| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#161 | ||||
__________________
#162 |
Any time, its hard to explain over txt what i did, alot of people have asked how i did it. I`ve found a pic of the belt set-up, i used a mk5 escort alt bracket spaced away from the block, and a cut-out for the wayer pump outlet....
#163 |
cheers for that Shandz, gives me a wee idea how to set mine up
__________________
#164 |
So what set-up u going for with urs?
#165 |
I`ve been thinking about more power, so spoke to Simon, and just looking at collecting parts for a turbo conversion!! And will be knocking on the door of 300bhp.
It was just a quick conversation and we came up with this. CR- Simon knows GT25- not decided on spec yet FRS exhaust manifold Sitech racing inlet FMIC Also not realy sure about the vvt, to use it aswel or blank it off.... Would be interesting to see what its like with vvt+turbo! Last edited by ShandzS1; 27-11-2008 at 05:35 PM. |
#166 | |
Quote:
__________________
![]() 0-60 in 5.03 and winner of the fwd sprints at ford fair 2009 and 2010. 1/4mile in 12.7@ 123mph |
#167 |
Yeah heard alot of people blanking it off when turbo`n the st head. Think i`ll keep it!
Whats the spec of ur engine etc? And any pics? |
#168 |
its just a high comp st engine steel rods forged pistons custom manifolds ect ect but in a fezz turb,theres a wee pic in my sig.
__________________
#169 |
What CR, turbo, managment u running?
Any bhp figures? |
#170 |
should be good!
Even if you dont run VVT you dont have to blank it off, just leave it on, oil pressure keeps it closed and it runs as normal.
__________________
My new project - http://passionford.com/forum/restora...bs-so-far.html |
#171 |
that is not right!
I you leave the vvt only disconnected, the cam goes into the following high tourqe position! The engine runs like this, it runs realy nice. but it dosnt have much power. the engine does have no valve ??overcuting?? (i just know the german word, thats the translation!) when the vvt is disabled and not manualy seted! Cheers Mark ( www.ST2000.de ) Last edited by Jackass1983; 28-11-2008 at 01:58 PM. |
#172 |
__________________
#173 |
lookin great mate, bound to go well and sound awesome
my good mate bought your old zetec and it now powers his rs1600i
__________________
my mk4 Escort Bonus, ST170 + throttle bodies in OAP gold 193 bhp & 13.7 1/4 mile at 102mph http://passionford.com/forum/picture...16v-bonus.html |
#174 |
#175 | |
Quote:
U mean Neil? heard it spun a big end shell, and he`s got another one in now and looking to fit bike carbs.... |
#176 |
Fast Ford snapper
#177 | |
Quote:
bhp don't want to say till i go back on the dyno in January, boost 20psi all the way to the limiter, custom inlet and custom exhaust manifold, and turbo is a custom spec-ed gt28.
__________________
#178 |
__________________
#179 |
In Training
Nice project you have going here!
![]() With a stock internal ST170 your hp goal is good for 350hp. I have seen some stock internals st170's up in the 370-380hp that is pushing it though. Last edited by patalrob; 29-11-2008 at 06:42 PM. |
#180 |
#181 |
In Training
Compression Ratio?
I don't think that they did any. You can get ahold of a guy over on focusfanatics bigfonsz is his name his is in the 390hp mark on the stock internales. http://www.focusfanatics.com/forum/s...d.php?t=179516 |
#182 | |
Quote:
#183 |
In Training
Yeah he's running on the standard rods and pistons.
I believe he had his tuner turn up the boost and ran a higher octane for this dyno run. But I think he had 2 tunes done, the 390hp one is his track tune and his daily drive around tune is at 330-340hp.
__________________
![]() SVT M-62 S/C http://passionford.com/forum/restorations-rebuilds-and-projects/263175-svt-focus-project.html |
#184 |
Colossal Pervert
Re-writing the laws of physics
__________________
![]() Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo. |
#185 | |
Quote:
__________________
#186 |
#187 | |
Quote:
So what boost is he running? 12psi.....? And was the compression ratio altered? |
#188 | |
In Training
Quote:
After talking to my parts guy today he said that this guy does have his lower end built. I thought for sure when reading his thread that he only had a boost-a-pump, CFM IM and 60lb injectors Boost for his 330hp is at 17 lbs. Boost for his 380-390hp is at 20lbs. |
#189 |
Thought that lol
#190 |
Neil just noticed the reply
Im going ST170 engine using the VVT at the moment, with Delorto 45's and weber Alpha 3D management Once the cars built up and running again, Ill then use it for a couple of events to check the new suspension and brakes are all set up OK, before going for new cams and verniers , and maybe a wee update to the management, Ill wait and see Ill put some pics of the engine all built up for you to see tomorrow, just finished it tonite, with my take on the water pump solution
__________________
#191 |
looking good
#192 |
Heres mine
just made a bracket , and shaft to mount the idling pulley, just need to go to the local autoparts to get the right sized belt also modified the alternator bracket and engine mount
__________________
#193 |
Capt Chaos
nice conversion there m8 must rev really well ,now get an mot and use it 4 now as is then when you get used to it up grade l8r cheers
Andy ![]()
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#194 |
Yeah looks ok, longs the water pump spins anti-clockwise....
#195 |
#196 |
its one of these tubular type manifolds , originally for a Focus, but modified to fit my car
__________________
#197 |
Why not just use the standard manifold?
You should just bolt a turbo to the focus manifold, looks like its askin for one lol |
#198 |
420
splendid work...
#199 |
So Dalsy, whens the next RSOC track day a k-hill?
#200 |
part of the bonus crew!!!
__________________
| Display Modes | |
