| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#201 | ||||
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/restorations-rebuilds-and-projects/222915-zetec-turbo-on-megasquirt-new-turbo-arrived-gt2871r-p.html |
#202 |
Looking good mate, were the crowns of the pistons thick enough?
The exhaust manifold hasn't been done yet btw, the current welds were way too dirty to reweld. Also the collector tube is pushed in a few cm which will fuck up your exhaust gas flow. Think the best way to go is redo it when it's bolted to the engine...
__________________
#203 | |
Quote:
Can machine 1 mm more off them and with the thicker gasket i'm coming to a 8.35:1 CR.. good enough. We'll redo the manifold then when engine is built up..
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 |
#204 |
turbo-herman
good progrees there mate.
now get cracking and build up the engine. should be a nice runner when done greetz herman
__________________
once you go turbo, you never go turboless ![]() why do people always think i'm crazy? i'm not crazy. i'm an airplane
#205 |
Cant wait till is finished!!
__________________
![]() 2011 Fiesta S-Edition. 2001 Fiesta Zetec-s 1982 Escort mk3 1.6 turbo. |
#206 | |
![]() Trader Score: (0)
Rep Power: 9 ![]() |
__________________
Saab 9-5 '98. 2.0T. Maptun Stage 1 225hp 340nm ![]() Youtube coment: Quote:
#207 |
Trader Score: (0)
Rep Power: 6 ![]() |
where's the progress?
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 |
#208 |
Ok, ok , little update
machined the pistons off to the minimum crown thickness. ![]() Attached the rods ![]() In the block along with the 1.8 mm headgasket Also painted the block black again ![]() tightend the rod ends ![]() installed the head ![]() making the downpipe ![]() Testfitting the manifold and turbo ![]() Started fitting some hoses and bailey stuf. Timed in the cams and mouted the alternator. ![]()
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 11-04-2009 at 02:44 PM. |
#209 |
looks awsome!
#210 |
Trader Score: (0)
great job
What gasket is that?
__________________
#211 |
Did the intercooler pipes an fitted some hoses today and started to reweld the ehaust to fit the .48 cosworth exhaust housing
__________________
#212 |
__________________
#213 |
did you make the exhaust manifold?? if so were did you get the tube from to make it??
#214 |
Trader Score: (0)
__________________
#215 |
__________________
#216 |
__________________
#217 |
Compensation Specialist
sorry if i havent read through this properly but how much power can a zetec head flow if turbo`d with bog standard internals?
#218 |
hi mate i take it by standard internal your on about valves etc in the head itself , around 220/250bhp before you have valve lift problems , with uprated valve springs easily genuine 300/330 at around 20 psi depending what inlet etc you run
#219 |
and what valve spring option do you have and were from?
#220 |
__________________
#221 |
She's a runner
have to map it a little though lol..
__________________
#222 |
Great job Gregor. I hope that I will start with zetec turbo on MSQ this year. I need a few parts for it yet and I need to finished some other jobs. But I hope that one day I will start an engine like You.
__________________
#223 |
chatter 4 life
nice work fella, what bracket did u use for the cable, if i'm right in thinking u used a fiesta turbo throttle body
__________________
check out the mk3 zetec turbo build http://passionford.com/forum/restorations-rebuilds-and-projects/182173-mk3-escort-2-litre-zt-28-3-2010-geting-pissed-off-now-still-no-spark.html Member of "The Daytime pf talk bollocks and random shite club #110 www.stocktonautocentre.com |
#224 |
Thanx,
TB is from a xr2i for now. Bracket is a modified fiesta one.
__________________
#225 |
A little update on my zetec turbo RST.
i didn't plan on taking the engine appart but when i saw dirt in the oil i removed the cams and saw they were damaged due to what i think is sand in my engine :'( To be sure also removed the rods from the crank and also a lot of deepscratches here, So decided to get me another set of head,cams and crank. While i had the head of worked on the new head a little. Also received my new gt2871 turbo and wastegate an acl bearings. Hope to put all the goods together ones again soon ![]() ![]() ![]() ![]() ![]()
__________________
#226 |
Trader Score: (1)
Rep Power: 33 ![]() |
looks mate. I take it the engine is running a bit rich.
#227 | |
__________________
#228 |
Hey mate, finally the @ home, all looking good?
Headwork looks properly too, nice work! Now only the exhaust manifold, and bolting it together right?
__________________
#229 | |
Thanks mate, was running a bit rich indeed, was stil in the mapping progress.
Quote:
Thanks mate, searching for some pipe now and welding can start
__________________
#230 |
__________________
#231 | |
__________________
#232 |
__________________
#233 |
turbo-herman
__________________
#234 |
YES I KNOW I CANT SPELL
any up dates??
__________________
" im special,, excuse my spellings" |
#235 |
Yes a little bit.... Engine has been completely stripped and put another crankshaft in with new acl main and big end bearings.
Head is all built and ready to be fitted. Exhaust manifold is 80 % welded. Engine should be back in end of this week. Also bought some bucket seats to go in. Will put some pictures up soon.
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 08-03-2010 at 11:59 PM. |
#236 |
luv this thread, i have a slightly different project. i have a mk2 mondeo running a blacktop zetec turbo. habing trouble with the megasquirt mapping? just wondering if any1 can give me a sum pointers for how to set it up?
im running the standard injectors and edis module? it seems like you guys have worked out all your bugs with the MS, any ideas guys? P.S i hope this car comes to the uk one day as i would luv to see it!!!! |
#237 |
This project has come to an end.
will be sold in parts, time to move on.
__________________
#238 |
__________________
#239 |
good work mate ad love to do this to my car
#240 |
__________________
| Display Modes | |
