| Register | Photo Gallery | Knowledge Base | Gold & Trader Accounts | Rules | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | My Recent Topics | Garage |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Display Modes |
#1 | |||||
__________________
![]() my saff rebuild http://passionford.com/forum/restorations-rebuilds-and-projects/261868-saff-re-re-build-smooth-bay-almost-complete-chrome-powder-coat-update-4-1-10-a.html my rs1600i van build http://passionford.com/forum/restorations-rebuilds-and-projects/203327-mk4-to-mk3-escort-van-rs1600i-rep-new-pics-15-12-07-a.html Last edited by jaimesdna; 04-01-2010 at 06:17 PM. |
#2 |
![]() ![]() ![]() Brian |
#3 |
how clean is that; love it on the white rimsawesome bud, credit to you! |
#4 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() a light skim of filler to see how thing are going ![]() ![]() ![]() the curve of this side of the slam panel is different to the passanger side so i made a template of the curve. cut slits into a piece of angle to bend it to the correct curve then welded it into shape ![]() taked into place ![]() welded in & ground down ![]() ![]() another skim of filler ![]() shoud hopefully be able to rub down the filler tomorrow to see how much more work needs doing
__________________
![]() my saff rebuild http://passionford.com/forum/showthread.php?t=261868 my rs1600i van build http://passionford.com/forum/showthread.php?t=203327 |
#5 |
Bufty
Very nice indeed though m8. |
#6 |
wow looks good cant wait to see it all painted!
keep up the good work!!
__________________
Eats Scoobys for Breakfast and Evos for Lunch! |
#7 |
you'll have a long time to wait to see it painted due to my lazyness lol
__________________
#8 |
i'm thinking about painting the whole car in base white. should dazzle a few people
__________________
#9 |
Looks really nice. good work
__________________
#10 |
YES I KNOW I CANT SPELL
dat looks rude mate very nice
#11 |
done sone more work this morning on the slam panel. just smoothing filler. there really is a nack to filler & i've just not got it lol
__________________
#12 |
looks great james.
where did you get the RL7's from? They 18's? Mart.
__________________
Check out my 2WD sapphire Cosworth resto thread right here >>>> http://www.passionford.com/forum/viewtopic.php?t=297533 |
#13 |
looks wicked...
#14 |
Looks great ,you cant beat a nice smooth engine bay
__________________
#15 |
look's fookin lovely..
nice work keep the pic's comin.. imo you should colour code the alloy's tho..
__________________
foot down,aRSe out,pulled over,banged up
#16 | |
Quote:
they were advertised in the back of fast ford about 5 years ago. cost Ł200 but there was a 500mile round trip to go & get them. yes they are 18's
__________________
#17 |
the whole car is gonna be painted base white (the whitest white), if the wheels stay white i'll re paint them the same white
__________________
#18 |
I really like that!! Very very very nice!!
#19 | |
Quote:
it's a lot whiter than the creamy diamond white..
__________________
#20 |
very very nice . some top work there
#21 |
cossie690 there are a few posts on here somewhere about alternative whites. moste people said the whiteset white was the base white used to mix all other whites.
__________________
#22 | |
Quote:
can't wait till it's finished!!
__________________
#23 |
thats coming along nicely.
#24 |
that looks real nice i like it.
