PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 25-08-2008, 09:09 PM   #1
Lee_R21Turbo
Trader Score: (1)
Lee_R21Turbo is an unknown quantity at this point
Default My Clio 172 Track Bitch
Thought I may aswell do a thread on PF about my track toy - I know a few of you have already seen it at a couple of track days so I thought I'd explain what I've done to it & what plans I have for it.
I bought it like this approximately a year ago......much cheapness too...Cat D write off.
First things first - time to strip it of anything unwanted...
Then I took it to my mate to fixup for me as he had a jig. It needed a new slam panel, new front panel, replacement subframe, new headlight and a slight tug on both chassis legs to straighten them up (hence the reason I decided to turn it into a track toy). It already came with a new bumper, wing & radiator which was handy.
See the crease in the chassis rail...
All fixed up (yes the new panels are a different colour of silver...couldnt be arsed having them painted - might do at a later stage though!!)
Once back from my mates bodyshop I needed to get it ready for its first trackday & MOT - so I fitted an ITG air filter I had lying around, front strut brace, bonnet pins...
....Cobra bucket seats & 2" harnesses..
...Silenced De-Cat pipe & Stainless Magnex Exhaust system with Oval outlet, new number plates....
I also fitted a rear strut brace & Alpine MP3 headunit - cant find pics though!!
She sailed through her MOT - I got her taxed & insured...£400 for the year.
I did my first trackday in her at Christmas last year at Donnington which passed without a hitch. Nothing more was done to it. I then did Bedford in Jan this year where I had my first couple of breakages....namely brake pads, discs & a driveshaft - nothing too major considering the abuse it took!
So a few more upgrades where purchased...
Eibach Springs, Braided Brake Lines, Grooved Discs & Carbon Lorriane Pads...
I sourced a 2nd hand driveshaft & filled the gearbox with Silkolene Pro Fully Synthetic Oil - we where now all ready for the Donington Track Day at the end of February.
After 3 sessions at Donington & the clutch gave up. Fortunately it wasnt that bad that I couldnt drive home on it. I was a little pissed off admittedly but thought well sod it - shit happens & it maybe a good time to upgrade a few parts. For the record the clutch material on one side had sheared from the plate & detached itself - a common fault I believe but it had lasted 50k so not all bad really.
Now this is where things start to go way out of control & the budget cheap track toy starts getting a bit serious & expensive!!!
I removed the engine & box together and instead of just replacing the clutch with a standard item I decided to go with a 4 paddle clutch. I also sent my gearbox away for an overhaul & to have a Gripper Diff LSD fitted into it. Now this took over 5 months to get back so I started buying other bits & pieces as I was bored.
New set of wheels...Compomotive 6 Spoke 16"
Jenvey Throttle Bodies..
Also purchased but I havent got pics of them yet...
3" Harnesses (to replace the skinny 2" efforts), new camera mount, rear camber shims, 182 Manifold & de-cat pipe, aftermarket management - Adaptronic, throttle body airfilter, throttle cable & throttle pedal off an early 172, powerflex dog bone mount, fire extinguisher, coilovers (should the lad ever get in contact with me), 300mm Sparco steering wheel & hub, 15" cut slicks, oil pressure & temp gauge.
Then whilst I waited for the gearbox to come home I relocated the battery into the boot..
Whilst the engine was out I also replaced the cambelt, turns out it didnt actually need doing as it had been done fairly recently as the belt was mint but least its piece of mind. I also ditched the air con pump & made a couple of bodge adjustments to the aux belt by way of a modded cosworth alternator bracket, MR2 1400mm 6 rib belt, Saab idler pulley & a 172 non air con alternator..
This brings us upto this weekends activities - engine & box is now back in place & up & running after a bit of stress getting it started due to me forgetting to re-attach the main ECU earth....anyway....
...the quip fetish has started....
Oil Cooler...
Breather...
Modded decat pipe to meet the 172 exhaust system...
More updates as & when they happen...not fitting the throttle bodies till after Christmas now as I want to do another couple of track days before the end of the year & I dont want anymore holdups!!!
__________________
Lee
'Just Modify It'
Renault 21 Cosworth, Volkswagen Bora Daily Drive, Renault Clio 172 Track Toy
Lee_R21Turbo is offline   Reply With Quote
Old 25-08-2008, 09:10 PM   #2
jacko
Trader Score: (0)
jacko is an unknown quantity at this point
Send a message via MSN to jacko
i found a clio cup race car a while ago and was daft enough to give it back lol
__________________
Paul Linfoot rs500 registrar questions and answers and spares
07759729390
jacko is offline   Reply With Quote
Old 25-08-2008, 09:15 PM   #3
Lee_R21Turbo
Trader Score: (1)
Jacko....what the hell did you do that for - they are awesome on track & seriously show up alot of much more expensive machinery!!
