| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#81 | ||||
__________________
2004 Focus ST 170 X 87/91 sierra cosworth 4x4 X 01 mondeo 2,0 tdi stv 115hk X 92 fiesta xr2i 1,8 16v (RS1800) X 88 sierra 2,0 sedan X 90 sierra 2,0i combi |
#82 |
a small update, not much happend to the fez , just driving it
i did got the broken koni shock back from koni after 3 months, got it true mot. for now i'm collecting parts for a 2.0 conversion and a gearbox rebuild with lsd escort mk4 lsd ![]() ![]() 2.0 zetec maf ![]() ![]() 2.0 zetec desk ecu ![]() ![]() oil temp and oil pessure gauge + oilfilter sandwichplate for the sensors ![]() ![]() greetz |
#83 |
#84 |
Trader Score: (1)
Rep Power: 33 ![]() |
Nice car.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#85 |
#86 |
Cossiemodo
Looks very nice
__________________
TF2 name TurboShed - 2Fort only servers usually. Left4 Dead - TurboShed - I hate zombies! |
#87 |
#88 |
a bit more
cylinder head cover of ![]() at first site all looks good, when i removed the cams 1 of the bearingcaps had som blue colloring on it and there where some with marks on them, and where the camshaft meets the bearing there where some marks on them the cams have been out before because the bearingcaps where marked, but when they refitted them they where possisioned the wrong way, i suspect this is the reason for the faults, and bad oil ofcourse the bores and tops of the pistons look good imo head of ![]() ![]() ![]() ![]() sump of ![]() gReetS |
#89 |
looking good mate
#90 |
Patronus
Nice work there mate, cool project
#91 |
thank you
#92 |
#93 |
Great project!! Love it!
__________________
![]() 2011 Fiesta S-Edition. 2001 Fiesta Zetec-s 1982 Escort mk3 1.6 turbo. |
#94 |
#95 |
#96 |
#97 |
#98 |
getting there mate, are u going to run it on carbs?
#99 |
#100 |
#101 |
Top Work!
__________________
#102 |
Looks really nice mate, i have recently done similar with my RS 1800.
top work you have been doing this is mine BTW
#103 |
ford whore
i want my fiesta imperial blue . . . it looks so good.
__________________
Ford . . . . feel the difference |
#104 |
Lovely work, keep up the good work
__________________
#105 |
#106 |
#107 |
#108 |
#109 |
#110 |
good work, dont forget to swap the crank position sensor casing with a manual casing one before you fit engine in like i did!! had to take the engine out again in mine to do it!! doh
__________________
#111 |
#112 |
#113 |
and finaly started the rebuild
new pistonrings after checking the gap clearance ![]() new main bearings ![]() crank in ![]() the crankshaftseal housing ![]() cleaned up ![]() gasket in place ![]() the housing mounted to the block ![]() and the seal in place ![]() ARP conrodbolts vs OEM ![]() newbig end bearings ![]() nr1 and nr4 in ![]() ![]() i checked the running clearance on the main and big ends and checked the endfloat, all was well |
#114 |
new o-rings for the injectors,ford head bolds and new pistonjets
![]() new 1.8 fiesta waterpump ![]() 4 pistons in ![]() pistonjets ![]() ![]() i cleanedthe feulrail ![]() got the injectors in the feulrail , al new seals ![]() i than matched the sandwich plate runners to the ports and gave them a mild pollish ![]() ![]() also i mached the inlet manifold to the sandwich plate ![]() thats it so far hope you like and if you see something thats not ok then please tell me |
#115 |
Beautiful as always mate
__________________
Mondy Mk3.5 2.2 TDCi Titanium X --> Monster Conversion Sierra Mk2.5 1.8TD SW RAT Drifter --> Rust Under Construction Mondeo Mk1.5 1.8TD Interceptor --> Daily Airco Cooled Orion Mk1 1.6d --> Sleeper 1.6TDi Fez Mk3.5 1.8d --> Sleeper 1.8TDi Streetperformance.be --> No / Low Budget Cup Designed 4 Performance << may the Ford be with you >> |
#116 |
life is good
awesome mate love the car
__________________
2001 ford focus zetec |
#117 |
cleaned and painted HO inlet manifold
![]() ![]() painted the sandwichplate ![]() cleaned and painted the throttlebody ,pollished the inside, pollished the butterfly and knife edged it, also made the inlet edge smoother before ![]() after ![]() ![]() cleaned and painted the sump ![]() i bought a oil pickup-pipe, when i recieved it the wiremesh was out so i chopped the 2.0 oil pickup-pipe and got that mesh and got it in the 1.8 pipe ![]() ![]() ![]() ![]() ![]() new oil pump
#118 |
the latest updates
oil pickup-pipe fitted ![]() new gasket on the clean sump ![]() sump fitted with some stainles steel bolts [IMG=http://img44.imageshack.us/img44/9190/picture004gj.jpg][/IMG] ![]() new 1.8 waterpump ![]() skimmed block ![]() headgasket ![]() head and piper cams ready for fitting ![]() ![]() ported and flowed exhaust port ![]() ported and flowed inlet port ![]() ![]() head on block ![]() piper cams fitted ![]() ![]() now i need to sort the timing and the 2.0 is ready :mrgreen: gReetS |
#119 |
my latest update
i have some vernier pulley's , i only had to drill a hole to match the piper cams so i can fit the dowel's ![]() pipercams ![]() drilled the hole in the pully ![]() pully on and locked with the dowel in place al timed up ![]() ![]() a new ford timing belt ![]() ![]() i painted the timing covers and moddet the upper cover so you can see the pully's than started on the inlet manifold ![]() gasket in place ![]() ![]() the sandwichplate and injectors in place ![]() the other gasket ![]() ![]() and the HO inlet on and this is how it will look ![]() ![]() a few litlle things and its ready gReetS |
#120 |
| Display Modes | |
