| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#121 | ||||
#122 |
Borg Warner EFR Equipped!
![]() Trader Score: (0)
Location: In the unit, building a 450bhp Time Attack Focus!
Rep Power: 12 ![]() |
Well...
![]() Back together - going to have a final spanner check tomorrow morning and then it's in with the fluids and fire up time
__________________
Sierra Cosworth RS500 Time Attack Focus ST170 E46 330d Touring **Take a look at my Time Attack build!**
#123 |
good going mate
__________________
![]() nail 0-60 in 3.4 1/4 in 11.58 its not abuse anyway you spazz |
#124 |
PassionFORD Member
Fingers crossed!
#125 |
nice one will, you don't hang about do you!!! What is the paint you have used on the rocker cover? Looks great
__________________
#126 |
Ginger Welsh Boy
Trader Score: (0)
Rep Power: 16 ![]() |
Respect mate, your probably on par with Andy and the Streetracers crew when it comes to a tight time schedule! Fair play!
How's it run?
__________________
![]() Focus Cosworth Projecthttp://passionford.com/forum/restora...7-10-09-a.html Focus RS Toyhttp://passionford.com/forum/restora...on-the-go.html |
#127 |
__________________
#128 |
Ginger Welsh Boy
Trader Score: (0)
Wicked pal! Well impressed with your perseverance!
__________________
#129 |
__________________
My carbon clad s2 |
#130 |
Well - she's done over 100 miles now and all seems well - going to need a quick map check before Oulton as there are a couple of lean spots now - can only think the freshen up has helped efficiency in places...
Few photos i've just had chance to upload - nothing special The old vernier pulley - you can see the wear on the edges of the teeth - seeing as i had my brand new verniers left over from my monster engine build - made sense to put one on i thought! ![]() How things looked first thing Thursday morning - all the bits ready, new head gasket, head bolts, gaskets, seals etc. etc. ![]() ![]() And i decided to knock a little something up for the oil breather as the original setup was showing its age, hose pulling out, leaking oil etc. etc. ![]() ![]() ![]() Apologies for me being rubbish with taking pics - but i didn't take any pics between putting the head back on: ![]() And this! ![]() However - all is well, she's up and running and done 100 miles of mixed driving and all appears fine so far
__________________
#131 |
Colossal Pervert
Good stuff getting it back running so quickly!
Interesting to show the wear on the pulley.. unfortunately they all do this, and pretty quickly too!! Best to go for a steel-toothed pulley (with an aluminium centre section if you want).. Did you baffle that breather plate on the other side?
__________________
![]() Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo. |
#132 | |
Quote:
Not directly baffled - i didn't have time - want to see how it behaves first - what i have done though is reduced the hole size - instead of a 10mm hole all the way through - the hole is 8mm and offset to the top. I have considered the concept of it oil surging under braking - but with the size of the hole and the angle of the fitting/hose - i imagine it will quickly return. It's a vast improvement on the original setup - that was pouring smoke out after a short burst of spirited driving!
__________________
#133 |
nice car bet it sounds fantactic!
#134 |
Ginger Welsh Boy
Trader Score: (0)
Cracking work will, i look forward to passing you on the 8th
__________________
#135 |
Super pussy eater
looking good mate, sounds like you've busted your balls getting it done!
ps, that breather plate is pretty much how mine is, but mine isnt offset lol. dont forget tho that my engine is the other way round, and i got a baffled sump so oil surge shouldnt be a worry |
#136 | |
Quote:
Fingers crossed Oulton will be fun
__________________
#137 |
Ban[B][/B]ned
I should be their, throwing oil on the track as you pass.
Seriously, best of luck Will.Benni. |
#138 |
Well - Oulton Park was awesome!
Car is a true weapon on track - fell in love with it all over again ![]() Was passing Saph Cossies and Focus RS's for fun Did 35 laps yesterday in 5 lap bursts - found the oil temps to be hitting 120 after 5 laps and then leaking a noticable amount of oil when parked in the pit garage. I suspect i'll whip the engine out over winter and drop a new set of big end and main bearing shells in and reseal the sump. Other than that - all is well
__________________
#139 |
Looked & sounded great on track yesterday mate
__________________
ps3 game tag carlo-ybe ![]() If you need cosworth parts contact mark 07548064979 www.mt-motorsport.com |
#140 |
__________________
#141 | |
Ginger Welsh Boy
Trader Score: (0)
Quote:
That's some nice bit of carbon goodness pal, lets hope it helps
__________________
#142 |
nice looking bit of kit...
