PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 18-04-2008, 11:25 AM   #81
Sticky.
Sticky.'s Avatar
Trader Score: (4)
Sticky. is an unknown quantity at this point
Lets hope with the new alternator & bonnet mods all goes well with peggy in May.
Sticky. is offline   Reply With Quote
Old 18-04-2008, 11:28 AM   #82
Mike Rainbird
Moderator
Mike Rainbird's Avatar
Trader Score: (3)
Mike Rainbird is an unknown quantity at this point
Quote:
That's the plan .
__________________
Mike Rainbird
Sarcasm is just a free service I provide.
http://www.rsnorfolk.co.uk/
Nordschleife, there's only two barriers to worry about - the ones on the left and the ones on the right .
Mike Rainbird is offline   Reply With Quote
Old 18-04-2008, 11:31 AM   #83
Luca
Lukesville
Luca's Avatar
Trader Score: (2)
Luca is an unknown quantity at this point
Function over Form everytime
__________________
Built @ JKM Performance - NEW SPEC 471.9 bhp
thetrolley +500hp/ton - 134mph over 1/4 mile
April 2011 - 11.74 @ 129.15mph
Luca is offline   Reply With Quote
Old 18-04-2008, 11:37 AM   #84
James90RS
James90RS's Avatar
Trader Score: (10)
James90RS is an unknown quantity at this point
Send a message via MSN to James90RS
Stunning as usual Mike, and I like the bonnet
James90RS is online now   Reply With Quote
Old 18-04-2008, 11:38 AM   #85
Trader Score: (14)
Twins is an unknown quantity at this point
Quote:
Originally Posted by Coldo View Post
That would have to make a hell of a difference for it to be worthwhile in my opinion.
Same with the Imperial Blue escort (warren i think his name is) - The bonnet looks gash but if it does the trick then fair enough i guess?
Your car is quality though
It has made a hell of a difference on Warrens but still we had issues at Time Attack when that much heat is being generated in the engine bay its not healthy to keep it in there.... The bonnet got burnt again but not as much,we have heat wrapped what we can now so hope fully after a test run maybe the bonnet can have its 3rd coat of paint!!!!! Any way Mike your missing 1 row of louvres!!!!
__________________
My carbon clad s2
Twins is offline   Reply With Quote
Old 18-04-2008, 11:44 AM   #86
Mike Rainbird
Moderator
Trader Score: (3)
Quote:
Originally Posted by Twins View Post
It has made a hell of a difference on Warrens but still we had issues at Time Attack when that much heat is being generated in the engine bay its not healthy to keep it in there.... The bonnet got burnt again but not as much,we have heat wrapped what we can now so hope fully after a test run maybe the bonnet can have its 3rd coat of paint!!!!! Any way Mike your missing 2 rows of louvres!!!!
I have had my manifolds coated (see previous posts ) and I have proper heat shields all round the car, so I sould be okay with the ones I wanted . Deliberately did it how I wanted, as I didn't like the angles on Warren's and wanted it to look different too .
Bonnet won't be painted until next week, so will be the normal one on for Sunday .
__________________
Mike Rainbird
Old 18-04-2008, 11:54 AM   #87
Sticky.
Sticky.'s Avatar
Trader Score: (4)
Quote:
Originally Posted by Mike Rainbird View Post
That's the plan .
Old 18-04-2008, 02:08 PM   #88
Luca
Lukesville
Luca's Avatar
Trader Score: (2)
Mike have you considered removing the bulkhead panel between bulkhead / bonnet.
Would this not allow additional cooling by letting the air escape.
Not sure on escort but on my car the scuttle panel is vented so i can get a good dose of hot air out of this via removing the bulkhead panel...
__________________
Old 18-04-2008, 02:22 PM   #89
Mike Rainbird
Moderator
Trader Score: (3)
Don't want to cut it about .
__________________
Mike Rainbird
Old 18-04-2008, 03:18 PM   #90
dumped
Trader Score: (0)
dumped is an unknown quantity at this point
Why have you vented your coil pack location, just for extra laughs when you park in the rain? What out electrics have you vented????
dumped is offline   Reply With Quote
Old 18-04-2008, 03:28 PM   #91
Mike Rainbird
Moderator
Trader Score: (3)
Quote:
Are you a spastic? Have you even LOOKED where my coil-pack is located in the previous pictures prior to passing comment? Looks like a "no", so !
__________________
Mike Rainbird
Old 18-04-2008, 03:40 PM   #92
dumped
Trader Score: (0)
sorry, I have looked closer - its your air injectors and whatever that control box is lol.
