| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#721 | |||||
B1mbo
__________________
![]() mt-motorsport.com
#722 |
Wye Valley Hardcore
Awsome awsome work fella! Not seen this before.
__________________
![]() "BRAVERY IS THE CAPACITY TO PERFORM PROPERLY EVEN WHEN SCARED HALF TO DEATH"
#723 |
Capt Chaos
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#724 |
aka Turbosailorboy
![]() Trader Score: (5)
Location: Under the water.... .......in a nuclear submarine
Rep Power: 12 ![]() |
Few more bits collected
Suede 350mm diameter with a 90mm dish ![]() Odyssey 25 Race Battery, small but heavy ![]() ![]() And a piece of PF history ![]()
#725 |
Cake lover!
Good work Andy, Richie you best be feeding him up while hes working.
__________________
![]() 88 Saph - 455bhp & 438lb/ft 02 CTR - 248bhp & 184lb/ft |
#726 |
aka Turbosailorboy
#727 |
Capt Chaos
__________________
#728 |
Puma Nutter!!!
Ritchie just remember the alcons have no dust seals and that the pistons etc are horrendously expensive from alcon. a guy called jacko on projectpuma has had all the pistons, pipes, shims etc remanufactured out of better materials much cheaper than alcon bits.
Also for a car like yours you might be better off buying belled discs off hispec when your current ones wear out as they are cheaper than alcon replacements plus having the advantages of being belled discs. Alcon FRP 4 pots are awesome brakes and in my experience they brake harder than anything from hispec/brembo/wilwood with the same disc and 4 pot set up. (ive had them all over the years) Id say the alcons on FRP standard 295mm discs are only slightly inferior compared to the 330mm discs and AP cp5200 4 pots i have on my current car. You can get bigger discs for them with spacers. A well maintained set of alcons are awesome, they just take a bit of care to keep in good nick. Richard parry jones tested them at boreham and he was doing 0-80-0 brake tests back to back to make them fade and he was sick first ![]() The only problem i can see is you may reach a power limit with the engine youve got!! certainly not a problem with speeds and wieght of the car. What does the exhaust tunnel do??? is it purely for noise purposes or are you planning on running it suuuuuper low for track???
__________________
![]() Medically Discharged!! Officially insane!!! My Project Thread: http://passionford.com/forum/restora...e-job-fix.html |
#729 |
aka Turbosailorboy
Hi Warren
![]() Thanks for the info ![]() I've heard some horror stories about them , but like you say, they are very good if maintained in A1 condition. Pistons are all clean and free to move. Was going to spec to Martoon about a seperate disc/bell set up anyway Exhaust tunnel is purely to enable me to get it as quiet as possible and i don't want side exit exhausts as flames out the side gives the game away ![]() ![]()
#730 |
looking good fella,
__________________
#731 |
Puma Nutter!!!
People only have horror stories because they are a race caliper on a road car then wonder why they siezed up with 40000 miles road driving
![]() ![]() As long as you have a good pad compound and clean them regularly then to be honest you wont have to do much. Most people i know with FRPs find that once theyve got them in good condition (you never know what your buying until you look really), just a caliper service once a year keeps them sweet with the occasional piston replacement if they are scored. I suspect if your using it as a trackday beast then they will be off the car more often anyway so things like keeping them clean wont be an issue. The Jacko guy is getting lots of stuff remade in stainless and titanium so the life can be extended anyway!!! Theres a rebuilding guide on the site in the FRP area. Obviously with the amount of power your running you might eventually reach the calipers limit on trackdays etc ( i assume the rest of your braking system is all race stuff anyway) but if it were me, id see how it goes first before choosing to go bigger as we all know how horrendously expensive 6 pot AP's are
__________________
#732 | |
Quote:
![]() Glad to see you got some enthusiasm for it dude and work is getting done, even if it is by your mate
#733 |
Cake lover!
Warren, Richie will be fine with those brakes as hes a pussy when it comes to braking
__________________
#734 |
Puma Nutter!!!
