| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | ||||
__________________
#42 |
just before xmas i managed to get hold of a turbo off ebay but the exhaust housing was f**cking massive and would have had to be used with an external wastegate,i got hold of a standard erst exhaust housing again from billyrst,luckily i had a garret turbo main shaft that fitted the exhaust housing so used that with the compressor wheel from the turbo from ebay
all i had to do then was send it off to gbturbo solutions to be balancedwhen i got the turbo back i bolted it on and it smoked like f**k all the time this is when i found out that it was the turbo oil return pipe i had made was causing the problems ![]() the kit was £35 plus £10 postage but then i also had to pay £15 customs charges
__________________
#43 |
once i had sorted the kit out i went to my dads place on saturday and fitted it to the car
![]() ![]() i welded the part onto the sump with the engine in place as didnt have enough time to take the engine out to get the sump off,i drained some of the oil before i drilled the hole then when i had drilled the hole i drained the rest out to wash any bit of metal that might have got into the sump when i drilled the hole,once the bits were done i had to run the pipe round the front of the exhaust as it would hav just kinked the pipe if i had routed it any other way ![]() now the car is back on the road again and no smoke now which makes a change
__________________
#44 |
when i get chance ive got a few other ideas i want to get started on so as soon as i start them i will update,also if anybody knows where i can get hold of a set of fiat barchetta door handles that would be a great help fiat want £60 each handle but if i cant get any second hand i will have to buy new items
__________________
#45 |
nice one fella! its looking good mate.
#46 |
ive had a set of ebc greenstuff front pads sat around for a while now so i thought i would put them on
![]() ![]() i then thought while i had the front end in the air i might aswell put my anti roll bar poly bushes on aswell ![]() ![]() then i also thought i might aswell put my adjustable lower arms on aswell ![]() ![]() all on and bolted up ![]() just got rear brake pads to do now
__________________
#47 |
got braided front brake pipes to fit when i get chance
![]() already got braided lines on the back
__________________
#48 |
picked up another toy yesterday
another s2 and its got full leather in it so will be swapping that into the estate
__________________
#49 |
well ive put the leather interior in and it looks better than i was expecting
will put pics up when photobucket is working
__________________
#50 |
ok photobucket is working now so heres some pics
![]() ![]() ![]() ![]() going to try and get my digi dash finished over the weekend and maybe get it fitted aswell
__________________
#51 |
What a difference
.....thats one sweet estate
#52 | |
Quote:
hopefully i will be starting a combi van project soon and putting all the stuff from my erst i bought into the combi
__________________
#53 |
That will be interesting you gonna go for the black theme or something different?
#54 | |
Quote:
just got to wait and see what the combi shell is like and if its good i will hopefully get it mid march then going to save for a set of 17s instead of the erst standard wheels
__________________
#55 | ||
Quote:
if it turns out like the estate its gonna be well worth it mate......i have a bit of a soft spot for black cars with dark wheels |
#56 | |||
Quote:
i will have whatever wheels i get for the combi painted a similar colour to the estate wheels im hoping to get it as good as the estate and hopefully keep the costs down under £2500 and then maybe see if fast ford would like it enough to do another feature,was also thinking if performance ford would do a grudge match with the 2 cars
__________________
#57 |
#58 |
looking good mate!! i sold my mk3 estate used to love it!! the pic with the engine in the back is the best proper sums the old estates up!! im looking at another mk3 estate local to me so might have some work cut out lol!!
1 time i had my mk3 full to the limit with scrap metal n stuff in the back the exhaust scraped all the way home from work lol 7 mile!!
#59 | |
Quote:
exhaust didnt scrape which was good yeh that sounds good then mate hopefully you will get it be good to see another estate being done
__________________
#60 |
hey fella , the estate is looking good, leather looks sweet! keep up the good work mate.
