Project "ASBO" XR2
Old 29-03-2008, 10:33 PM
Gooey
Gooey's Avatar
Default Project "ASBO" XR2
After owning lots of Ford machinery both old and new, I ve gone Old Skool again and bought a Mk2 XR2. It was origionally Turbo'd pushing out near on 200 bhp but whilst driving it home, It decided to melt a piston :-X
It did look like this but alot has changed
The car wasnt built to a standard I liked so the project begun. It was completly gutted inside and out and basically all the bad bits of which there are lots are slowly been put right as and when funds allow
This was its state 2 weeks ago :-[
The car was full of Autometer guages but these have been sold and I ve spent just over a grand on a set of Defi's from Japan including a HUD
The car had a Mk3 dash installed but it looked gash so I binned it and my brother has modded a Mk2 dash although you can barely recognise it anymore. I picked it up last weekend after getting it flocked
Gooey
Gooey's Avatar
New Mondeo push button start
Next up were the wheels as I didn't like the Wolfrace ones that were on it.I bought these off ebay from Germany which cost in total with postage.......... 104 of your finest English pounds
Sent them away to be refurbished and they came back a week later looking like this
They ve since been wrapped in a set ot Toyo T1-R's and now sit in my mothers dining room looking very Carlos Fandango LMAO
Old 29-03-2008, 10:34 PM
Gooey
Gooey's Avatar
The engine choice was always going to be a Duratec but I hadnt planned on the turbo lump expiring as soon as it did so a 2 litre Zetec is currently been built up to be dropped into the engine bay
Modified Engine Mount
Nice Shiny Manifold although I have some Heat resistant material to wrap it in
Inlet Manifold which is currently having its ports opened up
then these should work a treat, Crackle Black Jenvey Throttle Bodies with Emerald Management
The next find was once again German Ebay and comes in the form of a rocker cover bearing a certain old skool feel to it as it sort of resembles a BDA one
Fiesta lights on whatever I ve owned including the ST have always been bad so I ll be running Xenon's FPMSL
Random bits from Ford
Gearbox is a proper nightmare. Im using the gears from a RS1800 as these are best for acceleration, a late spec zetec escort bellhousing as the starter motor is located at the back allowing my manifold to run under the front nicely and finally the LSD out of a Series 2 RS turbo as pictured
Latest pics of the flocked dash
And starting to install the guages
Seats have been modifies and put back in the car properly
Cage has been removed and had extra bars welded into place
Then refitted into the car
Gooey
Gooey's Avatar
I got a inlet manifold from ebay a while back now but upon fitting it up to the head, there was quite a bit of metal fouling where air should be going so out came the dremel and now there all nice and smooth.
Wrapped my very blingy looking manifold in some thermotec wrap, took me fooking ages and my hands itched like fook afterwards with the fibreglass dust that was on it.
Bloody snap straps I got were way too big so I need to get something else now to hold it in place properly.
When the inlet and head were finished machining, we tried the throttle bodies up against the inlet and I very nearly wet myself with excitement
Rocker Cover went from looking like this
To this
My paint sprayer did it for me in the end with the Orange detailing
Vernier Pulleys were anodised red but have now been painted the same orange as well
Wing mirrors were Matt Black but have now been coated in paint to match the rest
And my Porn horn which has been on my last 3 cars hasnt escaped the spray gun either
Old 29-03-2008, 10:35 PM
Gooey
Gooey's Avatar
Today we spent most of the day breaking down 2 gearboxes and rebuilding one out of them.
The RS1800 internals were picked as being better than the Escort GTi ones for better acceleration so both boxes were stripped down.
The RS1800 internals were swapped into the Escort bell housing meaning the starter motor could be located at the back of the bell housing allowing better clearance for my spangly manifold.
The Series 2 LSD was also fitted into it and tomorrow will be bolted to the engine ready to be dropped into the car
Engine was sat in the corner looking very glam and I nearly shot my bolt when it was uncovered
We also removed the fuel cell today to begin tidying up the pipe work and repaint the brackets as parts of it had to begun to rust
A quick picture of the car as it stands at the moment, not alot from previous pictures of it but things are moving along quite quickly now
Old 29-03-2008, 10:36 PM
Gooey
Gooey's Avatar
Well we got a little bit more done today.
My light weight TTV flywheel
And fitted to the engine
RS Turbo clutch
Completed Engine and Gearbox Build up
I attempted to fit the wing mirrors today and after lots and lots and lots of swearing, they finally made it onto the car
Old 29-03-2008, 10:37 PM
Gooey
Gooey's Avatar
Things are moving along very quickly now, I got there this morning to find my engine hanging on the crane and the car pointing up in the air :shock:
Within an hour we was like this 8)
We trial fitted the manifold on to see how much clearance we had
and to be honest doesn't need much modding at all considering it is designed for a focus
Next up we fitted the throttle bodies, fuel rail and regulator :P
We wondered if the strut brace would clear the bodies and lo and behold, it did
It was deemed too normal and restricting to the bodies as it was tight for clearance so it will be cut and a new strut brace designed to run between the head and injectors 8)
Fuel cell re installed with freshly painted bits
Couple of pictures of the Heads up display mounted on the dashboard
Few more pics of the dashboard, one of the front with a few more colour co ordinated bits
and a few of the metalwork behind :shock:
Sorry if it doesnt all run in order, copied and pasted from another forum
longdog
longdog's Avatar
fook this is going to be good
loving them wheels
pratley
pratley's Avatar
Have seen that car before, looks wicked!
Loving the new wheels.
