PassionFord
Welcome to Passion Ford!
Welcome to Passion Ford.
Thread Tools Display Modes
Old 09-09-2008, 07:04 AM   #81
alistairolsen
Trader Score: (0)
alistairolsen is an unknown quantity at this point
do either of you know if swapping in the n/a inlet cam off the 2.5 is possible or beneficial on a T5?
alistairolsen is offline   Reply With Quote
Old 09-09-2008, 07:48 AM   #82
Andy_P
Trader Score: (0)
Andy_P
Send a message via MSN to Andy_P
Quote:
Yes it can be.
Speaking from experiance with the 4 cylinder white blocks (T4 / 2.0T) I've changed both inlet and exhaust cams from my 2.0T to n/a with very good results.
The only problem is (if this applies to the 5 cylinder) depending on the year the engines can be fitted with either hydraulic or mechanical lifters and the cams are not interchangeable.
Also, I'm not sure how far along the timeline you are with your mods but if you're running a standard td-04 housed turbo (16T etc) these are somewhat of a backpressure monster and although the n/a cams do give added perfromance, they're more suited with larger housings. Not sure if this applies so much if you're only going to swap the inlet cam though.
Russ no doubt will be able to tell you more.
Andy P
__________________
Andy_P is offline   Reply With Quote
Old 09-09-2008, 08:12 AM   #83
alistairolsen
Trader Score: (0)
for a start Ill run it standard, 400bhp/tonne should be ok for a good while. After that ill be aiming for about 380bhp with 300ftlbs helf from 3500 to 7k ish. Probably run a GT30 and a boost controller, standalone and a new exhaust manifold.
Reason for the torque cap is grip, and being able to use cheap, standard bottom ends and heads.
I just know in the vauxhall xe and let motors, in higher states of tune its worth 20+BHP!
cheers
Old 09-09-2008, 08:29 PM   #84
RickyLee53
Trader Score: (0)
RickyLee53
Quote:
Originally Posted by mad russell View Post
All i can say is that i am trying out a few they are all custom made though its not like the cossy tuning world
Russ
haha,
I'm not in the cossy world either.
Just wondered on Cam spec as this will obviously change the powerband massively which does look pretty narrow.
__________________
Fastest sohc and 1.6 civic in the uk. 4.7 to 60, 8.9 to 100, 12s at 119.6mph.
Builders of the fastest stock B series, 400hp, 12.2 @ 120mph on Road tyres.
RickyLee53 is offline   Reply With Quote
Old 10-09-2008, 04:56 AM   #85
mad russell
Volvo Mad
mad russell's Avatar
Trader Score: (0)
mad russell
As Andy has said there CAN be improvments made from N/A cams but i have never seen someone do any proper testing which i hope to change soon
Russ
__________________
Volvo 850 T5-R 591 bhp 524 ftlbs torque so far on an Autronic SM 4 (UK First) runs 2.5 bar full time
Have a look at my project :
http://passionford.com/forum/restora...lvo-850-a.html
Silver Evo 6 Autronic stage one ??? bhp,Autronic SM 2 plug and play,Mongoose exhaust,
Gaz Coil overs,18 inch,Compomotive Mo wheels,
mad russell is offline   Reply With Quote
Old 10-09-2008, 04:59 AM   #86
mad russell
Volvo Mad
Trader Score: (0)
mad russell
cheers
Hi A
If you do run the car with an autronic Sm4 it has nice standard features like launch control and traction control
Russ
__________________
Old 10-09-2008, 05:01 AM   #87
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Originally Posted by RickyLee53 View Post
haha,
Hi Ricky
Fear not about the cams and power band this was just a test not the finished result i will soon be going back to the RR and will carry out many tests i have in mind hopefully the RR owner will not be so scared this time
Will post the results i get
Russ
__________________
Old 10-09-2008, 11:31 AM   #88
Spiky
Spiky's Avatar
Trader Score: (1)
Spiky is an unknown quantity at this point
Send a message via MSN to Spiky
awesome car
where did you get the intake pipe?
__________________
Mario Kart WII Friend Code 3523 2250 4279
>>>> My YouTube Videos <<<<
>>>> My 205 GTi-6 Track Build <<<<
PS3 Gaming TAG >>> spiky1975
Spiky is offline   Reply With Quote
Old 10-09-2008, 11:45 AM   #89
elliot
Trader Score: (0)
elliot
The 2.5 20v cams do have more lift but they are also a longer duration.
inlet is 250dr 8.45lift,exhaust is 252 dr and also 8.45 lift.Not sure you would see alot of gain TBH
Standard T5 cams are inlet 242 lift 7.95 and exhasut 243 with 7.95 lift.I have some piper cams in mine they are pretty mild but made a fairly big difference.As Andy p has said the big restriction is the tdo4 exhaust housing.
elliot is offline   Reply With Quote
Old 10-09-2008, 11:53 AM   #90
space hoppers
Trader Score: (0)
space hoppers
Hi Ricky
Russ
old snot box !!!!!!!!!!!!!!!!
did you sort it with pete at the weekend then ???????????????
