PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 03-07-2007, 08:45 PM   #41
GTechR
GTechR's Avatar
Trader Score: (0)
GTechR is an unknown quantity at this point
Default Small update 3/7
Right just a small update, as I fukked up and got the wrong Gas, I aint been able to crack on with the welding, So I decided to reposition the Extinguisher, this it turned out, was easier said than done. I originally intended putting it behind the passenger seat, but like a prat, I didn't measure the size of the extinguisher prior to fitting the seat, the result being no room, so the next plan was to fit it up under the dash on the bulkhead, but after a bit of investigation, I couldn't find a suitable position due to there being a double skin.
So the final location ended up being on the trans tunnel, I fabricated a mounting plate using checkplate and a couple of exhaust bobbins.
Then ran the pull wires upto the extinguisher, one from inside the cabin and one outside. And mounted them to the floor.
All mounted up with the wires in place and the lines for the nozzels.
Mounting straps in place to stop the extinguisher flying off in the case of a crash.
I'll not go into geat deal with the fabrication of the foot plate, but basically I made a cardboard template, and then transfered that to some checkplate. It's then mounted to the floor using 2 alloy brackets, and held in place by 2 further brackets mounted from the left rear (a handy bracket already there) and top right, (a mouting point for the glove box)...
Also refited the battery box.
Once all that was in place I tested the footplate to make sure it'd take the weight.
While lookin at it, I decided that I didn't like the big hole where the glove box was, I intend fitting the ECU there so I thought it would be a good idea to put a cover over it... So out came the cardboard again. Resulting in this...
And everything in place...
Needs a bit of tidying but quite happy with it.
__________________
REMOVED BY WEBTEAM
GTechR is offline   Reply With Quote
Old 03-07-2007, 11:17 PM   #42
Trader Score: (14)
Twins is an unknown quantity at this point
__________________
My carbon clad s2
Twins is offline   Reply With Quote
Old 14-07-2007, 11:49 PM   #43
Lambchop
PF Idiot Sniper
Lambchop's Avatar
Trader Score: (1)
Lambchop has a spectacular aura aboutLambchop has a spectacular aura about
Send a message via MSN to Lambchop
I always wondered where my wheels were going!!
BUT
Where did they go then?
__________________
Birds shouldn't be moderators ; )
Lambchop is offline   Reply With Quote
Old 15-07-2007, 10:51 AM   #44
GTechR
GTechR's Avatar
Trader Score: (0)
Hi mate... A guy bought them of me at FITP, I think they where going on a Escos trackcar...
__________________
REMOVED BY WEBTEAM
Old 15-07-2007, 04:45 PM   #45
digita1dragon
digita1dragon's Avatar
Trader Score: (0)
digita1dragon is an unknown quantity at this point
Send a message via MSN to digita1dragon
Hey Gary, not seen this before! Cool project. Impressed with the work!
__________________
XR2 Turbo: Self Destruct Initiated
Part of the XRTwo.com massive
digita1dragon is offline   Reply With Quote
Old 04-08-2007, 07:01 PM   #46
rs_daz
Trader Score: (0)
rs_daz is an unknown quantity at this point
Nice work mate..
That Tony Law Manifold will that bolt up the rs2k exhaust? has it a flange on the end like the std manifold??????
__________________
rs_daz is offline   Reply With Quote
Old 04-08-2007, 08:33 PM   #47
GTechR
GTechR's Avatar
Trader Score: (0)
No mate it's just a plain tube, but i'm gonna build a custom system anyway so it's not a problem.
__________________
REMOVED BY WEBTEAM
Old 13-08-2007, 10:07 PM   #48
rs_daz
Trader Score: (0)
Ahhh right ok nice one
__________________
Old 16-09-2007, 04:52 PM   #49
GTechR
GTechR's Avatar
Trader Score: (0)
Right as you may have seen, in my 'eventful day post' i've started on the Maxi again...
If you've been following the thread you will know that welding is not my strong point, married with the fact i'm curently using a gasless welder, it's taking alot of time... this is due to me blowing big holes in the metal when I hit a thin bit, and generaly the weld being... dirty!! I've found the best way to make it look neat is to over weld it ( I doubt that's a profesional term) and the grind it back down, it's not pretty but it's solid, but i'm going to overlay it with glass fibre matting anyway so it's no major!!
Anyway pics >>
This is the passenger side...
This is where I got upto before I had my "Accident"
As I say it's not pretty, but it's solid...
This is where I found a thin section and blew a big hole in the metal...
A couple of the inner arch finished...
And another of the top.
The next few are the drivers side...
Completed...
Inner arch...
Top...
The final 3 are work in progress shots before the first 2 pics...
Hopefully there will be some regular updates now, as i'm just doing the odd hour here and there...
