PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 23-10-2008, 12:59 AM   #1
cossie04
Trader Score: (1)
cossie04 is an unknown quantity at this point
Send a message via MSN to cossie04
Default Sierra 24v Estate - Ongoing project
I thought i`d put up a thread about my estate for those that are intrested in something slightly different. In June this year, i bought this estate which had been standing for about a year. When i come to collect it, the battery was flat so connected a decent battery and it started and purred like a kitten. So on the trailer and take it home. It started as 2.9 V6 4x4 Ghia in mercury grey, came with 16" alloys, full stainless exhaust, front Koni Adjustables, air-con, strut brace and loads of spare parts...
First job was to get it booked in for an MOT and see what it needed. Meanwhile, i had bought a set of Momo Arrows with a decent set of tyres and a cossie front bumper, so the wheels and bumper were fitted while waiting for the MOT.
A few days later, it went for its MOT and it failed mainly on one plate of welding, seized brakes and few silly little things.
The only bit that needed welding...
So then it went to my local mechanic, and a few days later it was MOT`d again! 8)
Once the Mot was done, i started to get bits together for the 24v conversion. Luckily, i had a 24v engine in my garage from a previous 24v project
Viscous fan removed
Cleaned up
So I ordered a new sump gasket set, 6 individual head to manifold gaskets, and 2 manifold to downpipe gaskets...
I also ordered some Vectra V6 injectors, these will be fitted at a later date...
Then i started by draining the oil from the 24v engine in order to remove the sump...
And off came the sump
It was at this point i was expecting to see loads of bits of tensioner blade in the bottom of the sump but to my amazement there was no bits at all, so i checked the oil pickup pipe and it was all clear with no bits stuck in it. Next we removed the oil pick up pipe and fitted a 12v 4x4 item which is slightly shorter and has a slightly different angle on it to clear the modified 4x4 sump, and removed the windage plate so the sump would fit. Then the gasket and sump were fitted along with the modified oil return pipes, front diff and a new oil filter...
Then the i started removing the engine and gearbox from the estate. My method for removal was to unplug wiring and pipes from engine, unbolt the exhaust and 2 props, remove starter motor and gearbox, remove front driveshafts, and lift engine out the top. Had a couple of problems along the way but found a way round them. Couple of pics of car being dismantled...
Nearly out...
And out...
The next day i started off by refitting the 2.9 clutch and flywheel, then fitting the gearbox, front prop,starter motor and crossmember
The crossmember needed modifiying to allow clearance for the oil return pipe so a small bit was shaved off on one side
Once that was all ready, i set about removing the existing crossmember and anti roll bar so that i could fit the new engine and gearbox by laying the engine in front of the car and carefully lifting the car over the engine...
And all bolted in...
And that is how it sits at present. Today i fitted the steering rack, anti roll bar and lower arms, front bumper and the rear prop. Now i am ready for the wiring loom which will be fitted shortly, so tommrows job is to tidy up the engine bay and do what i can for the moment.
cossie04 is offline   Reply With Quote
Old 23-10-2008, 09:28 AM   #2
JohnnyB
Trader Score: (0)
JohnnyB is on a distinguished road
good work mate
__________________
Passionfords Sex therapist, If you need info or need a hand, I have done it all!!!!!!
PSN emcclariion
JohnnyB is offline   Reply With Quote
Old 23-10-2008, 09:40 AM   #3
Daveysaff
Skint Passionford User
Trader Score: (8)
Daveysaff is an unknown quantity at this point
Dave Caraher
Send a message via MSN to Daveysaff
Looks good
__________________
I'm gonna finish it soon....... Honest
MEATPIES!
help support C.R.A.P!!!
Daveysaff is offline   Reply With Quote
Old 23-10-2008, 11:25 AM   #4
wess-rs
wess-rs's Avatar
Trader Score: (0)
wess-rs is an unknown quantity at this point
Send a message via MSN to wess-rs
Good job!!
__________________
2011 Fiesta S-Edition.
2001 Fiesta Zetec-s
1982 Escort mk3 1.6 turbo.
wess-rs is offline   Reply With Quote
Old 23-10-2008, 09:05 PM   #5
the youth
Trader Score: (1)
the youth is an unknown quantity at this point
Send a message via MSN to the youth
doing a good job m8, I remember doing my 24v conversion last year, enjoyed doing it.
steve
__________________
Mondeo ST TDCI and XR4x4 cosworth YB race car
NSSCC 2011 16th overall and 3rd in class B
Matt lewis motorsport supporting my racing in 2011
http://www.mattlewismotorsport.co.uk/
the youth is offline   Reply With Quote
Old 23-10-2008, 09:12 PM   #6
Northants Ford Fan
Trader Score: (0)
Northants Ford Fan is on a distinguished road
looking good mate, reminds me of my old 4x4 estate that used to surpise a few people especailly at mk doing donuts on the spot, people were like that wont do anything, soon made them eat their words
Northants Ford Fan is offline   Reply With Quote
Old 23-10-2008, 10:32 PM   #7
cossie04
Trader Score: (1)
Thanks for the comments.