what springs do you have on the back? what does it drive llike bein that low? have you got shims on the back? and one more question lol, where did you get the fuel pump cradle? cheers mate. good luck with the rebuild |
#25 |
they are castle performance springs. handling is ok, im sure it would be much better if it sat a bit higher so that is a bit of a compremise i guess. yes it has got some shims on the rear courtesy of mike r. the fuel pump cradle is just the standard one been powder coated silver
__________________
#26 |
Post Whore
cool never seen a saff done like that
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 OME+ XR3i http://passionford.com/forum/restorations-rebuilds-and-projects/247202-my-xr3i-project-engine-progress.html |
#27 |
never really liked the tow eye, so off that came. there was also a repair needed to the cross member wher the meta is double skinned & water had got in. all the rot was cut out & replaced with 2mm steel
![]() ![]() ![]() ![]() ![]() this leaves the problem of no tow eye. so thanks to my mate tony a new one was made. the actual tow eye was from his old fiat bravo. he then drilled & tapped a piece of round bar to screw it into & cut some strenghting plated to weld round it. then weld them to the cross member. i was gonna fit this to the middle of the crossmember but i'm now thing it will probably just cause it to bend, it will probably be welded to one side ![]() the bottom end is now back together with the help from tony all the old parts were checked & re used as they had only done 6000 miles. the compression was lowered & valve cut outs were done by harvey gibbs courtesy of mike r ![]() also new high quality long studs were purchased from mike r, so hopefully wont be having any problems with these ![]() after a long time searching for a good head with lots of life left in it i finally founf this on ebay for Ł650. its fully ported & has double valve springs. it was check by harvey through mike r & found to be a good head. ![]() ![]() ![]() ![]() as the engine is long studded it causes problems doing up the nuts as you cant get a 18mm socket in the holes. so there are two choices, machine down a socket or machine the holes bigger. as i thought id probably just end up loosing the socket i guesse it'd be a better option to machine the head. this was done by another mate of mine who is a precition engeneer. he is the same person that machined the broken studs out of the block. ![]() these are some of the other parts i have brought alloy air box lid to fit a t4 inlet pipe. Ł70 off ebay. i'm really happy with it. the quality is excelent ![]() ![]() verniers from jasesapphy .i also got some brembo 8 pot calipers from an amg merc. these really are huge ![]() ![]() i will get some audi rs4 356mm disks to go with these when i have spare cash i mocked up some disks just to make sure they fit behing the wheels ![]()
__________________
#28 |
after a long time searching i finally found a small turbo plenum chamber. these thing are like rocking horse shit to find & normally cost a fortune. i got this from a passion ford member (cant remember who) for Ł150 delivered. i'll probably get the hole for the air charges sensor welded up & moved to the middle. then get it powder coated the same as the old one
__________________
#29 |
great work
loving the amg calipersill keep my eye on this |
#30 |
here's a small up date. finally started the passanger side inner wing
![]() not too sure what this hole is for, so out it came ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() thats about it, will update again soon
__________________
#31 |
Virgin-popper
Fav project of the month! Keep up the good work
#32 |
looks awesome
#33 |
looking sweet as always bud keep it up
#34 |
Only just spotted this... top work!!!
![]() I'll be keeping an eye on this...
__________________
![]() Sapphire Cosworth Build... From Scratch!!!... MAD built, Vi-PEC managed... coming soon! West Sussex RS Owners Club |
#35 |
great work there mate,they calipers look peak
#36 |
like the under bonnet job alot
MORE PICS
__________________
2001 mondeo tddi stv 87/91 cossie 4x4 stage 3 x'car 92 fiesta rs 1800 sorry for my bad english * |
#37 |
update time. its been cold so i've been avoiding going out int the garage unitill i got a heater. after looking i found this on ebay
![]() so im now running out of excuces to not not go out there i sold the amg calipers as it was gonna cost a fortune to get disks bell etc. so with a big thanx to NUTS RuS i got these. 350mm disks & brembo 4 pot calipers. the calipers will be painted white to match the car ![]() the tow eye is now welded in with strengthining plates ![]() ![]() ![]() ![]() oil cooler brackets are welded in althout im not gonna be running the oil cooler at the moment ![]() ![]() ive brought some aero catches to hold the front bumper on ![]() ![]() ![]() ![]() i had to make some drop brackets to mount them but i'll add some pics of them later ![]() finally today i got the bay in primer, dusted with black & ready to rub down ![]()
__________________
#38 |
looking good..brakes look awesome.how much were they? pm me if you prefer
#39 |
swindon rsoc
looks spot on mate! think i might copy your idea of the heater! then i havent got a excuse not to get some more done on mine!!!
#40 |
lookin good mate i think the RL7s look awesome in white mate
__________________
![]() BWC = BLACK & WHITE CAT http://www.cheshirersoc.co.uk/forum/ http://sierrarscosworth.com/ http://passionford.com/forum/restora...ff-update.html my on going resto Last edited by hitchwest; 22-02-2009 at 07:23 PM. Reason: cos im fick |
| Tags |
| chrome, churches, coating, company, hhghg, michellejanecouk, powder, saffyahoocokr |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| my saff build hopfully with pics | bamcossi | Restorations, Rebuilds & Projects. | 1 | 05-06-2008 10:46 PM |
| Will 4wd saff (REAR) brakes bolt straight on a 2wd saff | lawnsy | General Discussion. | 13 | 28-05-2006 07:52 PM |
| Saff Cossie - track car build cancelled! All parts for sale! | RichardPON | Restorations, Rebuilds & Projects. | 222 | 02-01-2006 06:27 PM |
| Saff Engine Build (Lots of pics) | cossiestu | Restorations, Rebuilds & Projects. | 8 | 26-04-2005 08:12 PM |
| Ok the saff re build has begun!(56k beware) new pics 5/4/04 | warleydaddy | Restorations, Rebuilds & Projects. | 76 | 15-05-2004 01:39 PM |