__________________
the official spec r show car
space hoppers is offline   Reply With Quote
Old 10-09-2008, 06:48 PM   #91
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Originally Posted by Spiky View Post
awesome car
try here www.flexiblehosesupplies.co.uk
Russ
__________________
Old 10-09-2008, 06:49 PM   #92
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Hi Elliot
Well said that man
Russ
__________________
Old 10-09-2008, 06:50 PM   #93
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Not yet
__________________
Old 12-10-2008, 01:34 PM   #94
mad russell
Volvo Mad
Trader Score: (0)
mad russell
A few updates had another run on the rollers yesterday to see if the claims people make that N/A cams are better in the volvos well i found it had lost 10 hp over last time but really wanted to run the car on race fuel to see what happens
Flwheel
Wheels
The car made it home after ok but i think i have an ill turbo as Rod said to me after the run you cannot develop a 591 bhp car without a few setbacks
I still have much work left to do but the testing process continues .
I will be back.
Russ
__________________
Old 12-10-2008, 01:58 PM   #95
CossieRich
Did Someone Mention TUV
Trader Score: (1)
CossieRich is an unknown quantity at this point
Send a message via MSN to CossieRich
So it is deffo turbo then Russ? Would have pissed passed 600 on the next run
__________________
Rich
MAD Built, GT30, 2.5 bar, MAD Spec inlet cam, Pro Alloy RS500 Intercooler and Rad, Bara Diff, AP 330's, Vi-PEC ECU, 2WD. 480 bhp. 474 ft/lb. Click HERE for my Cosworth Project. Big Thread
CossieRich is offline   Reply With Quote
Old 12-10-2008, 04:38 PM   #96
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Not 100 % sure yet yes 600 would of made my day the water injection was not working
Russ
__________________
Old 13-10-2008, 04:43 PM   #97
CossieRich
Trader Score: (1)
Next time Russ. Let me know when/if you are going back and i will drive over
__________________
Rich
Old 14-10-2008, 02:06 PM   #98
orion turbo
orion turbo's Avatar
Trader Score: (0)
orion turbo
what a sleeper love it!
__________________
uncle henrys employee
1989 2wd sapphire cosworth
1993 2wd rs2000
1988 vw jetta gti 16v
orion turbo is offline   Reply With Quote
Old 14-10-2008, 02:22 PM   #99
AustenW
AustenW's Avatar
Trader Score: (0)
AustenW
Send a message via MSN to AustenW
Some good power there.
Have you installed darton sleeves?
What work have you done to ensure the bore doesn't split / deform?
AustenW is offline   Reply With Quote
Old 14-10-2008, 02:43 PM   #100
Less.
Unprofessional Waffler
Less.'s Avatar
Trader Score: (0)
Less. is on a distinguished road
Send a message via MSN to Less.
Makes a refreshing change from all the cossies
Less. is offline   Reply With Quote
Old 14-10-2008, 06:26 PM   #101
elliot
Trader Score: (0)
elliot
Its the later 2.5 block in the newer cars and the focus st's that are spliting liners.The 2.3 blocks get taken to 750-800 before liners in Sweden
Old 14-10-2008, 07:55 PM   #102
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Will do rich
Russ
__________________
Old 14-10-2008, 07:56 PM   #103
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Many thanks
Russ
__________________
Old 14-10-2008, 07:57 PM   #104
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Hi Austenw
No sleeves yet
Russ
__________________
Old 14-10-2008, 07:58 PM   #105
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Russ
__________________
Old 14-10-2008, 07:59 PM   #106
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Well said Elliot
Russ
__________________
Old 21-10-2008, 07:16 AM   #107
nk_12321
nk_12321's Avatar
Trader Score: (0)
nk_12321 is on a distinguished road
Talking
how much you spend in this project??? your volvo is one of most beautiful I ever seen!!!!
