| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#161 | ||||
Wye Valley Hardcore
__________________
![]() "BRAVERY IS THE CAPACITY TO PERFORM PROPERLY EVEN WHEN SCARED HALF TO DEATH"
#162 |
very nice mate
#163 |
Wye Valley Hardcore
So I spend bloody ages getting it running......
..... Then start taking it to bits again. ![]() Nice new inlet. ![]() ![]()
__________________
#164 |
Fucking superstar........
Trader Score: (0)
Rep Power: 20 ![]() |
Inlet looks great!
__________________
#165 |
Formerly know as Puss
Very nice
#166 |
#1 in Spelling Club
Glad to see it in its new home!
I can't even begin to tell you the amount of work that went into that Inlet. Welding and blending that Throttle-body plate alone took ages!! Nice project BTW.
__________________
![]() Renaultsport Megane F1 230 I've earnt £450 for doing almost nothing!! Click here to see how!! |
#167 |
Advanced Retarded user
Was watching that inlet on e bay, if i had an RS, i would have been bidding! you got a bloody good inlet for that money!!
#168 |
looking good mate, thats a great buy too!!
__________________
used to be telhonda1 |
#169 | |
Wye Valley Hardcore
Quote:
I'm using the anti lag take off for the brake servo which is convieniant and runnign a brass T peice for boost, fuel pressure reg etc take offs at the end and I had to use the near take off for the air temp sender. Roll on FITP. I've never managed to get a car there!
__________________
#170 |
post whore
new inlet looks way better.great read this mate.keep it up
#171 |
glad to see yours is running now! mine ran aswell but not very smoothly, its dead again now lol and i havent a clue why, didnt change a thing!!
#172 |
Wye Valley Hardcore
I had a play with the sensor gaps which helped. I also re wired most of my loom as the CPS wires had been reversed and not soldered, just taped together and coil wiring was scotch blocked
__________________
#173 |
id set my gaps and thats when it started! not moved em or anything and now its dead again, probably send it down to jano to find its out of petrol pmsl!
#174 |
If i did not have my new inlet i would have been bidding too lol
__________________
My carbon clad s2 |
#175 |
#176 |
Wye Valley Hardcore
One step forward and 2 back! Gone up to do some work, went to start it, wouldn't start, then noticed the timing was out.
So wento to time it back up and noticed the one cambelt tensioner bolt was loose. The fucker has threaded the hole in the block! So now I don't know what to do. Looks like the engine has to come out to drill and tap a new set of holes.
__________________
#177 |
try helicoiling it
__________________
''Mary had a little lamb, she tied it to a pylon...10,000 volts went up its a*se & turned its wool to nylon'' |
#178 |
#1 in Spelling Club
I've seen this happen. As above, Helicoil it, but obviously its an ass to get to.
__________________
#179 |
Power
great progress with the car
bad about the the thread in the block tho
__________________
wanted s2 rs turbo clocks |
#180 |
#181 |
Wye Valley Hardcore
Had a quick look tonight with a fresh head and it looks like its actually just a bad thread in the block thats stripping the standard tensioner bolts. SO I put a tap through it and wound in one of the old mans high tensile, more argressive threaded bolts, still 8mm 1.25 thread and it seems to be holding it a treat. That and some locktite sould do the job fine.
__________________
#182 |
Looks smart
Brian
__________________
#183 |
Wye Valley Hardcore
Desided not to bodge the cambelt tensioner as its pretty important is doesn't work loose.
![]() Water pump also had a light leek and I've got some braided brake hoses to replace every line on the car do would be easier to just drop the enigne out and start again. ![]() Will probably get soem proper loombraid as well.
__________________
#184 |
Trader Score: (0)
Is that an RS1600i anti roll bar set up? Nice!!
__________________
#185 |
#1 in Spelling Club
I think thats the right choice. Do it properly. It's an ass, but once it's done, it's done!
