| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#121 | |||||
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/restorations-rebuilds-and-projects/222915-zetec-turbo-on-megasquirt-new-turbo-arrived-gt2871r-p.html |
#122 |
#123 | |
Trader Score: (0)
Rep Power: 6 ![]() |
Quote:
By the way I have interesting thing too, my car doesn't stall sometimes as I turn the key to off position she keeps on running (i'm not using relay board) The black wire we talked about after turning the key keeps giving 3.7 volts from the alternator that don't kill the relays... didn't figure out how to sort it so I put additional switch to break that wire in case the car keeps running the engine.
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 |
#124 | |
Quote:
The black is ground imo... Anyway like you said, learning all the time. I made my own relayboard but we'll see how well that's all gonna work Have you got the map online wich your engine is running on at the moment?
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 |
#125 | |
Trader Score: (0)
Quote:
The black one isn't ground wire (there are no ground wires in the ignition switch) Red one is plus from batery, then there is that ACC yellow (first turn of the key), then black wire (second stop of the key) and the black blue ignition wire that gets plus only during cranking. All the grounds are brown anyway. My msg file is from the default files on the MS page. But thats one set up for edis, so it will not suits you anyway
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 Last edited by Maki; 19-04-2008 at 08:21 PM. |
#126 | |
Quote:
I'll have a look with the voltage meter tomorrow... and get it sorted. thanks for explaining the wire purposes
__________________
#127 | |
Quote:
Wiring to MS is all sorted.. got power on it when cranking trough the black wire
__________________
#128 |
Well, after 2 days of trying to get it running, replacing one direct coildriver in the ms ecu and uploading the firmware again resulted in finally getting it running.
Now the finetuning can begin... already heard some nice chatter today, me is happy
__________________
#129 | |
![]() Trader Score: (0)
Rep Power: 9 ![]() |
yes thanks for ripping my MS apart
Here is your vid
__________________
Saab 9-5 '98. 2.0T. Maptun Stage 1 225hp 340nm ![]() Youtube coment: Quote:
#130 |
sweet
#131 | |
Well , did some work on the MS.
After fitting the tip 132 transistor for running the idle valve i made some adjustments in the megatune software and now it's running smoothly at 900 rpm. Also put in the standard value resistance in the ecu in stead of the one working with the ford sender as i now have the GM sender ( clt) . That also is working fine now. I've now got the same problem as Maki... Quote:
Thanks
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 18-05-2008 at 06:18 PM. |
#132 |
Do I get you right? It runs without playing with the throttle??
So that's an improvement How is the temperature now??
__________________
#133 | |
Quote:
Yes, it idles great now...at 900 rpm without playing with the throttle at all ![]() After replacing te resistance for de clt sender in the sensor from 27000 to 2490 the temperature is ok. When cold the clt and iat are the same and after some mins of idle it's at 70 Degrees orso. Looks like its working gooed. Thing now is the remaining current of 3 volts and the fan's aren't cutting in now but we're getting there...
__________________
#134 |
Trader Score: (0)
You should have left the fan on the standard plug and also I can't understand why your resistores for the clt where changed at all. Who from the stone age did assemble your MS???? did he hear anything about easytherm??
__________________
#135 | |
Quote:
__________________
#136 | ||
Quote:
__________________
#137 | |
Quote:
well, the one why assembled my MS is a local dealer, didn't know to much about him at the time... I tried easytherm myself but couldn't get it right, thought let's get it back to basics and it's working fine now.
__________________
#138 |
Trader Score: (0)
How is it going Gregor? I ran yesterday 13,62 quarter on mine. Started with 15.59.... so I'm getting there. So far it's only 10 psi of boost
__________________
#139 |
Verry nice one :P:P
I 'm stil strruggling to get it to pass the 6100 rpm makr. When i hit like 6000 it's like it hits the rev limiter. Fiddling with dwell and spark maps and maybe onthe capacitord for the ignition in the ms. Otherwise ir runs fine to about 10 psi same as yours,... Plans are to run it to about 21 psi or so. but my engine stil is getting hot even with the blowers on constatly :P Well hope to see nice time like yours on the quarter mile soon 13.6 on 10 psi is fast..... i only ran a 14.7 orso when it was on mfi with 12 psi i think.....