Old 18-04-2008, 04:11 PM   #93
Mike Rainbird
Moderator
Trader Score: (3)
What you mean is "You have now looked, rather than assuming" .
1. The control box is a sealed water-proof unit for the HIDs .
2. The injector wiring is also properly sealed in Raychem and the heat radiated from the header tank will keep this area dry .
Any other ill thought out criticisms you wish to make?
__________________
Mike Rainbird
Old 18-04-2008, 04:28 PM   #94
dumped
Trader Score: (0)
lol, no i had looked and viewed the coil on the passenger side, just not in enough detail compared to the bonnet, my bad. How is heat from your header tank going to keep the area dry when your car is parked up and cold, as its this time I would have expected the cold/damp electrical problems when you go to use it. Added to the fact once your running it your super vents are supposed to keep it so cool that it wont dry out. I personally would not have vented the passenger side so as not to risk introducing problems. These problems may not exist, I guess you will find out.
Much like fitting a 4Xcossie cooler and having cooling problems, or a Pro alloy monster cooler then having to add another water cooler. What is the root of your problems as I dont remember gareth lloyd running into all this bother yet its a T4 anti lag job or does he?
Old 18-04-2008, 08:58 PM   #95
trevCOSS
trevCOSS's Avatar
Trader Score: (6)
trevCOSS is an unknown quantity at this point
Send a message via MSN to trevCOSS
I think the bonnet will look fine, dont mind it at all Mike also hopefully it will help with the temps.
__________________
My Cossie
Fat people love Cake
trevCOSS is offline   Reply With Quote
Old 18-04-2008, 09:55 PM   #96
Warren
Trader Score: (0)
Warren is an unknown quantity at this point
Mike I look forward to see how long your coatings last as for proper heat shields well I'll look forward to your excuses I wouldn't expect anything less from you when less louvers in a bonnet can create less heat under the bonnet..............
__________________
Work Hard Play Harder
Warren is offline   Reply With Quote
Old 18-04-2008, 10:50 PM   #97
cozzymatt
cozzymatt's Avatar
Trader Score: (0)
cozzymatt is an unknown quantity at this point
Send a message via MSN to cozzymatt
nice cheese grater!!!
cozzymatt is offline   Reply With Quote
Old 21-04-2008, 09:34 AM   #98
Mike Rainbird
Moderator
Trader Score: (3)
Martin,
I don't have any issues now, I just wanted to give the cooling system an easier time / helping hand, as Warren had advised of the significant improvements with his - and as Tesco says - every little helps .
__________________
Mike Rainbird
Old 21-04-2008, 09:56 AM   #99
Dan
Trader Score: (0)
Dan is an unknown quantity at this point
Nice mod, I think it'll look fine Mike!
Dan is offline   Reply With Quote
Old 01-05-2008, 12:41 PM   #100
Mike Rainbird
Moderator
Trader Score: (3)
__________________
Mike Rainbird
Old 01-05-2008, 12:45 PM   #101
carlo
Trader Score: (4)
carlo will become famous soon enough
Send a message via MSN to carlo
Foook me that looks bad when did that happen mike
__________________
ps3 game tag carlo-ybe
If you need cosworth parts
contact mark
07548064979
www.mt-motorsport.com
carlo is offline   Reply With Quote
Old 01-05-2008, 12:48 PM   #102
Luca
Lukesville
Luca's Avatar
Trader Score: (2)
__________________
Old 01-05-2008, 12:48 PM   #103
Matt Evans
Black Country RSOC
Matt Evans's Avatar
Trader Score: (0)
Matt Evans is an unknown quantity at this point
Fuck me thats looking an expensive job mike?
How did you manage that?
__________________
Visit our local group (Black country) RSOC web site www.bcrsoc.co.uk
Matt Evans is offline   Reply With Quote
Old 01-05-2008, 12:51 PM   #104
Mike Rainbird
Moderator
Trader Score: (3)
The front prop let go on the way back from Central Day whilst at 7500rpm in 4th .
__________________
Mike Rainbird
Old 01-05-2008, 12:53 PM   #105
Dan
Trader Score: (0)
!! Fook me Mike thats some damage!
Will it still make Germany or is that out of the question!?
Old 01-05-2008, 12:54 PM   #106
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Trader Score: (1)
Charlie Chalk is on a distinguished road
Send a message via MSN to Charlie Chalk
Ouch! Bad luck Mike, Will it be sorted before 'Ring?