__________________
#186 |
Wye Valley Hardcore
__________________
#187 |
Wye Valley Hardcore
Your right. I just woke up this morning and desided I'd take the engne out, then I had no choice but to do it then. FITP is going to be a struggle now though! But saying that, it might not have got there at all if I hadn't done this anyway.
__________________
#188 |
Trader Score: (0)
__________________
#189 |
gutted mate! jano sorted mine out on tues!
#190 |
2 steps forward 4 steps back... once its done tho, smiles all round!!!! What did you do with your old inlet manifold? Looked alright! Judging by the new inlet manifold and the man that used to own it, must be a bit funky!
#191 |
Ka driver
its come such along way might as well do this bit as well as the rest. Really like the new wheels suit it well!
__________________
![]() www.two-tone-ka.tk 1.8 zetec ka 0-60 in 7.81 secs Daily Driver: 206 GLX 2.0 Ltr HDI 1800 zetec on ITB in a Ka |
#192 | ||
Wye Valley Hardcore
Glad to hear you got it running mate!
Quote:
The old inlet will be up for sale if anyones interested. Basically the car wouldn't start and it was suggested my injector port milling was causing an air leak. Which it wasn't and the day I bought the inlet was the day I got the car started! The new inlet really is some peice of kit though! ![]() Quote:
__________________
#193 |
glad your getting close mate, i would still recomend you take it jano when your ready!
#194 |
Wye Valley Hardcore
After all the help he's given me over the phone etc it would be a bit cheeky to take it anywhere else
I've phoned him before at 10pm on a Saturday night asking why my car won't start!
__________________
#195 |
![]() great thread. very nice project,looking good now. lovin the wheels.whats the expected power of your engine? am just starting my journey .......http://passionford.com/forum/restorations-rebuilds-and-projects/293932-erst-s2-project-full-shell-resto-now-keeping-updated-2-10-09-a.html |
#196 | |
Wye Valley Hardcore
Quote:
Sounds like the start of an expencive RS journey. This cars about to run into double figures
__________________
#197 |
yea a good 3.5 k 2 start with on my list
will be worth it though.can i ask why u changed the arb set up, is the rs turbo 1 that bad??
#198 |
Wye Valley Hardcore
Compared to the RS1600i and Series 1 set ups, the Series 2 ARB is simplily terrible! The RSi and S1 were both motorsport based and have adjustability.
__________________
#199 |
cool thanks for that,might have to look into that.sounds and looks like a pig of a job lol.keep it up,il keep an eye out at the shows
#200 | |
Eruption 101.3fm
Quote:
Thats nothing fella, i rolled my car down the country lanes one night about 6 years ago. It was past 1am on a monday night / tuesday morning. I called jano as i had no-one else i could ring in my phone book for that type of help. He was at the side of the road with a borrowd pickup truck and his pals scrapping my car off the road within an hour. He then took my car to his yard and re shell'd my S2 into a Mk5 escort within a week running on cossie management. He will help anyone who needs it and has saved me thousands £ over the years by explaining the pro's and con's of everything. I have alot of respect for him and always advise people to chat with him when building any car to help you save what i have. Danny.
__________________
Eruption 101.3fm London. Live stream.. www.eruptionhardcore.com ![]() "Dont judge a Fwd car, judge the driver who knows how to build and handle one." |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| how long are M1 road works wxpwcted to last | Ginge ! | General Car Related Discussion. | 11 | 21-03-2009 09:30 PM |
| Been a long road, started in 1991 and now she's finished | Jim Green | Pictures, video & Photoshop Forum | 57 | 27-10-2006 05:38 PM |
| Car's been off the road for too long so I got one of these.. | sunny | General Car Related Discussion. | 26 | 31-08-2006 11:11 AM |
| Looks like another sh*t year ahead | fordyracer | General Car Related Discussion. | 3 | 23-01-2005 01:45 AM |
| Well, not long now for winter and car off the road | ESCYSCOTT | General Car Related Discussion. | 8 | 15-10-2004 02:31 PM |