__________________
nk_12321 is offline   Reply With Quote
Old 21-10-2008, 06:43 PM   #108
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Hi There
Your first post on PF and you post on a thread about a volvo thanks for the kind words
Its cost much money and is still far from finished
Russ
__________________
Old 15-11-2008, 06:12 AM   #109
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Ok Time for a few updates
After the last run on the rollers where we made 591/524 ftlbs on the race fuel i went to do another run the car started to smoke not badly but there was smoke there so run aborted to see what i had damaged after having the turbo checked and all was ok i started to look at the engine i had at first thought the headgasket had not liked the race fuel which can happen but then found this
I had thought it could of happended on the 2.3 block as the V70R and focus ST's are having crack's in liners even with stage one let alone 591 hp so now i have found out for myself and other future customers where the limit is of the 2.3 so i am now looking at the best routes to cure the problem for good.
I thought it would interest some people to show what happens when you push the limit of the parts designed for 240 bhp its a set back but one that will make the car 100 % reliable once i have finished my R&D .
If your running the standard 2.3 block and claim to have more than 600 hp i would say
My breather system and dump valve has arrived i am going to do away with the volvo pot etc and try this out :
I have now got the time to spend to do all the small jobs i have been meaning to do on the car so took to the bonnet with a drill and hole saw
I have decided to have a roll cage added to the car and also plan a few more changes to the inside of the car
Russ
__________________
Old 15-11-2008, 06:28 AM   #110
kev 3dr
Trader Score: (1)
kev 3dr
Send a message via Yahoo to kev 3dr
This is one project mate !!!
will that engine bolt straight up to any rwd gearbox in the volvo family ???
__________________
Clito 172 track toy
another project to come soon..........
kev 3dr is offline   Reply With Quote
Old 15-11-2008, 10:33 AM   #111
AustenW
AustenW's Avatar
Trader Score: (0)
AustenW
Hi Austenw
No sleeves yet
Russ
Dont say I didn't warn you
Its very common
Old 15-11-2008, 01:57 PM   #112
MadRod
Happily retired
MadRod's Avatar
Trader Score: (0)
MadRod is an unknown quantity at this point
He will have a nice neat loom installed next week, the rats nest fitted (Russes development wiring) was losing him about 200bhp well thats what it looked like .
Cant wait for this to get completed, it will be a very fast car indeed .
MadRod is offline   Reply With Quote
Old 15-11-2008, 03:45 PM   #113
massivewangers
Trader Score: (0)
massivewangers is an unknown quantity at this point
Send a message via MSN to massivewangers
That's bonkers
A friend of mine had a standard T5-R and it was useless in the wet, just spun up constantly, this one must be a handful!!!
__________________
Q. What's the difference between a Saxo and a porcupine?
A. The pricks are on the outside of a porcupine.
massivewangers is offline   Reply With Quote
Old 15-11-2008, 05:55 PM   #114
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Not without some serious fab work
Russ
__________________
Old 15-11-2008, 05:56 PM   #115
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Its very common
Hi AustenW
I cannot remember if you had put liners in your or not ?
Russ
__________________
Old 15-11-2008, 05:57 PM   #116
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Thanks Rod
Cannot wait to get it all looking right and going right
Russ
__________________
Old 15-11-2008, 05:59 PM   #117
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Quote:
Originally Posted by massivewangers View Post
That's bonkers
Hi MW
Thanks for the comment its a good deal of fun thats for sure its amazing how much grip you can get with a decent setup
Russ
__________________
Old 20-11-2008, 05:21 PM   #118
space hoppers
Trader Score: (0)
space hoppers
i reckon you should let Q finish the car off for you
__________________
Old 20-11-2008, 05:52 PM   #119
MadRod
Happily retired
MadRod's Avatar
Trader Score: (0)
Im actually re-wiring it, not up to Q standards but looking good. I suggested doing the Q mod of threading the fuel pump wires through the spare wheel so it cant be removed but Russ dont want such extreme mods as hes only looking at 600bhp.
Old 20-11-2008, 06:00 PM   #120
mad russell
Volvo Mad
Trader Score: (0)
mad russell
Hi S H
If i want it set on fire or the unique immobilser mod done then thats a good idea otherwise Rod will have to do
Russ
__________________
Tags
10, 535, 850, bhp4702, custom, ft, gt30, inch, jobs, lbs, paint, sleeper, turbo, v70r, volvo, wheels, wide
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Volvo 850 T5R Shanny General Discussion. 36 19-05-2008 04:44 PM
T5R and T5 VOLVO 850? cheeky dog General Discussion. 10 27-10-2007 12:31 AM
Volvo 850 Estate FlashRS Cars for sale 0 04-05-2006 09:23 PM
Volvo 850 T5 tuning SapphyMike General Discussion. 0 20-02-2006 12:17 PM
Volvo 850/V70 R Deano General Discussion. 26 15-03-2005 09:56 PM
Content Relevant URLs by vBSEO 3.3.0