__________________
#140 |
Colossal Pervert
Could be valve float perhaps? Strange on a CVH head though.
edit: unless you've changed the valve springs
__________________
![]() Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo. |
#141 |
Trader Score: (0)
1. look for the rev limits in the settings.
2. it could be that you ar getting to hot because of the bad ignition timing. 3. my quarter improved a bit.... I ran 12.99 at 0.9 bar of boost and it's not the end 4. remember that problem with the engine not stalling after you turn the key off? I think I have a soliution for it, but first will try it out on mine.
__________________
#142 |
__________________
#143 | |
Quote:
2: coolingproblems were on mfi also. 3: nice one. what are your reaction time,1/8 mile time and speed at the end. 4: already solved "the engine not stalling when the key is turned off" problem
__________________
#144 | |
Trader Score: (0)
Quote:
2. then I think your intercooler is blocking the air suply to the rad or you have shit thermostat. Mine used to overheat on the RST engine, but now it doesn't although the intercooler and the rad stayed the same. 3. don't remember reaction time on the 12.99 run, but one of the best was 0.59 4. how?
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 Last edited by Maki; 02-07-2008 at 06:32 AM. |
#145 | |
Quote:
2. drove it without intercooler with the same problem. 3. still verry good time, wonder wat all the results are. 4. It's getting powered through the alternator light bulb in the instrument panel. Adding a diode to that line to prevent reverse current will fix the problem. ( Thanks to JesseT )
__________________
#146 |
gregor .as for your injectors the rover ones you have are 390 cc and are good for 350 bhp.i had the same ones in my 2ltr ztec mk2 fiesta ,which was running ms ,my ms was ms v3 and was 225 bhp on 8 psi .any way nice build mate keep it up
#147 |
Colossal Pervert
390cc injectors good for 350bhp? That's one hell of an engine that burns so well!!
__________________
#148 | |
Quote:
was hopeing to get around 280 bhp on this engine... we'll see what it brings. Had 230 bhp on 11 psi on mfi. Currently driving it @ +/- 17 psi gonna set it at a rolling road soon.
__________________
#149 | |
Trader Score: (0)
Quote:
3. best result 2.02 60 ft, 175.71 kmh, 12.99 but hey I'm in drag racing since 2002 4. that's exactly the way I did it... so far it works.
__________________
#150 |
Congratulations Gregor. Its looking really great. Hope that It will be working well. I hope that I get the MS this month.
__________________
#151 |
Well after cleaning the brakes all around using ultrasonic bath refitted them with new pads.. seems to be working much better now
Made a new logfile today. running 1,3 bar it pulls nice but have to get some decent tires because as soon as the turbo is spinning the wheels do the same. The tires are scrubbing the arches so also i'm thinking of some other wheels.... what do you guys think of the log... stil a little rich on boost i think?? Thanks.
__________________
#152 |
Colossal Pervert
Doesn't look too bad.. try and keep it in the low 12's until you're say 500-1000rpm away from the rev limiter and then progressively richen it up to mid 11's for safety.
Did you fix your issue?
__________________
#153 | |
Quote:
I've got the rev issue as it's not revving over 6000 k. ZVH's aren't that revvy i've been told but on EFI it should be better and i see some people over here making more rpm...
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 Last edited by Gregor; 10-07-2008 at 08:40 PM. |
#154 |
As my old rims had an offset wich was to smal ( et 28 ) so was rubbing the arch constantly i treated the rs to some new ones.
Turned out to be 17 inch OZ superlegerra's. Looking good to me! First the old rims...then the new ![]()
__________________
#155 |
Hé dude, looks much better then I suspected!!!
__________________
#156 | |
Nice wheels mate. See you next weekend ok? ill take my vid cam with me. So find a nice bit of empty road.
__________________
#157 |
is half man, half amazin'
looks much better on those mate
#158 |
Got some work done once again to the rst.
finally hooked up the oilcooler. ![]()
__________________
#159 |
Nice looking car, Bet there a bit thin on the ground in you country too
__________________
Ibiza SDI Daily 70mpg boi! S2 RS Turbo
#160 | |
Quote:
It's going ok but as my zvh isn't that revvy dicided to go full zetec Turbo. Bought me a decent silvertophead with cams and all at the last meeting over here so the builing can begin once again Will be getting some steel rods in there at the same time so the boost can be turned up a bit more when it's finished. Just need to find out what springs will have to go in the head and what gasket to use, thinking of a cometic.. The new head...
__________________
| Display Modes | |