Well, today i just sorted the odds and sods out. Also spoke to Simon who is doing my loom and he says he should be able to come and fit it in the next couple of weeks. So meanwhile, i hope to get the exhaust fitted. I`ll be using the top halfs of the 24v downpipes cut just below the lambda sensors and then it will be welded to the bottom halfs of the 12v downpipes. So i`m on the hunt for a standard 4x4 exhaust to use with the downpipes as the current exhaust is a bit too loud at times.
So i ftted the n/s manifold...
Then fitted the power steering bottle...
Then connected the fuel and water pipes and fitted the airbox using the original bracket and cutting the lug off the side of the box. Then i connected the accelerator cable along with the clutch cable, and refitted the gearstick gaitor and trim. Starting to look good at this stage
Tommorow, i`m going to do the oils. Top the gearbox and front diff up with oil and also put some engine oil in. Will also look into fitting the electric fan for the cooling.
Old 24-10-2008, 02:24 AM   #8
BillyCabrio
BillyCabrio's Avatar
Trader Score: (1)
Location: Dartford, Kent - Home of the two way one way system.
BillyCabrio is an unknown quantity at this point
Send a message via MSN to BillyCabrio
__________________
If Ford made Cabriolets like Carlsberg make beers, then this would probably be the BEST Cabriolet in the world.......
^^^^^^^^^^^^^^^^^^**CLICKY SIGGY**^^^^^^^^^^^^^^^^^^
BillyCabrio is offline   Reply With Quote
Old 25-10-2008, 07:22 PM   #9
cossie04
Trader Score: (1)
Managed to get some downpipes today and a half decent centre section. The back half has been cut off but I have a couple of back boxes and bits of pipe to try when it comes to be fitted...
Also painted a set of sideskirts i had in the garage, will fit these in the next day or two...
Old 25-10-2008, 07:35 PM   #10
SOO
Trader Score: (0)
SOO is on a distinguished road
Send a message via MSN to SOO
looking good mate!!
SOO is offline   Reply With Quote
Old 25-10-2008, 08:23 PM   #11
marky_g
Fleet Manager
Trader Score: (0)
marky_g is an unknown quantity at this point
Send a message via MSN to marky_g
cool
__________________
Click to see my RS Turbo project
http://passionford.com/forum/showthr..._g#post3406438
marky_g is offline   Reply With Quote
Old 25-10-2008, 08:23 PM   #12
Roosie
500bhp Cosworth in making
Roosie's Avatar
Trader Score: (7)
Roosie is an unknown quantity at this point
Send a message via MSN to Roosie
looking good mate
Roosie is offline   Reply With Quote
Old 03-11-2008, 01:20 AM   #13
cossie04
Trader Score: (1)
Bit of an update...
I`ve now had the exhuast done thanks to rob at my local garage. We used the system above which was modified to fit the 24v, the downpipes were cut and mated to the 24v downpipes just below the lambda sensors.
Drivers side downipe modded and rewelded...
Then fitted...
Then the passenger side pipe was modded and welded. On the 2.9 12v exhaust, you have a slide on mount on one pipe and a coupling mount on the other, so the slide on mount was modified to take a coupling to make fitting/removal easier and then was all fitted...
Then it was just a case of fitting the centre section and modifying a granada backbox to fit it...
With that done, i started to remove the dash in order to fit the new wiring loom. Most of the dash is now out with only the main bit still in the car ready to come out tommorow...
Then the loom can be fitted as and when my sparky can get round to it. Theres also a couple of odd jobs i have to do tommorow so will update again shortly...
Old 03-11-2008, 02:04 PM   #14
gainzo
Trader Score: (0)
gainzo is on a distinguished road
looks sweet mate keep up the good work
gainzo is offline   Reply With Quote
Old 09-11-2008, 02:43 AM   #15
cossie04
Trader Score: (1)
Small update. Today i managed to get the cooling fan fitted. I used the air con fan which was modified to fit the radiator and fits nicely...
Air con rad + fan removed...
Fan then fitted using a modified bracket at the top and cable ties around the sides, lol...
Mangaged to take the clocks apart and fit the 24v rev counter, forgot to take pics while doing it tho...
My HID kit also turned up in the post...
Went for the 8k bulbs in the end and what a difference they make...
All fitted...
The kit was so easy to install aswell and was completely plug and play, took about 30-40 mins fitting...
Also made up a little bit of extension pipe for the power steering fluid return, used from an old bit of fuel pipe...
Old 30-11-2008, 10:14 PM   #16
cossie04
Trader Score: (1)
Last week, the old 12v engine loom was removed ready for the new 24v loom. Yesterday, the new loom was fitted, along with the EGR bracket and EDIS 6 module. On the first turn, it didn`t want to start, so i changed the fuel pipes round and she started straight away!
With that done, i`ve started fitting the dash back in, bar the drivers lower dash part as some wires still need connecting. Still plenty off things that need finishing off, that will be done over the next couple of weeks. I`m also pleased to report that i`ve done 183 miles towing a car and trailer since the conversion, and pleased to say, didn`t miss a beat once!