__________________
REMOVED BY WEBTEAM
Old 16-09-2007, 08:21 PM   #50
749steve
Trader Score: (1)
749steve is an unknown quantity at this point
keep it going gaz it will be worth it when its done
__________________
civic type r, gsxr 600 srad, giant xtc team
all cared for by
www.fstautomotive.co.uk
749steve is offline   Reply With Quote
Old 17-09-2007, 07:10 PM   #51
redrsmk5
Trader Score: (0)
redrsmk5 is an unknown quantity at this point
Blimey mate!! looking great so far
__________________
" You'll Never Walk Alone "
JFT 96 - 15th April 1989....never forget them.
THE most successful English Club Ever!
View the madness here - underside resto finished!
http://www.passionford.com/forum/vie...asc&highlight=
redrsmk5 is offline   Reply With Quote
Old 17-09-2007, 11:55 PM   #52
carl_f
Trader Score: (0)
carl_f is an unknown quantity at this point
the project looks mint mate
__________________
thanks carl
carl_f is offline   Reply With Quote
Old 19-09-2007, 02:48 PM   #53
GTechR
GTechR's Avatar
Trader Score: (0)
Another Small update, finished the passenger side arch...
Then a quick try to make sure the arches still fit...
Passenger side...
Drivers side...
It would appear that i may have been a bit enthusiastic when nocking the arch into shape, but nothing some matting a filler can sort...
Next on the list is to start fabricating the arch extensions on the rear Bumper...
__________________
REMOVED BY WEBTEAM
Old 22-09-2007, 10:18 PM   #54
GTechR
GTechR's Avatar
Trader Score: (0)
Had a couple of hours free this afternoon, so I made a start on the rear Bumper...
First, the section that I originally cut off the arch, placed roughly on the bumper...
As you can see, as with the front it has to be built up...
Initial template made with cardboard...
If you squint, you get a rough idea of what it'll look like...
It'd be a bit boring going thru the phases of laying the matting, so here is the final layer...
And a couple, with the arch cut back off...
Now the hard work starts...
__________________
REMOVED BY WEBTEAM
Old 25-09-2007, 10:30 PM   #55
GTechR
GTechR's Avatar
Trader Score: (0)
Right here we go again...
Managed to get the other side of the bumper done today. Not going into quite as much detail, but basically same proccess as the other side.
Arch removed...
Bumper removed off the car, and staring to strengthen the new arches.
And cleaned up, to start laying the fibremat on...
more to follow soon.
__________________
REMOVED BY WEBTEAM
Old 28-09-2007, 08:42 PM   #56
GTechR
GTechR's Avatar
Trader Score: (0)
Another couple of hours today...
Building the arches up on the bumper, first laying some matting...
And the other side...
I then trimmed the matting back and laid the first coat of fibre filler on...
Hopefully get that sanded down in the near future, so I can start shapeing them up better.
__________________
REMOVED BY WEBTEAM
Old 28-09-2007, 09:15 PM   #57
xr3-keith
Trader Score: (0)
xr3-keith is an unknown quantity at this point
looking good mate, wish i had the patience to do that
top job
__________________
Birkbeck Auto Repairs Ltd
Sidcup KENT
xr3-keith is offline   Reply With Quote
Old 29-09-2007, 06:39 AM   #58
Trader Score: (14)
__________________
My carbon clad s2
Old 29-09-2007, 10:18 AM   #59
redrsmk5
Trader Score: (0)
Great work Gaz mate
__________________
Old 29-09-2007, 12:32 PM   #60
GTechR
GTechR's Avatar
Trader Score: (0)
Cheers Mart
__________________
REMOVED BY WEBTEAM
Old 29-09-2007, 09:31 PM   #61
marco polo
marco polo's Avatar
Trader Score: (1)
marco polo is on a distinguished road
Send a message via MSN to marco polo
looking good cant you go any faster
marco polo is offline   Reply With Quote
Old 29-09-2007, 09:33 PM   #62
GTechR
GTechR's Avatar
Trader Score: (0)
I know mate...
__________________
REMOVED BY WEBTEAM
Old 29-09-2007, 10:12 PM   #63
NEEDFORSPEED
Trader Score: (0)
NEEDFORSPEED is an unknown quantity at this point
very nice project mate! the only one ive ever seen was a white one in performance ford! keep on with the pics!