#143 |
And here's the in car video of Oulton - only a few laps sadly!
__________________
#144 |
PF Idiot Sniper
just found this and realised you have the same bonnet as on the frs i bought on sat. glad i'm not alone
__________________
![]() ![]() Birds shouldn't be moderators ; ) |
#145 |
Lukesville
__________________
Built @ JKM Performance - NEW SPEC 471.9 bhp ![]() thetrolley +500hp/ton - 134mph over 1/4 mile April 2011 - 11.74 @ 129.15mph |
#146 |
I Love BooST
really like the look of this focus
#147 |
nice vid will, looked like fun!
__________________
#148 |
Right!
I'll keep this updated as often as i get time - but i'm hoping to have the whole project completed by the end of January at the latest to give me 3 weeks shakedown time prior to a trackday at Beford in February The car will be doing plenty of track days/ring trips etc. so there will be a LOT of overengineering So, we'll start with the progress to date Picked up a complete ST170 engine and gearbox: ![]() ![]() And got myself somewhere suitable to do the work: ![]() And so it begins: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And i finally got what i wanted from it! The block and crank! ![]() Few leftovers ![]() A 'few' boxes have arrived already - i'll get photos as and when i can
__________________
#149 |
Ginger Welsh Boy
Trader Score: (0)
Cracking matey, hope you still have that nice inlet you can maybe adapt to the new engine
__________________
#150 |
Cockend - how on earth do you expect me to get roller barrel throttle bodies in there as well as the supercharger! Nugget!
Drop me a text later about Modball
__________________
#151 |
Ginger Welsh Boy
Trader Score: (0)
Well I'm sooooooooo sorrrrry, didn't think the hoover would be going on this new engine build
I replied to your text the other day!
__________________
#152 |
So whats the plans Will? Just using the lower mileage bottom end?
__________________
Tim ![]() For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys. For all your stickers ~ Email stickerpaul@yahoo.co.uk |
#153 |
Good luck with it will, will be keeping my eye on this
__________________
#154 |
Good luck with the build!
__________________
#155 |
Few parcels arrived over the last few days:
Contents include: Some bits for the engine build: ![]() Some custom ground billet CAT Cams for the new head: ![]() Some RATHER sizeable custom 6pot APs: (see fag packet inside disc!) ![]() And some super lightweight custom offset Compomotive rims for them to live under ![]() Got to say a big thank you to Martin @ Reyland for his time and help with the brakes/rims
__________________
#156 |
Ginger Welsh Boy
Trader Score: (0)
Look very lush matey, now get rid of the hideous bonnet and you'll a top notch motor all round
__________________
#157 |
Liking the new brakes. 362 or 355?
__________________
#158 |
Super pussy eater
top stuff will, stu must be paying you too much lol
![]() just out of interest, do you know if the st170 cam cover will fit the silvertop head? if it does, please let me know!! |
#159 |
Unknown.
It won't fudge, My mate is sticking a ST head onto a silvertop and the camcovers don't swap, as hes got a quipped silvertop one that he wanted to go onto a ST, but it won't!
Will, Cool car, keep the updates coming
__________________
GE - 1D - T |
#160 |
In Training
Nice numbers with the powerworks setup!
I had picked up the very last powerworks from CFM. All I have left is to get it tuned. Keep up the great work!! BTW: What kind of boost are you seeing with the BBK?? |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| advice on supercharged ST170 engine build? | SVTyler | General Car Related Discussion. | 5 | 07-10-2009 10:09 PM |
| Starting a Ka Project, can anyone help??? | scottp | General Car Related Discussion. | 7 | 03-09-2007 07:03 AM |
| orion project starting | bai1ey | General Car Related Discussion. | 3 | 30-08-2007 08:07 PM |
| Thinking of starting a s1 project...................... | RsDarren | General Car Related Discussion. | 5 | 11-05-2006 11:58 PM |
| project van starting to take shape | Tank Mike | Pictures, video & Photoshop Forum | 15 | 25-12-2005 09:17 PM |
