| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
**Edited by webteam** |
#2 |
The floorpans are in the tops and bottoms of the A pillars are repaired and the bulkhead and closures are in ...
![]() ![]() ![]() Been a bit tied up getting this racecar mk2 built ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#3 |
Been doing some more .. Along with fitting up Matt Downers new Duratec Powered car and doing the front suspension on the Mk2 racecar, oooh and bubbling,tubbing and gearbox tunneling another mk1 ..
anyways engine mounted ![]() gearbox tunnel started along with the new floor x-member ![]() and the Fostek Atlas being fitted with the 4link/watts brackets and disc brackets
__________________
**Edited by webteam** Last edited by John Doe; 09-05-2008 at 08:21 PM. |
#4 |
Amazing!!! Great job mate. My big respect.
And the wheels looks the nuts.
__________________
#5 |
very jealous of the front end on that mk2 Gary!
in practice, how much more room do you gain for the front wheels from that?
__________________
#6 |
9500RPM torqueless wonder
Amazing
__________________
Titanium Gray RX8 230 |
#7 |
wikid project man
#8 |
Stunning work
__________________
ps3 game tag carlo-ybe ![]() If you need cosworth parts contact mark 07548064979 www.mt-motorsport.com |
#9 | |
Quote:
Plus your shell was mint compared to that mk2, it had been cut about and patched so much over the years that it really was an un-economical repair what with an escort front end costing 2.5k in panels alone its worked out cheaper doing this .. The Mk1 though is staying with the escort/capri legs, and will have a tube front end as its for a road car not racecar.
__________________
#10 |
welding looks all good!!
#11 |
Passionford Thread Killer
__________________
![]() Low Slung Denim |
#12 |
Stunning
Brian
__________________
#13 |
Bubble arched Mk 1's are the dogs danglies
![]() ![]() Mega project you got there mate ![]() ![]()
__________________
#14 |
Unknown.
Amazing, Will watch this!
__________________
GE - 1D - T |
#15 |
ditto will be watching this!!
__________________
[CLICK TO SEE MY SAPH RESTO!! http://www.passionford.com/forum/viewtopic.php?t=240033 |
#16 |
__________________
My carbon clad s2 |
#17 |
Formerly know as Puss
Very nice
#18 |
Fucking superstar........
Trader Score: (0)
Rep Power: 20 ![]() |
Awesome!
__________________
#19 |
Axle in
__________________
#20 |
hi there, i,ve just had something similar done on my mk1 and i,ve bought a set of 15x7 comp ml,s for it. what tyre choice would you recommend for these? size,s and witdth,s it,s bubble arched, on coilovers and will be a road car!! any help would be great please
__________________
s-line van s-line audi car mk1 cozy soon |
#21 |
depending on who built your car, you will probaly max out with a 9" rim on there, so i would say use an 8,5" tyre on a 9" rim for the road, I dont go by the numbers on the tyres on road tyres as they are not accurate as the sidewall tread is included in the measurement, You'll have to take a rule with you when you buy. As tyre widths vary with manufacturer.
For your 15's and again depending on whose built the car, you'll have to run a low profile on something like a 185 to 205 width if you want to lower the car. The car should fit the wheels, not the wheels fit the car, as the wheels hub height dictates the suspension pick up points.
__________________
**Edited by webteam** Last edited by John Doe; 20-05-2008 at 09:21 PM. |
#22 |
the welding looks amazing
![]() keep us posted mate
#23 |
The seat/ cross members are done along with the inner seat mounts and prop tunnel ..
![]() ![]() rear fire wall mounts next and then the cage .. multipoint weld in
__________________
#24 |
unreal what would something like this normally cost someone for the shell?
__________________
#25 |
About the same as a standard Gp4 Rally shell 6-7k
__________________
#26 |
Firewall upper and lower mounts are in
![]() ![]() ![]() and the prime cage is in (prime= the basic 6 point + rear diagonal), the rest of the bars (15 separate bars inside) will be going in along with the front end, but i need to finish up the Mk2 racecar first. ![]() ![]() ![]() ![]() ![]() ![]() The other 15 bars are mainly diagonals and front triangulation to the top mounts.
__________________
#27 |
You are one talented man. Your fabrication and welding skills are simply amazing.
Dont suppose you want an apprentice?
__________________
Tim ![]() For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys. For all your stickers ~ Email stickerpaul@yahoo.co.uk |
#28 |
That's the bollox
Only a lottery win separating me from getting a mk 1 and having this done
__________________
#29 |
Thanks for the replies
__________________
#30 |
B1mbo
that looks brill !!
__________________
![]() mt-motorsport.com
#31 |
Trader Score: (0)
Rep Power: 4 ![]() |
Now that is what I am talking about...
#32 |
Some more
__________________
#33 |
The original Rouge Trader
Some splendid work and welding their Gary.
__________________
![]() Steve the Plumber. |
#34 |
Cake lover!
Very good. I have seen your work up close on Al's old MK1 and Stu's Mk2 both stunning cars.
__________________
![]() 88 Saph - 455bhp & 438lb/ft 02 CTR - 248bhp & 184lb/ft |
#35 |
Some pics of the front spaceframe .. due to the cost of Mk1 front panels being around £2,500 from the screen to the front panel .. and thats just for the panels without fitting costs, we decided to do a spaceframe front end, also the cars modified at the rear so may as well do something up front too
The main hoops are 38mm CDS and the parts join back into the main cage are 42mm CDS, the top mounts are my own camber adjustable one that i normally let into standard inner wings. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#36 |
Keep them pics coming, what a work of art.
__________________
#37 |
is half man, half amazin'
wow
#38 |
Care Free.......
Trader Score: (0)
Rep Power: 6 ![]() |
stunning work
__________________
G-G-G-G-G-GIRO UNIT!!!!! Team Giro Unit bodged up '3i.. ![]() http://www.passionford.com/forum/viewtopic.php?t=233059
#39 |
Finished doing the top plate gussets on both sides and stuck a leg in there for the pics.
![]() ![]() ![]() The we put some panels on ![]() ![]() ![]() ![]() Neils got to bring his doors in and then i can get the front lined up and mount the panels and get the bubbles on the fronts.
__________________
#40 |
Will follow this
Superb work Got to love Mk1's done properly You got skills |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| my mk1 escort | sueedw | Pictures, video & Photoshop Forum | 35 | 23-10-2007 10:07 PM |
| is a mk1 escort pedal box the same as a mk2 escort????? | rosie | Old Skool Fords | 1 | 03-08-2006 08:18 PM |
| Mk1 Escort | Northern Bloke | Pictures, video & Photoshop Forum | 6 | 04-07-2006 07:02 PM |
| Mk1 Escort with V8 | Rich_w | General Car Related Discussion. | 2 | 24-12-2005 08:42 PM |
| mk1 escort vs escort cossie | conways rs | General Car Related Discussion. | 16 | 30-07-2005 09:34 PM |