__________________
Lee
'Just Modify It'
Old 25-08-2008, 09:17 PM   #4
rapidcossie
Trader Score: (0)
rapidcossie is an unknown quantity at this point
Send a message via MSN to rapidcossie
Lee....how much did you spend to get the car bought fixed and on the track before you started modding it?
__________________
Euan
Fastest Sierra in Scotland
188.1 mph at brunters in the wet
Built,tuned and prepared by AVA turbos
rapidcossie is offline   Reply With Quote
Old 25-08-2008, 09:18 PM   #5
jacko
Trader Score: (0)
it was a propper thing mate ill get some pics for you it was fast
__________________
07759729390
Old 25-08-2008, 09:25 PM   #6
Lee_R21Turbo
Trader Score: (1)
Quote:
Bought the car off fleabay for £1980 (should of been £2k but the lad didnt tell me the engine cover was missing so knocked him down )
Sold interior, spare wheel, headunit & cd changer, drivers Xenon headlight plus other odds & sods so made back about £300 by doing that.
Subframe cost me £70 used, slam panel & front crossmember was £80 ish, headlights say £60 for arguments sake. My mate didnt charge me anything for doing the work....yet...well I sort out his computer stuff & never charge him so give & take thing.
Seats & harnesses cost me £100 off fleabay - after all you need seats! lol
So it stood me at roughly £2000 before I started modding & going off the rails.
Jacko....please mate would be interested to see it.
__________________
Lee
'Just Modify It'
Old 25-08-2008, 09:26 PM   #7
rapidcossie
Trader Score: (0)
I remeber that thread about finding that car!
Lee....quite a cheap car then as it would be worth double that easy yeah?
__________________
Euan
Old 25-08-2008, 09:29 PM   #8
jacko
Trader Score: (0)
here you go the bloke didnt give us a thing for finding it storing it for 3 days then giving it back
__________________
07759729390
Old 25-08-2008, 09:32 PM   #9
Lee_R21Turbo
Trader Score: (1)
Roughly mate yes, at least double, I couldnt find anything of its age in normal condition, on the same milage for anything less than around £4500 - ok its been recorded as Cat D but well the only thing that gives it away is the crease in the chassis rail that you cant see normally as the gearbox mount covers it...very cheap really - out the box they are a crackin car for track use - only downside is the slight lack of grunt for the straights (although the corner speed you can carry especially on slicks more than makes up for this most of the time) which the throttle bodies should sort to a certain extent.
__________________
Lee
'Just Modify It'
Old 25-08-2008, 09:33 PM   #10
rapidcossie
Trader Score: (0)
Quote:
Quite fancy a wee teack car like this that could be used on the road too and always liked clios.
__________________
Euan
Old 25-08-2008, 09:38 PM   #11
Lee_R21Turbo
Trader Score: (1)
I seriously cant fault it mate - I did Croft in JCs 172 Clio last year, which made me buy one to be honest. Apparently I was lapping approx 1-2 seconds off Si B in his EVO & Ste_RW in his M3 - unfortunately I was unable to do Croft this year as my gearbox still wasnt back from having the Gripper fitted. I think Mr Rainbird was quite impressed with how it went at Bedford aswell - I had a good tussle with Charlie in his Cupra R & we were very evenly matched!!
__________________
Lee
'Just Modify It'
Old 25-08-2008, 10:01 PM   #12
jacko
Trader Score: (0)
i was thinking about one of the older 16v ones for me self
__________________
07759729390
Old 25-08-2008, 10:14 PM   #13
Lee_R21Turbo
Trader Score: (1)
Theres a guy that usually does Dono whenever I'm there, hes got a modded Williams 3, cage, coilys etc - before I started modding we were very evenly matched lap after lap - I'm now hoping after the money & effort I've put into it I should be able to gain on him now!
__________________
Lee
'Just Modify It'
Old 25-08-2008, 10:56 PM   #14
Shorty
Trader Score: (1)
Shorty is an unknown quantity at this point
Send a message via MSN to Shorty
SLAG!
Will have to blag a passenger ride mate, looks like a riot this.