__________________
[CLICK TO SEE MY SAPH RESTO!!
http://www.passionford.com/forum/viewtopic.php?t=240033
NEEDFORSPEED is offline   Reply With Quote
Old 09-10-2007, 07:59 PM   #64
D19 STE
D19 STE's Avatar
Trader Score: (0)
D19 STE is an unknown quantity at this point
Nice project
__________________
My project mint RS2000 http://www.sportingfords.com/forums/viewtopic.php?f=9&t=33
For the above you need to click on Projects/Restorations
Staffie Rescue CLICK ME
D19 STE is offline   Reply With Quote
Old 09-10-2007, 09:25 PM   #65
GTechR
GTechR's Avatar
Trader Score: (0)
Cheers mate
__________________
REMOVED BY WEBTEAM
Old 09-10-2007, 11:16 PM   #66
zippyobrien
Trader Score: (1)
zippyobrien is an unknown quantity at this point
Send a message via MSN to zippyobrien
looks brillaint,
i need to work out those fibre glass mating steps, got a carbon fibre spliter of my old mans skyline to fit on my fiesta, but it needs shortening.
car looks wicked though
__________________
nothing beats stella, like stella beats your wife
zippyobrien is online now   Reply With Quote
Old 18-11-2007, 08:33 PM   #67
GTechR
GTechR's Avatar
Trader Score: (0)
God time fly's when you dont have it...
Anyway not all done at once but the labour of a few odd days work...
Finally got round to making a start on the arches, first we have the moulds being made...
Moulds removed after the fiberglass has gone off...
More to follow soon...
__________________
REMOVED BY WEBTEAM
Old 18-11-2007, 10:52 PM   #68
marco polo
marco polo's Avatar
Trader Score: (1)
getting there mate
__________________
escort cosworth Grp N rwd in the making http://passionford.com/forum/showthread.php?t=207127
Old 18-11-2007, 10:56 PM   #69
GTechR
GTechR's Avatar
Trader Score: (0)
Hiya mate... Yeah slowly, got a few weeks off soon so hopefuly I can get a bit more done.
__________________
REMOVED BY WEBTEAM
Old 19-11-2007, 04:54 PM   #70
Minirotty
Lucifer II - 666
Minirotty's Avatar
Trader Score: (0)
Minirotty will become famous soon enough
cool stuff mate
__________________
www.SportingFords.com - The True Owners Club
Minirotty is offline   Reply With Quote
Old 19-11-2007, 05:32 PM   #71
Trader Score: (14)
__________________
My carbon clad s2
Old 19-11-2007, 09:28 PM   #72
Mixja
420
Mixja's Avatar
Trader Score: (0)
Mixja is an unknown quantity at this point
Send a message via MSN to Mixja
lookin good, love the maxi kit...
__________________
Well, soon anyways... Click me sig to see how its going...
_______________________________________
Only gone n started the series 1 aint i...
Click the banana to see what's happenin...
Mixja is offline   Reply With Quote
Old 04-12-2007, 08:47 PM   #73
GTechR
GTechR's Avatar
Trader Score: (0)
Been back in the garage today so i'm cracking on with the arches...
First of all I preped the original bodywork to fit the arches by laying a layer of fibre matting, Doubt this is how the pro's would do it, but I thought it would give the arches something to stick too...
I then rivited the wings to the arches, I first put a thin layer of fiberfill where the leading edge of the arch meets the metal so when the arch is tight on the wing it fills the gap...
Starting to rub down the first layer...
And then layed the second layer of fiberfil...
Thats it for now... Need to get some more fiberfill.
__________________
REMOVED BY WEBTEAM
Old 04-12-2007, 11:10 PM   #74
NEEDFORSPEED
Trader Score: (0)
quality work!
__________________
Old 05-12-2007, 01:35 PM   #75
Trader Score: (14)
__________________
My carbon clad s2
Old 05-12-2007, 04:41 PM   #76
GTechR
GTechR's Avatar
Trader Score: (0)
A few more hours today...
Flattend the fibrefil down...
and gave em a coat of filler...
Front arch is flatted back off. So then just to guage how much more work I need to do with the filler, I gave the front arch a quick coat of primmer...
Thats it for now, I'll probably just crack on for a few days without pics, you can only take so many of the same thing...
So hopefully the next instalment will see the arches all done
__________________
REMOVED BY WEBTEAM
Old 05-12-2007, 11:51 PM   #77
Minirotty
Lucifer II - 666
Minirotty's Avatar
Trader Score: (0)
Impressive
__________________
Old 06-12-2007, 04:09 PM   #78
GTechR
GTechR's Avatar
Trader Score: (0)
Cheers for the comments guys...
Another 'small' update... Bonded the other side on today and managed to get the first coat of fiberfil on.
__________________
REMOVED BY WEBTEAM
Old 07-12-2007, 01:07 AM   #79
massivewangers
massivewangers's Avatar
Trader Score: (0)
massivewangers is on a distinguished road
Send a message via MSN to massivewangers
Good stuff mate, watching this with interest
__________________
Q. What's the difference between a Saxo and a porcupine?
A. The pricks are on the outside of a porcupine.
massivewangers is offline   Reply With Quote
Old 07-12-2007, 10:46 PM   #80
GTechR
GTechR's Avatar
Trader Score: (0)
Double post...
__________________
REMOVED BY WEBTEAM
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