Photos and another small update to follow...
Old 30-11-2008, 11:21 PM   #17
boothy
Trader Score: (14)
boothy is on a distinguished road
good stuff mate, bet it sounds cool.....
boothy is offline   Reply With Quote
Old 01-12-2008, 08:26 AM   #18
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
What a spot on b there mate.I thought it was ilegal to work on your car at the side of the road.I friend of mine had an estate with the same engine in and he said it went like fook.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 09-01-2009, 04:48 PM   #19
James
Trader Score: (0)
James is an unknown quantity at this point
Send a message via MSN to James
very impresssive stuff!
i want one!
any further update?
__________________
James is offline   Reply With Quote
Old 10-01-2009, 12:39 AM   #20
cossie04
Trader Score: (1)
Quote:
i want one!
any further update?
Not just yet, apart from it`s covered in filth and needs a bloody good wash lol
Fitting Vectra injectors soon, photos to follow...
Ed.
Old 10-01-2009, 04:50 AM   #21
kev 3dr
Trader Score: (1)
kev 3dr is an unknown quantity at this point
Send a message via Yahoo to kev 3dr
Im likin this alot and making me want another 4by estate !!!
__________________
Clito 172 track toy
another project to come soon..........
www.impactsignsanddesigns.co.uk
kev 3dr is offline   Reply With Quote
Old 13-11-2009, 03:17 PM   #22
cossie04
Trader Score: (1)
I`ve just realised i havan`t updated this thread for a while so i`ll give you a quick summary...
I`d done 15k miles on the new 24v engine and was really pleased to say the least. That was until the front prop snapped while in motion causing a split in the sump and putting a hole in the gearbox. I then decided to convert the car to 2wd as this was the easiest option as i already had most of the parts. All fitted back together, 150 miles later and the engine decides to eat itself internally . So another donor car was sourced and the engine was robbed out of it, then fitted to the estate. Then almost immediatley after, the rear diff decided to die so its been parked up ever since.
I`ve decided to pull my finger out of my arse and get it done now, the car has gone for an mot today so will update soon...
How it looks at the mo...
Old 13-11-2009, 03:28 PM   #23
S1 Combi
S1 Combi's Avatar
Trader Score: (0)
S1 Combi is on a distinguished road
sorry to hear of the bad luck mate,hope its sorted soon
__________________
210 BHP & 194 lb/ft
S1 Combi is offline   Reply With Quote
Old 13-11-2009, 03:44 PM   #24
m4tt274
m4tt274's Avatar
Trader Score: (2)
m4tt274 is on a distinguished road
Send a message via MSN to m4tt274 Send a message via Yahoo to m4tt274
this looks really cool m8. and good man for driving it.
what went wrong with the engine?
__________________
mk1 fiesta restoration! - http://passionford.com/forum/restora...-now-on-d.html
m4tt274 is offline   Reply With Quote
Old 14-11-2009, 08:07 PM   #25
escort van s.n
escort van s.n's Avatar
Trader Score: (0)
escort van s.n is on a distinguished road
very cool car
__________________
white van man rule the highways
escort van s.n is offline   Reply With Quote
Old 14-11-2009, 08:51 PM   #26
mk3_escort
Advanced 5 Door User
mk3_escort's Avatar
Trader Score: (0)
mk3_escort is on a distinguished road
great stuff, havent seen a Sierra estate on the road for ages
mk3_escort is offline   Reply With Quote
Old 15-11-2009, 08:30 AM   #27
cossie4i_
TT T38 Power
Trader Score: (11)
cossie4i_ is an unknown quantity at this point
Send a message via MSN to cossie4i_
Suprised i have never seen this thread before
I do miss my old 24v 4i
Sorry to read about your current troubles.
Steve
__________________
TT T38, AB07 Cam, Ported Head, Hart Inlet, Spec-R intercooler, Air Injectors, Gripper Diff , Turbosystems Mapped.
cossie4i_ is online now   Reply With Quote
Old 15-11-2009, 01:01 PM   #28
johnandhissaffy
white fords look best
johnandhissaffy's Avatar
Trader Score: (1)
johnandhissaffy is on a distinguished road
Send a message via MSN to johnandhissaffy
looks nice mate good work love this
__________________
psn = johnsrules
johnandhissaffy is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
My project Sierra GT 24v Cosworth Remko GT Restorations, Rebuilds & Projects. 30 12-10-2009 03:14 PM
mk3 5dr RSturbo estate update 27/8 Mr.T Restorations, Rebuilds & Projects. 117 27-08-2009 08:23 PM
Mk3 ESCORT ESTATE ---> S1 Estate Project - No longer for sale. 7xrskb Cars for sale 10 13-04-2008 09:50 PM
My ongoing Escort Cosworth project SortedCossie Restorations, Rebuilds & Projects. 18 30-10-2007 10:27 PM
Focus RS Ongoing Project. pd689 Restorations, Rebuilds & Projects. 41 13-07-2007 03:13 PM