__________________
Shorty is offline   Reply With Quote
Old 25-08-2008, 11:07 PM   #15
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Trader Score: (1)
Charlie Chalk is on a distinguished road
Send a message via MSN to Charlie Chalk
Euan, you'll love it, Went out with Lee a few times at donno xmas last year, was a good passneger ride, Even the grass cutting
I drove my mates the other day and was in it for about an hour, and loved it, handle well for a standard car
With a few mods, I'd imagine there top fun
Nice one on doing the thread, will watch this Lee
__________________
GE - 1D - T
Charlie Chalk is offline   Reply With Quote
Old 25-08-2008, 11:20 PM   #16
JonnyBravo
Trader Score: (0)
JonnyBravo will become famous soon enough
Cool car Lee, shame I won't have something suitable to rape you in at Donny
__________________
JonnyBravo is offline   Reply With Quote
Old 26-08-2008, 12:48 AM   #17
richard_syko
richard_syko's Avatar
Trader Score: (0)
richard_syko is an unknown quantity at this point
Cool car
richard_syko is offline   Reply With Quote
Old 26-08-2008, 07:48 AM   #18
Spiky
Spiky's Avatar
Trader Score: (1)
Spiky is an unknown quantity at this point
Send a message via MSN to Spiky
poor car
dones't know what it's got ahead of it
cool project, looking to buy one of these for normal road use
Spiky is offline   Reply With Quote
Old 26-08-2008, 08:45 AM   #19
maxest
Trader Score: (1)
maxest is an unknown quantity at this point
Coool thread and coool car! I didnt think much to these clios until i took one to croft the other month,,, now i'm looking for another to use solely for track use,,, still not sure whether to buy a standard road car and strip it, or go all out and buy a cup car,, thing that puts me off those is that there all LHD
Look forward to more updates
__________________
www.cosworthrsspares.co.uk
maxest is offline   Reply With Quote
Old 26-08-2008, 09:00 AM   #20
Spiky
Spiky's Avatar
Trader Score: (1)
cup cars are 8k ish, and come with sequential
building a good spec one will be cheaper,
but i'd get a cup car if i was doing it again
Old 26-08-2008, 09:03 AM   #21
maxest
Trader Score: (1)
I know they are been looking at a couple,,, two thing against is that 8k is alot of money sat there when it will prob get used at a guess 10 times a year, also the sequential box although cool, will prob be alot of upkeep,,, whereas i can buy a nice 172 for 3k ish,, strip it out, set of slicks and that'll do... also at 8k i would prob prefer an evo
__________________
Old 26-08-2008, 10:34 AM   #22
Charlie Chalk
Unknown.
Trader Score: (1)
Cup car for 8k? Any links?
Lee, you need a dash like the one Jacko posted
__________________
GE - 1D - T
Old 26-08-2008, 10:40 AM   #23
Lee_R21Turbo
Trader Score: (1)
Funny you should say that - there was one on ebay the other week - only problem being is that all cup cars are LHD so it wouldnt fit mine!!
__________________
Lee
'Just Modify It'
Old 26-08-2008, 10:41 AM   #24
_DAN_
Yoon
Trader Score: (0)
_DAN_ is an unknown quantity at this point
Cool project. Love how it started off simple and cheap.
_DAN_ is offline   Reply With Quote
Old 26-08-2008, 10:48 AM   #25
Charlie Chalk
Unknown.
Trader Score: (1)
Make one Lee, Don't exactly look hard does it!
__________________
GE - 1D - T
Old 26-08-2008, 10:51 AM   #26
Lee_R21Turbo
Trader Score: (1)
Naah - cant be arsed - I'm having a standard one flocked though!!!
__________________
Lee
'Just Modify It'
Old 26-08-2008, 10:52 AM   #27
Charlie Chalk
Unknown.
Trader Score: (1)
Fair one, you doing donno xmas??
__________________
GE - 1D - T
Old 26-08-2008, 10:58 AM   #28
Lee_R21Turbo
Trader Score: (1)
Yes mate....gotta book it yet!
__________________
Lee
'Just Modify It'
Old 26-08-2008, 12:12 PM   #29
vibrating_cake
Trader Score: (0)
vibrating_cake is an unknown quantity at this point
brilliant little cars!!!
i love the track slag on a damaged shell idea!
propper fun little car, i bet you'll have some great times in it!
keep us updated!!!
