| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#161 | ||||||
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#162 |
picked up some tarox 6 pots and bells today and brake balancing valve for the rear disck conversion, hope to have all fitted 2moro
__________________
#163 |
oh and a t34 with 0.63 exhaust housing
__________________
#164 |
oh mummy!
this is getting even better
#165 |
oh yes because with a bit of luck in a couple of weeks i should have a full cream leather re-trim with red piping
__________________
#166 |
fitted the tank back up with the escos fuel pump inside, and rand the new brake lines around the rear with then new brake balancing valves
__________________
#167 |
oh will try and get pics up 2mo if weather is ok to carry on
__________________
#168 | |
Quote:
are these spats still available?? I would love to have them on my mk3 but here in Holland you can't get them. can you still buy these in england? and if so, were? thanks and keep up the good work
__________________
#169 | ||
Quote:
__________________
#170 |
looks good fella makes me miss my old 16i
#171 |
cheers mate, should look alot better with an engine in lol
__________________
#172 | |
Quote:
hmmm..... I can't find them I'm looking on ebay.co.uk for "mud flaps" but no treasure for me are there any other words for these things???
__________________
#173 |
search rs motorsport and they will come up
__________________
#174 |
__________________
#175 |
thanks man
don't understand why I couldn't found these... thanks
__________________
#176 |
no probs
__________________
#177 |
looking good
__________________
#178 |
cheers mate, ben a bit lazy today, havnt done anything other than get rear lines and oil pressure t piece from burtons
__________________
#179 |
all these projects have got me thinking now
__________________
#180 | |
Quote:
__________________
#181 |
420
lookin good....
#182 | |
Quote:
__________________
#183 | ||
Quote:
__________________
#184 | |||
420
Quote:
#185 | |
Quote:
__________________
#186 | ||
Quote:
__________________
#187 |
at last a little progress
__________________
#188 |
top work mate
__________________
![]() Birkbeck Auto Repairs Ltd Sidcup KENT |
#189 |
cheers mate, its getting there slowly but surely
__________________
#190 |
spot on mate...nice work..
__________________
#191 | ||
420
Quote:
#192 |
i just started stripping down my 2.0 mondeo engine that i bought for Ł40 for the head so as soon as i goodies arrive from ian howell il start lapping the valves, new seals, valve springs and cams etc then asselmble bottom end
__________________
#193 |
looking v good
#194 |
cheers guys, my springs have just arrived from ian howell
__________________
#195 |
got the bottom end built tody but broke a piston ring hilst putting piston in block
, i used rig compressor but it broke second ring, so new rings and will complete and head should be done by the weekend so will update with pics all at once
__________________
#196 |
pics of oil seal housing, cleaned and prepped:
![]() ![]() pic of block mating faces cleaned up: ![]() machine work done to rods, 30 thou of eitherside of small ends, oil hole drilled and balanced and machined for calibra pistons and the balanced: ![]() ![]() ![]() ![]() ![]() new mains and shells: ![]() more cleaning and prep photos: ![]() ![]() ![]() fitting rods and pistons in bores (exceptone ring broke) [IMG]http://img.photobucket.com/albums/v508/bamiosh/P1010246.jpg [/IMG] pics of freshly ground and balanced crank: ![]() will update when have new rings and have built head
__________________
#197 |
i seem to have missed some of the pics with crank, oil pump etc in (well everything minus pistons and rods due to the broken ring)
__________________
#198 |
#199 |
rings and area six exhaust cam were meant to turn up today but nothing has arrived
__________________
#200 |
__________________
My carbon clad s2 |
| Display Modes | |