__________________
GE - 1D - T
Charlie Chalk is offline   Reply With Quote
Old 01-05-2008, 12:55 PM   #107
carlo
Trader Score: (4)
Gutted for you mike hope you get it sorted
__________________
contact mark
07548064979
Old 01-05-2008, 01:01 PM   #108
Mike Rainbird
Moderator
Trader Score: (3)
Will be ready Sunday night .
__________________
Mike Rainbird
Old 01-05-2008, 01:04 PM   #109
T3ORA
Trader Score: (0)
T3ORA is an unknown quantity at this point
happy day's
how's your pocket feelin now mike
T3ORA is offline   Reply With Quote
Old 01-05-2008, 01:07 PM   #110
James90RS
James90RS's Avatar
Trader Score: (10)
Quote:
Originally Posted by T3ORA View Post
happy day's
I should think it has lost a few stone, but still weighs more than the worlds fattest man
Shitter Mike!! Glad it will live again though
Old 01-05-2008, 01:11 PM   #111
carlo
Trader Score: (4)
He prob lost a few stone when it went bang at that speed must have shit yourself ehh mike?
__________________
contact mark
07548064979
Old 01-05-2008, 01:12 PM   #112
Mike Rainbird
Moderator
Trader Score: (3)
happy day's
Empty . Just some fluff, an old jelly baby (covered in aforementioned fluff ) and a button left .
FOR SALE:
One Quife thickwall casing - "slight" damage - Arladite supplied for minor repair!
__________________
Mike Rainbird
Old 01-05-2008, 01:13 PM   #113
Charlie Chalk
Unknown.
Trader Score: (1)
Top man
__________________
GE - 1D - T
Old 01-05-2008, 01:13 PM   #114
Mike Rainbird
Moderator
Trader Score: (3)
Quote:
I'm used to it by now .
__________________
Mike Rainbird
Old 01-05-2008, 01:15 PM   #115
carlo
Trader Score: (4)
thats the spirit nice to see your not dishearted
__________________
contact mark
07548064979
Old 01-05-2008, 01:26 PM   #116
Ryan
Trader Score: (0)
Ryan is an unknown quantity at this point
Send a message via MSN to Ryan
mike your determination and unflitching dedication to your car is very very very admiral, i would have fucked it off ages ago. probably about after the 5th drive shaft got spat out.
FAIR PLAY MATE!
Ryan is offline   Reply With Quote
Old 01-05-2008, 01:51 PM   #117
Mike Rainbird
Moderator
Trader Score: (3)
Quote:
FAIR PLAY MATE!
Wibble .
__________________
Mike Rainbird
Old 01-05-2008, 02:15 PM   #118
Nash
Cake lover!
Trader Score: (3)
Nash is an unknown quantity at this point
Gutted for you mate.
Good of Charlie to come and get you I recon he will buy you AA cover for your birthday.
Wibble .
Fpmsl
__________________
88 Saph - 455bhp & 438lb/ft
02 CTR - 248bhp & 184lb/ft
Nash is offline   Reply With Quote
Old 01-05-2008, 02:15 PM   #119
kjc300
Trader Score: (1)
kjc300 is an unknown quantity at this point
FAIR PLAY MATE!
Ryan, you almost chuck the towel in if a bit of dirt lands on the car!!!
Anyway Mike,
Welcome to the 150+ Front Prop Carnage Club!!!
__________________
Cheers, Kev.
kjc300 is offline   Reply With Quote
Old 01-05-2008, 02:24 PM   #120
kitchy
RS2000 4x4
Trader Score: (0)
kitchy is an unknown quantity at this point
Send a message via MSN to kitchy
shit thats some serious damage! glad its getting sorted quick tho,
__________________
Audi S3 aka "Sabine" MRC remapped, 254.7bhp & 261.9lb/ft
kitchy is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
escort 1.4cvh wiring loom & escort mk4 efi header tank grsford Cars & Parts Wanted. 0 14-01-2008 06:01 PM
FITTING MK6 ESCORT RS2000 RECAROS TO A MK5 ESCORT 1.8 ZETEC steelcabby General Car Related Discussion. 11 03-01-2008 11:49 PM
escort rs turbo fuel pump and an single escort cossy wheel ////ANTHONY Cars & Parts Wanted. 0 28-06-2007 11:48 PM
focus/late spec escort wanted for swap with escort cab 749steve Cars & Parts Wanted. 1 28-08-2006 09:46 PM
escort mk3 escort se cabriolet running problems (wont run) S1 JOHN General Car Related Discussion. 7 23-08-2005 01:51 PM