__________________
2.0 16v ZETEC power yea---- 4-2-1 cammed 45's on management and some bald tyres!
vibrating_cake is offline   Reply With Quote
Old 26-08-2008, 10:21 PM   #30
Andy_R
Trader Score: (3)
Andy_R is an unknown quantity at this point
Its come a long way Lee, look forward to a shot once the geometry is sorted the ATB will assist heaps too, im sure. Donno last Christmas was scarey, it just didnt handle right at all! Roll on the boddies being fitted
__________________
Andy_R is offline   Reply With Quote
Old 26-08-2008, 10:30 PM   #31
Phil2002
Phil2002's Avatar
Trader Score: (2)
Phil2002 is on a distinguished road
good stuff looks like a right laugh. maybe in the new year a track car may happen. cozzie first then toys. keep up the good work.
phil
__________________
Phil2002 is offline   Reply With Quote
Old 26-08-2008, 10:36 PM   #32
Si B
2Evos,1Escos and 2EscVans
Si B's Avatar
Trader Score: (58)
Si B is on a distinguished road
Simon Burroughes NotoriousSiB
Send a message via MSN to Si B
Cool little car Lee, and having seen it go, very quick too!
Like a quicker, newer version of my old Mi16 205.
Will look forward to racing you again soon
Si
__________________
Si B is offline   Reply With Quote
Old 26-08-2008, 10:59 PM   #33
ESCYSCOTT
Trader Score: (1)
ESCYSCOTT is an unknown quantity at this point
Send a message via MSN to ESCYSCOTT
i'll kick ya arse Lee!! You doin mallory with it?
__________________
ESCORT COSWORTH NOW SOLD
ESCYSCOTT is offline   Reply With Quote
Old 26-08-2008, 11:02 PM   #34
Lee_R21Turbo
Trader Score: (1)
Andy_R - the handling probably wasnt all that bad - was probably more my driving!! LOL!
SiB - thanks mate - yes - I'll look forward to it!!
EscyScott - bring it the fuck on pal!! LOL! Hoping to do Mallory yes - want to get it on the road first before booking anything incase summat goes tits up!!
__________________
Lee
'Just Modify It'
Old 26-08-2008, 11:12 PM   #35
ESCYSCOTT
Trader Score: (1)
fook that pal, just borrow some trade plates, drive it down the motorway to run her in then get it mapped at full belt on the rollers!!! PMSL. Thats how I did it LOL
__________________
Old 27-08-2008, 02:28 AM   #36
BillyCabrio
BillyCabrio's Avatar
Trader Score: (1)
Location: Dartford, Kent - Home of the two way one way system.
BillyCabrio is an unknown quantity at this point
Send a message via MSN to BillyCabrio
Jeeeeez!!
I can't believe that was February that we had rapid brake replacement at Bedford in the dark!!!
You'll be pleased to hear Johns box FINALLY came out over the weekend! The poor car has been under cover since the clutch bearing gave up the ghost many months ago
I can't wait for my new & improved passenger ride Lee
__________________
If Ford made Cabriolets like Carlsberg make beers, then this would probably be the BEST Cabriolet in the world.......
^^^^^^^^^^^^^^^^^^**CLICKY SIGGY**^^^^^^^^^^^^^^^^^^
BillyCabrio is offline   Reply With Quote
Old 11-05-2009, 10:45 AM   #37
maxest
Trader Score: (1)
Any updates lee, ive just bought a 172 for a track day car!
__________________
Old 21-01-2010, 07:09 PM   #38
Diggerspug306
Trader Score: (0)
Diggerspug306 is on a distinguished road
when u fitted the bucket seats, did u have side airbags before? because ive got some bucket seats to go in my clio and dont want to put the airbag light on.
Diggerspug306 is offline   Reply With Quote
Old 21-01-2010, 07:38 PM   #39
Spiky
Spiky's Avatar
Trader Score: (1)
You need a diode
Old 21-01-2010, 10:38 PM   #40
Diggerspug306
Trader Score: (0)
wat sort of diode and what do you have to do with it?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Clio 172 forums????? Spiky General Car Related Discussion. 1 01-04-2007 07:52 PM
RENAULT CLIO 172 marceatspies General Car Related Discussion. 4 27-02-2007 01:49 PM
clio 172 cup? xr2fatturbo General Car Related Discussion. 28 05-05-2006 12:07 AM
CLIO 172 SPORT FLO Cars for sale 0 05-10-2005 11:34 AM
CLIO 172 ??? matts1 General Car Related Discussion. 35 27-08-2005 09:57 PM
