Help needed Turbo Conversion mk6 escort 16v
Could someone please point me in the right direction, I have a '99 1.6 16v escort zetec and looking to covert to a turbo as i have been informed this is possible after upgrading waterpump etc etc can some one confirm this is definately possible, rough costings and anywhere london based could do such a mod
many thanks
many thanks
swap to a 2.0 and THEN convert to turbo, the 1.6 is crap, sorry mate..
but if you want to do it the cheap way, megasquirt management, 300 quid
dsescent turbo and manifold, 100 - 150 quid
cossie injectors and a frst or xr2i injector rail, 30 quid
decompression plate and head gaskets, 60-100 quid depending where you look
new bottom shells, uprated conrod bolts, water pump, oil feeds etc, all the little parts, about 100 quid
oil cooler, 100 - 150 quid
engine, 100 quid from a scrappy
you can convert for 800 quid if you get a couple bargains, and do the work yourself, all i need now is managemnt and ive only spent about 400 quid, if youre in the know
well megasquirt is not a stable management it can be good one day and BANG fook your engine the mext and not many engine tuners will touch it cause that will happen
lol mine didnt go bang in fact it went very well!! as said if built properly it will work properly. best buying of a pro like phil ringwood.. extraefi.com
Yeah I've seen plenty of people running Megasquirt with no problems!
As said, it can be done, but the 1.6 is awful head on it doesn't flow well at all. At least use a 1.8, cheaper than the 2.0. and with the decomp plate route, done right can still see about 200bhp, which is alright in a FWD car!
I have got mk6 escort. when got it it was 1.6 si. then i put 1.6 cvh turbo lump in it wid cossie l8 mangement. mtx75 gear box. now engine comeing out and in middle of building 2.0l zetec turbo steel rod low com pistions. amining for 300 bhp ish.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Escortdriver1
31-07-2015 02:36 PM