#61 |
__________________
My carbon clad s2 |
#62 | |
Quote:
__________________
#63 | |
Quote:
__________________
#64 |
ok did a few bits on the car today,got a big cossie filter so fitted that
![]() also did a couple other bits aswell but got to dark to get any pics so will get them tomorrow
__________________
#65 |
ok finally got round to getting some pics of the frst inlet manifold and charge carrier pipe
as i used all the parts from the efi xr3i it had a remote iscv and it looked a bit untidy as i was using a erst charge carrier so the pipes were a bit messy,i had the frst inlet and charge carrier pipe sitting around for a while so fitted them to tidy it up a bit as the iscv is on the side of the inlet manifold ![]() ![]() i also got hold of some bonnet raisers the other week from a frst,the holes for the bonnet bolts were in different places so just had to drill an extra hole in each block ![]()
__________________
#66 |
your bonnet aint shut!!!!!
grrrr hate people that say that...had loads of people say it when i had my red popular...and just brought some off me mate so my bonnet wont shut again soon! looking good fella!!!
__________________
#67 |
i have the instructions on how to wire that astra gte dash into an escort if you want i'll email them to you? pm me your address
top work mate well done
#68 |
Them seats look very nice top work
__________________
NATH. MK4 ESCORT ESTATE COMBI TDI -ISH MK3 FIESTA 1.8 ZT AUDI A6 ESTATE QUATTRO V6 TDI R33 GTST |
#69 | |
Quote:
nevermind hey cheers for the comments aswell
__________________
#70 | |
Quote:
__________________
#71 | |
Quote:
__________________
#72 |
what you going on about lol...
im saying what people have said to me in the past when i had them fitted, ive brought some more yesterday off my mate for my silver bonus 90... i realy like the look of em!!
__________________
#73 | |
Quote:
yeh i cant wait for people to start saying the same about mine i need them at the moment as my fan is only standard so it has trouble coping with the heat especially with the front mount intercooler
__________________
#74 |
oh sorry mate, wonderd what you meant...
had some dodgy people basically jumping out infront of you, saying your bonnets open mate and actually coming up to the car and pushing the corner of the bonnet down lol!! i was like!! tis funny though when people comment but those people that do the above! piss you off! get some kenlowes on the front fella......they work a treat!
__________________
#75 |
yeh sorry mate my fault i didnt explain very well
yeh i can imagine it would get annoying yeh im keeping an eye out for some decent fans but got a few things to pay for 1st including a combi van beginning of march
__________________
#76 |
ok done a few little things lately plus also picked a combi van up aswell the other week,ive fitted a volt meter to the fuel pump feed so i can see if anything happens and the voltage drops at the pump i can stop asap
![]() ![]() also fitted an act gauge just need a sensor for it now ![]() also managed to get my astra gte digi dash ready to fit at the weekend at last ![]() ![]() ![]() ![]() looks a bit messy on the back but once its in you cant see it anyway
__________________
#77 |
My Cossie Ate My Money
cars looking awsome mate keep it up!
how difficult is it to wire in the astra gte digi dash into a ford, ive always wondered.
__________________
![]() I WANT ANOTHER COSSIE! Self Proclaimed King Of The Shot Peeners Xbox Live Gamertag: HeavyDarka |
#78 |
is half man, half amazin'
good work
shame about the turbz |
#79 |
good work mate, but gasher for not takeing the sump off to drill it lol! how are you getting on with the turbo now?
my mates just got 1 off ebay just wandering how long its gona last!
__________________
[CLICK TO SEE MY SAPH RESTO!! http://www.passionford.com/forum/viewtopic.php?t=240033 |
#80 |
Old Fords Never Die
Best modded mk4 estate on here, great choice of mods matey
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Mk3 ESCORT ESTATE ---> S1 Estate Project - No longer for sale. | 7xrskb | Cars for sale | 10 | 13-04-2008 09:50 PM |
| wanted mk3 van/combi/estate or mk4 estate/combi | mk1trb | Cars & Parts Wanted. | 1 | 06-09-2006 03:59 AM |
| FRST, ERST or ERST cabby wanted... | rsjohn | Cars & Parts Wanted. | 6 | 21-10-2005 11:17 AM |
| Best estate? | BlueSmoke | General Car Related Discussion. | 9 | 27-09-2005 07:44 AM |
| Eeek! Mondeo Estate may have to go.. EVO Estate due soon? | Disabled Account | General Car Related Discussion. | 16 | 06-07-2005 06:00 PM |
