1.8ZVH
Ported Head
Piper T2 cam
Piper adj pully
Bronze valve guides
uprated valves and double valve springs
recon gear box
new mongoose exhaust
90spec trim
chipped ecu
clifford concept 50 (£700 :O)
+ loads more
Good way to start
Yeh my welder needs a new liner and i ran out of gas, I need to fit the turbo sort the loom out and fit the fuel tank tomorrow, If the weather hold off.
car looking like its going to be mint when finished! i've got a s2 project but mines a daily driver which i have just found out this weekend not a good idea. i'm in the process of fitting a 2.0 zvh but forgot to order a new clutch so got to wait til wed to drive it lol. any way nice motor
thats where ive seen it then as i parents live in st.annes, used to see it in ansdell quite often. got a bit of work to do there pal, good luck with it.
Small update, I have decided to go EFI Fiesta turbo OFAB with 701s will get some pics up the weekend, Not looking forward to all the wiring tho.
Got all the bits to go on but no adapter plate. PM me if you have one.
Finally its ready to start the welding so its now at my mates garage for some much needed repairs once all welding is done i can crack on with rest, Only 2 arches and 2 sills, Inner sills and floor pan to do
p.s looking good mate. Just out of curiosity, how much the EFI components set you back in total?
Yeh thats R&B my car is in the body shop next to it PJ Auto body's i use the garage as it my mates business and he is doing loads of work for me all the welding and a full respray.
All the EFI parts inc loom, 2x inlets and 701 and a ofab ecu + more was £150 of "Cossie Sean" on here. But i have now sold my engine as i plan to to full zetec turbo.
I have a change or plan, Rather than buy the panels and all the other bits for my G reg shell i am picking a E reg shell up this weekend it comes with a shed load of bits and its had all the welding done so it should just be a case of paint and put it all back together.
Will put some pics up this weekend.
I finally have a update after a long day with 2 punchers on the trailer and the light stopped working on the trailer we got it home, I know i have cheated a bit rather than buying all the panels for my G reg one i have bought this E reg one. What you think i am pleasantly surprised just how good it is its had all the welding done i am well happy
