| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 22-01-2010 at 07:17 PM. |
#2 |
looks pretti kool tha!
they rondels?
__________________
#3 |
Very nice ,saw this at landgraaf
__________________
My carbon clad s2 |
#4 |
Took off the head and all the MFI stuff already...
Waiting for the EFI head i'm working on at the moment ![]() So much space over the gearbox... so finally some room for my oilcooler..
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 |
#5 | |
Quote:
__________________
#6 |
Inletports On the EFI head are ready to go.... Have to find me some time to do the exhaustports this week and order a new gasker and bolts to put the head on .
__________________
#7 |
Nice job m8!
__________________
#8 | |||
Quote:
Quote:
Quote:
Received the MS kit last week. The brains...with boostcontrol, launchcontrol an 4 bar mapsensor ![]() Inovate Wideband lambda kit with display.. ![]() Nice wiring loom... ![]() boostcontrolvalve, AIT sensor and TPS... ![]() I won't be getting bored the upcoming weeks
__________________
#9 |
Nice project Gregor.
#10 |
www.powerkings.nl
finally......
It's about time The space near the gearbox is great!!! I know!!! Plenty of room for a big filter and oil-cooler! And how are things with the downpipe?? Cheers Berry
__________________
#11 | |
![]() Trader Score: (0)
Rep Power: 9 ![]() |
Wow after all that time a topic hehe. Good luck with the build mate
__________________
Saab 9-5 '98. 2.0T. Maptun Stage 1 225hp 340nm ![]() Youtube coment: Quote:
#12 |
Looks perfect on the Borbet's! Lovely wheel!
Really suit the car |
#13 |
Finding my feet
Hiya mate, wots involved in swapping to efi, and what are the advantages, other than space above the gearbox?
__________________
ZVH Turbo Escort Zetec Turbo Mini!! |
#14 |
all the best with it m8
#15 | |
Quote:
Involved is : you need a efi head, injectors, fuel rail, frst/efi or stand alone management, wiring loom adapted, efi inlet, EFI flywheel with cps and some more .... lots of Mfi--> Efi comversion topics here on PF ..
__________________
#16 | |
Quote:
Have to work on it anyways because of the fitment of thme lambda sensor..
__________________
#17 |
injectors to be used....
380 cc rover injectors ![]() ![]() anyone know to what power these can be used??
__________________
#18 |
Finding my feet
Gregor,
so wots the spec of yours?? what management were you using etc... also just out of interest, wot gearbox do you use?? thanks
__________________
#19 | |
Quote:
spec was : 2.0 ZVH with accrelite pistons CR 8:1 standard head with kent 35 MDS chip, k&n, scorpion 2.5" Samco's, alu rad, cos intercooler adj cam poulie, -31 acruator. AP fast road clutch. New spec: As old but with AP paddle clutch Megasquirt 1V3 ecu with wide band lambda 2wd cosworth turbo 13 row oil cooler At home ported and polished efi head. hopefully a grs intercooler if i ever get it send here,,, :S Already driving it with a stage 1 box from the gearboxman but wondering how long it wil cope with the increased power.. cheers
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 15-03-2008 at 06:46 AM. |
#20 |
Trader Score: (0)
Rep Power: 6 ![]() |
good topic
Will be interesting to read your thread
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 |
#21 |
Exhaust side of the head all done now... zo waiting for bolts and gastket to put it on..
![]() Also made some bonnet spacers to help cool the engine... and looks nice as wel ![]() ![]()
__________________
#22 |
Trader Score: (0)
What bolts and gasket are you planing to use?
I've used felpro and standard RST head bolts as I was advised to use stretch ones, but to use them I had to machine the head in the place where bolts sit to go deeper by 8 mm
__________________
#23 | |
Quote:
Had it like this the last 2 years on my mfi ZVH.
__________________
#24 | |
Trader Score: (0)
Quote:
By the way did you study MS wiring already?
__________________
#25 | |
@ maki.
The wiring for the MS isnt that difficult mate. They are al marked.
__________________
#26 | |
Trader Score: (0)
Quote:
And at the moment I'm stuck with fidle valve so was wondering maybe Gregor has thought about it already.
__________________
#27 | |
Ah ok. Why didn't you bought the MS loom then? it isnt that expensive.
__________________
#28 | |
Trader Score: (0)
Quote:
__________________
#29 |
I bought the MS loom so its all marked....
__________________
#30 | |
Trader Score: (0)
Quote:
__________________
#31 | ||
Quote:
__________________
#32 |
Did some work again...
reground the valves/valveseats, put on new valvestemseals, put on the springs+valves,cam, thermostathousing and adj pulley. ![]() ![]() ![]() Weird thing is the cam looks a littte off-set... but seems to have ran like this the whole time so shouldn't be a problem. Got the bolts for the head and some other gaskets and nuts from the ford dealer. Now waiting for the headgasket from burton so all can go on the bottom end
__________________
#33 | |
Trader Score: (0)
Quote:
__________________
#34 |
#35 | ||
Quote:
__________________
#36 |
greggie, wel done mate
keep up the good work
__________________
![]() 2011 Fiesta S-Edition. 2001 Fiesta Zetec-s 1982 Escort mk3 1.6 turbo. |
#37 |
looking good
#38 |
Worked on the ports off the inlet manifold to match the head and placed it on the head together with e fuelrail and injectors
__________________
#39 | |
Is this car still not finished
Nice work. Now get that thing runnig
__________________
#40 |
While waiting for the headgastket , started to renew the brakelines as something wasn't right in the lines that were there.... the brakes didn't respond verry well so all new lines in there with a wilwood brake bias valve for the rear..
some pics.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() When the cos brakes are reconditioned they're coming back on with the braided hodes
__________________
| Display Modes | |
