there that strong
so i know have all my bits
so the beam all ready laid out, colours are different as i wanted it bright and shiney
the bushes
the tough bushes
couple of little bits from ford
my friend matt (jona bona) came round to help me fit these beam bushes as no where was open with a press due to the time of day, so 3.30pm he was here, got the beam in the vice and made our own little press machine with the vice and some old suspenion plates and cups, couple of attempts 9trying not to scratch the beam ) and they popped in lovely
we then went about fitting the beam, what a nightmare, the std bolts were to short as the bushes were taller, so quick phone call to llyod again and he said use engine cradle bushes to get them in and swap over to std bolts once plates were on, we tried everything frst with jacks and nothing
so when we looked we realised the arms had to go, so this was a simple job bar we put the arms on backwards, so left to right and right to left , soon enough changed over and went for another attempt
this did not go well, as the beam is heavy now and still couldnt get it in, so i bolted the diff on for some leavage, and we finally got the beam in after a lot of swearing and messing about and was 6.30pm when it finally went in
so couple of little pics of it in place with all new bolts
so alls i need knwo is a diff mount, driveshafts,wheelbearings, brakes, braklines,abs sensors and suspension and the rear is done, im going to try and order most of it next week, and try and find some abs sensors
but its getting there now and its getting closer to its wheels, doesnt seem much but i think it does, and im never taking this beam out again as its too much grief, roll bar will be on tomorrow if i can be arsed to get out bed
Old 16-01-2009, 09:37 PM
  #152
COS 22
COS 22's Avatar
looks well, keep the pics coming !
Old 16-01-2009, 09:58 PM
  #153
martrs
martrs's Avatar
Thats looking cool rich
Old 16-01-2009, 10:32 PM
  #154
xr4x4rs
xr4x4rs's Avatar
tried ringing u earlier, give us a ring when you get 5 mate
Old 16-01-2009, 11:10 PM
  #155
fezzajsy
fezzajsy's Avatar
Old 17-01-2009, 12:40 PM
  #156
Twellsie
Twellsie's Avatar
looking good Rich, which powder coaters do you use these days, i have a few bits i need doing?
Old 17-01-2009, 12:49 PM
  #157
Tev
Tev's Avatar
you havent got time to send things to the powder coaters, hurry up and change your cam cover over
Old 17-01-2009, 12:51 PM
  #158
xr4x4rs
xr4x4rs's Avatar
one not far from your work mate, up bayton road, duno the name but there on the same little road as just tyres i think the tyre place is called
Old 17-01-2009, 01:13 PM
  #159
TrevCos
TrevCos's Avatar
Wish I had the skills to do things like this, that is looking fab.
Old 17-01-2009, 01:41 PM
  #160
tezmanian devil
tezmanian devil's Avatar
smart project you got goin here dude, if only i could afford a esc cos
keep up the good work anyway chap, i'll see ya tomorrow
Quick Reply: escort cossie rebuild i update 8/4/16 supra diff fitted