@ nash.ritchie, technical info, rebuild guide, spare parts sourcing etc for alcon calipers can be found here: http://www.projectpuma.com/viewtopic.php?t=2231 you need to register to see it but its free to register.
__________________
#735 | |
Quote:
4000k miles no problems there for richy then thats around 10 years use, the alloy will have corroded before he does 4k miles ![]() ![]() ![]()
__________________
![]() Autronic ECU, Reyland brakes, mapped by chip. |
#736 | |
Capt Chaos
Quote:
![]() ![]() ![]() ![]() i think not .
__________________
#737 |
Puma Nutter!!!
mmmm i feel there is bufty force in him as he wouldve just rattle canned the shell and had it running by now if there was no bufty force at all
__________________
#738 |
aka Turbosailorboy
Getting closer to paint time so got my friend to do a quick photoshop to see what it will look like Frozen White vs Racing Blue
![]() ![]() Looks cool |
#739 |
Puma Nutter!!!
Whatever colour on outside, perhaps spray the cage black and have a medium tint on the rear side and back windows
then you can pull off the sleeper look![]() theres going to be a few big power cars that will be like "wtf" as you sail past on track!!
__________________
#740 | |
aka Turbosailorboy
Quote:
Got my painter coming up to look at what we can do ref painting cage a different colour. Windows defo getting a light/medium tint as well. I need to improve my driving before i go sailing past anybody |
#741 |
Unknown.
Frozen white, Black alloys.
__________________
GE - 1D - T |
#742 |
frozen white is the way forward
__________________
power is nothing without control |
#743 |
FUCK me just read the whole thread.. all i can say is thats going to be one insane ford KA.. some serious work already gone into this...brilliant job...
__________________
I've Lost the Plot one day I'll Work it Out |
#744 |
not keen on the white but will look good with tinted windows
__________________
loysport http://www.bafabrications.co.uk/ PM MONSTER FOR CUSTOM VIN TAGS carpartsexpress mail order ford parts 01914272186 |
#745 |
__________________
#746 |
Cake lover!
White looks good mate. I think zinc yellow might look cool, but i dont know if you would get tired of it and then go onto paint it white anyway.
__________________
#747 |
Passionford Thread Killer
Copper slip orange ??
__________________
![]() Low Slung Denim |
#748 |
polaris
__________________
www.mattlewismotorsportonline.co.uk NEW ONLINE SHOP http://www.passionford.com/forum/showthread.php?p=3849679#post3849679 Ronnie amis, sponsored by MOTORSPORT DEVELOPMENTS. Doug miller, sponsored by PUKKA PIES
#749 |
formerly beefy-rst-2
__________________
![]() founder of the parmo apprcieation scoceity ... SUPPORTER OF RONNIE AMIS !!-team airtec/gs automotive !!! Quote: Originally Posted by Will @ M Developments Honestly, a roller T4 like wennys would suit your needs perfectly. If it did blowjobs and made parmos you'd need nothing else in life
#750 |
polaris like my escort mate..
i would post a photo of my car up from escortrscosworth.com but i dont no how ![]() thanks steven..
__________________
#751 |
frozen white looks cool
__________________
#752 |
Nice Project
#753 |
Absolutely insane mate! Love the amount of work going into this.
#754 |
*** Sierra RS Custard ***
Radiant Red with anthracite wheels.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
![]() Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff 2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused ![]() www.VauxSport.com |
#755 |
Blue with the inside painted Anthracite.
Looking good mate. |
#756 |
__________________
#757 |
tvr candy apple red, its a lovely colour in the light.
same as this mosler http://images.google.co.uk/imgres?im...a%3DN%26um%3D1 Last edited by PAUL S; 09-11-2009 at 09:40 AM. |
#758 | |
Quote:
Too fancy a colour for the KA I reckon, needs to be a bright colour but a plain one IMHO, base colours are timeless
__________________
#759 |
i would be tempted to go with a dark grey, something like Mercedes Tenorite grey, looks awesome in the sunlight
![]() kinda like this
__________________
#760 |
does it matter what colour you paint it ???
im sure it will get changed twice a year anyway
__________________
| Display Modes | |
