| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#81 | ||||
chatter 4 life
__________________
check out the mk3 zetec turbo build http://passionford.com/forum/restorations-rebuilds-and-projects/182173-mk3-escort-2-litre-zt-28-3-2010-geting-pissed-off-now-still-no-spark.html Member of "The Daytime pf talk bollocks and random shite club #110 www.stocktonautocentre.com |
#82 |
will take some in A little while
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#83 |
chatter 4 life
ok mate kwl
__________________
check out the mk3 zetec turbo build http://passionford.com/forum/showthread.php?t=182173 Member of "The Daytime pf talk bollocks and random shite club #110 www.stocktonautocentre.com |
#84 |
![]() very pleased with these, have to check dash one for colour match, fingers crossed
__________________
#85 |
chatter 4 life
how much did they cost if u don't mind me asking
__________________
#86 |
i tried getting a better pic as previous didnt do it justice
__________________
#87 |
Ł115 for the 2, no copying
lol
__________________
#88 |
chatter 4 life
ouch, so witch 1 was cheaper cos ready fancy the speaker pod 1
__________________
#89 |
think the speaker one was the dearer one as more work went into it, glad nobody has said they have done it as i thought of it the other day and hoped it was poss 1st done
__________________
#90 |
need gauges now though, what good brands are there?
__________________
#91 |
chatter 4 life
ford racing, colins,auto meter, there loads mates
__________________
#92 |
cheers mate, will get on ebay
__________________
#93 |
more money spent
, went fords earlier and brought new headlight adjusters, headgasket, bolts, loom clips and focus rs spark plugs , rings come today from autovaux, they delivered quickly
__________________
#94 |
How much were the rings in the end? And how much you get the plugs for?
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far... Classic Fords FTW! |
#95 |
rings were Ł54 and plugs were around Ł8 each
__________________
#96 |
oh had me block sprayed today, opted for black and gearbox being cleaed and sprayed 2moro, will get pics up when collected and assembling
__________________
#97 |
collected me gearbox and block today, gearbox is a series 1 box with lsd, will upgrade at a later date.
![]() block painted up (ignore sump, its just its seat ![]() rebored and honed ![]() another one of block showing oil return ![]() a few parts i brought from fords, headlight adjusters, triple layer head gasket, headbolts, focus rs plug and loom clips ![]() ordered more parts from fords again today, its non stop
__________________
#98 |
more bits today, paddle clutch arrived with free brackets in it for rear disc conversion
, sump and flywheel. and collected all new flywheel and clutch bolts etc from ford
__________________
#99 |
420
lovely work...
#100 |
Brian
__________________
#101 |
cheers guys
__________________
#102 |
chatter 4 life
nice 1 fella, ford racing rev counters are avilble but not cheep
__________________
#103 |
can you get them in 52mm?
__________________
#104 |
chatter 4 life
not to sure i have a look about for u fella.
how much did u pay for the speker gauge pod
__________________
#105 |
cheers mate, think it was about Ł60-70, sumit like that
__________________
#106 |
#107 |
cheers mate, i think il get under it 2moro and start fitting brake lines etc, realli dont want to though lol
__________________
#108 |
didnt really do anything today
, dropped pistons, crank, rods, bolts, clutch and flywheel etc to be balanced and crank is to have a 10 though re grind. set up engine stand ready for when parts are done. hopefully if weather is dry 2moro il get out and work on it
__________________
#109 |
love it mate...one day im going to have one of these...
__________________
#110 |
cheers mate, its only a 1.1. shell, just a very expensive one
, engine is costing a fortune, new nuts, bolts, pumps, seals, for gaskets, crank regrind, shells and mains and balancing etc is costing alot more than first planned but i plan on building it to last instead of a slap together and wahooo it runs then after 300 miles it has no oil pressure , do it right and it should see you right if looked after i believe
__________________
#111 |
not much progress today, got all loom in the inner arch in conduet, hooked up on the hooks welded up on inner arch to hold it and zip tied into place, solder and connect indicators to loom through hole in inner wing, and fit servo on passenger side as it never had one before and made a plate to match conteur of bulkhead where servo bolts up to reinforce
, couldnt get any pics due to it starting to rain , will take one of the plate tho little progress though lol, ahhh also brough a tubular manifold of ebay, but will require a t3 flange welding on.
__________________
#112 |
oh and got splitter back but is satin black and looks way to shiny, so think maybe matt black?
__________________
#113 |
tubular manifold came through today
__________________
#114 |
__________________
My ProjectS.. http://www.passionford.com/forum/vie...456351#1456351 REMOVED BY WEBTEAM |
#115 |
need to get out 2moro and get underneath it
, atleast with it being clean now i dont realli get dirty lol
__________________
#116 |
grills been debadged by twins
__________________
#117 | |
Fast Ford snapper
Quote:
AWESOME!!!! Intended doing that to mine... nice to actually see one done
#118 |
Looks mint that. very very nice.
__________________
#119 |
had a little bit of progress today (wel tiny bit), fitted master cylinder and graphics to the bonnet lol
.pic of plate i made up to reinforce behind the brake servo ![]() picture of servo, linkage and master cylinder bolted up ![]() pic of graphics put on the bonnet ![]() pic ot car at end of today ![]() and a pic id taken of me t34 .48 exhaust housing for something else lol .im avoiding going underneath and doing brake lines at the minute due to lazyness .anyone have any pic of where the brake lines bolt up on wings on the t piece? cheers
__________________
#120 |
need a downpipe for this bye the way if anyone has one?
__________________
| Display Modes | |
