My XR3i+..... New engine and clutch 27/01/16
#121
Fleet Manager
bite more today
down pipe and starter motor shield
oil filter and oil feed t piece
got my lower arms today so they'll go on 2mora and it can go back on all 4's!
#123
Fleet Manager
bit of an update its back on its wheels
now no exactly what i need to complete it
also doin 300mm brake conversion
bargain basement mk3 mondeo calipers Ł30
#127
Just been reading thru this m8...
Lovely motor! Looks good on the Cossie rims!
Im liking the turbo conversion, all the painted parts really tidy it up!
Keep us posted on how the conversion goes. Ive only just finished turboing my EFi Orion, if you need a hand or any advice let me know m8 as im only down the road from you!
#128
Fleet Manager
im stuck on the fuel pump just not priming god nos why think i may have broken something or dry joint in wiring
works fine one the floor as soon as i mount it it dose not want to no
so the hunt is one for a pump assemlys and wiring
#130
Fleet Manager
well thats not cured the problem of not starting pumps priming im gettin fuel but not starting i checked the ignition last time had a good spart god knows what it is have totaly rebuilt it now so i can diagnose the fault guess ill make a start the weekend
#136
Fleet Manager
tryed that and nothing, there so far aprat i dont think i could have go the round the wrong way to be honest,
gonna try book it in at grove garage get mark to look over its its more of likley something stupid but i jus cant work it out
#139
Fleet Manager
Right the enthusiasm has returned and with the impeding sale of my rs turbo hopefuly some funds, believe I've traced the non starting fault to the crank position sensor believe this engine needs the longest sensor and I only have an aftermarket item so gonna change that hopefuly that'll sort it, also plan to fit a turbo pre rad and ERL water injection while in at it
#140
Fleet Manager
Right been out and done abit this evening cool rad and turbo off, old cps out and that's as far as I got will be putting my refurbished turbo and new cps in tomorrow
#141
just looked at all you pics thinking what it could be and the wrong crank sensor was a thought lol . normally if the crank sensor isnt picking up on the flywheel you wouldnt get fuel or a spark ??? hope you sort it soon
#142
Fleet Manager
Thing Is I have spark and there's fuel at the regulator but maybe it's not actually firing the injectors well it's all stripped off now and I'm going to be having a little play tomorrow hopefuly time to get some motivation back now my house is 99% done lol
#143
Fleet Manager
Fleet Manager
Fleet Manager
Right boost monkey ofam ecu ordered, new ram air filter and pipe work ordered
Just waiting to take the car to Karl at Frenzy Perfomance Engineering for him to hopefuly get her running
#153
Fleet Manager
Right last few bits to get it all together now
New air filter pipe and hard pipe
Vxr injectors
Sick and tired if the old stretched ERST boost hose so made up a better one
Ended up costing about 20 quid
Didn't need both silicon pipes in the end
All fitted
Luckily I had a 63 to 51mm reducer
It's going to Frenzy Performance engineering on the 20th of April
Vxr injectors
All fitted
#154
Fleet Manager
well i was stripping the car down to give it a good clean before it when to Karlos_G and i discived this
well it seems i may have got to the bottom of my non running xr3i/frst running issues
one leaking water pipe
i have tried to turn the car over on many occasions odv it wouldn't start on any of them so its not be run under pressure just turned over on starter motor
not happy
not happy
#155
Fleet Manager
Well dispite the cam belt going I carried on doing the bits i intended I'll be fitting the new belt today
Refreshed the lights
Painted rim black to hide cracks and filler
This is how they are now just waiting to have the etec red done
Painted the rocker cover with wrinkle coat
Nice stainless oil cap
Got an escort RST expansion tank that's soaking in our "dump tank" at work so cleaned the cap
That's all for now waiting for pipe work to turn up so I can fit the new tank
#156
Fleet Manager
Fleet Manager
The belt rotted through from a leaking hose on the water pump, I've ordered an new hose now and changing the position on the headder tank to where an MFi cars would be, don't know if it's damaged the valves yer find out next week when it goes to Karlos_g for OFAM ecu conversion