Old 29-03-2008, 10:41 PM
jonnyrsturbo
is half man, half amazin'
jonnyrsturbo's Avatar
wow mate, seen this in pf mag ages and ages ago loved it then, lovin it even more noe
good work fella
Old 29-03-2008, 10:46 PM
roro22
roro22's Avatar
Car looked mint when you bought it!
Looks something special, nice one!
Old 29-03-2008, 11:06 PM
PF Dave
PF Dave's Avatar
Good work Pete, and loving the fact the porn horn is making a repeat appearance! Top stuff! Looking forward to seeing it at FITP - Tea will of course be on tap for the day!
Old 29-03-2008, 11:14 PM
purple_fiesta
No longer a ford owner ..
purple_fiesta's Avatar
Looks well tidy, I agree about the old wheels they looked gash. Should of cleaned that gear box up abit though, looks manky compared to the rest!
Old 29-03-2008, 11:20 PM
TimC
TimC's Avatar
Please say you cleaned all the crap out resting on the valves in this pic?
Old 30-03-2008, 08:04 AM
Great work there ,looks like c fosters old one
Old 30-03-2008, 08:38 AM
Gooey
Gooey's Avatar
It was Chris's old one but has since been stripped back to a bare shell and rebuilt.
Al the metal shards were removed before been put together properly, that pic was during the process
Old 30-03-2008, 08:58 AM
Fiesta SuperSport
Fiesta SuperSport's Avatar
Looks awesome Pete Mate, I spot some of my bits already!!!! Lol
Just give us a shout if you need a hand with anything!
Looking forward to seeing it go!
Old 30-03-2008, 04:54 PM
chrisr
chrisr's Avatar
looks mint mate, ive still got the origional performance ford mag article on ti
Old 02-04-2008, 07:17 PM
teddie1986
teddie1986's Avatar
looks great, love it
Old 04-04-2008, 11:46 AM
G1EN
G1EN's Avatar
OH MY GOD..... What a car and what a project.... If i was to buy another XR2, it would an absolute bog standard one or this one (if saying it was for sale. lol)
Well done fell. Keep it coming. Love it.
Old 04-04-2008, 11:51 AM
madmack99
I Love BooST
madmack99's Avatar
that is sooo nice what a project nice engine too for it
Old 04-04-2008, 01:46 PM
Spammage
Spammage's Avatar
The original car original car was the mutts this car looks to be oustanding!!!!!
I'm lovin all the new and shiny parts what's your budget if you don't mind me asking????
Old 04-04-2008, 02:50 PM
fezzajsy
fezzajsy's Avatar
gonna be awesome m8..nice one
Old 06-04-2008, 08:06 PM
Gooey
Gooey's Avatar
Budget is a little on the pricy side considering I sold my 06 Fiesta ST for it and have now spent all of it and more LOL
Done a bit more to it today, the wiring has been left until its back on 4 wheels but...............
the rad and fan are in
One custom made strut brace, just needs crackle blacking now
Freshly painted Oil cooler
Porn Horn fitted
Manifold finally finished
Cleaned up a old set of standard lights and hammerited them black, they ve come up surprisingly well
Also fitted the Coilovers today and have started stripping down the brakes to be repainted. The exhaust and brakes will hopefully be on the car when I go up next weekend so it will be a chance to crack on with the wiring
Old 06-04-2008, 08:22 PM
GTechR
GTechR's Avatar
Lookin good Pete...
Old 06-04-2008, 08:28 PM
XRT_si
XRT_si's Avatar
Looks like its evolving nicely.
Who welded the extra ars int he cage out of interest? Wouldnt mind having it done to mine.
Old 06-04-2008, 08:33 PM
haz87
haz87's Avatar
Top Work Pete
Old 06-04-2008, 08:41 PM
Gooey
Gooey's Avatar
The chap that is rebuilding the car is called Steve Crooks, he removed it and then put in the extra diagonal and harness bar. He then made the strut brace last week
Old 06-04-2008, 08:49 PM
COLEYST200
COLEYST200's Avatar
i must say thats very nice work your doing mate nice car
Old 07-04-2008, 02:59 PM
fezzajsy
fezzajsy's Avatar
Old 07-04-2008, 03:15 PM
Spammage
Spammage's Avatar
My that is a bit pricey defo worth it. Looking outstanding already. Although the base car wasn't in bad condition. Looking forward to seeing it finished!!!!!
Old 08-04-2008, 08:58 AM
Rossco
Rossco's Avatar
Looks wicked mate.
Get the rest of the bits and some more paint over to me and i will sort them as soon as I can
Old 08-04-2008, 06:46 PM
Nash
Cake lover!
Nash's Avatar
Superb!!
Old 08-04-2008, 07:02 PM
hai07222
hai07222's Avatar
Remember seeing this in PF, great car
Old 08-04-2008, 07:18 PM
Gooey
Gooey's Avatar
Originally Posted by Rossco
Looks wicked mate.
Cheers Rossco
Old 08-04-2008, 07:19 PM
woolford
woolford's Avatar
excellent looking car loved the feature.
Old 09-04-2008, 12:08 PM
w3dal
w3dal's Avatar
Pete cant wait to see this matey.
Still on for the FITP convoy???
Dal
Old 09-04-2008, 12:53 PM
Reid
Reid's Avatar
this looks fucking awesome!
Old 09-04-2008, 01:19 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
I actually prefer them with turbo engines, but its understandable having a Zetec, they do go well
love the build anyway, keep at it
Old 09-04-2008, 05:02 PM
Simmo
Simmo's Avatar
I love this... good work!!!
Rocker cover looks awesome!!!
Quick Reply: Project "ASBO" XR2
